View Full Version : Integra
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32
  1. quick intake question
  2. gsr or corvette?
  3. A question for Integra owners
  4. tires
  5. question
  6. Just Wondering...GSR with a CHERRYBOMB???
  7. Removing front rotors.....HELP!!!
  8. 96 rear speakers
  9. Causes of unchanged fuel filter
  10. GSR eats alot of GAS!!!
  11. car vibrates after burn out
  12. checkers??
  13. shifter bushings worth it?
  14. My speedometer is broken
  15. crvtec
  16. Cheep Ls motor
  17. no brakes
  18. Intalling an exuast system
  19. Race Question
  20. generic header?
  21. Catalic Converter QUESTION
  22. Stock GS-R exhaust manifold cracked?
  23. Help on 89 integra
  24. condensation in headlights, help?
  25. Big Problem
  26. ***need-help***
  27. GSR Head on LS block
  28. Which model of spark plug is better for integra GS (B18B1)?
  29. 1991 Acura Integra ???Where is the water pump located ;-)
  30. F/s B18b1
  31. Integra Cross-Drilled Slotted Rotors
  32. big ass rims for integra
  33. what length rods do i need
  34. Poll-acura Inegra Body Project
  35. LS with GSR bottom end?
  36. Skunk2 springs got here today. VERY quick question
  37. 1994 Integra LS vs 2000 Civic SI
  38. grey smoke and no power in first
  39. cat?
  40. inertia switch/ 90 integra
  41. integra console
  42. I need canadian specs
  43. SRS light
  44. SRS light came on
  45. GSR motor Q's
  46. pullys blowing out alternator
  47. Quick ECU question
  48. Question On Stock Acura Cassette Player
  49. stock 96 integra LS, want to get to turbo
  50. what trannys will fit in my 92 integra!
  51. How Much Hp Does A B18b1 Have?? Im New
  52. Time 4 a Swap....or rebuild!!
  53. Engine starting to vibrate
  54. why is turbo on a LS so good
  55. Whos right? Integra Question
  56. What's mean about my spark plug type?
  57. New Ricer Needs Help!
  58. Please Help!!! Im New And Need Help On My Car
  59. Code 43
  60. B18c5?
  61. 95 Integra miscellaneous parts for sale...look!!
  62. 97 integra w/ 120k miles.....
  63. Which EXHAUST SYS should I get...
  64. Which Gives More TORQUE POWER...
  65. Conversion to 5-speed transmission
  66. anyone with a integra (94-01) helms/chilton manual...help plz
  67. Integra VS. Lancer which would you by.
  68. Short Shifter Installation
  69. Aftermarket Pistons?
  70. custom exhaust
  71. Thinking of selling my teg
  72. What If You Have No Choice But An Automatic?
  73. Rattling Hatch...
  74. Looking to buy an integra
  75. supercharged integra gsr ???
  76. B20z?
  77. Integra LS vs GSR
  78. new project plan
  79. Question for the Integra guys-
  80. engine boring
  81. Everything Is Goin Wrong
  82. help bolts from under teg popped off
  83. Does the GSR have a RISTRICTION PIPE after the CAT???
  84. shift boot
  85. 91 Integra Where to get engine parts?
  86. Really Pissed off!
  87. Suspension suggestions
  88. how to convert ls to ls vtech
  89. Just redid timing
  90. integra gen2 project....ur advice
  91. Ceramin header question, Need advice
  92. Serious short shifter problems, it broke in half and stock one wont work
  93. used turbo or new one?
  94. frankenstein swap
  95. Uneven Tire Wear
  96. 1991 acura integra upgrading
  97. Short Shifter Install
  98. Anyone have 94-97 integra service manual?
  99. your thoughts on what the best thing for an intergra would be
  100. Why 4-2-1 Headers?
  101. Greddy Evo?
  102. intake!
  103. Anyone Got A Turboed At Ls?
  104. Where to get motor mounts??
  105. AEM bypass valve questions
  106. ENGINE SWAP: GSR to Type R help!
  107. LS/Vtec
  108. cat heat shield
  109. 60k miles maint
  110. g2 teg project help?
  111. Big news on the new release of the JDM Integra type R!!!!!!!
  112. ? for people lowered on stock shocks
  113. White boy in an Integra...
  114. cheap speed
  115. Is this suspension worth the $$?
  116. sound/performance exhuast
  117. Spark plug upgrade - worth it?
  118. What's with the LS?
  119. need major help
  120. moding my RSX type S
  121. Insurance...List your rates
  122. best of the best
  123. gsr?LS?
