View Full Version : Escort
Pages :
1 2 3 4 5 6 7 [ 8]
9 10 11 12 13 14 15 16 17 18 19
- BPT drive trany conversion
- Died on the way to work
- clutch adjustment - really need to do it?
- oil pan leaking
- 1999 Ford Escort Sedan Horn Problems
- harmonic balancer
- what sounds good on a 1.9L 93 escort?
- 1997 escort lx 2.0l sohc
- 1.8 engine with oil leak.need some help
- Blower & Wiper Problem
- 98 Escort Wagon battery problem & smoking tail pipe.
- Rims
- ford escort bodykits
- Speedo not working (1993 Escort LXD)
- engine change
- side windows won't defog!!!!!!!!!!!!
- Rear struts and springs?????
- 1998 Escort ZX2 - Starter Problems
- 1997 Escort Alarm Problem
- 89 Escort Brakes
- 1.9 engine and transmission
- FS: 88-89 1.9 New clutch kit
- ZX2 sepentine belt replacement
- What transmission will bolt up?
- Where is my fuel filter?????
- 01 ZX2 Issues (any info will be helpful)
- 1993 escort lx
- small barrel like object on side of ford escort 1990 1.4 lx carb
- Tail/Brake Lamp
- ??? Abs ???
- How do you change the tail light on a 98 Escort?
- 1990 ford escort keeps stalling at junctions, idling speed erratic
- ford escort 1989
- 96 lx 5SP QUESTION
- Car will not start, 1991 Escort 1.9
- Horn Relay
- Rabbits chewed up F8CE-AE car part for 1998 Mercury Tracer (Ford Escort)
- 89 escort GT 5 speed clutch help!?!
- Escort seat belt
- Another tranny problem from a 93 lx
- any bodykits
- where hp
- where?
- '97 Escort-won't start-not battery-won't turn over
- 97 Transmission Problem
- 93 escort need new rims!
- 93 Escort 1.9 sluggish
- horse power gains
- Broken Crank Pully
- 96' Transmission problem
- other bodykit fitting
- 96 escort clutch
- headlamp/light replacement options
- decent bodykits
- 94 escort won't turn over
- The never ending Escort heater saga...
- will it fit?
- 1989 ford escort bodykits and horse power
- Headlight and Airbag light
- 92 escort sedan, brake/highmount wont work.
- Idling too fast.
- 93 Escort Replacement Rear Bumper
- Fuel Tank Sending unit
- 1.8l 92'escort fuel pressure question.
- help......getting really annoyed
- 91 escort gt 5spd fill issues...
- 95 Escort - Heater Problem
- 95 Alternator Pulley
- 96 Mark 5 Escort Wont Start Please help
- New Owner '97 Escort LX
- 1.8l spark plug pattern on the rotor .
- Torque Converter
- rear disk. does hand brake work
- How do i a Fill 91 GT 5spd Tranny?
- Headgasket
- 92'escort 1.8 gt starts good,idles rough,dies
- Bad thermostat housing = lack of heat...
- escort hand brake (disk)
- bpv escort engine
- Tranny parts f/s - 5spd '95
- looking for power
- For Anniepooh30
- Happy Thanksgiving
- bad lug nuts
- need to change my engine
- 92 1.9L w/ Automatic will fit in which year Escort?
- Oil Odor
- Just picked up a 95 Escort LE Wagon, what do I need to know?
- Defrost push button
- ZX2 problems
- clutch info
- i'd like to swap my engine
- revs at 100km
- 1994 escort gt engine swap
- modifications?
- 1.8l Dohc Gt
- converison
- Shifter lamp
- what type of oil to use
- '91 Mileage
- '91 LX Headlight
- Custom fit hood
- Humming Noise from the back.
- Winterize '91 Escort
- solenoid/transmission/both?
- plug wires
- '91 Electrical Questions
- What size breaker bar?
- New Tranny? Acceleration Problems...
- Options for a 97 with bad engine
- EGR solenoid location on 93LX
- 93 escort lx electricity demons
- 92 escort ex 1.8L transmission
- 1989 ford escort
- starter
- 1000 bucks or bust!!!
- 96 Ford Escort
- Need a new clutch
- spark plug
- timing - zetec 2.0L
- 98 escort intake help
- purge valve - P1443
- 97 escort wagon with fuse problems
- (94 L.x)
- Tranny? Clutch?
