View Full Version : Escort
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [ 17]
18 19 20
- ***Does anyone have an e-version of Ford Escort Repair Manual?***
- 95 with 1.9 engine overheated-damaged?
- getting in rear springs
- 90 Escort. What's wrong?!
- trans overdive
- getting out rear springs
- how to get more power,at least 90hp
- 98 Squeal/chirping Noise
- Problems starting warm engine, 1.8 zetec 94
- Muffler change
- 95 escort steering tough
- 92 Escort Wiper Fuse?
- spring coils
- 97 Escort-squealing/chirping noise...help!
- super or turbo
- Kills with AC on
- oil going in to air filter
- 93 ESCORT Wagon Not Shifting into OD
- 99 zx2
- Please help
- Drum Bakes
- bosch platinum sparkplugs. thought?
- 94 1.9 Escort won't start
- P or 3???
- 97 escort radio removal
- did my AC just blow? or was it a BS mechanic?
- If replace one of the headlights with a big air intake pipe...
- Need Advice!!!! 93 Escort LX
- 1.9 head job
- intake and exhaust
- Alternator upgrade
- air conditioning condeser....
- I need a '93 Escort GT 5 speed transmission
- 1987 EXP for sale
- 94 Trouble starting...
- How do i replace my front wheel studs? 93' escort lx
- Timing makes exhaust loud?
- 93 Escort Speed Sensor Problem
- 93 escort-need help starting-stay running
- 1997 Escort LX...major problems again
- K&N air filter does seem to work
- Ford Escort 93 Hatchback front right brake caliper sticking
- electrical problems?
- Replacing Head Gasket, T-stat etc
- 97 Escort AC Compressor Replacement
- '95 Scort for Sale
- 1991 Ford Escort Will Not Start
- escort wagon 93 not enough power
- squeeking sound on hard right turns
- 93 Escort 1.9L Ran Out of Oil
- Interference Engines?
- Manual to auto conversion
- Need help on removing the MAF sensor
- Stuck Shifter
- Removing/repairing bucket seats
- Module, Hide n Seek
- Front Wheel Bearing.
- Timing Belt
- Fuel Pump going bad????
- Supra sounding escort?
- Any tips or "should do" when changing the Tranny Fluid for a 94 Escort Wagon?
- Y2K ZX2 error code?
- Need '93 GT hood and fnt. bumper. Got one?
- where do i get a body kit for my 89 escort?
- Chilton and Haynes Wrong about EDIS
- 93 Escort question
- A/C Problem following Heater Core replacement
- Overheating problem
- Need New Engine
- Plug Temp Rating
- Engine Swap-Let me know if re-post
- Timing Belt Broke 93 1.8 did i Kill it??
- Escort Zetec 1.8 -94 wont start
- 1.8 manual transmission problem
- Alternator Blues
- fan runs constantly
- A/C, need help
- Where's the thermostat?
- 93 Escort GT Auto transmission problem
- 98 contour radio plug into a 94 escort gt stock harness?
- 91 Escort running weird!!! Please HELP!!!
- 1997 Escort Wagon A/C
- Best exhaust system options for 98 zx2
- how do I drain the radiator on the zx2?
- Manual seatbelts for my Ford escort LX 94
- My car.... exhaust, gas, a whole list of problems...
- 1995 Escort Clutch/Clutch pedal problem
- Thermo / Temp switch location for / on radiator for 94 Ford Escort
- Eng.,Trans.,can remove as 1 unit?
- EGR Valve location
- interference engine?
- 94 escort gt disk brakes.....
- Rattlesnake Escort or Cosworth Illusion?
- Stops after braking downhill
- door!!
- rear bumper
- 93 esort hatchback wont start
- spark plug removal
- 87 auto escort spurters at times?
- 91 1.9l in 95 model troubles
- How can i stop Beeping seat belt.
- 97 Escort acceleration problem
- 91 gt
- 91 escort 1.9
- 1.9 SOHC for sale
- 1992 Ford Instrument Panel lights dimmed & off
- gt for sale
- galaxie 500 circa 66 not 2dr.
- Exhaust Systems Help?
- 1992 Ford Escort missing
- Overheating Engine... help please
- '88 Escort Wagon wont start
- 1.8L DOHC (bpt) engine swap
- No spark!
