Our Community is 662,000 Strong. Join Us.
View Full Version : Escort
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20
  1. rattling noise
  2. Changing Power Steering Fluid
  3. Emergency brake light won't go off
  4. Changing Oil
  5. Changing Oil
  6. ford escort zx2 2000- knocking sound/ service engine soon light
  7. 95 Escort Cigarette Lighter Fuse
  8. Fan Not working
  9. BPT drive trany conversion
  10. Died on the way to work
  11. clutch adjustment - really need to do it?
  12. oil pan leaking
  13. 1999 Ford Escort Sedan Horn Problems
  14. harmonic balancer
  15. what sounds good on a 1.9L 93 escort?
  16. 1997 escort lx 2.0l sohc
  17. 1.8 engine with oil leak.need some help
  18. Blower & Wiper Problem
  19. 98 Escort Wagon battery problem & smoking tail pipe.
  20. Rims
  21. ford escort bodykits
  22. Speedo not working (1993 Escort LXD)
  23. engine change
  24. side windows won't defog!!!!!!!!!!!!
  25. Rear struts and springs?????
  26. 1998 Escort ZX2 - Starter Problems
  27. 1997 Escort Alarm Problem
  28. 89 Escort Brakes
  29. 1.9 engine and transmission
  30. FS: 88-89 1.9 New clutch kit
  31. ZX2 sepentine belt replacement
  32. What transmission will bolt up?
  33. Where is my fuel filter?????
  34. 01 ZX2 Issues (any info will be helpful)
  35. 1993 escort lx
  36. small barrel like object on side of ford escort 1990 1.4 lx carb
  37. Tail/Brake Lamp
  38. ??? Abs ???
  39. How do you change the tail light on a 98 Escort?
  40. 1990 ford escort keeps stalling at junctions, idling speed erratic
  41. ford escort 1989
  42. 96 lx 5SP QUESTION
  43. Car will not start, 1991 Escort 1.9
  44. Horn Relay
  45. Rabbits chewed up F8CE-AE car part for 1998 Mercury Tracer (Ford Escort)
  46. 89 escort GT 5 speed clutch help!?!
  47. Escort seat belt
  48. Another tranny problem from a 93 lx
  49. any bodykits
  50. where hp
  51. where?
  52. '97 Escort-won't start-not battery-won't turn over
  53. 97 Transmission Problem
  54. 93 escort need new rims!
  55. 93 Escort 1.9 sluggish
  56. horse power gains
  57. Broken Crank Pully
  58. 96' Transmission problem
  59. other bodykit fitting
  60. 96 escort clutch
  61. headlamp/light replacement options
  62. decent bodykits
  63. 94 escort won't turn over
  64. The never ending Escort heater saga...
  65. will it fit?
  66. 1989 ford escort bodykits and horse power
  67. Headlight and Airbag light
  68. 92 escort sedan, brake/highmount wont work.
  69. Idling too fast.
  70. 93 Escort Replacement Rear Bumper
  71. Fuel Tank Sending unit
  72. 1.8l 92'escort fuel pressure question.
  73. help......getting really annoyed
  74. 91 escort gt 5spd fill issues...
  75. 95 Escort - Heater Problem
  76. 95 Alternator Pulley
  77. 96 Mark 5 Escort Wont Start Please help
  78. New Owner '97 Escort LX
  79. 1.8l spark plug pattern on the rotor .
  80. Torque Converter
  81. rear disk. does hand brake work
  82. How do i a Fill 91 GT 5spd Tranny?
  83. Headgasket
  84. 92'escort 1.8 gt starts good,idles rough,dies
  85. Bad thermostat housing = lack of heat...
  86. escort hand brake (disk)
  87. bpv escort engine
  88. Tranny parts f/s - 5spd '95
  89. looking for power
  90. For Anniepooh30
  91. Happy Thanksgiving
  92. bad lug nuts
  93. need to change my engine
  94. 92 1.9L w/ Automatic will fit in which year Escort?
  95. Oil Odor
  96. Just picked up a 95 Escort LE Wagon, what do I need to know?
  97. Defrost push button
  98. ZX2 problems
  99. clutch info
  100. i'd like to swap my engine
  101. revs at 100km
  102. 1994 escort gt engine swap
  103. modifications?
  104. 1.8l Dohc Gt
  105. converison
  106. Shifter lamp
  107. what type of oil to use
  108. '91 Mileage
  109. '91 LX Headlight
  110. Custom fit hood
  111. Humming Noise from the back.
  112. Winterize '91 Escort
  113. solenoid/transmission/both?
  114. plug wires
  115. '91 Electrical Questions
  116. What size breaker bar?
  117. New Tranny? Acceleration Problems...
  118. Options for a 97 with bad engine
  119. EGR solenoid location on 93LX
  120. 93 escort lx electricity demons
  121. 92 escort ex 1.8L transmission
  122. 1989 ford escort
  123. starter
  124. 1000 bucks or bust!!!
