Our Community is 705,000 Strong. Join Us.
View Full Version : Escort
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. 96 ford heater stopped
  2. Poor gas mileage
  3. no heat 2000 escort zx2
  4. '99 ZX2 Check engine light
  5. 91 LX 1.9L failed emissions
  6. Seat belts no longer move
  7. Diagnostics and tuning
  8. Front end noise
  9. Ford Escort 2XZ problems... Need advice
  10. 2003 ZX2 won't start
  11. 93' Not starting
  12. horn/cruise control
  13. No headlight chime 99 escort se
  14. Ford escort Wagon 96 - Cylinder #3 Misfire
  15. Anther Problem...
  16. 97 escort, 2.0 soch timing belt
  17. 99 timing belt
  18. Manual shift issue
  19. 2002 Ford Escort leaking gasoline please help
  20. 93 Escort Intake Gasket 1.9 engine
  21. p0340 error code but no driving problems
  22. Ford Escort 2001 - Help!
  23. 92 radiator fan won't run
  24. 2002 ZX2 cranks but wont turn over after water pump
  25. automatic transmission
  26. Escort accelerates by itself
  27. Parting Out Escort
  28. 99 escort can/how fix valve seat??
  29. Car Pulling or Drifting to the Left
  30. Escort Drivers in Canada
  31. Throttle Body
  32. Fuel pressure test port
  33. Escort91 noisy fuel pump,stalling problems
  34. Is This an Escort?
  35. New Air Intake Filter
  36. 98 Escort zx2 horn and park light problems
  37. Transmission Noise?
  38. 1994 Escort 1.9l no heat
  39. Tie Rods
  40. TIPS: Things you can do for your 91-96 Escort LX
  41. TIP: Fix those doorjam switches // no dome light...
  42. TIP: Smell When Run Heat on FULL...
  43. Weird coolant color
  44. Alternator
  45. 99 escort Head Gasket trouble
  46. 97 Starter removal
  47. 99 escort emergency brake adjustment
  48. Wrongway Escort
  49. '90 runs cold then stalls no fuel, no spark
  50. 99 escort ZX2 DOHC timing belt
  51. 99 escort ZX2 DOHC timing belt
  52. 2000 ZX2 stalling while driving - no codes
  53. A Sad Day
  54. Stupid Check Engine Light
  55. 500k
  56. Trans Sensor: So what is this ???
  57. need new IAC?
  58. Drum brakes
  59. Side Moldings
  60. Need to jack up the engine in my '91 Escort (1.9L)...
  61. steering wheel shaking, pulling to the right
  62. where is my AC low Pressure port?
  63. 98 Escort not downshift properly
  64. Ford Escort Motorcycle!
  65. low idle escort zx2
  66. Air intake silencer
  67. Advice
  68. 03 temperature problem
  69. 97 Front Caliper Dust Boot replacement.
  70. Fog Light ughh
  71. 96 Wagon Axle
  72. CV Halfshaft replacement
  73. Front Wheel Bearings--99 escort
  74. Shift Stuck in Park 1992 Ford Escort
  75. wont start
  76. Hazard Switch Question
  77. 93 Escort Transmission Fluid
  78. ford escort zx2 engine stumble
  79. 93 Escort headlight problem
  80. 93 Escort LX Wagon wont start.
  81. Aftermarket Keyless Entry in 2000 ZX2
  82. 1995 escort transmission swap
  83. Escort Suspensions
  84. 99 Escort ZX2 2.0L DOHC code 1383
  85. 1994 Escort-Plz Need a Opinion
  86. 96 Wagon Sway Bar Size?
  87. 1994 Ford Escort
  88. 93 drum brakes stuck
  89. Transmission
  90. 01 escort 2.o dohc
  91. '97 error code "not completed"
  92. o2 sensors not working
  93. Can't find my battery
  94. ford escort high RPM stutter??
  95. 95 Escort Turn Signals and Hazard Switch not working????
  96. Air Intake
  97. Need to replace bearing in alternator
  98. 99 escort ZX2 DOHC
  99. Rims
  100. Project Escort.
  101. Power Steering fluid leaking
  102. leaking transmission in reverse only
  103. 99 escort no start
  104. Front right wheel heating up
  105. My Transmission Problem
  106. A/C Clutch
  107. '99 Escort brakes pulsing
  108. 1994 escort fuel rail???????
  109. Clutch not disengaging
  110. Synthetic oil
  111. 1998 2.0L SPI Escort - won't start
  112. Help...2002 ZX-2 Air Cond. Flow Acting Up; vacuum leak?
  113. Cat Converter
  114. Exhaust manifold studs ... replace 'em!!
  115. Would a bad O2 sensor cause stalls?
  116. 96' airbag light code?
  117. Brake Light Switch
  118. 98 zx2 timing belt changed wont start
  119. Gas Guzzler problem
  120. Engine Sounds...
  121. 1997 Escort Wagon 114k Check engine light.
