View Full Version : Integra
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Upgrading Properly?
  2. 94-97 Grill Inserts
  3. Conversion Question
  4. Who Is A Good Source of OEM Parts?
  5. car temp
  6. turbo b18a or b18b
  7. Sell me YOUR Integra!
  8. civic headers on a teg?
  9. poll !!!!!
  10. pulley kits and cam gears?
  11. Type r cams in Gsr
  12. 97 integra ls stalling
  13. David vs goliath!
  14. What do you think of this car??
  15. vtec pistons in a non-vtec engine
  16. Alternator repair is good, but light is still on, ignore?
  17. AEM tru-power pulleys
  18. Stalling
  19. 97 Turbo Kit
  20. What will i run??
  21. damn noise!
  22. 2001 Integra Rotor replacement.
  23. Distributor help
  24. LS motor
  25. battery/alternator question
  26. Squeaky Windows !!!! HELP
  27. rear tire wear problems
  28. overheating
  29. ?'s about buying a integra
  30. teg not idleing then bouncing!?!?!?!
  31. *SAD NEWS* Teg was wrecked
  32. Fuel Regulator
  33. My New Teg
  34. Ecu Question
  35. gsr wiring harness
  36. 89 integra iac problem???
  37. 90 LS needs new springs
  38. Integra cd player
  39. whats up
  40. question on '90 Teg parts
  41. Help! 97 b18 swap into 90 integra LS
  42. about under drive pullys on an LS?
  43. Whiney noise
  44. suggestions on engine
  45. are stiff shocks bad?
  46. Header and exhaust
  47. door open warning sound
  48. 92 Gsr
  49. Will Ls Distributor Fit Gsr Motor?
  50. Engine Mount Help B18c1-96 Civic Lx
  51. Ok,Not Confused Anymore!
  52. JDM main relay
  53. chk engine lt on, and no shifting ability
  54. DOES THIS SEAM WORTH THE MONEY>?
  55. Valve Cover paint?
  56. Would that ECU really help?
  57. Please Help my stalling problems
  58. what next?
  59. 92 IntegraGS wiilcrank..wont start
  60. In the market for a Type R...need some help
  61. 97 integra LS
  62. 1992 B18B JDM Motor
  63. stalling problems
  64. what do you think?
  65. got stopped by cop cause of loud exhaust?
  66. Stripped BOlt
  67. what's a good low to mid range cam?
  68. quick ? about boost control
  69. t25 turbo in my teg
  70. Timing Belt question
  71. Weird Sound Comin From Engine
  72. s14 front end conversion
  73. integra vs. sentra
  74. Color of Fuel Injectors?
  75. Favorite magazine(poll)
  76. Question
  77. tune up
  78. Front Lower Control arms
  79. GSR Brake Question
  80. Coilover reccomendations
  81. alignment adjustment 90 integra gs
  82. So what extra pieces should my Teg have on hand?
  83. Got my cam seals........$12.95 woo hoo
  84. 87 integra tach
  85. Update on My JDM Motor
  86. New here, 1995 integra
  87. Why Is My Integra Shaking?
  88. 91' Integra good?
  89. Next Mod?
  90. oil
  91. pic photoshop'd?
  92. swap ?
  93. dash
  94. headlight problem
  95. Power shifting.... wtf?
  96. To much wheel spin,help!!
  97. Aem Ems
  98. Help me please 1990 Integra cutting out while driving!!
  99. I torqued something too much and need help
  100. Rev Limiter Kicking in at 5K? Why?
  101. Can I fit 215s without scrapping?
  102. smoke after shut off
  103. Rough Idle
  104. white bulbs for clear corners
  105. ECU w/exhaust question
  106. "How to" Thread!!!
  107. acura integra 1996 ever so loud & noisy...
  108. what does lsd stand for and do?
  109. 93' Integra
  110. Alternator Q?
  111. cold on idel , really not around 2300 rpm??
  112. ABS light code
  113. 2nd gen teggy idea
  114. What Tires
  115. K20 swap for LS
  116. Integra GSR oil type
  117. GSR Brakes
  118. stroked and boosted b18c1
  119. black smoke help!!!!!
  120. 97 GS-R radiator
  121. WHere can i get an integra body?
  122. 1995 Acura Integra
  123. Used Acura Motors
  124. Y blocked m0d?
  125. Still can't get these Fcuking cone lights off
  126. does anyone have a stock GS-R intake and resinator box ??
