View Full Version : Integra
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. ls upgrades
  2. Short Shifter
  3. lowering springs
  4. swap
  5. 92 integra GS vs. 93 Legend 4dr.
  6. blower
  7. It's getting hot in here...
  8. need a some help
  9. brake light won't turn off
  10. cheap performance
  11. Thermostat..how to replace?
  12. Exhaust and Pulleys
  13. Sway Bar Kit
  14. 93 Ls... into a GSR killer... or almost?
  15. got boost?
  16. Clunking noise while turning...
  17. engine swap for 1990 LS
  18. Clutch Install
  19. Engine Specs.
  20. Special Edition emblem
  21. wide-body 93 integ?
  22. Performance Parts??
  23. Looking For A Shop In My Area!!
  24. engine running hot
  25. Transmission info !!!!!
  26. Stock Throttle Body Size on the 1.8L
  27. how much you willing to pay for a 97 J-spec RHD integra Type-R?
  28. Will the integra 99 2 door front bumper fit on a 4 door integra???
  29. 2000 teg removed catalytic, how to fix check engine?
  30. Strut? rear 'pothole' rattle
  31. Help! Brake lights not working!
  32. 95 GS-R TB work with 95 LS IM?
  33. Conversion of RSX to ITR
  34. I have no words for this.
  35. Help me create a "SLEEPER"!!!
  36. air filter, brake and coolant flushes???
  37. JDM Conversion of RSX to ITR
  38. product review
  39. Turbo GSR?
  40. please help on installing coilovers
  41. vtec enguagment
  42. Problem with my Integra.
  43. lsd
  44. ls Heat shield removal
  45. Possible update to the teg situation
  46. Pics of Type R
  47. Shifting Time
  48. cheap parts 90-93 integra
  49. Turbo Clutch by RPS?
  50. rsx vs. integra vs. celica vs. civic
  51. Egr Valve
  52. Problem with GS Shifting?? Help?!!!
  53. training a clutch ?
  54. gsr troubles
  55. Will a B16A auto tranny fit a 90 LS motor?
  56. Need help removing passenger side motor mount
  57. am I just wasting my time?
  58. apex vafc setting
  59. GSR 1/4 mile times
  60. gs-r ?
  61. springs and shocks
  62. LS VTEC HP question
  63. GSR vs LS
  64. intrument/tail lights
  65. i need help on swapping the engine in my rsx-s
  66. Smog failed on 92 integra
  67. does your swap eat up alot of gas
  68. maybe in the wrong place?
  69. 99 GS-R or 98 LS...Which way to go...
  70. wondering if there is a difference
  71. Hi rpm's on freeway
  72. coilovers
  73. Which is Better Rsx- type S or Prelude Vtec
  74. mixing usdm and jdm?
  75. Rear window washer is not working
  76. 96 SE or 95 SE coupe or 94 LS coupe
  77. Lsd
  78. type R vs. GS-R
  79. Advice on 1st Integra?
  80. which catback i should get?
  81. Front End Problem
  82. 13 sec type r
  83. Just got a '91 - some questions for y'all;
  84. Discerning between the 1.7L and 1.8 engine
  85. IAC valve help
  86. 98 2Dr Black GSR for Sale - 97K!! Very Good Condition!Boston area!!
  87. Help me !!! LIP KITS
  88. What is GSR exactly?
  89. 1991 integra gs specs?
  90. I heading to track for first time and need some tips.
  91. I bought it!!!!
  92. hondata and short ram
  93. cheap parts for 90-93 integra
  94. Racing w/ automatic
  95. muffler question
  96. HID conversion
  97. Itr collector size
  98. somethin isn't right..
  99. Sema
  100. RSX stock vs. Jetta WOlfsburg
  101. i heard this could work!!!!!!
  102. how much boost
  103. tokico gas shoxs vs. tokico non gas
  104. Where can I get a good JDM Engine?
  105. power difference with cams?
  106. Bolt-ons
  107. tires
  108. Where would the wheel lock be?
  109. in dash dvd player...does it fit?
  110. lsd on gsr
  111. AEM Pulley Kit and Nology Hotwires, Worth the money?
  112. header compatability
  113. slight vibration at 3+ rpm's ?
  114. Need RSX -S oem parts
  115. Type - R question
  116. AEM V2 on RSX Type S
  117. LS/GSR catback exhaust interchangable??
  118. GSR high prices
  119. GSR powered!!
  120. Need Help Aspap! Please
  121. Type R Head Setup Questions??
  122. Hi Newbi Teg Driver !
  123. FS: 1990 Acura Integra LS
  124. ls-vtech or gsr?
