View Full Version : Integra
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Ive got a no hot start question
  2. 1991 TEG LS B16 swap questions
  3. two-tone paint job
  4. Itr Pistions In An Ls?
  5. Please help
  6. integra LS 98: does it have idler pulley
  7. GSR tranny
  8. must get more power !!!!!
  9. starting...oddities
  10. vafc and vortec fmu
  11. screw the leak
  12. custom turbo help
  13. integra ls's chances
  14. Bodykit Mystery...
  15. Swap Options LS/92
  16. Is the b18a1 harn. same for auto/5speed?
  17. 96 gsr HELP
  18. nitrous good idea or bad??
  19. can any one help me out???
  20. opinions please.
  21. valves on a 1995 GS-R
  22. Power antenna
  23. GSR speakers.....
  24. Which Trbo Kit Keeps the A/C & p/s?
  25. 91 4-door Body kits
  26. COmpression?
  27. Head Gasket
  28. 1st gen info...
  29. turbo kits for an LS
  30. Does anyone know anything about these exhausts
  31. reflashing
  32. stock clutch / lightened flywheel?
  33. how many washers on diy rear camber?
  34. Rain Water+Cai
  35. 90 integra gs transmission problem
  36. ****stereo Code****
  37. How do you put on a Head Gasket?
  38. 20w-50 oil
  39. pics of my setup
  40. going turbo
  41. big advantage??
  42. what to do with my car?
  43. New Coil
  44. LS Special Edition
  45. Aem V2???
  46. Problem w/ my GSR????
  47. GSR speaker sizes
  48. Noise from clutch
  49. what do you motor head think
  50. 91 Integra for sale
  51. Best oil for integra gsr
  52. need help
  53. install help again
  54. cold air intake hp?
  55. strange noise
  56. FS: Acura IntegraB18BLS 4-door 5-speed
  57. new toys
  58. making an offering on a car
  59. Swapping out auto tranny
  60. Front tranny mount bolt
  61. Fuel Pressure ASAP!!!!!
  62. b18c5 prices
  63. rev an ls to 8000
  64. STRANGE GRINDING NOISE, help plz
  65. vtec "kick"?
  66. help
  67. Freakin fuel leak... help
  68. 96 integra LS hatchback?
  69. b18b project
  70. 2 Piston Calipers?
  71. honda motor desicion
  72. 1995 Integra LS
  73. DIY ground wires? anyone?
  74. ITR Valve springs
  75. cardomain.com?
  76. who would win
  77. know any reliable engine importers?
  78. Shift Boot
  79. Hard Time Getting Timing Belt On
  80. Seattle Tegs Unite
  81. My Maint Reqd light is on... what could be the problem?
  82. Make-A-Wish Cae
  83. honda s2k topend
  84. Radiator
  85. Rim Question
  86. difference
  87. what intake mainfolds
  88. Revive an Integra
  89. deeper problems than just windows
  90. Piston-Valve clearance problems?
  91. does a 98-01 integra front bumper fit a 94 .?
  92. Quick Question
  93. 90-93 with a b18c5
  94. 93 integra for sale
  95. 2005 type r
  96. wondering about a broken steering lock
  97. Buying a 2000 gsr
  98. Rear Brake Light
  99. Integra cool
  100. ls/vtec
  101. OEM prices?
  102. I have a Bad Wire harness
  103. Does anyone here have a turbo LS?
  104. p28 turns into ak47!!!!
  105. exhaust
  106. turbo kits
  107. 94-97 & 98-01 difference
  108. How difficult radiator replacement 92 Integra?
  109. Hesitation
  110. 90-93 integra hks exhaust
  111. headlight grounding
  112. Ebay parts??
  113. LS? or GSR?
  114. Going turbo
  115. greddy turbo, 5zigen exhaust??
  116. 98 front bumper conversion???
  117. ABS Light won't turn off
  118. Lights
  119. always blowing heat
  120. roll cage
  121. Help with engine block/head identification
  122. Timing belt basic questions
  123. Where is the crank angle position sensor ?
  124. Rear Seat Nightmare
  125. Unstable idle
  126. help with starting my 95 teg LS
  127. battle
  128. help on engine swap
  129. will someone please help me on this one?