  122. Code p0351, Ignition Coil
  123. Ignition switch
  124. Roof rail removal
  125. Head removal?
  126. Need to replace valve cover gasket after removal?
  127. WooHoo!
  128. 93 Escort 1.9L Cam Seal
  129. Treating rusted sills?
  130. Tranny pump gasket replacement, help please.
  131. 1998 Escort wagon serp. belt problem
  132. 1989 Ford Escort GT 1.9L EFI - Stalling
  133. A/C Clutch not engaging....CCRM removed....Is it a bad solder or is the CAW faulty?
  134. timeing
  135. Replacement Steering Wheel Reatining Nut?
  136. 1999 brakes suck
  137. Full Throttle and Cranking to start
  138. Axle/CV Joint?
  139. Clutch/Trans Questions
  140. 92 Escort Radio and Dome Lights
  141. Security LED
  142. Engine cuts when stopping and error code p1131
  143. Engine gaskets ... Felpro "heads-up"!
  144. 2000 ZX2 Water pump replacement
  145. '93 Escort quit turning off! Yes you read that right.
  146. Dirty engine
  147. 1998 Ford Escort Shuttering
  148. Window Deflector
  149. Airbag cover
  150. 95 Escort Wagon Rear Lateral Link trouble
  151. Under hood engine cover
  152. shorted out 94 escort - dead in water?!
  153. What would cause spark knock on a cold engine ('91 Escort)?
  154. 1994 1.9L Will Not Idle - Runs at 2000 RPM
  155. Low Brake Pedal After Tranny Rebuild
  156. 98 escort giving me 15mpg only
  157. Warning: aftermarket fuel pump inlet screen
  158. 1.9 timming marks
  159. 1995 1.9 escort timing belt broke
  160. 96 Wagon Rides Bad!
  161. 2 Body questions
  162. Voltage regulator bypass test ... dangerous?
  163. Engine shuts off at a slow to stop
  164. 97 escort lx rpm's dropping and bouncing
  165. 95 Escort runs hot
  166. 98 escort wont start but engine turn over
  167. Power source for clutch switch
  168. Buying advice - Escort --> '92 up to 2002
  169. 01 zx2 horn and cruise issues
  170. AC problems
  171. what wire do you huck u the rpm green wire to
  172. AC issues
  173. No brake pedal pressure
  174. Alternator
  175. 95, 1.9 press brake ignition turns on
  176. 93 GT, need help
  177. wiring/electrical
  178. Rear Bumpger
  179. 98 ZX2 wont start, no fire to plugs
  180. Help 99 Escort ZX2 2.0L DOHC upper O2 sensor
  181. Paint?
  182. 93' 1.9L/ 4cyl./auto- OIL PUMP?
  183. 99 Escort ZX2 2.0L DOHC missfiring
  184. Wiper arm removal
  185. Has anyone installed aftermarket radio themselves?
  186. Shift Lock
  187. Escort muffler
  188. 2001 zx2 cranks but wont start
  189. 1.9 liter heads ?
  190. Mystery Engine Componant
  191. 97 Escort missfire
  192. zx2 fuel rail
  193. 97 valve seat
  194. 2000 escort zx3
  195. 97 escort misfire cylinder #3
  196. Power Windows - 93 Escort Wagon 1.9L
  197. Bad Vibrations
  198. Adjusting the timing
  199. coolant gauge not working
  200. Weird Noise COming from Engine
  201. Horsepower
  202. 98 Escort ZX2 speedo problem
  203. 95 escort retracting seatbelt noise
  204. 98 ZX2 manual to auto converison
  205. 97 escort runs like crap
  206. Hmm... Damper or No Damper?
  207. 98 Escort problem
  208. 96 escort
  209. 91 Escort GT surges at stop
  210. 92 escort gt,1.8,randomly dies
  211. 95 escort problems
  212. Escort 99 keeps jumping on first drive of day for about 150 Yards (CEL 0401)
  213. 98 escort, blower does not work
  214. White exhaust valve in cylinder
  215. Question about spark plugs for my car.....
  216. Odometer Check!
  217. Clutch or CV joints?
  218. '99 Getting high water temps
  219. Escort Muffler
  220. Horn--1997 Ford Escort LX
  221. 98 ford scort ac blower don't work
  222. Bad Smell At Higher Speeds
  223. 99 escort
  224. 98 Escort delayed shift when cold
  225. Shaking
  226. Wheel nut size
  227. Need help getting a Catalytic Converter for a 98 Escort
  228. The Beauty
  229. Bad Vibration
  230. Shifter (D)
  231. What is Car Service?
  232. 2.0 valve cover on a 1.9 N/A?
  233. 91 escort only runs when i pump the gas
  234. 99 escort died
  235. 96 Escort 1.9 Idle issues
  236. 96 escort misfire on 4.
  237. I push the gas but the car wont go!
  238. Putting a Turbocharger in my 2002 Ford Escort
  239. Throttle Problem
  240. Heater blows COLD! Help
  241. 1.9L 1994 Trouble code
  242. Las Vegas
  243. Escort Hazard
  244. Anti-Theft Window Crank Device ?
  245. Fuel Pump help
  246. trouble codes
  247. Escort Chime
  248. jerking when heater is on
  249. Crank Position Sensor
  250. car dies after warm
