Honda
> Integra |
View Full Version :
Integra
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
What do you think?
what kinda gas do ya use?
Need a new header
integra exhaust
Tranny Help Please
95 Gsr Teg. Question(door)
Stock shocks with coilovers
Purpose of a header flange...
LS crank lacks clearance in GSR Block
Finally getting my car
93 integra parts????
tire question
question about rear suspension
Whats the difference between a cold air intake and a short ram intake?
dyno qustion
How do I??? HELP!!!!!!!!
a/c type 12 or 134a
Oil pan
performance chip
hood won't close all the way
engine type
What would you do scenario??
Just wondering....
92 integra high revs
b16 in teg
Short shifter... Performance?
Skunk2 short shifter
need some help here
ls/vtec qustion
94 gsr talking crap
1/4 mile times??
What year is car
what are the best??
Difference between an LS and GSR Header?
93 Integra Leak?!?!?!
Tranny Problem Please Help
Black 1994 Integra Gsr Stolen!!!
Wheelguyz.com Anyone?
spring heights
wheres the pull
Altezzas
88 integra question
Some quick questions...
gas efficiency
type r clip to my 94 gsr
2001 gsr DYNO
How to post pictures!
newbi and need help
new here
Brake Pads
Tuning Sites
suspension help
98 GSR questions
Will RSX Wheels fit on a 2001 Integra?
Pulling out Dashboard
buy integra?
Ignition parts?
where to find paint?
About how much does a new paint job cost for a teg?
1991 Integra Hks Exhaust
GSR with LS 5 speed
HELP Installing Speakers
where to buy new lense covers for '89 teg
Whistling sound at idle.
Paint
Do RS model integra have rear disc brakes?
Where to download service manual?
Head work
Do u guys think these will look good ??
Windshield wiper motor and switch 96 teg
throttle body and intake manifold?
after effects of "car diet"
Putting it all back together
clutch and brake problems
wtf? My "Maint Req" light flashes for about 5 seconds after I start my car...
acura integra 2000
exhaust question??
cold air problems
Locked Up Disc Brakes
Installing a BOV
engine miss at high revs?
alternator problems
CA Smog Standards...EEEK!!
get my teg back 2morrow
rims
gsr auto tranny
b18a vs b18b
2000 Civic Si Motor
advice on new teg
1995 teg ls service manual
another question
2 questions
Tsudo Exhaust
What about the Integra SE?
gas problem
Help, please
Ignition coil and Nology wires
AT to MT problems i've ran into
Am I screwed?
What is better an acura rs or an ls?
car radio question
car diet
do i need cat?
Springs
Installing a Short Throw Shifter
B-series turbo
Need Quick Head Unit Help
catalyst converter heat shield fell off
intrega specs?
90 Acura Integra
clicking
DC ceramic header
Is This Just Wrong!!! (pic)
My floor mats and floor get wet when it rains... why?
Clutch
Valves
Cams
timing belt
squeaking noise
Tokico Illumina
LS Camshafts
Alternator RF Signal
need help on mods
ABS/Synchros
92 integra losing all power help
lsvtec or gsr
clicking noise
Tranny question
clutch
Chiltons or Haynes?
another resonator question... need opinions
Oil leak
cams
car buying question
body style question
Acura integra...yay or nay?
Sturt/tie bars
aftermarket tail lights illegal?
Re-ring Kit
1 Bar??
What Wheels?
assembling coilovers
Teg to Accord front conversion
vtec controller
loose shift lever
CRV Crank
check engine light
megan strut bar combo
Blower motor (91 gs)
b20 + teggy
Need Vin Check Badly!!!!!!
zex or nitrous express
Need 1996 Integra LS ecu
here are some (pics) of my integ tell me what you think?
New (pics) Of The Integ, Whatcha Think?
skunk2 and tokico
Installing Cams
Which type of resonator do I need to remove raspy exhaust sound?
how do you remove dash panel
92 integra with a 94 front clip
Z3 fenders
type r rotors
Bolt patterns
4 door mirrors
integra turns off
upgraded fuel injectors
Synthetic or regular
uploading pics
magnaflow exhaust
Fuse diagram
here is some pics of the integ, i'll get some better ones later.
Q about type of integra
type r or gsr
Short Ram Air intake
AEM cold air intakes
Tranny Prob
92' Integra ideal?
suspension?
Light Wiring... Screwed!
installing tokico coilovers
driver's door warning sound
GSR rims
Smog Legal GSR...Technically
port and polished head
hondata?
Would this Fit?
Camber adjustment options
perfect setup?
catalytic converter
what should i do
Honda Integra 2002
please help
exhuast question
difference between 93 gsr distributor and 95 gsr
turbo?
upgrading ecu
91 integra
grinding
Integra VS Maxima
chip?
No Heat
Help with GSR
which exhaust?
Question about rims
distributor problems wont start
ls vtec
what engines are "swapable" in a 96 integra?
Oil Light
Removing Crankshaft Timing Belt Sprocket?
Smarter decision
Need B17 engine
Question about type R pistons
tires rubbing
Teg Type-R
How much would it cost?
1991 integra brake fluid problem
oil filter question
Wheel Alignment
Is this a good Turbo?
What Wheels is everyone running on? Any suggestions?
Just got a teg 97 LS 48,000
too much oil?
new coilovers
should I?
Tires
no vtec
What brand of manifold and downpipe let me keep A/C in GSR?
quick question
Someone smashed my passenger window!
sealt belt
wiring for vtec hookup
WTB: 90 93 Integra rear e-brake cable, master, and booster
exhuast
wont rev past 3k
can i find this
map sensor
Upgrading Properly?
94-97 Grill Inserts
Conversion Question
Who Is A Good Source of OEM Parts?
car temp
turbo b18a or b18b
Sell me YOUR Integra!
civic headers on a teg?
poll !!!!!
pulley kits and cam gears?
Type r cams in Gsr
97 integra ls stalling
Web
AF
