View Full Version : CL/Inspire/Saber/TL
Pages : [1] 2
  1. Condensate Drain
  2. 2005 acura TL navigation problems!!
  3. Crankshaft pulley slipping
  4. 97 acura 3.0CL check engine light
  5. How long do TL's usually last?
  6. acura cl-s 2001 Problem
  7. Oil Change
  8. 2001 Acura 3.2CL Timing belt replacement
  9. 96 2.5tl acceleration problems
  10. Big VSA PROBLEM on 03 TL-S
  11. 99 Acura 3.2 Tl-how To Clear Airbag Srs Light
  12. How to retrieve "Code" for Radio\CD Player
  13. 2001 TL Won't Start . . .Help
  14. 1997 Acura CL 3.0 Keyless entry question
  15. 2009 Acura TL Official Images and details
  16. Stabilizer Links
  17. Auto to Manual
  18. 2K Acura 3.2 TL Fuel Filter
  19. Cost of keeping the car
  20. 98 2.5TL Idle problems, please help
  21. 99 Acura 3.0 Cl Problems
  22. 1998 Acura CL Radio
  23. HELP!!!!! 97 tl
  24. 1998 CL EGR Valve
  25. New 02 sensor cables too short
  26. Door sills
  27. 2002-3.2CL State Farm totaled it - most of the car is fine (including vtec)
  28. Thinking Of buying a TL
  29. Timing Belt or Not
  30. EGR valve
  31. CL & TL Add on lip
  32. Bad Alternator? or bad batteries.....
  33. 2004 Acura TL
  34. OBD code
  35. Go synthetic or not
  36. 2000 Acura 3.2TL Question
  37. 1996 acura tl cd player swap after doesnt start
  38. 2003 TL S-type Radio code
  39. 2000 TL questions
  40. Help With Tl Lights
  41. what is ABS DTC 62 "ignition Voltage"?
  42. Acura Transmission Miles to Engine Miles..Need Help..!
  43. OBDII connection on Inspire '95
  44. Just bought 95 honda inspire. need info please
  45. 03 TL type S clicking in the dash
  46. 05 acura tl remote programming instructions
  47. considering a 2002 Acura TL 3.1
  48. Acura CL SRS light not on at all!
  49. Acura TL 2003 Remote keyless help to program
  50. help me find the wing for 97 TL
  51. electrical problem?
  52. 97 cl 2.2 trans replacement
  53. 05 tl clear headlight
  54. Power difference between 3.0 and 3.2?
  55. Rear brake piston is sticking, any help?
  56. Distributor O-ring change
  57. H.I.D.'s Burned Out???
  58. 96 TL wont start... wtf
  59. tl stockies weight
  60. Questions about a 89 preludeproject
  61. 04-07 Acura TL Rear Seat Removal?
  62. After market air cleaner
  63. After market air cleaner
  64. After market air cleaner
  65. Acura TL 3.2 Altezzas?
  66. 2003 tl3.2 ?
  67. help help help...
  68. 99 tl 3.2 watery tail lense.
  69. 1996 2.5TL blower motor problem
  70. 2001 cL swap w/ 2004 TL engine
  71. Painting Acura CL2.0
  72. Mods for CL Type-S
  73. Timin Belt problems
  74. Automatic Trans problem?
  75. Engine Stutter
  76. 1997 Acura CL fuse cover
  77. rebuilt title
  78. where is obd 2 connector
  79. Current gear Lightbulb replacement...on the dashboard
  80. timing belt change
  81. 3.2 TL Assistance Please
  82. Acura Cl radio code!!
  83. 05' Acura Tl Key?
  84. 2000 Ford explorer limited
  85. annoying noise
  86. lookin 4 parts
  87. South Florida Acura Meet
  88. 1997 acura CL 2.2 vtech Idle Loping Issue
  89. Clicking noise
  90. Clicking noise
  91. Clicking noise
  92. Clicking noise
  93. Clicking noise
  94. Clicking noise
  95. Clicking noise
  96. Clicking noise
  97. Acura Car Owners
  98. 2005 ACURA TL w/manual trans-DON'T BUY!
  99. Device to use while changing a battery
  100. Engine Light and ABS Light
  101. Handsfree kit
  102. How do you know if your battery is weak?
  103. Mid Grade Gas in an Acura 3.2TL Type S?
  104. Replacement Parts
  105. 1999 Acura TL
  106. 2005-06 TL..how do you like yours?
  107. 2002 TL-S remote & key
  108. 1997 Acura CL 2.2 EGR Valve Sensor bad
  109. 1st Generation Audio
  110. ABS and TCS Lights On
  111. '96 TL radio code??
