View Full Version : Integra
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Semi-Oscillating RPM
  2. CEL blinking
  3. 95 gsr, v-tec not working intermittent???
  4. b18a1 cyl. bore help
  5. advice on best way to remove paint
  6. Integra Performace, anyone know????????
  7. 94 integra NO SPARK PLEASE HELP !!!!
  8. How to read codes on a 91 Integra?
  9. h22 or b18c in my 91 LS??
  10. gs-r burnin oil!!
  11. power window issue
  12. help with h22 swap
  13. H22 in 96 integra?!?!?!
  14. need info on 91 integra
  15. H22 Swap
  16. need
  17. help w/ mods
  18. Fuel pressure?
  19. help advancing my cam timing
  20. 1993 integra - $3600, fair deal??
  21. Turboing GS-R
  22. Help finding parts
  23. 89 integra
  24. How do you install a 4 pt Harness
  25. 90 Integra LS
  26. Hydrolic S80 transmission?????
  27. no horn, brake lights or cruise control
  28. Anyone Who Knows Car Domain Help!
  29. 98 Integra
  30. Transmisson Problem (87 integra)
  31. 95 Integra LS???
  32. Want This Body Kit!!!
  33. Stock Body parts (87 integra)
  34. where is the tranny dipstick
  35. intake hp?
  36. integra is stuck in neutral...need some help
  37. Is it worth it?
  38. Searching for Integra / LS Swaped Cars to Sponsor!
  39. 86 integra
  40. 92 integra ls throttle body size
  41. all pullies not working?
  42. paint job?
  43. 3rd gear going
  44. were to get new interior
  45. D16A1 DOHC...sTuMpEd!!
  46. throwing codes. 8 9
  47. problem with new caliper!!!!
  48. Sponsor question
  49. 95 integra motor info might buy tommorow need help please
  50. Distributor problem
  51. I have issues with my starter; Please help
  52. Ls/vtec
  53. Hammering sound on idle
  54. EF lover turns to DA (pics of my new car)
  55. Paint Question
  56. Brake master cylinder 91 integra?
  57. No overdrive 91 integra?
  58. tell me if its worth it
  59. b18c6
  60. clutch
  61. strange power window/mirror problem
  62. DA on road course, wheel to wheel racing
  63. obd2 to obd1 conversion??
  64. 96 Se 5400$????
  65. LS difference
  66. idle problems
  67. trunk release problems
  68. Another turbo question
  69. what do you need for a turbo setup?
  70. Strut Bar Install
  71. good sites to order parts?
  72. 2000 integra gsr, maintenance
  73. Clutchmaster Stage 1 and ACT 12lbs Flywheel
  74. Starting Problem
  75. Tsudo camber kit
  76. 92 Brake pads and rotor Q
  77. pulling the block...
  78. gauge cluster for ef!
  79. Safe bore measurement?
  80. out of money whats wrong with tranny?
  81. out of money whats wrong with tranny?
  82. out of money whats wrong with tranny?
  83. out of money whats wrong with tranny?
  84. throttle body
  85. 94 Teg
  86. Block Question
  87. HP Difference?
  88. Clutch swap
  89. 91 'Teg GS
  90. LS/VTEC Header Issue *********
  91. LS/VTEC Header Issue *********
  92. not shifting help
  93. b18c1 turbo or b18c5
  94. maintenance light wont turn off
  95. Maintenance Required Light Flashing!
  96. This has probably been asked millions of times, but please look.
  97. how much HP?
  98. Cost to rebuild a B18 Engine
  99. RC Engineering Injectors in Stock 94 GSR Manifold...?
  100. drive shaft assembly
  101. Urgent!! Short Throw Shifter Install
  102. Need Help With Integra!!!
  103. type-r motor
  104. 1995 Inegra GS-R
  105. Cost Questions
  106. gsr engine swap, or head swap??
  107. 1990 GS Teg Engine Problem
  108. k20a or type r engine?
  109. GS-R Spark Plugs
  110. 1993 Integra RS Has a miss. Is it the Cat???
  111. Adjusting Illumina struts.
  112. exhaust
  113. Brakes suck! Help!
  114. gas problem anyone knows whats wrong?