- Vehicle Overcooling!
- '94 1.9l Auto Tranny Problem.
- alternator replacement
- 97 Escort Frt-end alignment
- who's got subs in their late 90s escort?
- error codes 181, 186, 214
- check eng light off
- Fuel pump ground..
- looking for bodykit for 96 tracer
- clutch is acting up bad!!!!
- No power to solenoid
- Electrical shortage???
- Vacum hoses for 93 LX
- Another probelm
- 94 Escort LX engine problems
- What makes the tranny oil pump go out o a 97 escort/tracer on a regular basis ?
- Oil leak and P/S leak
- pictures
- 91 escort overheats
- Auto Trans still not shifting
- 97 Escort no 3rd gear
- Engine won't shut off
- more power
- 1988 Fort Escort
- 5 speed versus a/t survey =
- 98 zx2 transmission help
- wheres the thermostat housing
- Heater blower and a/c blower problem
- Voltage Problem
- lifter ticking maybe
- air blow fan doesn't work
- speedo not working
- cold air intake
- 89 Escort Auto Trans problem
- voltage problem
- Bad MPG/Rough Idle
- ????? Rear Defroster ?????
- Cylinder head replacement
- Corksport Strut Tower Bars For Sale
- trans on 1.9 95 escort
- '93 1.9 Escort Emissions
- For Sale On Ebay 91-96 Ford Escort Z3 Fenders
- 97 escort (UK) running hot/overheating
- Max boost on 1.9L?
- 5-speed fluid filler plug
- need help, seriously
- Strange noise when coasting...
- 90 GT Fog lights.
- 89 5-speed throwout bearing
- Air quality make up code, what this mean
- Airbag Warning Light?
- Sealing a Leak On Roof Ledge
- 91 escort problem.
- Light in shifting column
- Where’s the HEAT!!
- Door panel removal, simple or….
- vechile speed sensor
- 93' 1.9L Airflow sensor/check engine light
- '95 Ford Escort backup & plate lights
- Thanks for your help!
- blower only has two speeds high and low
- I have a 1998 Ford Escort LX
- 1995 Auto Trans gave up
- Cooling system/check coolant light 95 wagon
- 93 escort lx wagon stops when braking
- serpentine belt broke, how far can i drive it?
- 97 Escort Low Mileage Transmission Failure Help please !!!
- 99 escort feels funny when I stop
- Weird one..tires
- 89 5-speed removal
- escort 1.9
- Sea Foam
- auto tranny problems
- Head gasket problem???
- 89 Timing Belt Tensioner
- Alarm, Radio, Clock electrical problem
- 88 pcv valve
- replacement flasher for 95 wagon?
- Fuel Mileage
- NEW PROBLEM 89 Ford Escort
- Changing plugs on 97 escort lx
- Ford escort engine knock
- 1993 windshield wiper trouble
- Poll: How fast is your Escort?
- 97 escort
- water leak 97 mercury tracer/escort
- starter
- ??? Spark Plug Gapping ???
- 89 5-speed clutch
- Exhaust Flex Pipe, 1994 Escort 1.9
- monroe struts?
- Wheel interchange..
- 98 escort Speedometer stopped working, car died wouldn't start.
- Transmission Problems
- clutch question 98
- Electrics trouble ford escort 1.8 zetec 1997
- ???? Reoccurring Problem ???
- What!!?? Is This Thing???
- 1989 Ford Escort Problems
- Purpose of the "IMRC"
- erratic timing at idle
- Gas Mileage Drop!
- performance upgrades on escort?
- '95 1.9L transmission
- can I put a 98-99 zx2 engine in a 97 escort?
- dipstick keeps popping out
- towing an automatic
- automatic transmission fluid
- Check Engine Light
- ??? Buzzing noise ???
- ??? Air Conditioning Removal ???
- ??? Tar Sheets ???
- lexus lights
- AC Clutch Pulley Assembly
- Alloy wheels
- I need a Automatic Trans for a 94 1.9L
- 1995 Escort LX fuse/bulb question
- Help, My 93 Escort Has Starting Problems
- 97 Escort AC Clutch Replacement
- ProStart CT-3200
- auto seat belts
- Overheating may have caused severe damage?
- Turbo kit
- understanding the '97 A/C
- Throttle body swap
