Our Community is 662,000 Strong. Join Us.
View Full Version : Escort
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. Ford Escort intermittent AC
  2. 93 Ford Escort LX idling rough
  3. anyone find the clutch pedal pad replacement
  4. Engine Light for a few seconds on a full tank of gas?
  5. Help! Taillights not working on my 1995 N 1299cc Escort encore
  6. 98 escort zx2 smoke from engine and tailpipe
  7. Brakes??? Pedal going to floor
  8. '98 Escort for sale
  9. 98 escort sport problems
  10. detaching speedometer cable
  11. water reservoir churning
  12. brake and head light issues
  13. strut tower woes
  14. car not starting
  15. 89 Escort GT 1.9
  16. intake '91
  17. Lots of oil in breather.
  18. Escort engine swap
  19. 91 escort...bah
  20. '00 ZX2 Question - Idle
  21. Jerky gear chg in 1.9l 94 wgn auto
  22. 86 escort problem
  23. 89 Escort GT 1.9
  24. 89 Escort due for a major tune up...?
  25. Seatbelt Problems
  26. rs turbo brake calipers
  27. fuel issue
  28. '93 Escort LX revs up without gas
  29. 1987 Ford Escort Wagon Revving at Idle Problem
  30. 1987 Ford Escort Wagon Revving at Idle Problem
  31. 97' escort
  32. 99 Escort needs Engine. worth Keeping? Need ideas/ help...
  33. 1999 reliability=??
  34. 99 Escort, noise from flywheel
  35. 1993 ford escord lx
  36. Where is my PCV valve?
  37. i think it's the drive axel but.....
  38. 99 Escort with dying VSS--is it terminal?
  39. should I buy 95 w/89k--some issues w/car
  40. 99 Escort With No AC Need Help
  41. 95 escort wont start!!!
  42. 97 escort keeps blowing fuel injection fuses under the hood
  43. considering 95 Escort w/98k--what issues
  44. Intake Air filter
  45. 87 1.9l escort blows black smoke out the exhaust
  46. air cond on. motor hesitates
  47. CCRM (Constant Control Relay Module) ???
  48. 97 Airbag Code 34
  49. 1997 Escort Air Conditioning
  50. No A/C on 96
  51. AC / Fan speed
  52. '93 Escort LX wagon - life of engine?
  53. Rear strut brace 97 SE
  54. WTB rear strut brace 97 Escort
  55. key won't come out
  56. air/fuel ratio prob?
  57. '97 Escort issues...need help...
  58. Timing marks? on 1.9 liter
  59. Reprogram Remote
  60. 1.9l performance
  61. need front alignment specs
  62. 91 1.9L water pump
  63. 92 escort tach install
  64. Still High Rpms
  65. what can i do to my 97 escort?
  66. Fuel smell & bad MPG.
  67. door sensors?
  68. Engine turns but doesn't start
  69. no heat, no defrost, no ac
  70. No Air Conditioning
  71. Rack and Pinion
  72. 1995 wont start plz help?!?!?!
  73. 1995 won't start??
  74. High RPM
  75. 97 escort transmission
  76. Bumped and won't start
  77. Overheating - 99 Escort
  78. where is water pump?
  79. No Reverse Lights
  80. 97 escort exhaust question
  81. Frozen e-brake
  82. Shifter Hard To Move
  83. Hose ID?
  84. 93 escort wont start...
  85. 91 escort gt Overdrive?
  86. Mystery Hose and Stalling problem
  87. Driveaxle nut removal
  88. Paint
  89. 1.9L fuel injectors
  90. exhaust problem
  91. 99 Escort/Tracer Nothing from Blower
  92. Squealing noise from timing cover area
  93. Headlights
  94. A/c
  95. rough idle
  96. 92 Escort 1.9 L motor making a banging noise oil light blinking
  97. 93 1.8 escort eec test plug??
  98. Cutting out when at a low speed
  99. trans removal
  100. 95 Ford Escort Thermostat
  101. Escort '99 SE fuel pressure
  102. 1993 escort starter problem
  103. 98 shift point adjustment
  104. 2000 Escort CCRM WAC
  105. Cooling fluctuations
  106. Air intake duct
  107. 95 Escort won't start, acts crazy
  108. Anyone have carfax? I need to run a vin..
  109. 88 escort muchos problemos
  110. 1999 Escort Sedan A/C Problem
  111. How to Replace Valve Seals
  112. Nasty Knocking noise @ over 70mph
  113. 92 escort gt fuel pump relay?
  114. electrical / lights problem
  115. 96 Escort clutch replacement
  116. 95 Escort won't start
  117. air bag warning light
  118. Trying to help a friend
  119. 98 2.0L Zetec hesitates.
  120. 5-speed swap, '91 wagon, need suggestions
  121. 1993 automatic seat belt motor ?