  130. Honda Parts to Australia
  131. TPS Trouble
  132. 00 si tranny good?
  133. what air intake works for hybrid?
  134. automatic seatbelts wont return
  135. Which one 2 buy
  136. AEM cam gear help.
  137. turbonetics???
  138. cylinder sensors (CYP)
  139. Traction Problems
  140. Cant keep caliper sliders from freezing
  141. Whats the best year for the GS-R?
  142. need to know fast
  143. Rotor & Caliper Upgrades?
  144. obd2 gsr bad for HP??
  145. what to replace to make new???
  146. Need some help
  147. GSR running lean
  148. LS,GS...are they fun even tho no VTEC?
  149. generations?
  150. integra fuse box help
  151. jrsc headers,exhaust
  152. aem cam gears
  153. Check engine light??
  154. integra sir-g ???? what the?
  155. ecu ecu ecu i see you
  156. Short Throw Shifter
  157. Eibach pro-kit 1.3 drop
  158. my car shut off at 140mph
  159. thinking of trading my car
  160. GSR cams
  161. 95 Integra GSR 4 door
  162. please help!! aftermarket performance gauges question
  163. buzzing noise?
  164. front end conversion?
  165. Seat removal
  166. aem cam gears
  167. Whistling noise and problem starting
  168. h22/h23
  169. No spark!!!
  170. the best place to start?
  171. installing aftermarket gauges volts/oil psi/airfuel
  172. stage 1 cams vs stage 2 cams
  173. engine code p1457 evap system leak detected
  174. engine codes
  175. suggestions please
  176. H-Brace, Pillar Bar?
  177. Questions About my Integra Weird?????
  178. hang on tight wooooooooooooooooo!
  179. install help
  180. legal RHD integra to US? hard?
  181. How many of us name our cars?
  182. HELP!! Driver side door won't unlock!!
  183. Audio in Integra GS-R
  184. Got pics of my new GS-R.........
  185. wheel size
  186. Use Tsudo Anyone?
  187. jdm headlight swap
  188. racing music anyone???
  189. help!!!! what do i do first!!!!
  190. body kit from ebay?
  191. reseting the computer??
  192. Ignition upgrade
  193. Need more rubber on the ground
  194. racing hearts?
  195. burn-out
  196. 1st Model year teg (94)
  197. Your Exhaust Opinions Please
  198. 98-01 bumper swap
  199. Defrost vent not working
  200. similar exhausts.. same results??
  201. turbo/nitrous qustion
  202. pop!!!
  203. LS Turbo questions
  204. Top speed of a Integra?
  205. B16 Turbo Horsepower
  206. which exhaust
  207. new intake
  208. turbonator
  209. Replaced starter, no start?
  210. what psi should i set my fuel pressure at?
  211. Car Overheating
  212. b16 clutch
  213. Echeck
  214. Know nothing about clutches
  215. kinda got dicked
  216. ls v.s gsr
  217. b16a1
  218. Headers Leak?
  219. Have ya'll heard anything about "The Turbonater"?
  220. Distributor Problems
  221. 1997 acura integra gsr Surging at idle
  222. New to the forums, 2 questions about 96 GS-R.
  223. problem
  224. 90-93 integra redline
  225. what to do to valve cover??
  226. will this help and what next?
  227. Do your cars have EGR valves?
  228. turbo question?
  229. beginning mods
  230. radio codes
  231. gsr distributor
  232. clutch going?
  233. Squeeeeel Test
  234. cams
  235. flowmaster exhaust
  236. Vtec?
  237. Exhaust setup
  238. my 91 integra ls
  239. Basic questions
  240. h22a swap
  241. Looking for research materials..I want to learn
  242. test pipe??
  243. died out
  244. any one Parting out a 93 integra ls ?
  245. AROSPEED coilovers
  246. problems with my first gsr
  247. H22a in my integra: AC question
  248. My first GS-R........
  249. Cams install?
  250. coilcovers, shocks, springs
