Our Community is 705,000 Strong. Join Us.
View Full Version : Probe
Pages : 1 [2] 3 4 5 6
  1. 89 probe rocker panels
  2. overheating,no powersteering and no heat
  3. Need help from ford tech's please.
  4. Ford Probe Weight Reductions
  5. 94 Probe wont shift gears
  6. Selling t3 turbos
  7. 92 Probe running rough
  8. fuel pump
  9. HLA price ?
  10. No O/D, harsh 1-2 shift 93 Probe SE AT
  11. 1993 probe not firing
  12. Boreing Out Klze Q&a !!
  13. HigH Idle
  14. 93 KlZE engine making horrible sound
  15. 93 Probe SE Mods
  16. Advice on buying a Probe in need of head gasket.
  17. CHANGE WATER PUMP ON 1995 Ford Probe
  18. taking stock head unit out..help!
  19. 93 probe
  20. wrecked my probe
  21. Wanted: 89' Probe GT 2.2L Turbo distributor
  22. FS:93-97 GT MTX trans. + full part out
  23. 1994 Probe GT KL-ZE Swap For Sale!!
  24. wiring costs?
  25. 90 probe halfaxle removal
  26. Power Steering
  27. Probe running rough
  28. 94 ford probe se fuel problems need help
  29. Probe Status: Broken
  30. Looking for a 2.2T Probe.
  31. speaker problem for 89 probe
  32. (DIS) How to? Distributorless ignition?
  33. 94 PGT Stalling
  34. 94 Probe GT Headlights will not open
  35. help me please with my 89 probe gt turbo
  36. Electric Cooling Fan Motor Relay issues...
  37. alternator help
  38. Final: Parting out Highly Modded 2.0L
  39. Computer question
  40. 2nd gen 93-97 probe
  41. 96 Probe turns over but will not start...
  42. Distributor installed wrong
  43. bye bye Probe
  44. Advice Wanted (Supercharging)
  45. 1993 Probe Problem
  46. idler tensioner
  47. i got a code 55
  48. In need of trans mounts
  49. fast ticking on left side of engine
  50. stalls and dies when it is hot outside, accellerates improperly also
  51. My Probe Steering Wheel Locked up...
  52. 95 probe gt no spark
  53. 1993 Probe Wiring Diagram For Computer
  54. Great info for 2.5
  55. code 55?
  56. How To Disconnect/Turn off A/C Pump?
  57. probe for sale
  58. 95 ford probe Inspection is up soon,wanted items
  59. probe
  60. got some intresting problems even top tecks cant figure it out
  61. Running bad
  62. 1990 3.0
  63. 92 probe gl auto. making noise?!
  64. Flashing Over Drive
  65. KLZE heads,cams,intake manifold on the KL03??
  66. klze motor swap
  67. 91 Ford Probe Stereo Issues!
  68. KLZE motor swap
  69. New Probe Site
  70. Help! Please Need to find name of part
  71. 1991 probe fuel problem engine 2.0
  72. Help!
  73. Strange sound when in gear!?
  74. wanting to add sound to my 89
  75. CV joint
  76. Equalizer
  77. Tachometer Quit
  78. Engine wanted? Parting out 93' GT
  79. Heating problem
  80. just paid 275.00 for a 96 se auto 2.0 ltr
  81. Headlights don't work anymore
  82. 2nd Gen Probe GT, Tokico Illumin spring rates needed
  83. 2.0... problems blah help please
  84. help headlight popup motor is out
  85. how do i remove the right headlight motor?
  86. Targa top?
  87. Rack & pinion steering gear swap
  88. engine swap
  89. 93 ProbeGT automatic wont shift
  90. 1995 Ford Probe GT (For Sale)
  91. 89 Probe GT Turbo
  92. need to find valves.89 probe gt 2.2
  93. projector headlights
  94. whats needed to put in a turbo
  95. manual trans problem
  96. 93-97 Rear Bumper Body Kit
  97. probe headlight conv
  98. new car questions
  99. 92 Probe GL sputtering and lost power
  100. help?!
  101. 96 Ford Probe. Has Studder Need In-put
  102. 93 probe dont' star
  103. headlight swap
  104. US GT engine or jdm klze
  105. Base Probe KLZE swap...
  106. Low Idle
  107. 94 Distributor
  108. Very badly worn wheel bearing on Probe
  109. Headlight adjustment
  110. Headlight
  111. 94 Ford Probe GT idle question.
