View Full Version : Integra
- springs or adjustable coilovers
- checking compression w/ gauge
- integra life?
- what is this for?
- v-tec
- brakes, suppose to rub??
- moon roof
- How hard is it to make 13 second GSR/Type-R?
- for sale in ny 91 integra rs
- 94-01 specially made for integra box from jl audio
- just wanted to say
- Car cranks but doesnt start!
- my new integra
- where are all the O2 sensors?
- help a wannabe teggie
- FORUM RULES AND GUIDELINES - MUST READ!!!
- Overheating
- Exhaust
- air ride suspension problem
- NEWBIE QUESTION:Is my car OBD I or II?
- FS: 92 B17 Integra SoCal onLy
- GSR Malfunction, ....
- How much did you pay for your gsr?
- integra gsr to much?
- swapping ecu's help
- Best Place To Find A Type R Tranny?
- engine rattles at 3000 rpm....whats wrong?
- Clutch Free Play Problem
- Afew Questions
- Fuel pump
- zex wet kit
- Specs
- I have a 1990 acura integra
- ABS pump
- alarm
- 90 integra gs head unit install
- oil catch can, are they worth it
- Winter Driving
- Another turbo question
- damn abs light
- How good is honda/acura?
- B18c1 vs H22a
- can anybody diagnose this problem??
- My car is wrecked, now what?
- On Board Diagnostics
- 1999 Acura Integra VIN STAMPS?
- How to tell a GS-R?
- Need a quick and cheap way to fix cutoff!!!
- Used Engines for Integras
- Help!!!
- Cams For Turbo/Nitrous Setup
- can't start "clicking sound"
- Cams
- Problems in cold weather
- 1991 Integra Ls swap issues
- how do you turn a gs into a gsr
- Which exhaust system should I get?
- 92 B16 Integra for sale
- new owner of 90 integra ls automatic
- Need A Part Name
- 90 ls
- Clutch Bearing
- Grinding Gear
- New car
- Clutch
- Which is the best Teg
- should i swap
- Jdm Integra 99 vs S2k 00
- How do I make my headlight lenses clear again?
- How to make Angel Eyes... REALY cheap.
- Head porting: NA vs. boost
- NEX or HAYAME COILOVERS?
- Thermostat of Integra 95
- 96 GSR Fuel Type
- can you safely boost and Integra Type R..ie daily driver
- Exedy clutches....
- TPS removal and install
- auto tranny problem
- ls/vtec conversion! (type r)
- ECU fuse
- Integra Questions (Timing Belt, etc)
- tranny decision
- 5 speed conversion
- Ignition Coils
- Anyone help me out?
- The Never-Ending Project...
- car ran out of gas, now it wont start
- Friend has trouble as well
- Teg Problems *help* plz
- 20 V Battery ???
- parting out 90 int with B18 non V-tec
- turbo 101
- Short shifter
- 1991 Inegra Won't Start
- pic
- Product Reviews
- 91 teg engine swapping
- who would win
- Brake Light Problem
- resetting ECU
- Multi-Plate Racing Clutch?
- Switch is messing up
- radiator fan
- paint is fading
- acura service manuals
- FS: 94 gsr
- Honda Type-r Song
- Ground Wire Kits?
- Pics!! What You Think??
- Missing something in Engine Bay
- Horrible Gas Mileage
- 89 integra headlight mod
- GS-R vs. Type R
- turbo kit question
- will this work for my car??
- Doors And Dash
- Homemade Grill
- GSR tranny worth saving?
- What goes bad first, rings or valve seals?
- Pulling Motor Out
- suspension question
- steering ratio for 94-00 integra?
- Another Idle Thread!
- my car sounds like a cannon
- Who would win
- engine gives out when floored
- LS swap question???
- rear knocking please please help!!
- Tires
- Exhaust System
- cel code 8 , tdc sensor heeeelp..
