View Full Version : Escort
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19
  1. 1999 escort-A/C relay fix
  2. help removing radio from 1991 Ford Escort
  3. 5 Speed
  4. Fuel system problem
  5. Warning beeper when door opens - key out
  6. door remote - ideas on current draw?
  7. humming sound - fuel pump?
  8. 95 escort engine noise
  9. tranny
  10. escort transmission
  11. Lookin for a bloCk
  12. Black box under drivers seat
  13. oil change interval?
  14. Need a clutch alignment tool...
  15. 1995 1.90 Escort Engine Noise
  16. 96 escort wagon no power
  17. fuel injector cleaning
  18. can't remove cigarette lighter
  19. Don't Turn Off Coolant Supply To Heater Core
  20. Slight Miss when AC turned on
  21. What shocks/struts are good for the escort?
  22. HELP! Engine Cooling Fan
  23. coolant sensor
  24. 1993 Escort keeps running with key out
  25. Loping Idle, Dies Occasionally
  26. need help installing speakers
  27. HELP!!!! No Spark
  28. Escort Burnout Trouble
  29. Multiple O2 Sensors?
  30. Argh! What too do I need to pull the harmonic balancer on a 93 Escort 1.9L?
  31. 95 escort 5 speed with clutch problems
  32. head gasket? newbie wrenching on car
  33. These trouble codes right?
  34. serpentine belt in a 2.0 1999
  35. AC/Cooling System/ Spark Plugs
  36. 2.0 swap
  37. valve lifter retainer '95 1.9 ltr
  38. 93 manual tranny how much lubricant?
  39. Communications
  40. ford escort vibrates
  41. valve lifter retainer '95 1.9 ltr
  42. Cruise control Not working and it sucks on long drive to work
  43. 91 escort wiring HELP!!!!!
  44. 1993 Ford Escort with 1.9L strange knocking
  45. More than a little oil in the breather...
  46. Cheap clutches... opinions...
  47. labor for rack job=
  48. escort wagon flasher relay location ???
  49. Escort 94 getting extremely hot since i replaced the water pump.
  50. escort a/c ACP high pressure switch
  51. Problem removing steering wheel.
  52. 95 LX Engine Noise
  53. Aftermarket Grill?
  54. cooling fan
  55. escort 97 pressure relief valve pluged
  56. My radio doesnt work and im going nuts!
  57. problem with the alternator? ford escort 96
  58. Screeching/ Whistling noise
  59. 97 wagon, 33Kmi. anything i should know?
  60. iac problems
  61. High Mileage Escorts
  62. spark plug wires
  63. Rough idle when stopped
  64. Still idles rough and misses
  65. 97 Tracer A/C problem
  66. 1996 escort performace parts
  67. Escort 97 transmission leak help !
  68. 1986 Escort Trouble, NEED HELP!!
  69. '97 a/c questions
  70. How to replace belt tensioner assembly on 98 LX
  71. 99 Ford Escort (Tracer) starting issues CEL
  72. 93 Escort A/C Cycling Switch
  73. 95 Escort radiator fan switch????
  74. 97 Escort Tie Rod Troubles
  75. wet air conditioner compressor?
  76. 91' Escort 1.9L Rough Acceloration
  77. Escort 1996 ignition switch wire gets hot / fan
  78. Ignition switch wires burned, hot, fan
  79. Radiater fan not working
  80. wet carpet passenger side
  81. 89 escort
  82. Replacing corroded battery part
  83. 98 Ford escort wont restart.
  84. 1999 Ford Escort SE
  85. '95 Ford Escort LX fuse box
  86. dash/heater core
  87. 1996 Ford Escort Wagon 1.9l
  88. Could someone Please explain a P0401 code to me?.........
  89. vacation time.....or maybe NOT
  90. information
  91. 87 escort ac problem
  92. Help!!!
  93. 2.5 motor swap?
  94. Oxygen Sensor Location
  95. For Sale: 93 Escort service manuals
  96. 93 wagon in massachusetts - want it?
  97. Rough Idle
  98. Overheating Escort
  99. 97 Tracer Cooling Fan Control Module?
  100. Wheel interchange..
  101. 1997 Ford Escort Headlight assy R+R
  102. 1994 Escort A/C - Problem and Capacity
  103. Engine question........
  104. someone help my grocery getter
  105. engine rattle on 1993 1.9l Escort
  106. transmission
  107. brake questions
  108. Cooling fan/temp gauge not working
  109. 91 escort is gettting too hot
  110. 90 Escort Still Pinging! HELP! HELP! HELP!
  111. Stupid MAF sensor!
  112. I Failed My Smog Test
  113. 95 Escort Questions
  114. no acceleration when hot
  115. 1996 Ford Escort Tachometer Problem
  116. Service Engine Soon light - Overdrive issue
  117. 1.9 to 2.0 Escort heads
  118. 1.9 to 2.0 swap
  119. escort a/c
  120. 98 With no a/c clutch enguagement
  121. Rust problems
  122. Ford Escort Z-3 Fenders
  123. Were is the fuel pump located
  124. problem with forced air in 97 escort
  125. Fuel pipes in Escort
  126. Noises...
  127. escort A/c
  128. Mk1 (1974) motor options
  129. My Escort 89 xr3i Wont start
  130. dome light not working
  131. A/c
  132. 89 1.9
  133. hose on engine
  134. 95 Escort - How do you change break light
  135. anyone use or make forced cold air
  136. 91 GT 4 sale
  137. need to replace shocks/struts. big job?
