View Full Version : Maintenance
- Grinding Noise at Cold Start - Bulletin
- anti lock brakes my @$$
- Radio Anntena
- willn't start
- Power Windows (Driver side)
- Dropping Resistor?
- Cruise Control kaboomo.
- ECU Location
- OK guys o2 sensor again!
- AHHHHH 6months old and check engine light???
- Radiator Fans
- earthing?
- Best sealant, anti-seize, etc to use on switch??
- Eureka!!!!!! O2 sensor...
- G20 Radio Antenna
- air conditioner
- burning smell
- when to change o2 sensor
- broken boot
- Reliable shop in San Diego?
- OBDI or OBDII?
- I need a motor mount
- Bosch O2 Sensor
- G20 Service Manual
- Oil Pressure
- P10 Oil Pressure Switch Upgrade Info - A must read!
- P10 G20 Sensor..
- G20 Dashboard lights not working
- Check Engine light - 1994 G20
- Stalling Primera
- EGR and Emergency Brake Light
- NGK Plugs.../rough idle
- A couple of problems with my P10
- Auto Tranny
- Anyone else getting 18 mpg? ('93)
- Ghost in the machine
- Hoowdee!
- input please
- Transmission Noise Woes
- 95/G20t LSD/Axle Rare Specimen/Help!
- Transmission Whistle/siren noise
- Noisy Axle...
- O2 sensor or not?
- Noise at start-up when cold???
- Tail Light removal.
- Headlight harness
- Help: Rear Brake Calipers
- m
- Changing Brake Pads
- Oil Switch Part # (for dummy light)
- OIL on Spark Plugs. Its that bad?
- Transmission swap
- 91 G20 Good Buy?
- Idles rough in reverse gear
- Lighting Harness For P10
- Intermittent power loss- HELP!
- Clutch woes...
- Transmission noise
- need a clutch,,,go to nissan or infiniti
- Emission System Warning light, help :(
- Service Engine lights up again!
- How much oil is needed?
- Oil???
- My gearstick is still limp! and hanging to the right
- High Idle Speed
- ZMax for G20?
- Low Idling, but no stall
- how to: take off brake light off rear deck
- Cap and Rotor
- SE-r the same ad G20
- Monkey brakes !
- Please Help!!
- Low Rev Problem
- slllloooowww start
- Reverse pop-out!?
- P10 having getting access to shifter...
- clutch woes
- tune-up
- G-20 reliability...
- Chamber
- Do "oil leak" additives work?
- High Idling & Stalling PROBLEM!!!
- 5th gear slippage...
- Bad steering problem!
- squeaky rear brakes
- front engine mount leaking.
- Repair Manual
- tire wear
- My G20 is dieing
- steering wheel during breaking
- Exhaust Installation
- squeeking brakes
- got the frekkin dash bug!
- poor mpg. what's wrong?
- brake pads
- clutch - how to?
- window problems in cold weather
- lighting replacement
- Poping noise during low speed braking...
- Where is the sunroof fuse?
- Winter Tires Help
- Checking for melting wires....
- TBS's on instrument panel rattle? P11
- POS Car
- steering wheel shakes @ high speeds
- HELP! Interior Lighting...
- My Tach is Dying
- Swapping to DET
- Clutch does not grab quickly
- compter problem
- OBD Scan Tool and Oxygen Sensor Location
- Driveshaft replacement how to...
- Something in my dashboard....scaring me..:(
- stiff cluch
- Anti-lock brakes have mind of their own!!
- Knock Knock...
- Wheel stud is broken!
- Burning Oil...
- Anyone had this problem?
- no sulfer smell, better milage?!
- 60,000 Tune Up
- Another problem solved
- Running without fender liners?
- How to check ecu code on a 95 G20?
- Seatbelt light
- breaking in and gas mileage
- Reliablity over 100,000 miles?
- ok this is frikken weird :0
- Symptoms leading to starter failure
- ABS light
- Coolant and Transmision Fluid Question!
- Problems in reverse
- My gearsticks gone limp!
- RPM/ engine rev.
- Getting serviced in SoCal
- Oxygen Censors
- oil burned too fast?
- MAD electrical problems, all at once!
- Crackling noice in engine + ServiceEngine Soon came on
- Starter ...
- Air Temp Sensor
- Engine rattle/knock
- synthetic or regular oil?
- how HOT are they supposed to get?
- Anomaly of the week
- Stupid trunk
- vibration above 60mph
- It's to hot!
- cruise control fuse???
- steering wheel leather fading
- sunroof
- Weird problem
- dirty dirty upholstery
- worn out leather seats
- P10 Central Locking Problem
- Stalling p-10?
- leather seats
- 1st gear..........rough
- air conditonor
- Wipers Stopped
- GearBox Oil
- REPLACING OIL PAN GASKET...please help
- EngineService Soon lamp came on
- Coolant loss
- It happened!
- Minimum Octane
- Tach
- Simple Green
- armor all
- brake system bleed! how?
- G20 Scheduled Maintenance vs Dealer 'Check Up'
- Third Brake Light Replacement
- HOW TO: Converting your P10 G to 5 speed from auto Part 1
- Radiator flush/maintenance
- Power Antenna problems
- Recall list for 2000 G20 (includes:Infiniti Vehicle Squeak and Rattle Materials)
- steering wheel lock
- Stay tuned : I will be performing another auto to manual conversion within next 48 hr
- 95 G20 Headlight Bulbs
- OBD-I or OBD-II ??
- Rattling Instrument Panel P11
- For all of you who asked: Japan Motor Import
- Left headlight
- Had a little scare...now what???
- 99 g20t sunroof
- engine stall problem
- Brakes Squeaking
- ECU codes
- headlight washers
- disconnect ABS?
- drive cam
- Does dirty oil bring down mpg?
- torque wrenches...
- I Got A Question...........
- Hard Acceleration takes a lot of fuel
- Found a few mysteries in the trunk of my P10...
- How to get windshield wipers off?
- Gas Pedal 95 G20
- Trans. Making a squeel nd slipping!
- Sunroof leak
- Brake Dust
- How do i take the rear rotor off?
- Rattling from under the hood
- Brake Pad replacement Problems
- Fog Light Bulb s
- power antenna for p10? Cheap?
- funky noise
- EGR VALVE
- Rattling problem
- Squeek! HELP!
- What Clutch Should I get?
- Clutch cable
- Egine chek light is on.. T.T
- ABS light????
- Post back some answers !!!
- Time for a Clutch Change
- Sputtering
- To soft power stering
- Not Starting!!
- Fog lights pre-wiring: WTF?
- anoying sweaking noise --what is it?
- knocking noise at idle
- Frozen shifter!! Help!
- funky smell...
- Taking out the headlights
- My driver side window doesnt work anymore
- Fog Lights
- Service Department
- G20 Accessories
- higher than normal idle
- Oil Pressure gauge, possible problem?
- P10 front seat question, and possibly problem
- Car stalls
- anyone know how to get tether hook, part #?
- left lights keep blowing out