  125. 1/8mile tracks wtf???
  126. b16 or b18c tranny on my gsr??
  127. what does a b16 shift at??
  128. LS/VTEC Question
  129. what does this mean???
  130. Car Problem..
  131. blinking maint. req. light when I start my Integra
  132. Ek9 Lsd
  133. integra front bumper retainer clips?
  134. Clutch Pedal Weak Return Integra 94 LS
  135. WTB: 90-93 Teg suspension
  136. AEM v2
  137. WHat model distributor?
  138. Which Car?
  139. VTEC help
  140. Look what just hit the US market...
  141. IAC valce
  142. supercharge and turbo
  143. 1994 INTEGRA LS FOR SALE-(CL kit, $6.5k)
  144. project gsr
  145. Parting out my 96 GSR
  146. 90-93 intake
  147. Check Engine Light Problem 98 Prelude
  148. Do It Yourself Mods
  149. 90-93 version vs 94+ Integra
  150. post pics of ur integras
  151. maintenance light???
  152. Dyno Curves?
  153. trunk rattle?
  154. questions
  155. B18A1 More Power Lower RPM's.Possible?
  156. super charger or turbo?
  157. Any tips on where to search for a 95 SE?
  158. Double Exhaust
  159. South coast acura/subaru/imports event
  160. magnaflow exhaust brand new!!!
  161. Looking For Cars To Sponser
  162. Looking For Cars To Sponser
  163. 1991 Integra Parts, almost everything!
  164. peeling out
  165. Help me secure my secure my Type R
  166. 94 grs indiglo installation help
  167. parting out 94 teg LS sedan.
  168. Horsepower!!!
  169. Purchasing Tactics
  170. what RPMs should a teg idle at?
  171. How can i make my GS teg fast?
  172. cat back exhaust ?
  173. Is there a way to add scissor doors onto a sedan?
  174. about 15 miles of break in on my B20 so far, no more for a while, need teg parts?
  175. my car an Acura integra 97 gsr
  176. 95 Integra GS? is there a GS
  177. 89 Integra LS Wreck
  178. New Body Kit!
  179. vtec
  180. Audio upgrades in 2004 non s-type
  181. octane question
  182. Rotora Big Brake Kit - FS
  183. Injectors fail over and over
  184. tips on how to shave moldings
  185. O2 wire trick or drill tap for it?
  186. i/h/e question
  187. Some help please
  188. Might be getting a GSR!!!!
  189. Quick Question!
  190. Tanabe Exaust?
  191. DiY "Hyper Ground" system
  192. GSR vs. CRX
  193. cleaning out my head
  194. anyone know of a site for Sponsorship?
  195. ITR manifold, Spoon Throttle Body
  196. ecu pin outs
  197. anyone have a B series trans they didnt use that is for sale? even just the case??
  198. clutch adjustment question
  199. Alarm system
  200. estimate
  201. Should I buy a 2ndgen Integra?
  202. which should i get?
  203. MB Motoring wheels
  204. help
  205. Exhaust upgrade. 97' Acura Integra LS
  206. lowering question
  207. Motor Mounts
  208. Integra Sedan CatBack Exhaust
  209. Type R B16 cams for sale
  210. 94 ls for sale 1 of a kind
  211. Gsr-Crower stage 3 cams for sale
  212. ITR intake manifold vs. Skunk2 IM w/turbo setup
  213. Head Noise
  214. Vafc Install throws code
  215. My first teg.......... and i know i got a long way to go!
  216. Power Steering Pump Question
  217. Integra or GTI?
  218. gun metal integra
  219. b20 block
  220. 90-93: making half the taillight MORE white?
  221. how long before it'll rust?
  222. F*cking shopping carts! (story)
  223. lowering problem
  224. Generation 2 integra club?
  225. n/a power
  226. Poor throttle response after belt change.
  227. best cams for supercharged engine
  228. Cops broke my car! Story!
  229. installing springs
  230. Looking To redo my 1997 integra ls PLZ Help
  231. b18a/b18b?
  232. throttle body spacer
  233. high octane
  234. brake problems.
  235. Wings West Skirt for 2001 Gsr
  236. abs light
  237. Should I get SKUNK2 mega power exhaust?
  238. weird noise when i push gas
  239. injectors?
  240. which is a better spark plug: ngk iridium or bosch platinum +4?
  241. I got some water coming out of my tail pipe
  242. crank pulley bolt
  243. water pump ?'s
  244. best synthetic oil
  245. car insurance
  246. 2000 Integra Wreck, I need help
  247. Help
  248. How much would it be
  249. boost?
  250. my hatchback