  112. Spare Parts???
  113. differences between 2.2/2.3/3.0
  114. Seperating the forum: Giving the CL and TL each their own seperate forums
  115. 1st Gen TL fog lamps
  116. Waterleak into the trunk - 1998 TL
  117. Jsut got a 2000 tl any advice with mods
  118. Maintenance required
  119. ABS Light On
  120. 99 3.2tl
  121. 96 acura 2.5TL
  122. Acura CL vs Old Caddy
  123. Why not to buy an acura
  124. radio code
  125. Wiring Diag for 05 TL??
  126. Just curious of the kelvin rating on....
  127. 2001 acura cl ext paint color code please help
  128. 96 Acura TL 3.2 No Electricity going into the transmisson sub-harness connector
  129. What's That Smell
  130. aftermarket
  131. 99 TL idle rev 1000-2000 dies in gear
  132. low gas mileage on '97 cl 2.2
  133. 2003 TL v. TL-S
  134. carbonfiber hood for 98 acura cl
  135. 2000 tl a/c fan blower and compressor
  136. Does NE1 know where I can find info on how to fix ashtray?
  137. Vancouver BC Meet - July 1 11am
  138. 97 Cl 2.2
  139. Please help...1999 Acura CL 3.0
  140. 02 3.2TL-S odd noise - any ideas?
  141. Can anyone run carfax on this Acura?
  142. Programming keyless Entry for 2003 Acura
  143. '97 TL3.2 auto door lock
  144. Factory radio code?!?!
  145. acura cl 1997 srs and also cd error code
  146. 99 2.3cl intake noise
  147. 98 2.3 cl - fuel gauge problem
  148. Acura Tl
  149. 2.2CL Rear Suspension Question
  150. 2005 Acura TL vibration
  151. acura letters
  152. 97 Acura Cl 3.0 v6 Stroker Kit
  153. 02 Tl Tranny Question
  154. reset acura 99 cl check engine light
  155. HELP: 2000 TL HP gain
  156. Acura remote programming instructions
  157. looking to buy a 2002 tl . what 2 look out 4
  158. 99 tl aem short ram intake install
  159. aegean blue pearl paint code
  160. initial ignition timing advance possible?
  161. 99CL Engine Problem
  162. 3.2CL info please?
  163. Quarter mile performance for CL 3.0
  164. torque converter lockup solenoid
  165. EGR ISSUES on Acura CL 97 3.0CL
  166. Wanted 2004 stock TL wheels
  167. Moleskin for Tinted Windows
  168. 2003 TL brakes
  169. Project: Honda Inspire
  170. 2003 TL TYPE S mods
  171. 2003 Tl Type S Body Kit
  172. 96 3.2tl starter
  173. Whats The Diffrence?
  174. FORUM RULES AND GUIDELINES - MUST READ!!!
  175. Just finished timing belt & water pump install.
  176. Amp for stock Bose system?
  177. 2002 3.2 TL Type S
  178. No more CL?
  179. any good South Florida car clubs to join>?
  180. CL type S mods?
  181. TL Factory rims
  182. 1996 Tranny problems
  183. Used 99 TL
  184. Prices
  185. car won't start
  186. incorrect pin message
  187. 99 black housing headlight?
  188. Acura 98 TL 2.5 PROBLEMS
  189. cl headlights
  190. replacment bulb for TL HID
  191. Any clues?
  192. cold engine idle
  193. Is it the Starter?
  194. Where to buy?
  195. Looking for 02 TL type s rims
  196. Request for pricing info for '05 or '04 TL
  197. Resetting service options
  198. 03 3.2 CL tranny problems
  199. Cl recalls
  200. 03 Accord Coupe vs 02 acura CL
  201. 2.3 CL engine codes
  202. HELP! Car won't pass smog!
  203. P1259 VTEC Malfunction??????????????
  204. 2001 cl-s vs 2004 Mitsubishi Galant gts
  205. 2001 Acura 3.2TL Erratic RPM Problem
  206. Fourth Gear makes noise when you let off gas
  207. how do I program my garage door opener
  208. Acura 2.5 TL valve adjustment
  209. new problem for 01 acura cd has read
  210. Looking for 2.2CL Dash...
  211. Problems, problems, and more problems...
  212. h22 swap in the CL
  213. Repair manual?
  214. Racing Sparco Wheels
  215. Comptech parts...
  216. Opinions on the 04 TL
  217. Maint Req'd Light
  218. navigation
  219. Air Conditioning hissing noise! GGGRRRR...
  220. 1999 Acura 3.2 TL Passenger Airbag
  221. Transmission or throttle malfunction??
  222. Looking for performance shops in NYC
  223. 96-98 TLs-ABS and CHK ENG Lights
  224. 04 TL vibration
  225. Turning Off 2004 Acura TL Seatbelt Beep/Chime
  226. TL 2004 Ticking/Clicking Dash
  227. Should I by a 97' TL????
  228. honda accord....where is the fuse for the cig lighter and mirror adjustment
  229. Thinking about a CL
  230. Outside Temperature Not Accurate
  231. Updated Navigation DVD
  232. 2004 TL Rims
  233. 2004 Acura CL Type S prototype 300hp++
  234. Wheels on an '04 TL?
  235. fully built h22 turbo++
  236. 2.3 CL oscillating RPM - Possible valve problems?
  237. Guys Help
  238. NOS loaded J30 CL, 1st gen.
  239. New Navi DVD
  240. Cold air intake for 98 cl with the 3.0liter
  241. Distributor rotor for 3.0 CL
  242. 2004 acura tl seatbelt beeping
  243. Problem - Radio Resets and Loss of Memory
  244. Jspec Swap for 1997 2.2CL
  245. What do you guys think about the 2004 TL?
  246. 3.0cl VS 3.2cl
  247. Speaker Problems
  248. Supercharger for a 2.3CL?
  249. Body Parts for 3.2TL
  250. Up Grades
