View Full Version : Escort
Pages :
1 2 3 4 5 6 7 8 9 10 11 [ 12]
13 14 15 16 17 18 19 20
- IAT Sensor
- OBDII Code 1405
- Is a Zetec swappable 4 2nd gen? (91-96)
- Help-engine stalls/jerks a little only sometimes when in park and driving 40mph
- Need some help finding aftermarket parts!
- Exedy Clutch Disc if you have one click HERE
- @DR Electric Popping Rear windows
- 96 escort...need advise again please help
- Valve gone or piston or gasket? Which? '93 Escort
- online escort auto recycler?
- Tail light and Dash fuse keeps blowing
- 94 Escort wagon starting problem
- 1991 Escort was at the BRAKING point....FYI
- Stumped, hopefully you can help
- Escort 1.9 wont idlee
- OBDII Codes
- 1989 Escort
- Where is the cooling fan relay located?
- my car smells like Engine coolant
- MX-3 Seats
- head swap
- 1.9 or 2.0 engine -which is better.
- 99' escort jerks-transmission?
- Piston Compression
- Need help "engine light" came on!
- diagram for changing alternator belt in '92 ford escort gt.
- My Ford Escort Drawing !
- Rough Idle
- cooling fan 1992 escort
- Will this BRA fit?!? Help...
- 98 performance parts
- Changing headlight
- 1988 no spark
- 1997 escort weird electrical problem will not start
- 1987 Ford Escort Problems
- '94 escort 1.9 no acceleration
- a/c pump leaking?
- new to the escort thing
- Antifreeze linking from Muff.'93 escort
- tranny leaking at speed sensor interface
- loose shifter
- TSB's worth paying $$ for?
- engine races
- Clutch pedal feeling VERY loose
- 94 searching idle
- 94 Idle issues!
- problem with escort 1999
- car work humor
- Mods in 88 Escort
- Clutch Adjustment
- Escort, 1999 SOHC Timing Belt Replacement
- "Engine" fuse keeps blowing
- 94 escort ac
- 94 Escort A/C?
- 93 escort overheating
- dome light out after air bag recall
- Book/Manual preference?
- Tune up a 1993 Ford Escort
- 1995 Ford Escort (Mercury Tracer) Crossmember
- My Escort Drawing !
- cannot change headlight bulb!(escort 98)
- 93 Escort 1.9 Stalls when put into gear
- 97' advice...
- Head Gasket or Crack in crankcase?
- My car won't start,and i am desperate!!!!
- '99 Escort key fob reprograming
- Gas Mileage
- is it possable to clean maf sensor
- 95 escort lx problem
- signal lights
- Noise while steering
- 94 cutoff light?
- 95 escort missing and dying
- without mufflers?
- escort 1800i, slow ???
- WTB: I'm lookg for a '91 to '96 Escort GT. Anyone got one?
- Catalytic Converter
- 94 auto trans shaking when accelerating
- 1997 escort auto transmission
- Fuel cutoff light
- why would my car slave so much with heat or a/c on
- 1993 Escort Wagon Lx Rough Idle
- 1992 escort xr3i speed sensor?
- 97 corner turn signals
- airbag light
- 92 Escort Speaker Wiring
- 94 Escort Cranking, but won't start
- common bad rear springs?
- 97 aftermarket CD
- 94 Ford Escort - Engine quits at idle
- I'm new... 1st post. What's the best online store to buy 95 Escort Parts (engine)
- where is cruise control fuse?
- timing slipped
- missfire #1 cyl
- Cooling Fan Will Not Run
- MD 1993 5 speed escort for sale
- Need 1.8
- 1995 Ford Escort LX Wagon Brake lights always on when car runs
- 97 escort probs
- Escort Dies - Drives about 10 miles, then quits
- Fuel pump and cooling fan run with key off
- '95 Escort Wagon... A/C works.......... sometimes
- 97 escort lx
- Engine/trans swap from ZX2
- When to change things on 93 1.9L LX
- Short Shifters
- 92 Ford Escort Won't Start
- Top dead center
- Need auto tranny help
- i did it!
- trans problem
- 94 tracer - doesn't start
- The Power of the IAC
- Ford Escort 93 drive belt / clips / trans oil plug / Ignition leads
- 90 Ford Escort..........
- plug wire resistances...
- how do i tell if my thermostat is stuck open?
- turbo or a super chager?
- 1992 Ford Escort GT Stalling problems
- logical next car after escort wagon?
- cheap fix for missing tran mount bolt?
