View Full Version : Integra
- Stainless Steel Cat-back or axle back??
- 97 integra 4dr 1.8 gas gauge problem
- couple questions on 1990 integra
- Rear Defogger + More!
- cold temperature gauge
- clutch problem
- no lights in needles of all gauges
- 2000 teg front end noise
- Honda racers
- 2000 Honda S2000 for Sale
- what do you think of this car
- Help Me Buy The Right Silencer
- GSR question
- starting problem
- 94 integra cams
- 91 Integra LS Auto
- Buying a teg...
- HP diffrence
- Engine Runs Rough after Cleaning
- Off Idle
- whats the difference in weight between a 2 and a 4 door?
- valves ticking bad
- WANTING carbon fiber Type R center console complete
- just to clear somethnig up, (help)
- P0430 code
- B18A fuel injector ticking
- 95 accura integra gsr crank but not starting....
- What's wrong with my battery?
- integry tranny probs
- common repairs times : 96 Acura Integra 1.8 PFI auto
- common issues 96 Acura Integra 1.8 PFI auto
- Overheating only during stop-and-go traffic AND long freeway drives
- Distributor Help
- Blown head gasket
- 96 integra need help no start issue
- 93 Integra Starting problems
- crank but no start
- 87' Teg Starting Issue and PGM-FI light Please Help
- How to tell if motor is obd1 or obd2?
- problem starting
- Eating up O2 Sensors -- Running Rich
- 92 integra suddenly stopped runnning *please read*
- Tried everything to eliminate exhaust drone... any ideas?
- 98 Integra LS AT, Shifting problem
- Winter Rims
- GSR vs. LS/VTEC
- Rhino Ramps for Integra?
- B18B1 OBD2 to OBD1
- 1997 GS oil leaking
- Need help please major question
- Honda Integra
- 92 Integra LS major problems, please read!
- 95' no eng,trans
- Engine shutdown right after starting up.
- I need a t4 not a t3/t4 turbo manifold. b16 b18
- Newbie Upgrades 98 Integra GS-R STOCK
- Integra '94
- Rough Acceleration problems
- need answers fast,vtec wont work cause speeometer wont work ??? help
- need answers fast,vtec work cause speeometer wont work ??? help
- 94 GS-R V-TEC problems
- GSR (b18c) Cat problems - heads up.
- 96 JDM Integra Type R? Anyone?
- 92 integra fail safe problem
- B18C Identification
- No Start
- Integra Type-R registry
- clock/radio
- Finished B20 in integra91 HELP!!
- 2000 "LS"=reliability-??
- 92 DA wont start
- 2000 integra
- car wont start...
- Car won't start please help me figure this one out!!!
- 95 gsr shift problems
- 91 integra halo projector head lights and halo tail lights
- Where are you
- 92 Integra Master Cylinder "how to"
- 90 acura integra gs coolant tempature sensor/ driver side window
- B18A1 to B18B1
- first gen front end conversion
- Strange antifreeze leak...
- I need help from all of you integra owners
- Cams/Cam Gear confusion
- How fast can your integra go?
- rear caliper issue
- boost
- car dies.
- 1990 integra a/c problem
- integra dyin when car is stopped (at a stop light)
- Cams
- 1990 Integra DRL
- code 4 HELP!
- injector cleaning
- Is a D16a1 engine compatible with a 85 1300 transmission
- LS Vtec
- Different Size Tires for Acura Inte Gs 99
- Integra GS-R, Type-R cams difference
- In need of a hood for my 99 integra!
- Integra Motor Question.
- 1988 Head swap.
- smoke and dead spots in rpm
- 94 integra ls sport coupe 1.8
- Vtec Issues Please Help
- help..
- vs toyota mr2
- GSR question 150kmiles
- No Fuel!!
- Motor upgrade: ZC to B18c
- Engine light comes on when i hit 25-30 mph ?
- idle prob?
- Wierd noise when car starts??
- IAT location 1999 Integra GS-R
- main relay wire
- mild steel or cermaic coated?
- 90 integra, surges at 3000
- Oil pan question
- 90 integra ls b18b swap
- 95 no start starter question
- Rattling from under the hood
- firing problems
- No Heat?
