View Full Version : Integra
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Please Help
  2. Please Help
  3. Please Help
  4. i need an opinion
  5. integra question
  6. Acura LS mesh rims????
  7. do you know how to pull a front axel hub from an integra?
  8. high ideal
  9. Type R (ITR) rear calipers listed on Ebay
  10. Bench bleeding new master cylinder
  11. RPM questions for Integra
  12. 91 Teg. Will a performance header from a B18 fit on a B16?
  13. Temp gauge stays all way to right, even when off, when cold
  14. B18A1 vs. B18B1 vs. B18C1
  15. ball joint poped out while driving. no grease
  16. Click...click...no Crank???
  17. Teg Radiator ???
  18. Multiple electrical problems
  19. all motor or NOS
  20. what factory radios will fit an 1989 Integra
  21. 91 acura intregra with b16a swap
  22. My center electrode tip broke off
  23. true power pulleys
  24. Cigarette lighter socket
  25. Why
  26. acura integ keeps dyin help?
  27. Petrol Tank
  28. Mysterious water leak into interior
  29. spark
  30. right way to remove power stearing and A/C?
  31. 96 teg rs ... RADIO ????
  32. 92 gsr b17a1
  33. Project DA6.
  34. Looking to buy...
  35. center console question
  36. Smoked Speedo Head!
  37. help skunk2 intake manifold carb eo number
  38. Ls/vtec on 92 teg???
  39. SRS light on 95 integra ls obd1 ecu
  40. ls/vtec
  41. Going abroad
  42. Type R tranny or a b 16 tranny
  43. 90-93 teg spoiler questions
  44. Dash lights HELP!
  45. Oil leak at head
  46. Size of bolt for extracting brake rotors
  47. air conditioning belt installation??? how to tighten belt?
  48. integra brakes making noise brand new brakes
  49. Just bought a 91 Teg w\Xsi Swap.
  50. Window Tint
  51. replacing my power window controller i cant get it off
  52. Deal? Or not?
  53. WTK: ITR MT tranny in a teg
  54. 94 gsr acting up
  55. How do i make my gsr vtec hit hard?HELP me
  56. ZC/D16A8 running too rich
  57. Power Sear Belt Problem
  58. How can i tell if i have a integra gsr and so on
  59. SIR Cams
  60. No Spark
  61. help with seat belt
  62. Obd2
  63. 2001 Acura Integra?
  64. ls tuboor or gsr with mods?
  65. Antena
  66. polishing the heads
  67. turboing question
  68. Looking for attainable HP/TQ numbers on a b18c1 motor.
  69. looking for new engine
  70. 8 puck stage 3 clutch?
  71. 91 teg runs rough when hot
  72. 1989 Integra - Motor runs after turning
  73. difference between 1st and 2nd gen tegs
  74. HELP! my studs broke off the hub, and i can't pound them out!
  75. could someone help me with a carfax report
  76. ABS light on
  77. Engine + JRSC
  78. High Flow Cat for 95 GSR
  79. where can i get parts for my 88 teg????
  80. gauges just quit
  81. Integra GSR +98
  82. is this arm rest rare?
  83. R cams on GSR
  84. Gears Sticking?
  85. starter cranks slow at first
  86. 93 Integra possible clutch/trans problem
  87. To part or not to part.
  88. ecu code 15 ignition output signal
  89. need help, 94 ls integra
  90. All Clear Integra Taillights!!
  91. Battery light Help please
  92. spring
  93. 92 shuts off when it warm up
  94. NSX sidevents on an Integra?
  95. suspension help
  96. Another ls/vtec ?
  97. Zc ???
  98. Subframe
  99. Integra or Civic
  100. rim bolt patter???????
  101. 96 ls or 99 gs
  102. GSR fuel rail
  103. Gsr CrankShaft
  104. Looking to Buy Integra
  105. Looking to Buy Integra
  106. Looking to Buy Integra
  107. Cylinder Hear ID Code #'s
  108. Valve cover differences?
  109. Pacesetter Header w/ Ceramic Coating!
  110. DA headlights :(
  111. turbo integra!
  112. 96 ls low 15 1/4
  113. 96 integra LS DIY?
  114. 91 Acura LS Wiper, Cruise and Defog problems
  115. Freon issues
  116. b18 to b20
  117. Acura Integra Distributor
  118. Gsr Headers
  119. Spark Pulg Gap For 94 Acura Ls
  120. 90 Integra
  121. Acura Integra B18B1 wont start
  122. help please!! my moonroof of my 1996 integra
  123. ZX motor swap
  124. Tune Up
  125. Steering wheel horn
  126. have to wait 5 min to start???