- 02 sensor information
- Failed fuel system, car won't start, but ran till I parked it
- 1997 Ford Escort LX Station Wagon Problems
- The best way to Torch a Scort ?
- Main Fuse?
- Auto Trans not shifting into 4th gear
- 1994 Escort CD Player problems
- anyone have a swirl pot for sale?
- 97 escort problems!
- 91 lx 1.9L with a few problems
- thanks from a newbie
- cheap lame performance mods
- Pacesetter headers
- Parts interchange
- 93 ford escort blown head
- Aftermarket Header
- 1998 escort shifting proplems
- Suggestions for Anti theft switch location
- help my tires keep spinning
- 1987 Escort Pony...Timing belt
- 88-90 Escort LX Grommet 4 Kickdown Linkage
- what are the best cheap mods for 1.9
- 93 1.8 running terrible
- 91 Escort hatchback
- quick question on front bumpers
- I need help wiring my cd player
- 1 more time guys helpppp please
- 1990 Ford Escort GT The story
- Ticking noise from intake or engine??
- another idle
- cooling fan 94 lx
- please help
- Did a 91- 96 come with power windows or doors
- 94 Lx trouble
- 1996 Escort Engine light code P1443
- What are the best universal mods
- Fuel Pump Relay
- 1.8L DOHC Valve Cover Bolts
- Improving gas mileage
- wheel bearings
- 1994 Ford Escort LX Overhaul!!
- dealer replaced alt, then batt, still have problem
- 97 Ford Escort LX...common problem?
- Intermittent Hard To Start
- Car lopes and sometimes dies when stopped
- Shifting problems with my 93 escort LX 1.9
- escort wont start
- escort 95 hesitates at low rpm
- Mount for new temperature gauge sender.
- Temperature Gauge Not Working
- 93 1.8 will crank but wont start
- radiator problem
- Need help with 92 Tracer
- engine stalled while driving
- 92 ford escort transmission r and r
- Brake Issues with 98
- IAT Sensor
- blow main fuse
- any helpful cleaning tips or maintance
- Escort with weird clutch problem!! Has pressure, then it doesn't???
- Dies when i stop
- escort 99 tranny
- P0113 Intake air temperature circuit, high input
- 91 Escort wagon shutdown and no start
- fail safe mode?
- egr?
- Gas mileage
- any helpful tips on repairs or mods
- 91 escort door won't unlock
- just one more prob
- Blinking Check Engine Light
- Replacing 5 speed tranny I have ???'s
- Cheap Escort
- 1993 escort - fuel lockout
- Check Engine warning light
- not good
- Autozone codes???
- Hissing noise... not the tires, or a snake.
- mk1 escort no spark
- Ford escort mk1 no spark
- Lower the steering wheel
- Junkyard
- Junkyard
- e-RAM does it work
- need help changing brakes
- New Auto Forum Website
- 90 Escort Project For sale
- speakers
- 97 Escort Error Code
- 92 egr question
- 93 Escort Fuel pump relay
- Boot Stuck!!!
- car kicks before shifting
- Cranks and sputters but no start
- SRS Light on 94 Escort
- 1995 escort won't turn off
- trailer hitch reciever for escort?
- 1987 Ford Escort Wagon A/C...
- Leaded Fuels
- Spark plug Gap
- 94 std 1.9 tranny on it's last leg...
- engine stutters a little
- noob engine swap to 2.0 spi help
- Gas Mileage on a 93' escort LX
- Car running rough
- 1.9L engine problems
- Does anyone know if Cosworth bodykit will fit on American escorts
- What is the best motor for a second gen
- Engine cranks but wont start
- plug wire maintance today I got a question
- 95 escort hatchback stereo wiring help
- 93 wagon just started blowing hot air
- 95 escort stereo wiring help
- Performance suspension for 90 escort
- 1993 Ford Escort Droning Noise, Slow Start
- standard 93 Escort what should i do to the engine
- Trying to check my head gasket is hell
- Gas smell in car / Poor gas mileage
- HELP!! i can't get my steering wheel out of lock
- Total n00b to car stuff, help me out!
- '94 Ford Escort Replacement of Entire Wiper Arm
- timing belt/junkyard head and valves
- another '93 Escort that won't turn over
- replace clutch
- Owner's manual (98)
- 91 GT 1.8 Interchangeable Tranny?
- Please Help, Manual Trans Problems! Please !
- Cooling fan problem
Automotive Network, Inc., Copyright ©2013