  138. defogger help?
  139. how to slow wipers down?
  140. brake calipers
  141. how to jumper
  142. 1993 Escort A/C on/off control
  143. firing on 2 cylinders?
  144. Info for anyone w/ similar problem
  145. fuel air ratio 1993 GT
  146. Experience with BG44K Fuel Injector Cleaner?
  147. undoing a race car
  148. ZX2 Power
  149. Manually advancing odometer
  150. it's never died before, I'm worried
  151. too much cooling
  152. Need new Clutch Pedal Pad..where?!
  153. escort history good read
  154. Fan problem
  155. nedd to know
  156. A/C Wont engage
  157. 98 escort taillights
  158. is this a good price for HeadGasket work?
  159. 93 ecsort auto trans please help?
  160. please please please help meeeeeee
  161. Head Gasket ....Do it my self or ?
  162. engine keeps increasing revs
  163. Interest in parts/ parts car??
  164. cant start 93 escort
  165. Fuel Pump Module
  166. 93 Escort Tie Rod End
  167. Strangest AC problem I ever seen
  168. Air conditioner
  169. 94 1.9 missing...
  170. Speedometer Help
  171. 94 Escort, 1.9L, Lack of Power
  172. HELP, does anyone know how to connect the heat in a ford escort '88? HELP ASAP
  173. 98 ford escort please HELP me....
  174. 93 Escort harsh 1-2 shift
  175. overheating/ radiator fan inop
  176. Mustang h8ter
  177. Clutch Problem
  178. cooling fan relay wiring harness information needed
  179. replacing engine and trans 1993 wagon
  180. 2000 zx2 reverse lights on
  181. coolant seeping in floor and front defroster dont work!!!!
  182. 1997 Escort can't downshift to 3rd
  183. 5 Speed Transmission - Fluid Level
  184. Escort 94 idle ,neutral ... instable rpm (stall)
  185. 95 Escort revving like mad
  186. 5 speed - won't go in gear
  187. Cooling Fan Operation Question
  188. Blower problem with 97 escort
  189. 95 Escort Wagon, grinding/scraping noise in park and neutral
  190. Guages Run Amuck!
  191. electrical fan
  192. best place to buy an escort
  193. Kinda Dumb
  194. gauge housing and rear interior pannel removal
  195. 5 spd tranny locked in 4th.... help?
  196. 98 Escort zx2 5 spd won't start
  197. No Power at all
  198. Power window doesn't work
  199. Talk about weird
  200. 93 Escort keeps accelerating! Help!
  201. 97 Escort Not Starting Good Spark.
  202. Cylinder 4 Misfire dectected
  203. 2001 Ford Escort SE Power Windows Won't Work
  204. 90 Escort pinging
  205. 93 escort no check engine light, overheating
  206. '98 Escort Car Alarm Problem
  207. 95 Lx
  208. IAT Sensor
  209. OBDII Code 1405
  210. Is a Zetec swappable 4 2nd gen? (91-96)
  211. Help-engine stalls/jerks a little only sometimes when in park and driving 40mph
  212. Need some help finding aftermarket parts!
  213. Exedy Clutch Disc if you have one click HERE
  214. @DR Electric Popping Rear windows
  215. 96 escort...need advise again please help
  216. Valve gone or piston or gasket? Which? '93 Escort
  217. online escort auto recycler?
  218. Tail light and Dash fuse keeps blowing
  219. 94 Escort wagon starting problem
  220. 1991 Escort was at the BRAKING point....FYI
  221. Stumped, hopefully you can help
  222. Escort 1.9 wont idlee
  223. OBDII Codes
  224. 1989 Escort
  225. Where is the cooling fan relay located?
  226. my car smells like Engine coolant
  227. MX-3 Seats
  228. head swap
  229. 1.9 or 2.0 engine -which is better.
  230. 99' escort jerks-transmission?
  231. Piston Compression
  232. Need help "engine light" came on!
  233. diagram for changing alternator belt in '92 ford escort gt.
  234. My Ford Escort Drawing !
  235. Rough Idle
  236. cooling fan 1992 escort
  237. Will this BRA fit?!? Help...
  238. 98 performance parts
  239. Changing headlight
  240. 1988 no spark
  241. 1997 escort weird electrical problem will not start
  242. 1987 Ford Escort Problems
  243. '94 escort 1.9 no acceleration
  244. a/c pump leaking?
  245. new to the escort thing
  246. Antifreeze linking from Muff.'93 escort
  247. tranny leaking at speed sensor interface
  248. loose shifter
  249. TSB's worth paying $$ for?
  250. engine races