- Timing setting
- Timing setting
- engine question
- Trying to hook my ride up
- 1997 escort LX needs pads +rotor
- Disable Airbag Chime
- Exhaust options for 1.9l SEFI
- Reading Fault Codes 96 1.9
- Speedometer stopped
- crankshaft sensor?
- spark problem (?)
- 1993 escort transmittion problem??
- 1996 1.9 died
- NEED 91 Escortgt back bumper and RIMS
- anyone fancy swapping a elise for a cosworth
- 91EGT Seatbelt Problems
- 95 1.9 to 97 2.0 question
- Timing Belt broke....now won't start
- Cant shut off/disconnect door & key chyme
- Cut exhaust pipe?
- 1993 LX Wagon 1.9l Cooling relays
- Need some help on Relay?
- escort GT pony '88
- Y2k ZX2, no spark
- head swap???
- need so insight
- Will a '95 LX bumper or hood fit a '93 GT?
- engine runs rough, then gets better
- "94 Escort front hub
- A/C ruining my belt tensioner?
- Help w/ a S.E Michigan 1989 Ford escort
- A/C will not blow cool air
- '97 Escort Problems...HELP!!!
- 99 escort cutting out
- cant get radio out
- 93 LX Timing Belt Post-Replacement Problem
- 93 Ford Escort Headlight issues!
- TDC location on 2.0 SPI
- vacuum leak? egr? eexhaust?
- 97 Escort Brakes
- 1999 Ford Escort Front Brakes
- timing adjustment
- no fuel pressure
- I Need Help With Ford Escort
- 96 ford escort charging system
- Springs snap?
- Roll over?
- swap???
- Body kit for 93 Escort 4dr
- Non-Dealer Installed AC Question
- Hey Jeff will these work?
- 3rd gen throttle body?
- engine to fit gear box???????
- 94 Escort Lock Change
- 5 speed interchange 92 ?
- Engine swap 2.0 1997-1998
- 93 escort lx steering wheel and blinker problem..... HELP!!
- 97 escort, radio stays on
- trans
- 1992 Escort Wagon suspension
- oxygen sensor
- auto window problem
- escort / tempo motor swap
- escort backup lights
- 99 Escort with a rough idle
- Engine swap
- Window Tinting Question
- just bought a 1991 escort lx
- sealant issues
- 95 escort hesitation on take off
- 92 wagon battery problem
- 94 Ford Escort EGR help
- 90 escort problem
- 99 Escort power Give me your opinion. Will this work.
- Gas gauge says full
- 1.9L Engine Compatibility
- 2000 Escort ZX2 stalling
- 95 ford escort Seat belt problem..Help!!!
- what bolt pattern (wheels) for 2000 escort???
- i wana drop a 1.8L dohc in my 93 ford
- engine swap
- Check Engine Light
- Wandering idle
- New Here and have a few ?
- idle air controller
- motor swap
- Alternator replacment 2000 FORD ESCORT
- manual trans
- engine swaps
- 90 escort gt mods
- 92 manual transmission fluid?
- 98 escort zx2 headlight....
- Car cuts off when I hit the gas
- Exhaust back preasure
- 98 escort ZX2: works fine, loses power, chugs, dies, and smoke from exhaust
- '88 escort GT
- wiper problem: don't shut off
- 2.0l Spi Turbo Kit?
- 92 manual transmission question
- Losing coolant in my 97 Escort!!! plz help!!!
- ford escort 1.9ho fuel injection
- Automatic Transmission
- 93 Escort LX Ate two trannys?
- Loud Exhaust
- transmission heavy leak
- parting out 93 escort GT
- oil in air cleaner
- 1999 escort
- 89 Escort idles super fast at times
- '87 won't start & unknown wires
- Broken Electric Window Switch
- Cherry bomb!!
- cylinder head valves
- 95 Starting Problem
- Muffler pipe size
- new speakers...
- would like to know alot about 2.0 SPI Swap
- Ford Exp Board!!!
- new Paint job help
- 93 Escort having problems on hills and on highways
- Too cheap and too broke.
- need to know all that i will need for this
- Stock HorsePower??
- Bodykits??
- Cam/Crank Sensors
- oil change frequency
- Focus Parts On Escort?
- stupid door panel...
- Died Escort and wont start
- Sound System...?
- Escort Starting Problem
- cough grind cough clank sputter
- in shop 6 times new story every time
- Did someone say customize?
- 91 escort 1.9L head gasket
Automotive Network, Inc., Copyright ©2013
