View Full Version : Integra
- Why is this so cheap?
- Open hood without release cable????
- Please Help
- Please Help
- Please Help
- i need an opinion
- integra question
- Acura LS mesh rims????
- do you know how to pull a front axel hub from an integra?
- high ideal
- Type R (ITR) rear calipers listed on Ebay
- Bench bleeding new master cylinder
- RPM questions for Integra
- 91 Teg. Will a performance header from a B18 fit on a B16?
- Temp gauge stays all way to right, even when off, when cold
- B18A1 vs. B18B1 vs. B18C1
- ball joint poped out while driving. no grease
- Click...click...no Crank???
- Teg Radiator ???
- Multiple electrical problems
- all motor or NOS
- what factory radios will fit an 1989 Integra
- 91 acura intregra with b16a swap
- My center electrode tip broke off
- true power pulleys
- Cigarette lighter socket
- Why
- acura integ keeps dyin help?
- Petrol Tank
- Mysterious water leak into interior
- spark
- right way to remove power stearing and A/C?
- 96 teg rs ... RADIO ????
- 92 gsr b17a1
- Project DA6.
- Looking to buy...
- center console question
- Smoked Speedo Head!
- help skunk2 intake manifold carb eo number
- Ls/vtec on 92 teg???
- SRS light on 95 integra ls obd1 ecu
- ls/vtec
- Going abroad
- Type R tranny or a b 16 tranny
- 90-93 teg spoiler questions
- Dash lights HELP!
- Oil leak at head
- Size of bolt for extracting brake rotors
- air conditioning belt installation??? how to tighten belt?
- integra brakes making noise brand new brakes
- Just bought a 91 Teg w\Xsi Swap.
- Window Tint
- replacing my power window controller i cant get it off
- Deal? Or not?
- WTK: ITR MT tranny in a teg
- 94 gsr acting up
- How do i make my gsr vtec hit hard?HELP me
- ZC/D16A8 running too rich
- Power Sear Belt Problem
- How can i tell if i have a integra gsr and so on
- SIR Cams
- No Spark
- help with seat belt
- Obd2
- 2001 Acura Integra?
- ls tuboor or gsr with mods?
- Antena
- polishing the heads
- turboing question
- Looking for attainable HP/TQ numbers on a b18c1 motor.
- looking for new engine
- 8 puck stage 3 clutch?
- 91 teg runs rough when hot
- 1989 Integra - Motor runs after turning
- difference between 1st and 2nd gen tegs
- HELP! my studs broke off the hub, and i can't pound them out!
- could someone help me with a carfax report
- ABS light on
- Engine + JRSC
- High Flow Cat for 95 GSR
- where can i get parts for my 88 teg????
- gauges just quit
- Integra GSR +98
- is this arm rest rare?
- R cams on GSR
- Gears Sticking?
- starter cranks slow at first
- 93 Integra possible clutch/trans problem
- To part or not to part.
- ecu code 15 ignition output signal
- need help, 94 ls integra
- All Clear Integra Taillights!!
- Battery light Help please
- spring
- 92 shuts off when it warm up
- NSX sidevents on an Integra?
- suspension help
- Another ls/vtec ?
- Zc ???
- Subframe
- Integra or Civic
- rim bolt patter???????
- 96 ls or 99 gs
- GSR fuel rail
- Gsr CrankShaft
- Looking to Buy Integra
- Cylinder Hear ID Code #'s
- Valve cover differences?
- Pacesetter Header w/ Ceramic Coating!
- DA headlights :(
- turbo integra!
- 96 ls low 15 1/4
- 96 integra LS DIY?
- 91 Acura LS Wiper, Cruise and Defog problems
- Freon issues
- b18 to b20
- Acura Integra Distributor
- Gsr Headers
- Spark Pulg Gap For 94 Acura Ls
- 90 Integra
- Acura Integra B18B1 wont start
- help please!! my moonroof of my 1996 integra
- ZX motor swap
- Tune Up
- Steering wheel horn
- have to wait 5 min to start???
- Skunk 2
- Setup For Road Racing?
- Help! - Loss of power off line
- 92 gs tail/dash light
- 95 gsr
- ls/vtec best head?
- b18a vtec conversion?
- Adding gauges to A-Pillar help
- Please help - 91 teg won't start :(
- e-turbo??
- Rear Wide Body Fenders . . . (4PIX)
- Medium gray leather color name
- broken cruise control on 93...
- body parts
- Ls/Vtec. Posible or not????
- integra faq?
- Srs?
- 1992 teg won't start help please
- starting problem 1992 acura integra
- 97 integra ls
- 90' integra ls
- Please Help Me
- cam gear
- 90 Integra engine problem!!!!!
- No Dash Lights
- 1993 Acura Integra Transmission Overheated?
- turbo kit on ebay
- S15 Conversion Questions
- motor options
- 2000 Integra making noises at high RPMs
- Type R Spoiler
- street legal mufflers
- 92 integra gs window question
- No replacement for displacement
- no ignition spark
- '92 Integra 140K, 2600$ Should I ???
- Questions about a 93 Teg
- Water getting in under trunk. Help please!!!
- 93 integra wont start
- Couple simple questions need simple answers
- nitrous
- Fast Idle Thermo Valve
- Heat shield
- Greddy sp2 or skunk 2
- you guys think this suspension set-up would work?
- Just a quick question.
- Rubbing Tires
- Automatic transmission dipstick -- FOUND!
- Big plans for DA
- DA exhaust
- Rubber Flap?
- Electrical prob
- Starter???
- radiator
- clutch break in period???
- timing belt
- Water Dripping In Car
- Help please 91 integra wont start
- Semi-Oscillating RPM
- CEL blinking
- 95 gsr, v-tec not working intermittent???
- b18a1 cyl. bore help
- advice on best way to remove paint
- Integra Performace, anyone know????????
- 94 integra NO SPARK PLEASE HELP !!!!
- How to read codes on a 91 Integra?
- h22 or b18c in my 91 LS??
- gs-r burnin oil!!
- power window issue
- help with h22 swap
- H22 in 96 integra?!?!?!
- need info on 91 integra
- H22 Swap
- need
- help w/ mods
- Fuel pressure?
- help advancing my cam timing
- 1993 integra - $3600, fair deal??
- Turboing GS-R
- Help finding parts
- 89 integra
- How do you install a 4 pt Harness
- 90 Integra LS
- Hydrolic S80 transmission?????
- no horn, brake lights or cruise control
- Anyone Who Knows Car Domain Help!
- 98 Integra
- Transmisson Problem (87 integra)
- 95 Integra LS???
- Want This Body Kit!!!
- Stock Body parts (87 integra)
- where is the tranny dipstick
- intake hp?
- integra is stuck in neutral...need some help
- Is it worth it?
- Searching for Integra / LS Swaped Cars to Sponsor!
- 86 integra
- 92 integra ls throttle body size
- all pullies not working?
- paint job?
- 3rd gear going
- were to get new interior
- D16A1 DOHC...sTuMpEd!!
- throwing codes. 8 9
- problem with new caliper!!!!
- Sponsor question
- 95 integra motor info might buy tommorow need help please
- Distributor problem
- I have issues with my starter; Please help
- Ls/vtec
- Hammering sound on idle
- EF lover turns to DA (pics of my new car)
- Paint Question
- Brake master cylinder 91 integra?
- No overdrive 91 integra?
- tell me if its worth it
- b18c6
- clutch
- strange power window/mirror problem
- DA on road course, wheel to wheel racing
- obd2 to obd1 conversion??
- 96 Se 5400$????
