View Full Version : Engine
Pages : 1 2 3 [4] 5
  1. Best Setup?
  2. new ecu?
  3. Hotshot Turbo?
  4. Weapon R Intake for G20...
  5. Glasspack Resonator
  6. I want Intake, JWT Pop has pipe or no? I want pipe, any Intake I can get with it??
  7. Fuel Pressure
  8. George do you now how much is capable the roller rocker motor rev?
  9. Exhuast??
  10. Hotshot header & Place Racing CAI
  11. 2.25" turbo exhuast?
  12. Reset Comp?
  13. how much does a JWT Air filter go for?
  14. Ecu
  15. Hotshot Or Place Racing Cai
  16. Advancing ignition timing
  17. Brullen Exhaust
  18. Pacesetter header and resonator
  19. anyone have problems with purolator oil filters?
  20. what happened to my engine?!?
  21. Transmission Whistle/Siren noise
  22. OEM exhaust mandrel bent ???
  23. Affect on performance (change wheel size)
  24. does anyone have a turboed auto trans?
  25. Stillen Header
  26. Just Changing the Exhaust headers?
  27. Shops in the Los Angeles Area??
  28. Grinding a new profile onto the stock cams?
  29. I want an exhaust
  30. Engine Break-In
  31. Adapter for Air Filter
  32. Turbo ... bo... bo..
  33. Z32 T25 Turbo
  34. most power with least amount of noise
  35. how long....Sr20det???
  36. JWT Roller Cams
  37. Air Horn Install???
  38. Ecu Code????
  39. tranny seals
  40. Turbo charger or super charger?!?!?!
  41. Greddy Evo Exhaust
  42. Dual tip exhaust?
  43. BKR7E -vs- PFR6B-11
  44. What type of ABS is on G20s???
  45. Oil Pressure Gauge Hook-up
  46. motor mounts for p10
  47. Short Shifters?
  48. Weapon R Dragon Intake
  49. Autometer Gauge
  50. Sunny GTi-R Gearbox
  51. 1/4 mile times
  52. Battery Relocation Kits???
  53. Radiator Problems??
  54. Pics Of Intakes In Any G20!
  55. exhaust systems
  56. Roller-rockers?
  57. HS Turbocharger
  58. HS CAI Prices
  59. SR20DET ECU wiring diagram needed
  60. RandomTech Cat?
  61. Limited slip diff stuff
  62. replacing the ECU with a different spec one?
  63. P10 Greddy Evo
  64. Pulsar GTi-R sr20det
  65. Swap Question a Lil Off
  66. Hose Technique
  67. level 10 on G20?
  68. P10det are still there i need help
  69. Intake Questions
  70. Engine Swap
  71. Energy Suspension engine mounts for our G20s
  72. does "TORNADO" really work?
  73. p10 CAI
  74. hotshot header
  75. Fuel Pump swap
  76. Problems with DET Swap
  77. Mufflers?
  78. HS CAI vs JWT Pop
  79. Pulsar/Sunny ever have 6 speeds?
  80. Exhaust Manifold
  81. How to make a custom intake pipe for P11
  82. New Exhaust Installation- Chain or Local shop ?
  83. gaskets?
  84. '91 Cams in a '99 P11?
  85. P11 Greddy Pics?
  86. Changing the stock cams. What about the ECU?
  87. 370cc Injectors??
  88. Finally got the HS header and CAI installed
  89. Differences in ECU between '91 & '96
  90. resonator and header
  91. Times for a SR20DET P10
  92. Ecu Codes
  93. How much power can standard mod bring you?
  94. header or exhaust?
  95. Want to install intake...what to do with sensor?
  96. Super AFC on a SR20DE
  97. Headers
  98. My intake won't fit
  99. Does The Aem Fit In A P11?
  100. TSB on Recommended Oil for SR20
  101. Clutch Job
  102. NOS wet vs dry
  103. Getting the G20 to 200 hp
  104. mystery part
  105. Transmission change.
  106. Max Hp
  107. Can you do this to get more air?
  108. Must be the starter right?
  109. exhuast systems comparsion
  110. earthing....some new tuners mod in japan
  111. Quit Exhuast
  112. Cobra MAF
  113. Best exhaust of G20???
  114. Octane Boosters
  115. Calsonic radiator
  116. Clutch Recommendations
  117. breather filter for stillen intake???
  118. Resetting ECU
  119. anyone NOS their P11 yet?