- Dashboard Removal
- 4-5 Blown in my B18 Tranny.......
- full exhaust?
- '93 Integra - intermittently will not start, but turns over
- noisy speedo cable
- 92 gs 4dr auto Key stuck
- Best Turbo Kit ofr 94 acura
- Just bought 94 Rs integra
- Turbo?
- Check out my mounts
- Can you guys diagnose my spark plugs?
- Update (my B18C1 swap)
- How do I start this teg without a key?
- 96 Integra Car Alarm going off randomly
- how to turn engine light off
- Integra oil Light comes on
- Should i tune a 98 Honda Integra Dc1 SOHC non vtec ?
- teg questions
- Honda Integra 2001 Quotes
- used Integra value
- No coolant to lower rad hose
- 1991 Integra GS wont start
- Quick question.
- ABS light
- 94 gsr window problem
- Acura Aftermarket Steering
- B17
- Mid to Late 80's Integra Trans Dipstick
- After market, or OEM Radiator Replacement?
- motor questions
- windshield
- brake light problem
- How to identify engine
- gsr cluster gauges not working
- have a quick qu.. need help..
- car died on highway
- legroom
- 1993 intregra
- 95 gsr p29 ecu????
- Help - Clunk noise when hitting bumps
- 90 accura integra 4dr for sale good parts
- ECU wont give code...limits rpm's to 3,000
- bolt size on cat heat shield????
- ls/vtech type r turbo?
- Do i need to pull the engine
- 91 Integra Having Problems Starting
- 90 integra b18b1
- Battery Light
- integra 90-91 not getting spark and fuel pressure
- Anybody Need A B18A Motor?
- where is the evap canister or hose at on my integra ..please help
- 91 Acura Integra STUCK IN S2 ON DASH WONT START???
- Clutch on 2001 Gsr?
- Integra Rear Hatch Removal
- b16a first gen. swap /integra 91
- radio code acura 1998 cd player
- Tranny problem?
- fuse box diagram
- Integra 2002
- Audio/Speaker Installation + Door Panel Removal Questions
- 1994 Manuel Transmission
- ecu for type s
- Searching for first car... I'm interested in a gsr in my area... Have some questions.
- For the love of God help me!
- abs light
- Integra Reliabilty
- engine swap
- Need help
- A/C compressor replacement help
- Windshield & Window Rattling
- Couple Questions
- swap question
- 91 w/ AT wont shift properly
- cruise control
- distrubitor
- 97 integra wiring
- Cheap place to buy an CAI?
- 1999 acura integra
- Just bought a 93 da with b20 block b16 head - have some problems!!
- Integra Sucks anti-freeze.
- 2000 integra - what to do?????????????
- Car does not like the heat?
- need a tip
- Peformance meter and OBDII diagnostic gauge.
- need better fuel economy for 89 teg
- Acura integra gsr models
- Helllp
- just sold my turbo eclipse, now going back to acura
- Project DA6 Photo Update.
- Major Problem
- Just got 92 integra and have a tranny ??
- Better Head?
- wierd problem
- new 2 this car but loves it
- 89 Integra engine puttering.
- Boosting a 98 Ls Integra
- questions help plz
- so many heads to choose from
- What alternator for my swap
- Do you smoke, and have window regulator issues?
- 2nd G1 Integra California Meet
- question about fuel injectors!
- jdm halo headlight wiring please help
- Help with door
- 86-89
- modifications
- 90 distributor differences at/mt
- Please Help Me!
- moroso valve cover
- "New-To-Me" 93 Integra, A couple Q's
- Tough problem here!
- Help!
- b18 motor problem, HELP!
- front end conversion
- b16a on my integra?
- OBD what?
- ls-vtec purchase possibility
- Brake Goes Soft while pressing it
- f20b in my 96 integra
- Integra = Good Daily Driver?
- buying integra
- Wires are Fun, Fun, Fun
- looking at a 91
- 91 Integra Auto Tranny Help
- 05 integra idle goes up and down alot while warming up
- Clutch pedal softens over night???
- Why is this so cheap?
- Open hood without release cable????