  125. 96 Ford Escort
  126. Need a new clutch
  127. spark plug
  128. timing - zetec 2.0L
  129. 98 escort intake help
  130. purge valve - P1443
  131. 97 escort wagon with fuse problems
  132. (94 L.x)
  133. Tranny? Clutch?
  134. Vehicle Overcooling!
  135. '94 1.9l Auto Tranny Problem.
  136. alternator replacement
  137. 97 Escort Frt-end alignment
  138. who's got subs in their late 90s escort?
  139. error codes 181, 186, 214
  140. check eng light off
  141. Fuel pump ground..
  142. looking for bodykit for 96 tracer
  143. clutch is acting up bad!!!!
  144. No power to solenoid
  145. Electrical shortage???
  146. Vacum hoses for 93 LX
  147. Another probelm
  148. 94 Escort LX engine problems
  149. What makes the tranny oil pump go out o a 97 escort/tracer on a regular basis ?
  150. Oil leak and P/S leak
  151. pictures
  152. 91 escort overheats
  153. Auto Trans still not shifting
  154. 97 Escort no 3rd gear
  155. Engine won't shut off
  156. more power
  157. 1988 Fort Escort
  158. 5 speed versus a/t survey =
  159. 98 zx2 transmission help
  160. wheres the thermostat housing
  161. Heater blower and a/c blower problem
  162. Voltage Problem
  163. lifter ticking maybe
  164. air blow fan doesn't work
  165. speedo not working
  166. cold air intake
  167. 89 Escort Auto Trans problem
  168. voltage problem
  169. Bad MPG/Rough Idle
  170. ????? Rear Defroster ?????
  171. Cylinder head replacement
  172. Corksport Strut Tower Bars For Sale
  173. trans on 1.9 95 escort
  174. '93 1.9 Escort Emissions
  175. For Sale On Ebay 91-96 Ford Escort Z3 Fenders
  176. 97 escort (UK) running hot/overheating
  177. Max boost on 1.9L?
  178. 5-speed fluid filler plug
  179. need help, seriously
  180. Strange noise when coasting...
  181. 90 GT Fog lights.
  182. 89 5-speed throwout bearing
  183. Air quality make up code, what this mean
  184. Airbag Warning Light?
  185. Sealing a Leak On Roof Ledge
  186. 91 escort problem.
  187. Light in shifting column
  188. Where’s the HEAT!!
  189. Door panel removal, simple or….
  190. vechile speed sensor
  191. 93' 1.9L Airflow sensor/check engine light
  192. '95 Ford Escort backup & plate lights
  193. Thanks for your help!
  194. blower only has two speeds high and low
  195. I have a 1998 Ford Escort LX
  196. 1995 Auto Trans gave up
  197. Cooling system/check coolant light 95 wagon
  198. 93 escort lx wagon stops when braking
  199. serpentine belt broke, how far can i drive it?
  200. 97 Escort Low Mileage Transmission Failure Help please !!!
  201. 99 escort feels funny when I stop
  202. Weird one..tires
  203. 89 5-speed removal
  204. escort 1.9
  205. Sea Foam
  206. auto tranny problems
  207. Head gasket problem???
  208. 89 Timing Belt Tensioner
  209. Alarm, Radio, Clock electrical problem
  210. 88 pcv valve
  211. replacement flasher for 95 wagon?
  212. Fuel Mileage
  213. NEW PROBLEM 89 Ford Escort
  214. Changing plugs on 97 escort lx
  215. Ford escort engine knock
  216. 1993 windshield wiper trouble
  217. Poll: How fast is your Escort?
  218. 97 escort
  219. water leak 97 mercury tracer/escort
  220. starter
  221. ??? Spark Plug Gapping ???
  222. 89 5-speed clutch
  223. Exhaust Flex Pipe, 1994 Escort 1.9
  224. monroe struts?
  225. Wheel interchange..
  226. 98 escort Speedometer stopped working, car died wouldn't start.
  227. Transmission Problems
  228. clutch question 98
  229. Electrics trouble ford escort 1.8 zetec 1997
  230. ???? Reoccurring Problem ???
  231. What!!?? Is This Thing???
  232. 1989 Ford Escort Problems
  233. Purpose of the "IMRC"
  234. erratic timing at idle
  235. Gas Mileage Drop!
  236. performance upgrades on escort?
  237. '95 1.9L transmission
  238. can I put a 98-99 zx2 engine in a 97 escort?
  239. dipstick keeps popping out
  240. towing an automatic
  241. automatic transmission fluid
  242. Check Engine Light
  243. ??? Buzzing noise ???
  244. ??? Air Conditioning Removal ???
  245. ??? Tar Sheets ???
  246. lexus lights
  247. AC Clutch Pulley Assembly
  248. Alloy wheels
  249. I need a Automatic Trans for a 94 1.9L
  250. 1995 Escort LX fuse/bulb question