  120. Anyone know where I can get a Hotshot CAI for cheap?
  121. ACT Clutch
  122. Anybody care to share Greddy Exhaust for P10?
  123. Cai
  124. Question on turbo oil lines
  125. Straight Pipe Exhuast? Yes\No
  126. What oil ???
  127. Haltech experiences?
  128. auto to manual question?
  129. Prolems: Static Noise at 5500 rpm in 2nd
  130. New engine vs. adding turbo to current one.
  131. 2002 G20 Automatic 0-60
  132. alchoul not to drink
  133. Going to look at a motor
  134. jwt or stillen cams?
  135. George/Luke - Pick yer brain please
  136. reset ecu
  137. P11 G20 w/ QR25DE swap... @*#&!!!!
  138. Question about installing new exhaust
  139. Home made CAI
  140. Custom 2 1/4" cat-back installed!!! Woohoo!
  141. Q for George
  142. Check out these muffler tips
  143. What are the best spark plugs for the G20?
  144. ? Are there any diffrence in engine 99,00,01,02
  145. what's a good clutch
  146. RWD DET's
  147. diferens between HSgen3 -4
  148. Confused
  149. lighting flywheel
  150. AWD DET ??'s
  151. A definate MUST!!
  152. det changeable parts
  153. Altitude calibration?
  154. How to clean engine???
  155. Unorthodox Pulleys
  156. Glasspack as a resonator ???
  157. Reactive Filter
  158. Stillen Header
  159. Will this CAI fit P11!
  160. 2000+ Cams??
  161. Sr20det in a Datsun 510!!
  162. to 22det
  163. 4 5Zigen exhaust applications for the P10!!
  164. 4WD 0-100 Time
  165. question about the 99-00 compared to the 2002 limited Sport package.
  166. engine misfire
  167. Prices HS header (gen4) UR pullies (2set)
  168. Camshaft and Injection
  169. Custom Exhaust or Greddy...?
  170. I Need This!!!!
  171. Early Sr20de Ecu And Wiring Harness!!!
  172. Custom Exhaust Shops - Columbus OHIO
  173. which one is cheaper?HS or PR
  174. tranny
  175. Quarter mile performance
  176. Custom Exhaust Pipe tubing for P10
  177. Header
  178. Q for Luke
  179. Bkr7e
  180. How much bhp?
  181. Questions for the DETers
  182. CAI /air condition ducts
  183. msd ignition vs stock ignition
  184. Who's G20/Primera has the most horses?!?!?
  185. Hotshot Turbo Kit
  186. Help
  187. New Info on JWT Turbo Kit
  188. Finally!!!
  189. Tip size, will it fit?
  190. Cam shaft fun!
  191. This is what Place Racing wrote back!
  192. To Ti423
  193. Cutting Tip of Greddy Exhaust...
  194. What Capacity
  195. To George Roffe
  196. '91 P10 G20 Cold Air Intakes
  197. What do you think
  198. What is this?
  199. Stillen Muffler
  200. $190 NEW OBX Headers... ...worth the $$$$
  201. Intercooler Piping
  202. 92 hotshot cai
  203. gear ratios
  204. Anthony I need your help....
  205. 2000+ Hotshot CAI...
  206. Exhaust options?
  207. SR20DETs in Montreal
  208. apexi s-afc
  209. Woohoo installed me an intake :)
  210. Random Tech Cat
  211. Heat sheilding for intakes
  212. Hotshot Header
  213. P11 Greddy Cat-back
  214. OBX mufflers?
  215. 2000 strut bar??!??!
  216. ported head
  217. Onorthodox pulley set
  218. Splash guards
  219. SuperSprint back box
  220. RPM / engine rev
  221. cold air intake
  222. Aluminum Housing for Intake!!!!
  223. I need a new clutch???
  224. quickest g20
  225. Good QUIET perfomance muffler?
  226. Intercooler
  227. JWT POP vs. STILLEN POP
  228. pop charger/ filter info/help
  229. P10 exhaust
  230. cams-good or bad?
  231. Has anyone heard of TODA
  232. Exhaust manifold
  233. AEW CAI for 2000 G20??
  234. Better than a DET Look!
  235. ECU resetting...
  236. JWT and Hotshot?
  237. What should I do???
  238. 1999+ Model Turbo??
  239. SR20DEturbo $$$$$
  240. power, reg, comfort switch question
  241. Hotshot or Place Racing CAI
  242. ebay intake question
  243. Something wrong with my tranny...
  244. P10 Automatic Motor Mount Question
  245. KN Filter ... worth it or not???
  246. Best INTAKE FOR G20
  247. Primera header
  248. chips for p10?
  249. Dastek Unichip
  250. Thermostat Question
