View Full Version : Probe
Pages : 1 2 [3] 4 5 6
  1. glowing turbo
  2. 1997 4cylinder probe modifications
  3. Busted Transmission??? Maybe
  4. 5 speed tranny for sale
  5. Boot Sensor?
  6. twin turbo
  7. What a coincidence
  8. '92 Probe won't run with MAF sensor connected
  9. no spark 93 probe
  10. probe web site
  11. just bought a probe
  12. electric turbo
  13. question
  14. A few problems
  15. 1990 ford probe parting
  16. 89 lx 4 banger alternator help
  17. is there such a thing as wheel adapters or somwere were i can go from a five bolt
  18. DriveTran
  19. 93 Probe Air Bag light
  20. Brakes
  21. how do i
  22. car shakes and stalls
  23. 1996 probe GT V6 no spark after car sits in sun
  24. 1992 gt performance parts
  25. Weird Tranny/Speedo Problem
  26. 93 probe ICM fix
  27. Quick question
  28. Battery drain, (F/P INJ ) fuse.
  29. probe blind spot?
  30. Lx 91 3.0 v6 fuel probs + fuses question
  31. 89 GT turbo Wipers won't stop
  32. power concerns
  33. engine
  34. radio install help
  35. 93 PGT transmission in 93 MX6?
  36. lol
  37. Performance
  38. 97 Probe Speed sensor Location
  39. need parts for my poor base model help please
  40. Cooling Fan Problem
  41. 93 Probe SE
  42. Probs fixed but 2
  43. Intermittent Speedometer
  44. parting out
  45. racing stripes
  46. Trans Prob
  47. 92 Ford Probe A/C Compressor
  48. Help on Brakes
  49. IAT sensor plug
  50. auto wont shift corr
  51. 93 Ford Probe GT Headlights Stay UP
  52. 89 GT Turbo -- Dash lights and tail lights
  53. AC Wiring Help
  54. tranny vacuum leak
  55. just got a probe
  56. F/S Flawless RX8 Wheels ((ONLY $525))
  57. wiring,.. help please
  58. 1992 Probe GL 2.2L Check Engine Light
  59. OD Light Blinking/ Trans Fluid Leaking HELP!
  60. j-spec cam??
  61. Anyone can put in my tranny?
  62. coil???
  63. problems
  64. Looking for engne
  65. Turbo Kit
  66. Cold air intake help
  67. tire size?
  68. Need help changing brake light.
  69. Need SUNROOF ASSEMBLY for GT 1996
  70. Help! I need a 94 GT probe Transmission
  71. transmission
  72. 300zx headlight conversion kit question???
  73. 91 Probe Turn Signals
  74. 94 Pgt Mtx Fire Damage For Sale Ebay
  75. BULK BUY TURBO pipes
  76. $ question
  77. 94 probe GT body kits
  78. New engine?
  79. Control Arm
  80. Overheating!
  81. cant fugure it out
  82. KLZE with mods 178 hps at wheels?
  83. help PLZ 85 PROBE WONT RUN 8(
  84. after market
  85. Ford Probe Eyelid Headlights Problem
  86. parting out 2 1993 Probe GTs
  87. probe GTS
  88. need a lil question answered
  89. front shakes when i apply brakes
  90. need help
  91. KLZE 96-97 OBD-II Problems
  92. KLZE 96-97 ODP 2 Problems?
  93. Son wrecked '94
  94. need help finding vss --speed sensor
  95. '89 Probe GT
  96. Bottom End Blew OUT help!
  97. Klze Info Need Help!!!
  98. F*cked Car ran with no oil... HELP
  99. knocking noise???? wtf
  100. Please Help!!! My probe is flooding with gas and will not run
  101. bogging
  102. 89 probe gt new turbo for sale
  103. horse power
  104. 91 Probe LX overheating???
  105. 1995 Probe GT V6 2.5 liter FOR SALE
  106. pacesetter headers
  107. 91' engine light
  108. Probe wont start
  109. turbo for 2 gen
  110. how much work is it putting in a shortshifter
  111. probe gt rims
  112. 1st gen. faster than 2 gen.
  113. 93 engine light
  114. Swapping tranny gutz
  115. '94'Probe no Spark
  116. RPM problem
  117. 93 Probe GT Problem
  118. EGR valve flex hose
  119. Cheap Lifters
  120. New Lifters.
  121. Idle problem
  122. HOW can i tell if my pullie bearings are going out
  123. battery 2
  124. Battery???
  125. getting rotors off 89 probe?
  126. 89 LX parts car
  127. Aftermarket radiator
  128. smoke out oil cap? doesnt run with out cap?
  129. Front Bumper Sho gun Body kit for sale
  130. Problem with 93 gt
  131. noise when turning?
  132. Jingle Bells in front pass tire Wth?
  133. Cs Lip, Z3 Fenders, And Vis Nvader Hood? Help Me Build this car!
  134. will 95 pgt motor hook up in 93 gt????