  122. What exactly is a 'sc200'?
  123. 1999 Escort ZX2 Air Cond Hose
  124. ESCORT help ASAP PLEASE!
  125. radio wiring
  126. 1991 escort 1.9 wont start
  127. Question about oil on a '98 Escort...
  128. '88 Ford Escort Problems
  129. 93 GT engine cuts out
  130. 2001 Escort SE
  131. oil leakage
  132. bad starter... i think.
  133. Replacing rack&pinion bushings
  134. timing problem
  135. '88 escort dies and rough idle
  136. stolen 98 escort
  137. 1999 Escort - Break Lights Won't Turn Off !?!?!
  138. 1993 Escort
  139. Help! turn noise
  140. 98 escort headlight removal
  141. 98 door panels
  142. Electric window not working.
  143. 1998 zx2 cooling fan
  144. Cooling Fan not turning off
  145. erratic idle
  146. 1991 Ford Escort Lx
  147. 1995 ford escort
  148. Temp. Gauge on 98 Escort
  149. Replacing coil plugs and wires?
  150. 99 Escort ZX2 air conditioning
  151. buckin escort
  152. how does it sound
  153. bogging on acelleration.
  154. Error Codes ??
  155. suspension problem
  156. High RPM
  157. A/C compressor replacement in '95 Tracer/Escort
  158. A/C compressor replacement in '95 Tracer/Escort
  159. Preformance
  160. window tinting?
  161. Rear Wheel Problem?
  162. My 1998 Excort ZX2 possible O2 sensor problem?
  163. 95 Escort Transmission TX to TJ
  164. Got a gusher...
  165. '94 escort lx stall problem
  166. Parting out 91 escort gt red on grey/tan 5sp
  167. 2000 ZX2 bogs down in warm weather
  168. Looking for Some Advice regarding my car
  169. Rough Idle/Hesitation
  170. 94 overheating Problem
  171. 97 Escort Sedan-Questions Concerns
  172. ford escort
  173. engine swap queston
  174. Turbo charging
  175. Hole in the Firewall
  176. crank but no spark!??
  177. 97 ford escort/ 99 zx2 engine/trany swap
  178. Speedometer dropped to zero
  179. The Great 1991 Escort Mystery
  180. trans problem
  181. 1995 ford escort petrol
  182. Fan Always On
  183. Dash Lights, Turn Signals, and Braker Lights alll Out! (94 Escort)
  184. 2000 FORD ESCORT ZX2 for SALE!!!
  185. GT (with many extras) for sale
  186. Head-light not working ???
  187. Plenty of fuel, no fire
  188. Parting Out 1994 Escort LX Wagon
  189. Coolant Hoses on Oil Filter hosing
  190. engine codes
  191. Water Pump 1990 Escort
  192. 95 Ford Escort headlight problem
  193. Bad starter?
  194. Can I Reduce Noise At High Speeds 97 Escort
  195. power for washer jet lights
  196. PCV valve
  197. 94 automatic escort only shifts at HIGH rpms
  198. 17" Falken Circuit spec wheels for sale
  199. 95 Escort Wagon Overheating HELP!
  200. seatbelt
  201. Front Axle Noise
  202. escort oil change
  203. Rev increasing while Gear in Neutral or Parking?
  204. mounted dashboard, now engine won't start..someone?
  205. 97 fuel pump
  206. harness for 95 escort stereo
  207. mfi to ef wireing loom conversion
  208. front end/brakes/tie rod end?
  209. any performance parts
  210. 93 LXE 1.8 surging
  211. gas gauge stuck at 1/2
  212. only one headlight works
  213. 1993 ford escort fuel smell and leak when full
  214. catalytic converter or automatic transmission?
  215. 95 Escort Stereo
  216. Speed Sensor?
  217. My car is shaking, and won't start....fuel pump?
  218. 90 Escort LX- suggestions? long
  219. 1998 Ford Escort ZX2
  220. 91 GT auto...stalling?
  221. 98 ZX2 Brakes
  222. 1996 escort motor
  223. XR3i Cabriolet Hood not fully closing
  224. 98 Escort headlight problem
  225. cd installation help
  226. To much air
  227. Looking to buy for a 88GT
  228. Anyone know how to turn off the airbag indicator?
  229. 99 se sport 4 dr
  230. 2 questions escort se sport 1999
  231. Radio diisplay says "BAD"
  232. 93 Ford Escort Wagon problems
  233. clicking noise
  234. Funny noise and hesitation
  235. brake pulsing - need to change everything out?
  236. tire size
  237. Tough steering
  238. seat intercanageablty
  239. Noise while moving
  240. 93 LX Wagon Trans Prob
  241. Excort Reliability
  242. Transmission failure-torque converter?
  243. Bruit étrange... Escort LX 97
  244. Lack of heat (should be unrelated to blower motor)
  245. escort speedometer needle flailing
  246. 91 Escort GT Bad EEC IV?
  247. Neep Help Asap With 00 Escort
  248. Electric Window Stuck Down
  249. She moves!
  250. Sensor