  112. Idle Slugish
  113. 90 probe gl diagnostic port
  114. Spark Issues
  115. Can I change 90 Probe's Front Complete Axle?
  116. Can I change 90 Probe's Front Complete Axle?
  117. 90 Probe 5spd CV Drivers side
  118. idle air control motor
  119. J-spec probe
  120. 93 Probe GT Water Pump
  121. Clutch problem
  122. EGR Bypass? :::How To...:::?
  123. Buying a probe as first Car
  124. 90 tranny probs
  125. Want to put a 6 speed in a 93 probe
  126. Exhaust ? on a 92
  127. 96 Probe GT need help
  128. 90 Probe idling high occasionally
  129. sesor prob.
  130. 90 Ford Probe Turbo 2.2 $700 obo
  131. 90 Ford Probe Turbo 2.2 $700 obo
  132. 1991ford probe airflow meter
  133. 1991 probe lx v6 $700
  134. 1992 gt running probs.
  135. Failed emissions on '97 probe
  136. 89 Probe 5 speed for sale!!!
  137. 1991 probe fuel problem
  138. I am lost
  139. sparkplug cable order
  140. sparkwire order
  141. 89 lx 5spd only has one gear?!?!
  142. 93' Oil Pressure Problem
  143. dash
  144. tranny issues on 91 probe
  145. Transmission cooler
  146. 93 probe lhead light problem
  147. head lights problem
  148. ive got a question???
  149. 1991 Probe GL horsepower chip
  150. stuttering at 2500 rpms
  151. ECM Issues
  152. lites not working
  153. Distributor Needed
  154. Wiring 1990 ignition switch
  155. Interior Questions!
  156. 89 Probe Question?
  157. paint
  158. Anyone know this Code
  159. Klze Idle Problem!?
  160. 95 probe hard to start stutters real bad...
  161. mx6 nose
  162. Need some 2.0L parts...
  163. clutch does not come back up
  164. Another Probe problem
  165. Timing Belt Slipt
  166. Exhaust Noise
  167. Purchase help....
  168. Overdrive light and no 4th gear -- comes and goes
  169. EGR problem
  170. awd
  171. engine swap
  172. belt problems
  173. 95 probe
  174. 1989 Probe Owners out There?
  175. Can anyone help me figure out what is wrong with my 93 probe??
  176. 96 SE that wont start
  177. KLZE 1st Start up..no oil pressure!
  178. clicking noise From engine
  179. severe smoke
  180. 92 ford probe
  181. clutch problem?
  182. Over Drive Light
  183. 94 SE, Idle problem, not stalling
  184. 95 ford probe
  185. I Need Tranny Asap!! (90' Probe Lx..automatic)
  186. Proportioning Valve Discontinued?
  187. Door panels
  188. Checking out a Probe
  189. 96 probe what to look out for
  190. Probe Not Running
  191. need exhaust gasket,92 gt
  192. wierd running probs with 92 gt
  193. 91 probe 3.0
  194. Car not starting, HLP PLZ
  195. i need an ecu
  196. ram air and a vacuum line
  197. low beams
  198. 3 inch mandrel exhaust for sale
  199. i need help finding the electric lock actuator
  200. 9e probe gt problems
  201. 94 ford probe gt won't stay running
  202. Problem
  203. How do you time a distributor?
  204. ecu question...
  205. tranny question...
  206. value of 94 probe
  207. CD player
  208. J-Spec
  209. 1995 Ford Probe Starter Gone
  210. egr sensor
  211. 92 probe
  212. Secret to changing headlight?
  213. WHat's wrong with 93 probe now?
  214. Died & won't start
  215. FS- 94 Probe in NC whole or parts.
  216. How much is a 94 Probe SE Worth
  217. Starting Problems
  218. Advice on cold air intake purchase
  219. 1993 Probe Gt
  220. Front wheel (axle) bearing
  221. probe
  222. does this sound right for a Tune-up??
  223. compression
  224. Exhaust?
  225. front mount intake?
  226. Problem w/ probe
  227. IT WON'T START!!! 96 GT MTX Please Help!
  228. Worth Buying?
  229. Kl-ze Swap Help????
  230. Bucking on Acceleration
  231. 92 probe
  232. 93 Fuel Cut Off Light
  233. Timing belt slipped? Does it hurt engine?
  234. 89 Turbo Starting Problems
  235. 500 Whp Probe
  236. Need Help Re: 89 Turbo
  237. probe vs. mustang
  238. cams
  239. Clutch Fluid
  240. probe keeps chugging...
  241. 97' probe horsepower?
  242. A/c And Cooling Diagrams
  243. 1993 Probe starter removal
  244. a little help?
  245. 5 spd manual conversion
  246. Ignition Switch
  247. Analog to digital gauges.
  248. 1990 engine/trans swap HELP!?!
  249. Clutch or Transmission problems?
  250. Car Wont Stay Runnig - Help
