View Full Version : Engine
- What would be a decent price for a 1999 Sr20de w/40,000 miles???
- CAI vs K&N filter
- cam durations
- Twin Cam??? DOHC???
- inexpensive exhaust?
- Iridium vs Platinum
- what exhaust for my P10?
- 99 header on a 2k G
- sr20det swap
- Everyone with greddy mx exhaust
- What year motor, for what year car?
- Engine Swaps...
- Good and Bad Days
- Advanced Timing
- Intake, Header, Exaust
- JWT POP Cold Air extension???
- CARB certified mods....
- Yes,another exhaust question...
- Intake Vent
- More power for real cheap.....
- Silicon hose kits?
- K&N filter or original?
- What do all these mean?
- Judd SR20DE??
- Plug wire popping off
- Are These Terrible Prices!?!?
- Part Numbers!!!
- JWT s4/s3 cams
- JWT Header?
- Greddy MX Exhaust
- Just ordered Stillen Intake, Any tips..?
- just installed K&N air filter
- Help me out ya!
- engine pics...
- Can someone confirm....
- Installing an AEM Bypass Valve on a HotShot CAI
- Who's got the better muffler?
- Can you supercharge a "G"
- bypass valve
- General Q about engines
- exhaust-tion
- HELP!!! Transmission noise
- Bolt on turbo kits
- JWT S3 Cams
- diferent rmp levels... help me please!
- Another P10 flywheel question
- question about automatics?
- P11 Engine Pics
- 10:1 CR is this possible and whats the benefits and is it worth it?
- Maunal Swap
- Advancing Timing: Questions
- JDM red DEt valve cover
- Battery size for installing the HotShot CAI?
- wickedG20 or erikbronx question for u?
- Radiator upgrade?
- 94' G20 Won't Start
- Newbie: What to look for?
- DET swap/tranny issues
- Do 1999 P11 and 98+ B15 SE-R have anything in common engine wise?
- Air flow sensor stuffing up!? :(
- Holy crap that's fast!!!!!
- i need an exhaust!
- clutches
- Stillen Products
- ECU question
- At what stage would Water Injection be appropriate??
- SR20DET parts swapping
- ABS Light..
- Where to go to buy a good engine stand?
- Various Turbo Kits for the SR20DE
- Major Differences and other peoples opinion...
- Stoopid Ques. But Where is a safe place to...
- which cam is better
- Bad, bad luck...
- Straight pipe???
- Prices on JWT cams and ecu?
- Anyone hook a turbo up to there G?
- i need hp bad
- turbo shaft rpm-p-10det???
- Lightended Pulleys
- Cold Air Intake Problem
- BOV Recirculated!! (Die Luke, Die!!)
- air sensor on stock air box??
- Where to get a short throw
- Temperature went to 0 at 70mph!!!!! wtf??????
- FSM
- Someone have to know!!
- trick intake manifold
- air filter change?? how long
- anybody swaped they slushbox auto for a 5-spd in a g20 yet??
- rod bearings
- tranny experts -- need some help fast!
- is 94 p10 OBD-I or II?? (I don't have owners manual)
- Anyone that has done a GTI-R motor have a few pointers?
- what's a recommended tranmission oil to use (94 auto)?
- any problems sucking water with CAI installed?
- Powdercoat or ....?
- timing chain replacement
- any got a opion on the 5Zigen Fireball exhaust?????
- quick question about headers plus exhaust
- Homemade A/F Meter
- Lightened Flywheel p10???
- o2 censor???
- Newbie wann hook up my g20
- Dimensions for Intercooler on a p11
- Switching sr20di with sr20de (t)
- Try This Out!!! Modify Your Stock Intake To A Cold Air Intake W/o The Pipe!
- Magnetic Oil Pan Drain Plug
- HS CAI Install????
- Emission light? On?
- LSD tranny?
- Gibson muffler
- 2K+ Headers
- K&N Part No?
- Cheap HP
- Nos For Sale!!! Cheap!!!
