Our Community is 662,000 Strong. Join Us.
View Full Version : Escort
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. 93 escort replacing thermostat{where??)
  2. Escort clutch problem?
  3. 1996 Escort Problem Head Gasket/ Water Pump??
  4. 2000 Escort ZX2 Help with Charging System and Service Engine Soon Lights
  5. Valve chatter
  6. Air intake
  7. Engine dies at Stop Light
  8. swapping escort engines
  9. flywheel/flexplate cracked
  10. airbag readiness light in 97?
  11. engine turns over won't start
  12. 2000 Escort ZX2 Timing Belt
  13. 93 escort engine revs while trying to accelerate
  14. 91 escort wagon won't start
  15. Need Help
  16. Where is starter relay switch? 92 escot wagon
  17. 93 escort GT 1.8
  18. rear strut noise?
  19. 1.8L DOHC no-start, please help!
  20. (@ Escort 1.9..Can you bypass the fuel cutout switch?
  21. 94 escort starting problem
  22. Fan Relay Burning
  23. 96 escort starting problems
  24. Right side axel removal for a 98 escort
  25. Whats it worth?
  26. misfire
  27. 91 escort gt tranny problem need help
  28. 99 ZX2 chain of problems- air compressor froze
  29. Headlights
  30. Increasing Idle Speed
  31. Any common problems I should know before buying?
  32. escort fusebox?
  33. Are bearings a problem in 2001 Escort
  34. No crank issue.
  35. Pressure regulator?
  36. 95 escort a/c problems HELP!!!!!
  37. oil pump?
  38. Should I use gasket sealant?
  39. 94 Escort Lx - A/c Help!!! Blowing Warm Air
  40. 95 escort... very slow acceleration when warm, back firing, etc..
  41. 1994 Escort LX "A/C PROBLEM"
  42. Input/Turbine Speed Sensor
  43. 98 escort mileage
  44. 98 escort A/C
  45. 99 ZX2 won't start
  46. 95 escort over heated now won't run!!!
  47. all the sudden my car is very loud and slow
  48. 1996 Rear wheel bearings
  49. Wet Floorboards?
  50. Escort won't idle!!
  51. 90 wagon
  52. 1998 Escort not accelerating
  53. Service Manual 1994 Ford Escort LX Wagon
  54. Another AC problem (did search)
  55. 98 ZX2 trbl.code Missfire cyl.#1, Help
  56. 98 Escort- Annoying Clicking sound and Front end wobble, Please Help!!
  57. Radio Install In 91 Escort
  58. '90 Escort factory service manual
  59. 98 splash guards
  60. 1998 Escort lx - Lancer Evo body kit?
  61. Escort Revving like mad when clutch is dipped
  62. i need a transmission ASAP
  63. 97 escort, no start - replacing battery cables?
  64. where is the starter on a 1997 escort?
  65. Needing Key cut...
  66. Trouble in '95 Escort 1.9 Land
  67. Where do I top up the AC in my 97 Escort
  68. 97 escort wont start
  69. Siphoning Escort
  70. Escort Door Barrel
  71. 91 Ford Escort Fuel Pump
  72. 99 lx blower shot=
  73. 92 escort 1.9L not keeping charge
  74. 95 wagon no start
  75. 89 Ford Escort No Spark
  76. Fuse: Joint Box Side (niceguy6916 are you there?)
  77. really elementary starter question
  78. First gen engine swap
  79. Do you recommend ZX2 ??
  80. '99 idle problem driving me crazy
  81. 2000 Escort SE 2.0 A/C help needed!
  82. 99 Ford Escort Speedometer
  83. 92escort down shift to neutral while driving
  84. 97 Escort Help with O2 Sensor OBD2 Code
  85. 97 Escort keyless programing
  86. 2000 Escort Speedometer Sticking???
  87. "Whole lotta shakin' goin on!" A/C problem
  88. '93 Escort EGR Valve
  89. 93 escort wont start(startless in oregon)
  90. 1999 Escrot P0401 EGR
  91. 97 Escort Wagon stopped starting
  92. code 1131
  93. 1997 Ford Escort LX Transmission Problem
  94. 1998 Ford Escort has officially been named Christine
  95. Grille 94 escort lx
  96. 97 wagon keyless issues
  97. 95 LX Master Cylinder???
  98. 99 lx engine question=
  99. car won't turn off
  100. 99 Escort Is there a fuse for blower motor
  101. 1997 ford escort
  102. 93 Escort wagon
  103. 1994 Escort Wont Start!!!
  104. 96 escort A/C
  105. Sudden power loss and sound change
  106. 2001 escort
  107. ingnition problem and pully question
  108. Code 171...Please help!!
  109. Escort Fuel problem PLEASE HELP
  110. Installing A/C in Escort that don't have it?
  111. '94 fuel pressure regulator
  112. RE: I hate newer cars!!! help
  113. 2001 escort
  114. 1994 Ford Escort LX - NEED HELP
  115. 99 ford escort column safety switch
  116. Ignition switch help
  117. '93 1.9l starting difficulties
  118. 98 Ford Escort Engine & 5 sp Tranny
  119. 98 Ford Escort Engine & Tranny
  120. 95 Escort Ignition key cyclinder
  121. faulty "iac" cure(maybe)=
  122. audio system help
  123. Engine swap?
  124. Hood Latch Not Holding
  125. Help for Escort and ZX2 Idle Vibration
  126. 99 ford escort zx2
  127. 95 Escort (1.9) won't start
  128. 93 escort w 1.9 runs like crap
  129. help with keyless entry
  130. 98 Ford Escort, removing head??
