View Full Version : Integra
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. here is some pics of the integ, i'll get some better ones later.
  2. Q about type of integra
  3. type r or gsr
  4. Short Ram Air intake
  5. AEM cold air intakes
  6. Tranny Prob
  7. 92' Integra ideal?
  8. suspension?
  9. Light Wiring... Screwed!
  10. installing tokico coilovers
  11. driver's door warning sound
  12. GSR rims
  13. Smog Legal GSR...Technically
  14. port and polished head
  15. hondata?
  16. Would this Fit?
  17. Camber adjustment options
  18. perfect setup?
  19. catalytic converter
  20. what should i do
  21. Honda Integra 2002
  22. please help
  23. exhuast question
  24. difference between 93 gsr distributor and 95 gsr
  25. turbo?
  26. upgrading ecu
  27. 91 integra
  28. grinding
  29. Integra VS Maxima
  30. chip?
  31. No Heat
  32. Help with GSR
  33. which exhaust?
  34. Question about rims
  35. distributor problems wont start
  36. ls vtec
  37. what engines are "swapable" in a 96 integra?
  38. Oil Light
  39. Removing Crankshaft Timing Belt Sprocket?
  40. Smarter decision
  41. Need B17 engine
  42. Question about type R pistons
  43. tires rubbing
  44. Teg Type-R
  45. How much would it cost?
  46. 1991 integra brake fluid problem
  47. oil filter question
  48. Wheel Alignment
  49. Is this a good Turbo?
  50. What Wheels is everyone running on? Any suggestions?
  51. Just got a teg 97 LS 48,000
  52. too much oil?
  53. new coilovers
  54. should I?
  55. Tires
  56. no vtec
  57. What brand of manifold and downpipe let me keep A/C in GSR?
  58. quick question
  59. Someone smashed my passenger window!
  60. sealt belt
  61. wiring for vtec hookup
  62. WTB: 90 93 Integra rear e-brake cable, master, and booster
  63. exhuast
  64. wont rev past 3k
  65. can i find this
  66. map sensor
  67. Upgrading Properly?
  68. 94-97 Grill Inserts
  69. Conversion Question
  70. Who Is A Good Source of OEM Parts?
  71. car temp
  72. turbo b18a or b18b
  73. Sell me YOUR Integra!
  74. civic headers on a teg?
  75. poll !!!!!
  76. pulley kits and cam gears?
  77. Type r cams in Gsr
  78. 97 integra ls stalling
  79. David vs goliath!
  80. What do you think of this car??
  81. vtec pistons in a non-vtec engine
  82. Alternator repair is good, but light is still on, ignore?
  83. AEM tru-power pulleys
  84. Stalling
  85. 97 Turbo Kit
  86. What will i run??
  87. damn noise!
  88. 2001 Integra Rotor replacement.
  89. Distributor help
  90. LS motor
  91. battery/alternator question
  92. Squeaky Windows !!!! HELP
  93. rear tire wear problems
  94. overheating
  95. ?'s about buying a integra
  96. teg not idleing then bouncing!?!?!?!
  97. *SAD NEWS* Teg was wrecked
  98. Fuel Regulator
  99. My New Teg
  100. Ecu Question
  101. gsr wiring harness
  102. 89 integra iac problem???
  103. 90 LS needs new springs
  104. Integra cd player
  105. whats up
  106. question on '90 Teg parts
  107. Help! 97 b18 swap into 90 integra LS
  108. about under drive pullys on an LS?
  109. Whiney noise
  110. suggestions on engine
  111. are stiff shocks bad?
  112. Header and exhaust
  113. door open warning sound
  114. 92 Gsr
  115. Will Ls Distributor Fit Gsr Motor?
  116. Engine Mount Help B18c1-96 Civic Lx
  117. Ok,Not Confused Anymore!
  118. JDM main relay
  119. chk engine lt on, and no shifting ability
  120. DOES THIS SEAM WORTH THE MONEY>?
  121. Valve Cover paint?
  122. Would that ECU really help?
  123. Please Help my stalling problems
  124. what next?
  125. 92 IntegraGS wiilcrank..wont start
  126. In the market for a Type R...need some help
  127. 97 integra LS
  128. 1992 B18B JDM Motor
  129. stalling problems
  130. what do you think?
