View Full Version : Integra
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. trunk release problems
  2. Another turbo question
  3. what do you need for a turbo setup?
  4. Strut Bar Install
  5. good sites to order parts?
  6. 2000 integra gsr, maintenance
  7. Clutchmaster Stage 1 and ACT 12lbs Flywheel
  8. Starting Problem
  9. Tsudo camber kit
  10. 92 Brake pads and rotor Q
  11. pulling the block...
  12. gauge cluster for ef!
  13. Safe bore measurement?
  14. out of money whats wrong with tranny?
  15. out of money whats wrong with tranny?
  16. out of money whats wrong with tranny?
  17. out of money whats wrong with tranny?
  18. throttle body
  19. 94 Teg
  20. Block Question
  21. HP Difference?
  22. Clutch swap
  23. 91 'Teg GS
  24. LS/VTEC Header Issue *********
  25. LS/VTEC Header Issue *********
  26. not shifting help
  27. b18c1 turbo or b18c5
  28. maintenance light wont turn off
  29. Maintenance Required Light Flashing!
  30. This has probably been asked millions of times, but please look.
  31. how much HP?
  32. Cost to rebuild a B18 Engine
  33. RC Engineering Injectors in Stock 94 GSR Manifold...?
  34. drive shaft assembly
  35. Urgent!! Short Throw Shifter Install
  36. Need Help With Integra!!!
  37. type-r motor
  38. 1995 Inegra GS-R
  39. Cost Questions
  40. gsr engine swap, or head swap??
  41. 1990 GS Teg Engine Problem
  42. k20a or type r engine?
  43. GS-R Spark Plugs
  44. 1993 Integra RS Has a miss. Is it the Cat???
  45. Adjusting Illumina struts.
  46. exhaust
  47. Brakes suck! Help!
  48. gas problem anyone knows whats wrong?
  49. Difference in USDM type r and JDM type r
  50. 1991 Acura integra RS Mods
  51. need help with stock 94 ls sterio
  52. need help on information
  53. Vibration in shifter
  54. where is fuel pump at in 1989 acura integra
  55. Teg's diference
  56. brake lights stay on when turn lights on :( help
  57. Thinking about buying an Integra... need advice please
  58. 1990 Acura Integra Alternator
  59. which one to get
  60. GSR 1/4 Mile times
  61. Abs Light
  62. need help with some stuff
  63. Does a Integra GSR come with a LSD tranny stock?
  64. Is this a good buy?
  65. Tell me now
  66. DC2 inquires.
  67. timing problem
  68. need help asap
  69. WTT:89 Civic Sedan
  70. hahaha this is too funny
  71. Obd2 to Obd1 conversion
  72. Greddy Turbo Timer Install
  73. new throttle body/intake manifold
  74. head swap
  75. What should i do
  76. Vtec
  77. question
  78. Integra or Mazda MX6 turbo
  79. ? 94 Ls
  80. Auto to manual swap
  81. torque damper?
  82. 98 Integra Gear Indication
  83. Idle problem when in Drive
  84. Installing Tranny Please Help!!!
  85. Need info
  86. Trans problem
  87. 1994 integra VTi vs 1994 Vti-R & 1994 Type R..WHo is a integra expert!!!!!!!!!
  88. turbo flange ?
  89. 94 integra starting problem
  90. 98 LS pgm fi fiasco
  91. help needed
  92. question for everyone
  93. Car won't go into gear!
  94. Dec 96 Integra
  95. G20 vs GSR
  96. Mr2 vs integra type r
  97. issues 92 teg 5spd
  98. where to find the heads
  99. ebay Strut Bars
  100. Problems after installing clutch
  101. Greddy Reliability
  102. Water Pump and Rack an Pinion Replacement
  103. rust
  104. cams for the gsr
  105. gsr cluster. manual and auto, the same?
  106. anybody from conneticut
  107. 1st CALIFORNIA First Gen. Integra Meet
  108. gs-r question help?
  109. 94 - 97 taillights
  110. everything about engine?
  111. Break Down...HELP
  112. Nitrous question plz help
  113. Integra Swap
  114. Lots of Q's!!!
  115. acura/honda books?
  116. silencer question
  117. FS: 94 gsr
  118. Electrical problem?
  119. good site to buy engine parts
  120. new to the forums. I have a few Q's...
  121. supercharger??
  122. Adjustable shocks
  123. new motor for my GsR help
  124. Which track car to get next...
  125. apexi n1 super silencer install??