  115. Difference in USDM type r and JDM type r
  116. 1991 Acura integra RS Mods
  117. need help with stock 94 ls sterio
  118. need help on information
  119. Vibration in shifter
  120. where is fuel pump at in 1989 acura integra
  121. Teg's diference
  122. brake lights stay on when turn lights on :( help
  123. Thinking about buying an Integra... need advice please
  124. 1990 Acura Integra Alternator
  125. which one to get
  126. GSR 1/4 Mile times
  127. Abs Light
  128. need help with some stuff
  129. Does a Integra GSR come with a LSD tranny stock?
  130. Is this a good buy?
  131. Tell me now
  132. DC2 inquires.
  133. timing problem
  134. need help asap
  135. WTT:89 Civic Sedan
  136. hahaha this is too funny
  137. Obd2 to Obd1 conversion
  138. Greddy Turbo Timer Install
  139. new throttle body/intake manifold
  140. head swap
  141. What should i do
  142. Vtec
  143. question
  144. Integra or Mazda MX6 turbo
  145. ? 94 Ls
  146. Auto to manual swap
  147. torque damper?
  148. 98 Integra Gear Indication
  149. Idle problem when in Drive
  150. Installing Tranny Please Help!!!
  151. Need info
  152. Trans problem
  153. 1994 integra VTi vs 1994 Vti-R & 1994 Type R..WHo is a integra expert!!!!!!!!!
  154. turbo flange ?
  155. 94 integra starting problem
  156. 98 LS pgm fi fiasco
  157. help needed
  158. question for everyone
  159. Car won't go into gear!
  160. Dec 96 Integra
  161. G20 vs GSR
  162. Mr2 vs integra type r
  163. issues 92 teg 5spd
  164. where to find the heads
  165. ebay Strut Bars
  166. Problems after installing clutch
  167. Greddy Reliability
  168. Water Pump and Rack an Pinion Replacement
  169. rust
  170. cams for the gsr
  171. gsr cluster. manual and auto, the same?
  172. anybody from conneticut
  173. 1st CALIFORNIA First Gen. Integra Meet
  174. gs-r question help?
  175. 94 - 97 taillights
  176. everything about engine?
  177. Break Down...HELP
  178. Nitrous question plz help
  179. Integra Swap
  180. Lots of Q's!!!
  181. acura/honda books?
  182. silencer question
  183. FS: 94 gsr
  184. Electrical problem?
  185. good site to buy engine parts
  186. new to the forums. I have a few Q's...
  187. supercharger??
  188. Adjustable shocks
  189. new motor for my GsR help
  190. Which track car to get next...
  191. apexi n1 super silencer install??
  192. How much can i get for 97 ls
  193. Gs-R cams
  194. integra gsr
  195. plus sizing rims
  196. timing belt question
  197. turbo site question
  198. What does this mean.....?????
  199. Difference between gsr and itr gauge cluster!
  200. Will 94-97 lips fit on 98-01
  201. simple question
  202. Why is it so hard to find cypress green paint?
  203. Can Si cluster fit into 97 tegra Ls.
  204. remote car starter slight problem
  205. Difference between gsr and type r cams
  206. help getting integra started
  207. Chipped P28 in GSR
  208. LS crower 403s
  209. Head gasket replacement.
  210. RPM question
  211. What do you think?
  212. how much integra worth?
  213. first mods
  214. charging system problems
  215. ECU Question...
  216. integra vibrating while sitting there
  217. antenna not going up and down
  218. Which Clutch should I buy?
  219. Anyone from Dallas,TX
  220. Frame Help
  221. For Sale: 94 acura integra gsr
  222. Speedometer Issues!!!!
  223. Weird Noise?
  224. Squeeking when i turn on engine? should i still drive?
  225. Mirror Install on '92 RS
  226. Let me know what you think please. Thanks!
  227. Breath life into old Engine
  228. is it the clutch?
  229. Decent GSR for $4,000?
  230. pulleys?
  231. 1997 Acura Integra For Sale $2500
  232. jdm gsr turbo or usdm gsr turbo
  233. My GSR vs. Friends Prelude Type SH...
  234. Wanted GSR Tranny
  235. Lots of motor questions. Need help. Greatly apreciated!
  236. should i buy it??
  237. Integra GsR 130000 50 shot?
  238. Bought a 97 GSR First Mods? HELP!!
  239. 91 integra - check engine light and sputtering
  240. manual window problem
  241. '91 teg ls for sale, what you think?
  242. 2000 GS Power Window/Wiper slowdown
  243. Manual Tranny Fluid
  244. turbo installation price
  245. is CAI worth it?
  246. replacing the hood support rod
  247. Gsr Pops Out Of 5th
  248. 95 teg SE
  249. Advice on engine swaps...?
  250. 5zigen or HKS