  131. got stopped by cop cause of loud exhaust?
  132. Stripped BOlt
  133. what's a good low to mid range cam?
  134. quick ? about boost control
  135. t25 turbo in my teg
  136. Timing Belt question
  137. Weird Sound Comin From Engine
  138. s14 front end conversion
  139. integra vs. sentra
  140. Color of Fuel Injectors?
  141. Favorite magazine(poll)
  142. Question
  143. tune up
  144. Front Lower Control arms
  145. GSR Brake Question
  146. Coilover reccomendations
  147. alignment adjustment 90 integra gs
  148. So what extra pieces should my Teg have on hand?
  149. Got my cam seals........$12.95 woo hoo
  150. 87 integra tach
  151. Update on My JDM Motor
  152. New here, 1995 integra
  153. Why Is My Integra Shaking?
  154. 91' Integra good?
  155. Next Mod?
  156. oil
  157. pic photoshop'd?
  158. swap ?
  159. dash
  160. headlight problem
  161. Power shifting.... wtf?
  162. To much wheel spin,help!!
  163. Aem Ems
  164. Help me please 1990 Integra cutting out while driving!!
  165. I torqued something too much and need help
  166. Rev Limiter Kicking in at 5K? Why?
  167. Can I fit 215s without scrapping?
  168. smoke after shut off
  169. Rough Idle
  170. white bulbs for clear corners
  171. ECU w/exhaust question
  172. "How to" Thread!!!
  173. acura integra 1996 ever so loud & noisy...
  174. what does lsd stand for and do?
  175. 93' Integra
  176. Alternator Q?
  177. cold on idel , really not around 2300 rpm??
  178. ABS light code
  179. 2nd gen teggy idea
  180. What Tires
  181. K20 swap for LS
  182. Integra GSR oil type
  183. GSR Brakes
  184. stroked and boosted b18c1
  185. black smoke help!!!!!
  186. 97 GS-R radiator
  187. WHere can i get an integra body?
  188. 1995 Acura Integra
  189. Used Acura Motors
  190. Y blocked m0d?
  191. Still can't get these Fcuking cone lights off
  192. does anyone have a stock GS-R intake and resinator box ??
  193. Can teh integra hit 500hp?
  194. Questions on 90 Integra Front End
  195. Over Heating Nooooooo!!!
  196. what would you do
  197. Removing ignition key problem
  198. Car Security System
  199. nonVTEC engine builders check in
  200. Whats wrong with my tranny?
  201. Which is better greddy or d.c.
  202. Tranny prob? pl. hlp
  203. shocks install
  204. need some ideas
  205. fool the cops...
  206. New FAQ Thread!
  207. FAQ Thread!
  208. New FAQ Thread!!
  209. New FAQ Thread!!
  210. New FAQ Thread!!
  211. FAQ Thread!
  212. Hi All New and have some questions
  213. Whats up!
  214. Hey everyone! Check out my entry to Honda/Acura world.
  215. RS header?
  216. Fuel Filter Install on a "90-91" teg??
  217. Had my compression checked....
  218. J?w
  219. 93 Integra Lambo Doors
  220. timing belt
  221. need a front end
  222. Removing Gauge needle
  223. synthetic blend after full synthetic.
  224. Fuse keeps blowing...
  225. what pisses me off MOST about integra
  226. Low MPG
  227. remote start
  228. Integ Ls vs. Ford Focus, who wins?
  229. What exhaust??? Apexi world sport or stock???????
  230. What one Ford Explorer Can do
  231. hello new to this forums. have ?
  232. DID My Battery Die??
  233. starter help!!!!
  234. 97 GS-R slow starting heater
  235. 1st Generation Integra Rear Suspension
  236. Change Manual Trans. Fluid...
  237. Cam Measurement
  238. Type R Swap PLEASE HELP.
  239. 98 hatch for a 95, swap
  240. Help a beginner please!
  241. tranny question ( kind of long )
  242. 2000 Acura Integra for sale!!!
  243. Slow Start-Up
  244. can't figure sound out????
  245. What to do to my 91 Integra?
  246. MY new clutch..
  247. need advice
  248. question
  249. tranny question
  250. 92 Integra 1.8 MPG