  126. How much can i get for 97 ls
  127. Gs-R cams
  128. integra gsr
  129. plus sizing rims
  130. timing belt question
  131. turbo site question
  132. What does this mean.....?????
  133. Difference between gsr and itr gauge cluster!
  134. Will 94-97 lips fit on 98-01
  135. simple question
  136. Why is it so hard to find cypress green paint?
  137. Can Si cluster fit into 97 tegra Ls.
  138. remote car starter slight problem
  139. Difference between gsr and type r cams
  140. help getting integra started
  141. Chipped P28 in GSR
  142. LS crower 403s
  143. Head gasket replacement.
  144. RPM question
  145. What do you think?
  146. how much integra worth?
  147. first mods
  148. charging system problems
  149. ECU Question...
  150. integra vibrating while sitting there
  151. antenna not going up and down
  152. Which Clutch should I buy?
  153. Anyone from Dallas,TX
  154. Frame Help
  155. For Sale: 94 acura integra gsr
  156. Speedometer Issues!!!!
  157. Weird Noise?
  158. Squeeking when i turn on engine? should i still drive?
  159. Mirror Install on '92 RS
  160. Let me know what you think please. Thanks!
  161. Breath life into old Engine
  162. is it the clutch?
  163. Decent GSR for $4,000?
  164. pulleys?
  165. 1997 Acura Integra For Sale $2500
  166. jdm gsr turbo or usdm gsr turbo
  167. My GSR vs. Friends Prelude Type SH...
  168. Wanted GSR Tranny
  169. Lots of motor questions. Need help. Greatly apreciated!
  170. should i buy it??
  171. Integra GsR 130000 50 shot?
  172. Bought a 97 GSR First Mods? HELP!!
  173. 91 integra - check engine light and sputtering
  174. manual window problem
  175. '91 teg ls for sale, what you think?
  176. 2000 GS Power Window/Wiper slowdown
  177. Manual Tranny Fluid
  178. turbo installation price
  179. is CAI worth it?
  180. replacing the hood support rod
  181. Gsr Pops Out Of 5th
  182. 95 teg SE
  183. Advice on engine swaps...?
  184. 5zigen or HKS
  185. GS-R Speedo
  186. Engine Swaps
  187. Tranny safe to buy??? Please help ASAP!!!
  188. '91 auto-manual swap
  189. 3rd Brake Light
  190. 90 integra
  191. new teg
  192. will engine mods for then LS coupe work for the LS sedan?
  193. ITR Pistons in B16
  194. help on intake mani install
  195. Best Turbo size for LS engine?
  196. 1994 car wont start
  197. integra fans......
  198. Car Needed For Sport Compact Car
  199. When Revving, the more she BOGS - help!
  200. what next for suspension?
  201. Squeeking noise
  202. Intake mani replacement = not fun on GSR!!
  203. Clicking when i turn left??
  204. gsr tanny on a rs
  205. Super High Temp Urea Grease (P/N 08798-9002)
  206. Starting Problem :( ideas?
  207. 1991 rack and pinion
  208. Lower Ball Joints
  209. fuel preassure
  210. Ecm
  211. Good exhast??
  212. no spark
  213. 87 integra shifter ???
  214. just installed Injen RD cold air intake!!!
  215. help disconeccting the seat belt motor!!
  216. difference between LS and GS
  217. 95 Honda Integra GSI HELPP!
  218. Problem removing alternator
  219. im building my first head need a little help
  220. Difference between LS and GSR models (besides engine)?
  221. Need some exhaust suggestions
  222. Removing Radiator
  223. Suspension Question
  224. blower fan not working
  225. important question
  226. integra brake question
  227. $300 for what?
  228. need to know good struts and springs sales
  229. SR20DET parts
  230. transmission
  231. Do some tegs have window frames while others don't?
  232. ramhorn mani question
  233. question for ya
  234. Code: 1 Oxygen Content
  235. GS-R confusion
  236. Cluster swap
  237. automatic transmission shift kit?
  238. Has this happened to anyone?
  239. New guy here
  240. Best cams to get??
  241. LS type S swap
  242. Greddy style catback exhaust by tsudo?
  243. Simple question, need simple answer.
  244. 1st major issue with car
  245. hello im doing a ls/vtec just need a little help
  246. ok mileage poll
  247. not sure what kind of problem
  248. Guage color
  249. rpm problem
  250. Removing power steering speed sensor