- Engine shakes on first gear!! some advice please
- would an 94 LS oem muffler fit on 00 LS
- i'm lost in what to do
- CAT question
- acura integra gsr's and lightweight flywheels
- Gauge Lights?
- tranny or clutch problem?
- Integra Power Steering Belt
- Integra exhaust
- Buying 94 Integra GSR
- Proper way to race.
- Signal wire on the o2 sensor to install air fuel gauge
- Is it a good deal?
- Integra Ls Vibration Problem
- Wishes and reality
- 2005 Shelby Expedition
- FS:87 integra ls ECU
- wut about an 8lb. flywheel?
- Should I be putting more oil....
- power window help
- Acura Integra 2001 GSR Lifters
- Integ 96 Ls ..vibration Problem At First Gear
- 91 integra buildup help?
- Oil level
- Heard Sratching Noises When Braking, Changed rotors and Shoes but Still Hearing it
- shaving emblems
- Custom Angel Eyes
- B18C1 USDM Gsr owners only
- gsr diameter size?
- The bewildering ITR
- Ls Turbo questions
- trans problem
- Exhaust manifold heat shield
- HEADERS (yes the car has only one)
- Idle Problem
- dont taunt me please
- Would it be cheaper to replace the transmission or get a new case?
- Optima Battery (worth the money?)
- Integra eninge swap
- 1991 acura integra
- 1991 acura integra interior parts
- car keeps dying
- engine sputters after warmed up
- crazy transmission
- Why a difference with VTEC and Non-VTEC air filter?
- radiator
- Which is better for gas milage
- Altezza Integra tail lights for sale 94-01
- Oil leaking from my teg
- Heat Lines
- integra vs 240sx
- starting problems in cold weather
- vtec wiring troubles
- anybody in on the apexi group buy?
- Stripped Disbtributor Screws
- GSR slower than 00' mustang v6
- How do I change my brakes and rotors
- rear brake pads? am I missing something?
- Type R cams in Gsr
- MY HEART...on his "Teggy"??
- water leak?
- code 43, and I smell gas????!!!!!
- Want to do an LS Turbo have some ?'s
- anybody know the difference between P72 ECU V.S P73 ECU
- Acura Legend/Integra CC's???
- Cam Duration
- need a standard tranny for 91 integra
- want more power
- Radio Antenna wouldn't go up...
- Billet Front & Rear Upper Strut Bar for Sale
- VTEC Head
- 4-1 one peice without droping crossmember?
- wiNeed tips on how to launch faster with a automatic
- 94 Integra SE
- Overheating Help Please
- 92 GSR? peak and hold or saturated?
- Transmission wanted
- question about smog checks
- want more hp
- Needs Help
- 15" ROTAs
- whats the diff?
- Leak
- sponshorships
- HELP Finding Good and Trusty Mechanics
- 94 intergra
- wiring Q's, own a repair manual? please help me
- 94 LS (MT) vs. 02+ RSX (AT)
- Most Used Connecting Rods?
- Kyb Adjustables
- JDM Front end on a 4 door sedan???
- FS 01 integra
- wich car shall i coose
- b18c5 and more for sale plus more
- Spark at BTDC?
- throttle body and spacer
- new AF member, with questions!
- lower control arm
- Sites/Pics For Turbo Installs on Tegs?
- All parts of a 1994 Integra LS for sale.
- konigs
- coil overs?
- Best B-series motor for 91-94 GS-R?
- difference between 90/91 and 92/93 HP??
- Got a question on JDM Integras
- cai
- integra engines
- Type R Jdm Header
- stock specs
- Ebay Camber kits
- Need help with 94+ tail lights!!!
- 97 vs 01
- B18a-b18b?
- Tranny I.D.
- can injectors get louder than normal.
- Need DIY info on camber kit.
- Nj-g2 Integra Parts For Sale *cheap*
- Did I Do Damage from driving with the timing off
- FOR SALE: 01 GSR rims w/ tires!
