View Full Version : Escort
Pages :
1 2 3 4 5 6 7 8 9 10 11 [ 12]
13 14 15 16 17 18 19
- 93 Wagon 5 speed shifting problem
- only 2 cylinders firing
- seen a post once asking about reilabilty
- trans fluid
- reliability
- Radiator boiling over
- braking or trans??
- Alternator Change
- alternator and battery problems
- transmission problem?
- 97, airbag light blink 5-1
- thought of ya jet lee 10 mm wires
- brake lights remain on
- update people
- 1996 Escort LX
- rear defrost
- Tranny will go into gear when car is off, but not on. What gives?
- crank sensor location
- 1.9L Engine Block Drain Plug???
- 1993 ford escort/ trans swap/ problem
- Shop manuals--where to get them?
- 91 Escort transmission problems?
- tranny filler plug
- 93 escort GT 1.8
- confused
- timing belt on 98 2.0 question
- fluctuating Idle in a 2.0
- '97 Basic Maintenance & studdering
- ESKI 1989 looking for direction
- Windshield Wiper arm will not move
- Oil in air filter + oil on bottom of car
- '94 1.9 eratic iddle
- high mileage escort
- Extremely expensive transmission?
- Belt Moulding
- Few ?s about Catalytic Converter for 93' 1.9L lx
- what controls the shifting in a 86 escort?
- Stupid Header ? for a 93 1.9 LX
- 1995 Ford Escort Stalls after warming up
- removing old radio from old Ford - confused!
- 1988 Escort stalls and studders
- 93 escort wagon not shifting into 3rd, little pickup
- 1992 escort gt studders all the time at wide open throttle
- Escort ZX2 Electrical Problems
- 86 escort for parts or whole clean title
- Escort w/fuel cutoff light on, not starting but engine turning over
- Brake Lights Not Working
- 94 escort dying
- hellpppp starting problems need ideas
- 93' 1.9L LX needs to look better.
- A/C Running in Winter
- Transmission Maintenance
- Anyone know if I can tow a utility trailer with a 2.0?
- 1 gen gt pating out
- '99 Escort flaky anti theft
- Catalytic Converter Recommendation?
- '99 Ford Escort Zx2 Tension Setting?
- ??Governer??
- 95 escort lx Is it my head gasket?
- '91 escort won't shut off
- '95 tracer ignition relay location?
- High oil consumption
- 93 Ford Escort body! I need one!
- Auto.Trans.Interchange..98-00 to 93
- solved 97 1st gear only!
- '96 LX 1.9L: Starter Solenoid Location?
- Exhaust smell inside car
- Engine noise..
- No tachometer
- seen a guy on ebay selling twister
- Muffler Tip??
- 97 escort problem
- finally replaced with k&n
- 97 Escort tie rod twist-off
- My 87' Escort GT needs some new looks
- K&N for a 93' 1.9L
- Escort 98 zx2 stopping on highway
- That Dang Door Alarm!!!
- 90 Ford Escort Engine Upgrade Help
- For Sale 1993 5spd Escort Lx-e 1.8l
- Please Sticky
- Gear box only turning Left hand wheel
- 1990 Escort 'jerking' after 20 minutes
- 94 ford escort fuel cutoff indicator light came on???
- dumb k&n question
- air bag light???
- Tranny Fluid Dipstick
- 93 Escort Engine seizes up when bolts are tight!
- License plate light..lenses.
- My radio doesn't work. Any ideas?
- blinkers on = cd player off?
- many zx2 parts cheap
- battery/wiring/altinator problem
- Help!! Need to know how to wire the escort 2.0 injection(SPI) to the 1.9 harness!!?
- Car stutters momentarily at speed, and then is good again????
- what screws into bottom of 5spd tranny?
- Exhaust on 93
- stuttering at cruise speed
- 99 Ford Escort Tranny Just Stopped Working... Help?!?
- Speedo Cluster
- Blown Speakers??
- 95 escort worth a look?
- Zetec vs. Zetec???
- 40mpg abnormal?
- 92 egr tube to exhaust
- Warning-you left something on beep
- Transmission Going bad or new spark plugs???
- crank no start (suggestions welcomed)
- need advice quick - buying a 93 escort, again
- just used lucas oil product fuel treatment
- Not Sure if I need new fan or not.
- HELP! How do i get my door panels off in a 93
- Rear break change???
- Want more hp need help
- no start '95 Tracer 1.9L manual
- check engine light
- Am I being ripped off over a bad clutch replacement?
- changing auto transmission fluid.. need some help
- Transmisson messed up?
