Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
> Integra |
View Full Version :
Integra
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
two-tone paint job
Itr Pistions In An Ls?
Please help
integra LS 98: does it have idler pulley
GSR tranny
must get more power !!!!!
starting...oddities
vafc and vortec fmu
screw the leak
custom turbo help
integra ls's chances
Bodykit Mystery...
Swap Options LS/92
Is the b18a1 harn. same for auto/5speed?
96 gsr HELP
nitrous good idea or bad??
can any one help me out???
opinions please.
valves on a 1995 GS-R
Power antenna
GSR speakers.....
Which Trbo Kit Keeps the A/C & p/s?
91 4-door Body kits
COmpression?
Head Gasket
1st gen info...
turbo kits for an LS
Does anyone know anything about these exhausts
reflashing
stock clutch / lightened flywheel?
how many washers on diy rear camber?
Rain Water+Cai
90 integra gs transmission problem
****stereo Code****
How do you put on a Head Gasket?
20w-50 oil
pics of my setup
going turbo
big advantage??
what to do with my car?
New Coil
LS Special Edition
Aem V2???
Problem w/ my GSR????
GSR speaker sizes
Noise from clutch
what do you motor head think
91 Integra for sale
Best oil for integra gsr
need help
install help again
cold air intake hp?
strange noise
FS: Acura IntegraB18BLS 4-door 5-speed
new toys
making an offering on a car
Swapping out auto tranny
Front tranny mount bolt
Fuel Pressure ASAP!!!!!
b18c5 prices
rev an ls to 8000
STRANGE GRINDING NOISE, help plz
vtec "kick"?
help
Freakin fuel leak... help
96 integra LS hatchback?
b18b project
2 Piston Calipers?
honda motor desicion
1995 Integra LS
DIY ground wires? anyone?
ITR Valve springs
cardomain.com?
who would win
know any reliable engine importers?
Shift Boot
Hard Time Getting Timing Belt On
Seattle Tegs Unite
My Maint Reqd light is on... what could be the problem?
Make-A-Wish Cae
honda s2k topend
Radiator
Rim Question
difference
what intake mainfolds
Revive an Integra
deeper problems than just windows
Piston-Valve clearance problems?
does a 98-01 integra front bumper fit a 94 .?
Quick Question
90-93 with a b18c5
93 integra for sale
2005 type r
wondering about a broken steering lock
Buying a 2000 gsr
Rear Brake Light
Integra cool
ls/vtec
OEM prices?
I have a Bad Wire harness
Does anyone here have a turbo LS?
p28 turns into ak47!!!!
exhaust
turbo kits
94-97 & 98-01 difference
How difficult radiator replacement 92 Integra?
Hesitation
90-93 integra hks exhaust
headlight grounding
Ebay parts??
LS? or GSR?
Going turbo
greddy turbo, 5zigen exhaust??
98 front bumper conversion???
ABS Light won't turn off
Lights
always blowing heat
roll cage
Help with engine block/head identification
Timing belt basic questions
Where is the crank angle position sensor ?
Rear Seat Nightmare
Unstable idle
help with starting my 95 teg LS
battle
help on engine swap
will someone please help me on this one?
Honda Parts to Australia
TPS Trouble
00 si tranny good?
what air intake works for hybrid?
automatic seatbelts wont return
Which one 2 buy
AEM cam gear help.
turbonetics???
cylinder sensors (CYP)
Traction Problems
Cant keep caliper sliders from freezing
Whats the best year for the GS-R?
need to know fast
Rotor & Caliper Upgrades?
obd2 gsr bad for HP??
what to replace to make new???
Need some help
GSR running lean
LS,GS...are they fun even tho no VTEC?
generations?
integra fuse box help
jrsc headers,exhaust
aem cam gears
Check engine light??
integra sir-g ???? what the?
ecu ecu ecu i see you
Short Throw Shifter
Eibach pro-kit 1.3 drop
my car shut off at 140mph
thinking of trading my car
GSR cams
95 Integra GSR 4 door
please help!! aftermarket performance gauges question
buzzing noise?
front end conversion?
Seat removal
aem cam gears
Whistling noise and problem starting
h22/h23
No spark!!!
the best place to start?
installing aftermarket gauges volts/oil psi/airfuel
stage 1 cams vs stage 2 cams
engine code p1457 evap system leak detected
engine codes
suggestions please
H-Brace, Pillar Bar?
Questions About my Integra Weird?????
hang on tight wooooooooooooooooo!
install help
legal RHD integra to US? hard?
How many of us name our cars?
HELP!! Driver side door won't unlock!!
Audio in Integra GS-R
Got pics of my new GS-R.........
wheel size
Use Tsudo Anyone?
jdm headlight swap
racing music anyone???
help!!!! what do i do first!!!!
body kit from ebay?
reseting the computer??
Ignition upgrade
Need more rubber on the ground
racing hearts?
burn-out
1st Model year teg (94)
Your Exhaust Opinions Please
98-01 bumper swap
Defrost vent not working
similar exhausts.. same results??
turbo/nitrous qustion
pop!!!
LS Turbo questions
Top speed of a Integra?
B16 Turbo Horsepower
which exhaust
new intake
turbonator
Replaced starter, no start?
what psi should i set my fuel pressure at?
Car Overheating
b16 clutch
Echeck
Know nothing about clutches
kinda got dicked
ls v.s gsr
b16a1
Headers Leak?
Have ya'll heard anything about "The Turbonater"?
Distributor Problems
1997 acura integra gsr Surging at idle
New to the forums, 2 questions about 96 GS-R.
problem
90-93 integra redline
what to do to valve cover??
will this help and what next?
Do your cars have EGR valves?
turbo question?
beginning mods
radio codes
gsr distributor
clutch going?
Squeeeeel Test
cams
flowmaster exhaust
Vtec?
Exhaust setup
my 91 integra ls
Basic questions
h22a swap
Looking for research materials..I want to learn
test pipe??
died out
any one Parting out a 93 integra ls ?
AROSPEED coilovers
problems with my first gsr
H22a in my integra: AC question
My first GS-R........
Cams install?
coilcovers, shocks, springs
Timing Belt Change
Gsr Smokin Type R???
Web
AF