  124. What shocks would go best with H&R Sport springs?
  125. Sell LS and buy GSR or stay with LS?
  126. Wisconsin Integra?
  127. 98 Teg LS stock running 16s help!!!!
  128. no a/c & power steering belt = hores power?
  129. looking for a 4 dr GSR
  130. integra gsr 14 seconds et
  131. my new car (maybe)
  132. Good site for engine parts..
  133. Sellimg my 95 Acura Integra GS-R
  134. ls/vtec or turbokkk t3/t4
  135. lsvtec or turbo
  136. air conditioner slows the car down
  137. New clutch seems flimsy...
  138. USDM Front End on JDM Integra?
  139. venom 400 power chip
  140. Would these look good on a 95 red or gray integra?
  141. what did you drive?
  142. racing clutch and flywheel
  143. hmmm H&R + Tokico?
  144. need a distributor pleaseeeeeee
  145. Help with tires rubbing
  146. 142-140hp
  147. mods for gsr
  148. turbo on a type r
  149. puntuation
  150. SWAPPING an ENGINE FOR A GSR 97....
  151. Will a Civic strut bar fit on an Integra?
  152. HELP! motor mount replacement
  153. What do you think????
  154. Interior Swap
  155. Rattling noise from car, help?!?
  156. RSX Type S lighter
  157. *NEW MEMBER* "Hello."
  158. Will a 99 intake manifold fit
  159. these wheels??
  160. bnw and gsr
  161. LS/Vtec or Turbo LS?
  162. tranny leaking after replacing cv ax? help!
  163. 1991 integra w/ a nsx engine and 6 speed tranny
  164. switch from automatic to manual?
  165. awesome integra rims for sale
  166. GReddy Evo Exhaust
  167. 91 Integra not running
  168. help it's burning oil.
  169. Fd Integra
  170. auto body parts
  171. Enkei MM2 vs Konig Theory
  172. need help??
  173. 92-95 Integra Performance Ecu Chip Skunk2
  174. track times!!!
  175. Took some pics of the car today..
  176. Won't start
  177. Maintance Light
  178. 96 GSR vs. 95 Accord EX V6
  179. integra with b16 and vortech s/c
  180. Cam shaft
  181. ecu chips
  182. h22 swap ??? integra
  183. 94 Integra Gs-R Black Trace Image???
  184. hooked up sedans??
  185. Squeaky Suspension
  186. newbie question
  187. Sunfire Gt Tranny
  188. 1/4 mile time for a stock 91
  189. Wider track with wheel spacers
  190. Help With Turbo
  191. 215/45/17?
  192. an integra so fast it falls of the dyno!
  193. I need an Integra
  194. h22 engine swap questions
  195. Integra or Prelude?
  196. What should i get?
  197. ??? about seats
  198. 95 GSR Shifting Problems...
  199. best header
  200. bodykit
  201. Failed echeck in Ohio
  202. integra 2003 ls
  203. 205/40/17 or 205/45/17?
  204. New member with rsx
  205. need help
  206. g2 teg aero mirrors?
  207. turbo or supercharger
  208. exhaust?? what brand should i get
  209. did u ever hear of them tires ?
  210. rotor question
  211. Type R wastes M3's
  212. GS-R or RSX?
  213. Starter motor?
  214. help
  215. Custom catback
  216. broken timeing belt.. engine toast?
  217. looking for a good shop
  218. Nitrous GSR 1/4 mile
  219. thinking of rebuild or replacement + import JDM
  220. ?'s, keeping GSR naturally aspirated
  221. Maxima vs. GSR ?
  222. Integra LS ALL MOTOR peak 1/4 mile times
  223. how to switch doors
  224. ITR tire Q's
  225. HI. Im lookin for engines and power ratings over the years for integs
  226. need advice on slicks and nitrous
  227. 93 gs-r v. 95 probe gt
  228. Air intake
  229. is this a real gas saver?
  230. i figured out what i want
  231. Gsr Kiced ass Tonight
  232. Exhaust and intake
  233. Integra for sale
  234. i-vtec in RSX
  235. impossible?
  236. 98 - 01 lip kit
  237. Please take my poll and check out my GS-R!!!
  238. 97 Integra GS-R w/ NOS
  239. 95 Acura Speedometer Issue
  240. 1996 integra type r
  241. WHat Next???
  242. Quick Question
  243. how to slam
  244. problem with speed
  245. Quick Question Bout Body Kit
  246. Help with my 90 GS
  247. I need help with my signature
  248. 2001 Integra Ls Exhaust
  249. 94 integra ls Under 5g
  250. Integra vs 1.8T