  131. Replacing '97 Escort 2.0L Engine
  132. What's srong with my 1994 Escort?
  133. turbo zx2???
  134. 94 Escort LX Runs Terrible
  135. 97 Escort, Re-install of Belt Tensioner Asselmbly
  136. 97 Escort Electrical Problem
  137. 98 escort jerking
  138. 95 Escort Trans Problems
  139. PCV System Question
  140. 1998 ZX2 issues. HELP PLEASE
  141. 2000 escort fuel pump not working
  142. ATTN: mightymoose_22
  143. Broken Springs
  144. 93 wiper problems
  145. the black box on the ground terminal
  146. 1.9 Turbo?
  147. Escort 1.6 Zetec power loss
  148. Source for spoiler clips?
  149. Aftermarket Air Intakes
  150. NEED 1999 SOHC 2.0 litre Escort ZX2 ENGINE, Michigan perferably
  151. I want to add a factory tach.. but having probs.. help?
  152. Does Not Start
  153. AC not working - 2000 ZX2
  154. HELP.... brake problems 88 escort
  155. Where are starter bolts?
  156. ZX2 Escort Exhaust swap into SE??
  157. 1997 Escort Fuel And Heat Gauge Dont Work
  158. rear right tire eneven wear...
  159. Mod and Performance
  160. What kind of engine in my 98 escort zx2?
  161. Door Locks Make Sound when Key Is Turned On
  162. fuel injector or vacuum leak?
  163. 97 Battery light flashing
  164. Starting problem
  165. broken bolt
  166. My experience changing timing belt
  167. interesting overheating issue
  168. 93 Escort auto-tranny shifting problem
  169. engine races when put in Park
  170. I Need ADVISE!!!
  171. Removing 94 escort gt manual trans.
  172. will a 95 manual from a 1.9 fit in a 97 2.0
  173. new cd player, ac doesn't work.
  174. different brands coolant can be blent to use
  175. Quick Question
  176. gas gauge indicates wrong
  177. engine turns over but will not start
  178. timing belt
  179. Blower motor not blowing?
  180. motor shut off while driving.
  181. Air Filter Question
  182. Best place for new zx2 head? Longblocks?
  183. 1993 escort LX transmission capasity?
  184. 98 escort ac does not work
  185. oil in the coolant
  186. zx2 ac compressor
  187. 96 escort - metric or american brake lines?
  188. fuel filter need replacing?
  189. 2000 Escort ZX2 Power loss
  190. aftermarket help 92 gt
  191. Parts List
  192. Rough running, misfire, idle stumble cured with plugs!
  193. 97 escort wipers wont shut off
  194. Tranny Issue - New User
  195. help for changing engine
  196. Bass
  197. 98 ford escort
  198. rear break drums, can anyone help?
  199. Checking ball joints
  200. High Idle
  201. 1993 timing belt issues
  202. check engine light codes
  203. 97 sedan...no turn signals, im lost please help
  204. 1991 escort
  205. P1443 Code = Crack in Gas Tank?
  206. 1997 Ford Escort misfires when heat is on.
  207. TPS Adjustment
  208. I'm a mom not a mechanic.. any help?
  209. e3 plugs from advance auto
  210. help! smell coolant in the car- firewall leak?
  211. 93 Escort auto-tranny not up-shifting
  212. Wheel alignment spec's..Does anyone have?
  213. defrost help
  214. 1999 Ford Escort Idles high in Park
  215. '88 At 1.9 (( Help ))
  216. Just crossed 100k
  217. cyl 3 misfire code- what does it mean?
  218. when to replace O2 sensor?..
  219. Clutch pedal to the floor.
  220. Does anybody know ...?
  221. ford probe GT motor swap to Escort Gt
  222. '92 Ford Escort Smoke BAD
  223. 99 escort - p0125 code, engine temperature cold
  224. escort 1999 overheating?
  225. Front bumper
  226. 97 ford escort code p1443
  227. Rear Tail fuse keeps blowing
  228. Automatic Trans In Drive Doesn't Drive
  229. Escort GT Engine swap
  230. Fuel Filter
  231. How to change the inner tie rods? Rocket Science or not??
  232. Engine running cold
  233. 1991 ford escort died and will not start
  234. how to remove bottom back seats
  235. 96 Escort LX Wagon Not Charging?
  236. odd issue
  237. P1443 EVAP Issue
  238. P0443 & P0444 Codes
  239. Front end rattle/clunk in 98 Escort wagon
  240. speed sensor
  241. Transmission fluid
  242. 2000 Escort blower motor
  243. Big problem?
  244. 4EAT Tranny: Flushing and other maint ?'s ...
  245. spark plugs
  246. engine trouble in Hawaii...
  247. 98 escort 75,000 miles
  248. Hi from Spain!
  249. 1993 ford escort wagon electrical issue
  250. Escort GT Transmission Problems