- Removing the starter
- who has used Seafoam? and how did you?
- airbag removal for heater core replacement
- its me
- behind the stop sign car wants to die????? :-(
- what is apc's website? and parts for 87 escort GT
- 93 escort shifts from 1st to drive, no overdrive
- 1999 Escort Fuel Pump Removal
- Engine Lockup
- wtb: 97 transmission what will fit?
- Gas consumption horrible please help!!!!
- Looking for Cylinder Head 1.9L (J)
- Tires for my 95 escort
- Help
- Gear selecter light is out
- Timing Belt 95 Escort
- car won't start help me please
- need to set timing 98 escort 2.0L Zetek
- Cylinder head
- 93 1.9 l. bad miss at
- 1.9 engine; what is it worth?
- replace thermostat on 1995 ford escort
- How much for heater core replacement??
- where is my fuel pump relay?
- 97 has problems shifting
- Ford Escort 93 Hatchback Occasional Erratic Idle / PCV Valve Location
- Ford Escort LX 1992 104Kilometers
- 1999 Escort/Tracer Electrical Problem
- dead blower in 94 escort
- Help Please!!95 ticking noise
- is there a way to load test a battery?
- 1998 Ford Escort ZX2
- 91 escort temp gauge drops down and up
- car died
- crankshaft pulley hub
- Body kit
- after twenty mins car jerks and jumps
- fastest 1/4 mile (3rd gen)
- chassis rust- my car's lifespan is?..
- No Voltage From Battery
- Sway Bar Swap
- escort radio removal how to site i made 1999
- Kick Panels
- Please help
- Rear Defroster fusible link
- Vacume Lines On Throttle Body
- Shift Kits??
- '93 Escort GT for sale $700
- Heater is weak.
- 94 Escort turning over but not starting
- 92 escort 1.9 litre getting no spark
- 97 ford escort runnin' like poo
- Engine comression
- '99 radio removal
- 1994 lxi(uk model)boot release switch
- WILL not come out of park
- 97 Escort Electrical Question
- 1997 Escort Trunk Release
- 86 escort gt heater core
- factory tape deck wont drop down fix?
- upper air resonator only on a zx2?
- 97 Escort
- 1995 Escort - Rough at speed
- New Battery Car Still Won't Start
- Sawp engine tranny
- date/year of manufacture of a broken valve seat
- Engine Swap
- head cylinder?
- Replace Head Cylinder, headers, and cat exhaust
- 87 escort fuel system problems
- Escort Continues To Crank Over
- 1986 Ford Escort
- Axle stuck - wont come out please help!
- Please Help!!!!!!!
- car wants to die at low rpms, and now i've lost heater fan
- 1987 Ford Escort Wagon automatic seatbelt repair
- Best 1/4 mile times?
- Trouble Steering and Shifting
- air silencer air resonator removal how-to
- anyone put a cold air/air intake mod on this 2.0
- Shaved doors
- electrical help please
- 93 Ford Escort St. Wagon Won't turn over
- Heater Doesn't Blow...
- Starter relay switch HELP
- 97 escort cold air intake
- wheel locked
- no tail lights
- 2.0 load felt for others?
- cleaning a throttle body
- Shaved Doors
- heater core
- 93 escort grinding noise from right side
- question about the front bummper of a lx
- '97 guage cluster swap
- 97 escort shifter is stuck
- 91 Ford Escort LX +Battery terminal smoke
- Difference Between Escort And Mercury Tracer
- should i replace the alternator
- Brake Light Bulb Replacement
- Replaceing the Seedometer HELP!
- Escort shakes & shimmies while braking at speeds over 55mph
- escort wants to stall after warmng up
- Question about fusebox
- fuel injector fuse blown
- 93 escort wgn lx all crank no start
- starting problem
- front bumper removal
- IMRC modification
- BMW headlights
- How to pull off window crank to remove door panel?
- buy 1999 escort zx2?
- 91 escort automatic seat belts
- Hard to start
- 1990 Ford Escort Help Please
- need a part...
- Luke warm heater...
- mysterious liquid on the driveway..
- Ford Escort rear wipers
- 96 Escort Wagon LX Won't start when warm
- Help: No Rear, side or dash lights???
- coolant temp gauge screwy as heck
- 93 ford escort LX need help!!!!!!!!!
- 92 Escort GT 5 speed Won't crank
- im back
- no heat on 93 escort
- (93 Ford Escort wont shift while started (manual
- CID ? cylinder identification sensor
- 1993 ford escort 1.9lt cooling prob
- 91 Escort LX 1.9 surging after warming up
- Escort cooling fan assy