  127. Skunk 2
  128. Setup For Road Racing?
  129. Help! - Loss of power off line
  130. 92 gs tail/dash light
  131. 95 gsr
  132. ls/vtec best head?
  133. b18a vtec conversion?
  134. Adding gauges to A-Pillar help
  135. Please help - 91 teg won't start :(
  136. e-turbo??
  137. Rear Wide Body Fenders . . . (4PIX)
  138. Medium gray leather color name
  139. broken cruise control on 93...
  140. body parts
  141. Ls/Vtec. Posible or not????
  142. integra faq?
  143. Srs?
  144. 1992 teg won't start help please
  145. starting problem 1992 acura integra
  146. 97 integra ls
  147. 90' integra ls
  148. Please Help Me
  149. cam gear
  150. 90 Integra engine problem!!!!!
  151. No Dash Lights
  152. 1993 Acura Integra Transmission Overheated?
  153. turbo kit on ebay
  154. S15 Conversion Questions
  155. motor options
  156. 2000 Integra making noises at high RPMs
  157. Type R Spoiler
  158. street legal mufflers
  159. 92 integra gs window question
  160. No replacement for displacement
  161. no ignition spark
  162. '92 Integra 140K, 2600$ Should I ???
  163. Questions about a 93 Teg
  164. Water getting in under trunk. Help please!!!
  165. 93 integra wont start
  166. Couple simple questions need simple answers
  167. nitrous
  168. Fast Idle Thermo Valve
  169. Heat shield
  170. Greddy sp2 or skunk 2
  171. you guys think this suspension set-up would work?
  172. Just a quick question.
  173. Rubbing Tires
  174. Automatic transmission dipstick -- FOUND!
  175. Big plans for DA
  176. DA exhaust
  177. Rubber Flap?
  178. Electrical prob
  179. Starter???
  180. radiator
  181. clutch break in period???
  182. timing belt
  183. Water Dripping In Car
  184. Help please 91 integra wont start
  185. Semi-Oscillating RPM
  186. CEL blinking
  187. 95 gsr, v-tec not working intermittent???
  188. b18a1 cyl. bore help
  189. advice on best way to remove paint
  190. Integra Performace, anyone know????????
  191. 94 integra NO SPARK PLEASE HELP !!!!
  192. How to read codes on a 91 Integra?
  193. h22 or b18c in my 91 LS??
  194. gs-r burnin oil!!
  195. power window issue
  196. help with h22 swap
  197. H22 in 96 integra?!?!?!
  198. need info on 91 integra
  199. H22 Swap
  200. need
  201. help w/ mods
  202. Fuel pressure?
  203. help advancing my cam timing
  204. 1993 integra - $3600, fair deal??
  205. Turboing GS-R
  206. Help finding parts
  207. 89 integra
  208. How do you install a 4 pt Harness
  209. 90 Integra LS
  210. Hydrolic S80 transmission?????
  211. no horn, brake lights or cruise control
  212. Anyone Who Knows Car Domain Help!
  213. 98 Integra
  214. Transmisson Problem (87 integra)
  215. 95 Integra LS???
  216. Want This Body Kit!!!
  217. Stock Body parts (87 integra)
  218. where is the tranny dipstick
  219. intake hp?
  220. integra is stuck in neutral...need some help
  221. Is it worth it?
  222. Searching for Integra / LS Swaped Cars to Sponsor!
  223. 86 integra
  224. 92 integra ls throttle body size
  225. all pullies not working?
  226. paint job?
  227. 3rd gear going
  228. were to get new interior
  229. D16A1 DOHC...sTuMpEd!!
  230. throwing codes. 8 9
  231. problem with new caliper!!!!
  232. Sponsor question
  233. 95 integra motor info might buy tommorow need help please
  234. Distributor problem
  235. I have issues with my starter; Please help
  236. Ls/vtec
  237. Hammering sound on idle
  238. EF lover turns to DA (pics of my new car)
  239. Paint Question
  240. Brake master cylinder 91 integra?
  241. No overdrive 91 integra?
  242. tell me if its worth it
  243. b18c6
  244. clutch
  245. strange power window/mirror problem
  246. DA on road course, wheel to wheel racing
  247. obd2 to obd1 conversion??
  248. 96 Se 5400$????
  249. LS difference
  250. idle problems