  135. Do you like your ford probe?
  136. power windows
  137. horn issues
  138. ground problem?
  139. Need a KLZE ASAP!!!
  140. a good deal?
  141. If I were to get a PGT..
  142. Leaking trans fluid
  143. 93 probe se
  144. 93 Probe Gt problems in Michigan
  145. Calibrating TPS
  146. Power Steering occasionally quits working
  147. 93 probe 257000 k miles
  148. 95 Ford Probe Brake Question
  149. What do u think DRAG Question!!
  150. 89 Probe 2.2 motor
  151. help
  152. 93 probe gt won't start just turns over
  153. Diagnostic Trouble Code P0171 & P0421 What Should I DO ?
  154. Help!!!!!!!
  155. 93 pgt 5spd 4 sale
  156. 1993 PSE For Sale
  157. WTB: 2G Blue Interior Door Latch & Trim Panel
  158. FS: showgun front bumper
  159. Running wires!!! HELP Gauges n Stereo
  160. stailing
  161. Wipers: Winter/Summer?
  162. wtb:93 pgt 2.5 engine
  163. How can you tell the dif between the stock kl03 engine and the klze
  164. 2 1993 probe GTs for parts
  165. Performaqnce shop specializing in probes
  166. help confused on gt/se/base/pgt
  167. 1990 5-spd 4 cyl. turbo for sale
  168. conversion Auto - Man
  169. 94 GT Almost Starts
  170. OK!!!! I dont want to swap engines!!! BUT...
  171. Vehicle Speed Sensor?... I Hope...
  172. EVERY PRObE OWNER SHOULD RIGHT DOWN
  173. I have the $$$$$ what to do with my 1990 Probe LX V6...
  174. turbo, will it fit?
  175. vacuum diagram
  176. Coolant fan doesn't come on...
  177. engine swap, what will fit??????
  178. Back middle Spark plug smokes???
  179. 96 probe Gt
  180. 93 probe gt idle problem
  181. 89 probe won't shift into 3rd gear
  182. intake mainfold
  183. blinkin 'man. shift' light...
  184. Body Work
  185. External Trans filter and cooler conversion?
  186. 95 GT Stalling, sputtering, you name it......
  187. 90 Probe 2.2 Stalling
  188. How many coolant reservoirs are there???
  189. Changing the radiator???
  190. Oil Problem !!!
  191. Fs-ze Help!!!
  192. Will This Fit My Probe!!!! Help
  193. 94 Probe over heating
  194. valve
  195. Ford Probe Clutch/brake
  196. No Power 94 probe
  197. If you had a choice....
  198. No Power 94 probe
  199. 89 and 91 probe parts
  200. engine heats up quickly and burns spark plug wires???
  201. buying cars
  202. Repair questions...
  203. Coolant reservoir leak???
  204. electrical or tranny?
  205. 94 probe GT.. need ecu for it, HELP
  206. I need an answer quickly on how many spark plugs a v6 91 Ford probe has???
  207. Springs and intake help...
  208. PaceSetter Cat Back??? Has anyone Put one on their Probe 2.0?
  209. weapon R intake is it worth it??????????????
  210. probe heater control problem
  211. 91 Ford Probe dies when accelerating to fast.
  212. Klze!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  213. 15" tires for 91 Ford Probe LX???
  214. egr boost sensor
  215. Buying Low Milage 2.0 Mazda or Ford Engine
  216. please awnser-- probe tail lights?
  217. BUYING! Tail Lights
  218. Draining engine coolant on a 91 Ford Probe???
  219. FS: BRAND NEW 2.5 V6 Rear Engine Mount
  220. KLZE engine swap questions
  221. probe GT leather seats
  222. No turn signals
  223. Probe Wont Stay Running
  224. wiring diagram for a 95 stock radio
  225. MY 94 Probe GT makes a whistle sound WHY
  226. probe
  227. Wiring horn for APC steering wheel to red NOS buttons
  228. Heater on = Over Heat... Please help asap because its cold...
  229. Looking to buy pgt
  230. headers for probe GT V6
  231. My Probe GT makes whistle sound why?
  232. 95 probe engine with bad lifters
  233. Wtb 89-92 Probe Gt Turbo 5-speed
  234. Smoke on starting after the car sits for a while
  235. exhaust
  236. 96 Probe Bumper/96 GT Bumper
  237. Gauges
  238. How do I put in the indiglow gauge cluster for 91 Probe
  239. engine removal
  240. wtb 2nd gen gt
  241. coil spring se, ge
  242. 93 Probe GT Valve Cover Gasket replacement ?
  243. 89 FORD PROBE TURBO!! Newly Rebuilt, never used.
  244. 95 Distibutor for Sale
  245. WTB: 2G Blue Interior Door Panel
  246. Tranny suggestions?
  247. Oil Pressure on Probe 93 GT
  248. is it worth it?
  249. fuel pressure you need for NOS
  250. 93 pgt rear brake calipers wanted