  127. Can teh integra hit 500hp?
  128. Questions on 90 Integra Front End
  129. Over Heating Nooooooo!!!
  130. what would you do
  131. Removing ignition key problem
  132. Car Security System
  133. nonVTEC engine builders check in
  134. Whats wrong with my tranny?
  135. Which is better greddy or d.c.
  136. Tranny prob? pl. hlp
  137. shocks install
  138. need some ideas
  139. fool the cops...
  140. New FAQ Thread!
  141. FAQ Thread!
  142. New FAQ Thread!!
  143. New FAQ Thread!!
  144. New FAQ Thread!!
  145. FAQ Thread!
  146. Hi All New and have some questions
  147. Whats up!
  148. Hey everyone! Check out my entry to Honda/Acura world.
  149. RS header?
  150. Fuel Filter Install on a "90-91" teg??
  151. Had my compression checked....
  152. J?w
  153. 93 Integra Lambo Doors
  154. timing belt
  155. need a front end
  156. Removing Gauge needle
  157. synthetic blend after full synthetic.
  158. Fuse keeps blowing...
  159. what pisses me off MOST about integra
  160. Low MPG
  161. remote start
  162. Integ Ls vs. Ford Focus, who wins?
  163. What exhaust??? Apexi world sport or stock???????
  164. What one Ford Explorer Can do
  165. hello new to this forums. have ?
  166. DID My Battery Die??
  167. starter help!!!!
  168. 97 GS-R slow starting heater
  169. 1st Generation Integra Rear Suspension
  170. Change Manual Trans. Fluid...
  171. Cam Measurement
  172. Type R Swap PLEASE HELP.
  173. 98 hatch for a 95, swap
  174. Help a beginner please!
  175. tranny question ( kind of long )
  176. 2000 Acura Integra for sale!!!
  177. Slow Start-Up
  178. can't figure sound out????
  179. What to do to my 91 Integra?
  180. MY new clutch..
  181. need advice
  182. question
  183. tranny question
  184. 92 Integra 1.8 MPG
  185. springs or adjustable coilovers
  186. checking compression w/ gauge
  187. integra life?
  188. what is this for?
  189. v-tec
  190. brakes, suppose to rub??
  191. moon roof
  192. How hard is it to make 13 second GSR/Type-R?
  193. for sale in ny 91 integra rs
  194. 94-01 specially made for integra box from jl audio
  195. just wanted to say
  196. Car cranks but doesnt start!
  197. my new integra
  198. where are all the O2 sensors?
  199. help a wannabe teggie
  200. FORUM RULES AND GUIDELINES - MUST READ!!!
  201. Overheating
  202. Exhaust
  203. air ride suspension problem
  204. NEWBIE QUESTION:Is my car OBD I or II?
  205. FS: 92 B17 Integra SoCal onLy
  206. GSR Malfunction, ....
  207. How much did you pay for your gsr?
  208. integra gsr to much?
  209. swapping ecu's help
  210. Best Place To Find A Type R Tranny?
  211. engine rattles at 3000 rpm....whats wrong?
  212. Clutch Free Play Problem
  213. Afew Questions
  214. Fuel pump
  215. zex wet kit
  216. Specs
  217. I have a 1990 acura integra
  218. ABS pump
  219. alarm
  220. 90 integra gs head unit install
  221. oil catch can, are they worth it
  222. Winter Driving
  223. Another turbo question
  224. damn abs light
  225. How good is honda/acura?
  226. B18c1 vs H22a
  227. can anybody diagnose this problem??
  228. My car is wrecked, now what?
  229. On Board Diagnostics
  230. 1999 Acura Integra VIN STAMPS?
  231. How to tell a GS-R?
  232. Need a quick and cheap way to fix cutoff!!!
  233. Used Engines for Integras
  234. Help!!!
  235. Cams For Turbo/Nitrous Setup
  236. can't start "clicking sound"
  237. Cams
  238. Problems in cold weather
  239. 1991 Integra Ls swap issues
  240. how do you turn a gs into a gsr
  241. Which exhaust system should I get?
  242. 92 B16 Integra for sale
  243. new owner of 90 integra ls automatic
  244. Need A Part Name
  245. 90 ls
  246. Clutch Bearing
  247. Grinding Gear
  248. New car
  249. Clutch
  250. Which is the best Teg