- Intake
- Anybody have an opinion of a good full exhaust system?
- I'm only getting 300 mi. on a full tank -- what gives?? (94 auto g20 106k)
- help with timing adjustment
- The s3 cams are for sale!
- Starter Motor died today
- air filter???
- Need Help wheres low end!??!
- installing pulleys
- cali guys - CARB
- Lambda sensor - where to buy (UK)?
- MY2000+ owner FYI!!
- Hotshot CAI group deal!!
- intake/header combo...
- Pics of my 1999 SR20DE Motor I bought
- forced induction ???
- What short shifter fits a p11???
- chips and beer
- Motor Mounts
- supercharger on its way?...
- fuel pump
- Unorthodox Racing pulleys
- This is what everyone should be looking at and doing...
- New Header/Exhaust Install Questions???
- unorthodox racing pulleys??
- HELP Breather filter
- oil pressure gauge question 2!
- Hotshot costs.
- Turbo Engine & Auto Tranny ?
- Has anyone used a Techtom on their P11?
- need input g20.net
- Intercooler Dimensions & Misc.
- Shifter bushing
- Denso spark plugs
- Engine, Tranny Mods
- Help ~PR CAI~help
- GTECH Performance Pro meters?
- pully belts
- Custom Exhaust
- Best Platinum plugs for SR20DE
- engine cuts off in left turns !!! (p10)
- rod bearings, turbo rebuild?
- Valve Cover
- HELP: Quiet Exhaust!
- Aftermarket Catback Owners - HELP ME!!!
- Greddy MX fitment problem
- apexi n1
- afc?
- i just go a 240sx ready for swap which is better i need advise plz
- JWT POP Charger... will it fit?
- Tranny swap.. Lets try this again part 2
- Tranny swap..
- Intake noises???
- Leak down test results..
- Fuel Cut-off Problem
- Knock sensor
- Fuel Pump Lock Ring/How Do You Remove It?
- head swap is it possible?
- Weapon R
- tell me the different
- more HP?
- Where do I go?
- New Tranny for SR20DE+T?
- 93 G20 Spark plug gap?
- T25 Manifold Question
- CAI, Header + Exhaust install order
- does it's make different
- fuel filter
- Pulleys
- Turbo Question
- highport lowport head swap
- New timing marks
- MAF sensor
- Underdrive pullies
- JWT cams
- Upgrades
- Motor, Offers?????
- data loggers
- For All You Turbo People
- Blown motor..Swap or fix?
- High-Port CAI
- SR20DET Wiring harness
- Hot Air ?
- anyone take their cat out?
- anyone got apexi exhaust?
- i want to advance my timing
- Horsepower
- intake manifold swap
- Turbo
- Turbo G20
- Why not Supercharger instead of Turbo?
- Need Help.. pics please!!
- Timing Upgrade
- detonation
- Where can I get a stock SR20DE?
- WTF is my car doing!
- Closed Loop???? Open Loop????
- cam question?
- -98 DET engine
- CAI to short stack
- Dyno results
- Which DET is this and will it work?
- Sr20de + T
- Ever Tried Obx Bomber Series Exhaust?
- what else
- throttle body
- intake
- meow
- universal exhaust
- header question
- hi guys newbie here ... with not too newbie questions um i think
- Which Blow Off / Dump Valve??
- CAI for P10 or P11? ANYONE HAVE PICTURES?
- Which Exhaust?
- p11 Turbo
- What size of turbo should I choose? (for p10)
- My plugs were destroyed...
- Advice on buying a DET
- Ordering the Stillen HiFlow Intake
- Has anybody had to replace a fuel pump?
- G20 Spec V?
- motor mounts
- Turbo
- JWT Pop Charger Install Question #2
- JWT cam and ecu
- problem: weird smell in the motor
- Recirculating a Blitz DD BOV?
- 5zigen n1
- Help please...clacking noise from engine??
- [b]i Am The Best[/b]
- G20 Gas Mileage
- POS Hotshot Header
