View Full Version : Escort
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Transmission Noise?
  2. 1994 Escort 1.9l no heat
  3. Tie Rods
  4. TIPS: Things you can do for your 91-96 Escort LX
  5. TIP: Fix those doorjam switches // no dome light...
  6. TIP: Smell When Run Heat on FULL...
  7. Weird coolant color
  8. Alternator
  9. 99 escort Head Gasket trouble
  10. 97 Starter removal
  11. 99 escort emergency brake adjustment
  12. Wrongway Escort
  13. '90 runs cold then stalls no fuel, no spark
  14. 99 escort ZX2 DOHC timing belt
  15. 99 escort ZX2 DOHC timing belt
  16. 2000 ZX2 stalling while driving - no codes
  17. A Sad Day
  18. Stupid Check Engine Light
  19. 500k
  20. Trans Sensor: So what is this ???
  21. need new IAC?
  22. Drum brakes
  23. Side Moldings
  24. Need to jack up the engine in my '91 Escort (1.9L)...
  25. steering wheel shaking, pulling to the right
  26. where is my AC low Pressure port?
  27. 98 Escort not downshift properly
  28. Ford Escort Motorcycle!
  29. low idle escort zx2
  30. Air intake silencer
  31. Advice
  32. 03 temperature problem
  33. 97 Front Caliper Dust Boot replacement.
  34. Fog Light ughh
  35. 96 Wagon Axle
  36. CV Halfshaft replacement
  37. Front Wheel Bearings--99 escort
  38. Shift Stuck in Park 1992 Ford Escort
  39. wont start
  40. Hazard Switch Question
  41. 93 Escort Transmission Fluid
  42. ford escort zx2 engine stumble
  43. 93 Escort headlight problem
  44. 93 Escort LX Wagon wont start.
  45. Aftermarket Keyless Entry in 2000 ZX2
  46. 1995 escort transmission swap
  47. Escort Suspensions
  48. 99 Escort ZX2 2.0L DOHC code 1383
  49. 1994 Escort-Plz Need a Opinion
  50. 96 Wagon Sway Bar Size?
  51. 1994 Ford Escort
  52. 93 drum brakes stuck
  53. Transmission
  54. 01 escort 2.o dohc
  55. '97 error code "not completed"
  56. o2 sensors not working
  57. Can't find my battery
  58. ford escort high RPM stutter??
  59. 95 Escort Turn Signals and Hazard Switch not working????
  60. Air Intake
  61. Need to replace bearing in alternator
  62. 99 escort ZX2 DOHC
  63. Rims
  64. Project Escort.
  65. Power Steering fluid leaking
  66. leaking transmission in reverse only
  67. 99 escort no start
  68. Front right wheel heating up
  69. My Transmission Problem
  70. A/C Clutch
  71. '99 Escort brakes pulsing
  72. 1994 escort fuel rail???????
  73. Clutch not disengaging
  74. Synthetic oil
  75. 1998 2.0L SPI Escort - won't start
  76. Help...2002 ZX-2 Air Cond. Flow Acting Up; vacuum leak?
  77. Cat Converter
  78. Exhaust manifold studs ... replace 'em!!
  79. Would a bad O2 sensor cause stalls?
  80. 96' airbag light code?
  81. Brake Light Switch
  82. 98 zx2 timing belt changed wont start
  83. Gas Guzzler problem
  84. Engine Sounds...
  85. 1997 Escort Wagon 114k Check engine light.
  86. Code p0351, Ignition Coil
  87. Ignition switch
  88. Roof rail removal
  89. Head removal?
  90. Need to replace valve cover gasket after removal?
  91. WooHoo!
  92. 93 Escort 1.9L Cam Seal
  93. Treating rusted sills?
  94. Tranny pump gasket replacement, help please.
  95. 1998 Escort wagon serp. belt problem
  96. 1989 Ford Escort GT 1.9L EFI - Stalling
  97. A/C Clutch not engaging....CCRM removed....Is it a bad solder or is the CAW faulty?
  98. timeing
  99. Replacement Steering Wheel Reatining Nut?
  100. 1999 brakes suck
  101. Full Throttle and Cranking to start
  102. Axle/CV Joint?
  103. Clutch/Trans Questions
  104. 92 Escort Radio and Dome Lights
  105. Security LED
  106. Engine cuts when stopping and error code p1131
  107. Engine gaskets ... Felpro "heads-up"!
  108. 2000 ZX2 Water pump replacement
  109. '93 Escort quit turning off! Yes you read that right.
  110. Dirty engine
  111. 1998 Ford Escort Shuttering
  112. Window Deflector
  113. Airbag cover
  114. 95 Escort Wagon Rear Lateral Link trouble
  115. Under hood engine cover
  116. shorted out 94 escort - dead in water?!
  117. What would cause spark knock on a cold engine ('91 Escort)?
  118. 1994 1.9L Will Not Idle - Runs at 2000 RPM
  119. Low Brake Pedal After Tranny Rebuild
  120. 98 escort giving me 15mpg only
  121. Warning: aftermarket fuel pump inlet screen
  122. 1.9 timming marks
  123. 1995 1.9 escort timing belt broke
  124. 96 Wagon Rides Bad!
