View Full Version : Probe
- 2nd gen 93-97 probe
- 96 Probe turns over but will not start...
- Distributor installed wrong
- bye bye Probe
- Advice Wanted (Supercharging)
- 1993 Probe Problem
- idler tensioner
- i got a code 55
- In need of trans mounts
- fast ticking on left side of engine
- stalls and dies when it is hot outside, accellerates improperly also
- My Probe Steering Wheel Locked up...
- 95 probe gt no spark
- 1993 Probe Wiring Diagram For Computer
- Great info for 2.5
- code 55?
- How To Disconnect/Turn off A/C Pump?
- probe for sale
- 95 ford probe Inspection is up soon,wanted items
- probe
- got some intresting problems even top tecks cant figure it out
- Running bad
- 1990 3.0
- 92 probe gl auto. making noise?!
- Flashing Over Drive
- KLZE heads,cams,intake manifold on the KL03??
- klze motor swap
- 91 Ford Probe Stereo Issues!
- KLZE motor swap
- New Probe Site
- Help! Please Need to find name of part
- 1991 probe fuel problem engine 2.0
- Help!
- Strange sound when in gear!?
- wanting to add sound to my 89
- CV joint
- Equalizer
- Tachometer Quit
- Engine wanted? Parting out 93' GT
- Heating problem
- just paid 275.00 for a 96 se auto 2.0 ltr
- Headlights don't work anymore
- 2nd Gen Probe GT, Tokico Illumin spring rates needed
- 2.0... problems blah help please
- help headlight popup motor is out
- how do i remove the right headlight motor?
- Targa top?
- Rack & pinion steering gear swap
- engine swap
- 93 ProbeGT automatic wont shift
- 1995 Ford Probe GT (For Sale)
- 89 Probe GT Turbo
- need to find valves.89 probe gt 2.2
- projector headlights
- whats needed to put in a turbo
- manual trans problem
- 93-97 Rear Bumper Body Kit
- probe headlight conv
- new car questions
- 92 Probe GL sputtering and lost power
- help?!
- 96 Ford Probe. Has Studder Need In-put
- 93 probe dont' star
- headlight swap
- US GT engine or jdm klze
- Base Probe KLZE swap...
- Low Idle
- 94 Distributor
- Very badly worn wheel bearing on Probe
- Headlight adjustment
- Headlight
- 94 Ford Probe GT idle question.
- Idle Slugish
- 90 probe gl diagnostic port
- Spark Issues
- Can I change 90 Probe's Front Complete Axle?
- 90 Probe 5spd CV Drivers side
- idle air control motor
- J-spec probe
- 93 Probe GT Water Pump
- Clutch problem
- EGR Bypass? :::How To...:::?
- Buying a probe as first Car
- 90 tranny probs
- Want to put a 6 speed in a 93 probe
- Exhaust ? on a 92
- 96 Probe GT need help
- 90 Probe idling high occasionally
- sesor prob.
- 90 Ford Probe Turbo 2.2 $700 obo
- 1991ford probe airflow meter
- 1991 probe lx v6 $700
- 1992 gt running probs.
- Failed emissions on '97 probe
- 89 Probe 5 speed for sale!!!
- I am lost
- sparkplug cable order
- sparkwire order
- 89 lx 5spd only has one gear?!?!
- 93' Oil Pressure Problem
- dash
- tranny issues on 91 probe
- Transmission cooler
- 93 probe lhead light problem
- head lights problem
- ive got a question???
- 1991 Probe GL horsepower chip
- stuttering at 2500 rpms
- ECM Issues
- lites not working
- Distributor Needed
- Wiring 1990 ignition switch
- Interior Questions!
- 89 Probe Question?
- paint
- Anyone know this Code
- Klze Idle Problem!?
- 95 probe hard to start stutters real bad...
- mx6 nose
- Need some 2.0L parts...
- clutch does not come back up
- Another Probe problem
- Timing Belt Slipt
- Exhaust Noise
- Purchase help....
- Overdrive light and no 4th gear -- comes and goes
- EGR problem
- awd
- engine swap
- belt problems
- 95 probe
- 1989 Probe Owners out There?
- Can anyone help me figure out what is wrong with my 93 probe??
- 96 SE that wont start
- KLZE 1st Start up..no oil pressure!
- clicking noise From engine
- severe smoke
- 92 ford probe
- clutch problem?
- Over Drive Light
- 94 SE, Idle problem, not stalling
- 95 ford probe
- I Need Tranny Asap!! (90' Probe Lx..automatic)
- Proportioning Valve Discontinued?
- Door panels
- Checking out a Probe
- 96 probe what to look out for
- Probe Not Running
- need exhaust gasket,92 gt
- wierd running probs with 92 gt
- 91 probe 3.0
- Car not starting, HLP PLZ
- i need an ecu
- ram air and a vacuum line
- low beams
- 3 inch mandrel exhaust for sale
- i need help finding the electric lock actuator
- 9e probe gt problems
- 94 ford probe gt won't stay running
- Problem
- How do you time a distributor?
- ecu question...
- tranny question...
- value of 94 probe
- CD player
- J-Spec
- 1995 Ford Probe Starter Gone
- egr sensor
- 92 probe
- Secret to changing headlight?
- WHat's wrong with 93 probe now?
- Died & won't start
- FS- 94 Probe in NC whole or parts.
- How much is a 94 Probe SE Worth
- Starting Problems
- Advice on cold air intake purchase
- 1993 Probe Gt
- Front wheel (axle) bearing
- probe
- does this sound right for a Tune-up??
- compression
- Exhaust?
- front mount intake?
- Problem w/ probe
- IT WON'T START!!! 96 GT MTX Please Help!
- Worth Buying?
- Kl-ze Swap Help????
- Bucking on Acceleration
- 92 probe
- 93 Fuel Cut Off Light
- Timing belt slipped? Does it hurt engine?
- 89 Turbo Starting Problems
- 500 Whp Probe
- Need Help Re: 89 Turbo
- probe vs. mustang
- cams
- Clutch Fluid
- probe keeps chugging...
- 97' probe horsepower?
- A/c And Cooling Diagrams
- 1993 Probe starter removal
- a little help?
- 5 spd manual conversion
- Ignition Switch
- Analog to digital gauges.
- 1990 engine/trans swap HELP!?!
- Clutch or Transmission problems?
- Car Wont Stay Runnig - Help
- how do i
- Probe buyer.......maybe
- someone plz respond!
- where to get window motor/regulator '94
- Probe | Teen Driver
- Custom 94 Probe Gt 3,500 Or B/o
- getting rid of probeGT high performance parts and basics parts for sale
- how do i ?
- Flex pipe
- need a lil help
- timing 93 probe v6
- Power Window Master Switch
- Fuel Filter
- windshield wiper location?
- 93 2.5 to a 95 2.0
- Which to get
- where can i get a harmonic balancer???
- engine
- 97 ford probe check ingine light
- A place to start?
- 93 2.0L mystery problem with transmission
- Parting out 1989 Probe GT/ 5spd
- distributer test?
- a couple questions
- 93 probe GT starting problems...shorting out?
- Looking for a Probe in Missouri.
- 93 probe gt won't start
- Ball Joints, Bushings, Control Arms, Oh MY!! :-O
- probe newbie
- buying a probe
- Upgrades
- 93 probe gt for sale
- 94 probe se vs 91 celica gt
- 91 lx speed sensor
- Sensor
- projector head lights
- Motor Swap
- which is better?
- dont know