  125. 2 Body questions
  126. Voltage regulator bypass test ... dangerous?
  127. Engine shuts off at a slow to stop
  128. 97 escort lx rpm's dropping and bouncing
  129. 95 Escort runs hot
  130. 98 escort wont start but engine turn over
  131. Power source for clutch switch
  132. Buying advice - Escort --> '92 up to 2002
  133. 01 zx2 horn and cruise issues
  134. AC problems
  135. what wire do you huck u the rpm green wire to
  136. AC issues
  137. No brake pedal pressure
  138. Alternator
  139. 95, 1.9 press brake ignition turns on
  140. 93 GT, need help
  141. wiring/electrical
  142. Rear Bumpger
  143. 98 ZX2 wont start, no fire to plugs
  144. Help 99 Escort ZX2 2.0L DOHC upper O2 sensor
  145. Paint?
  146. 93' 1.9L/ 4cyl./auto- OIL PUMP?
  147. 99 Escort ZX2 2.0L DOHC missfiring
  148. Wiper arm removal
  149. Has anyone installed aftermarket radio themselves?
  150. Shift Lock
  151. Escort muffler
  152. 2001 zx2 cranks but wont start
  153. 1.9 liter heads ?
  154. Mystery Engine Componant
  155. 97 Escort missfire
  156. zx2 fuel rail
  157. 97 valve seat
  158. 2000 escort zx3
  159. 97 escort misfire cylinder #3
  160. Power Windows - 93 Escort Wagon 1.9L
  161. Bad Vibrations
  162. Adjusting the timing
  163. coolant gauge not working
  164. Weird Noise COming from Engine
  165. Horsepower
  166. 98 Escort ZX2 speedo problem
  167. 95 escort retracting seatbelt noise
  168. 98 ZX2 manual to auto converison
  169. 97 escort runs like crap
  170. Hmm... Damper or No Damper?
  171. 98 Escort problem
  172. 96 escort
  173. 91 Escort GT surges at stop
  174. 92 escort gt,1.8,randomly dies
  175. 95 escort problems
  176. Escort 99 keeps jumping on first drive of day for about 150 Yards (CEL 0401)
  177. 98 escort, blower does not work
  178. White exhaust valve in cylinder
  179. Question about spark plugs for my car.....
  180. Odometer Check!
  181. Clutch or CV joints?
  182. '99 Getting high water temps
  183. Escort Muffler
  184. Horn--1997 Ford Escort LX
  185. 98 ford scort ac blower don't work
  186. Bad Smell At Higher Speeds
  187. 99 escort
  188. 98 Escort delayed shift when cold
  189. Shaking
  190. Wheel nut size
  191. Need help getting a Catalytic Converter for a 98 Escort
  192. The Beauty
  193. Bad Vibration
  194. Shifter (D)
  195. What is Car Service?
  196. 2.0 valve cover on a 1.9 N/A?
  197. 91 escort only runs when i pump the gas
  198. 99 escort died
  199. 96 Escort 1.9 Idle issues
  200. 96 escort misfire on 4.
  201. I push the gas but the car wont go!
  202. Putting a Turbocharger in my 2002 Ford Escort
  203. Throttle Problem
  204. Heater blows COLD! Help
  205. 1.9L 1994 Trouble code
  206. Las Vegas
  207. Escort Hazard
  208. Anti-Theft Window Crank Device ?
  209. Fuel Pump help
  210. trouble codes
  211. Escort Chime
  212. jerking when heater is on
  213. Crank Position Sensor
  214. car dies after warm
  215. New Project Car: Escort Wagon SHO
  216. ZX2 Serpentine belt will not fit?
  217. ZX2 2000 Sepintine fell off
  218. Cig Lighter
  219. Ignition Lock Cylinder & Worn Keys...
  220. Verify Timing?
  221. Bad Gas Mileage
  222. Strange noise
  223. 97 ford escort lx headlights stopped working
  224. 96 ford escort front end problem
  225. 95 escort wagon, won't start
  226. Seriouslly GREAT!!! MILEAGE..
  227. Electrical problems..97 Wagon
  228. need info on ball joints
  229. Escort Key
  230. Major Start issues
  231. '99 Escort overheats, heater blows cold air
  232. ac 99 2.0
  233. 94 escort 1.9
  234. 1996 1.9L Trans Leak.
  235. wierd problems smell/sound
  236. Steering Wheel sliding in and out
  237. ford zx2 tranny
  238. Help
  239. 97 won't start
  240. 2000 ZX2 oil soaked spark plug
  241. 2001 escort zx2 serpentine belt
  242. 98 Escort, wiper & blower don't work
  243. 95 GT Needs some help.
  244. Ignition Key won't release
  245. Fuel problems on 2002 Ford Escort SE. Please help!!
  246. Is changing the timing belt on a '97 2.0 liter this easy?
  247. '94 LX Moisture/Water in Trunk ? (Foggy Rear Window)
  248. Please help 98 escort wont run
  249. Exhaust Flex Coupler
  250. How long to warm up?
