Our Community is 705,000 Strong. Join Us.
Honda
> CL | Inspire | Saber | TL
View Full Version :
Pages :
1
2
P0401 Code of Bad EGR Valve
P0401 Code on Acura CL
Bubbles in Power Steering Reservoir
CL won't start!
Fuel Grade
Acura CL 3.2L intake?
no heat when not moving?
Power steering problem? please help.
2005 TL, weird noise comes from under the gear stick
Removing spark plug wires
DIY Timing Belt Replacement?
2000TL starting issue
Rear Brake Pads
A curiosity question: Car Performance
Acura CL 3.0 Check Engine Light P0401 error code
Need help with codes
Transmission Fluid Level
Alignment
TL Maintenace ...?
98 Acura CL 2.3 Window Regulator
HELP! 2005 TL Sputters Coming Out Of 3rd Gear
3.2CL Windshield Wipers Won't Shut Off
2000 3.2TL runs fine cold, not hot
2000 TL running rough intermittently
Thinking of getting a '01 TL
Windshield Wiper Problem
98 Acura front suspension
Acura Hydraulic Lifter
Condensate Drain
2005 acura TL navigation problems!!
Crankshaft pulley slipping
97 acura 3.0CL check engine light
How long do TL's usually last?
acura cl-s 2001 Problem
Oil Change
2001 Acura 3.2CL Timing belt replacement
96 2.5tl acceleration problems
Big VSA PROBLEM on 03 TL-S
99 Acura 3.2 Tl-how To Clear Airbag Srs Light
How to retrieve "Code" for Radio\CD Player
2001 TL Won't Start . . .Help
1997 Acura CL 3.0 Keyless entry question
2009 Acura TL Official Images and details
Stabilizer Links
Auto to Manual
2K Acura 3.2 TL Fuel Filter
Cost of keeping the car
98 2.5TL Idle problems, please help
99 Acura 3.0 Cl Problems
1998 Acura CL Radio
HELP!!!!! 97 tl
1998 CL EGR Valve
New 02 sensor cables too short
Door sills
2002-3.2CL State Farm totaled it - most of the car is fine (including vtec)
Thinking Of buying a TL
Timing Belt or Not
EGR valve
CL & TL Add on lip
Bad Alternator? or bad batteries.....
2004 Acura TL
OBD code
Go synthetic or not
2000 Acura 3.2TL Question
1996 acura tl cd player swap after doesnt start
2003 TL S-type Radio code
2000 TL questions
Help With Tl Lights
what is ABS DTC 62 "ignition Voltage"?
Acura Transmission Miles to Engine Miles..Need Help..!
OBDII connection on Inspire '95
Just bought 95 honda inspire. need info please
03 TL type S clicking in the dash
05 acura tl remote programming instructions
considering a 2002 Acura TL 3.1
Acura CL SRS light not on at all!
Acura TL 2003 Remote keyless help to program
help me find the wing for 97 TL
electrical problem?
97 cl 2.2 trans replacement
05 tl clear headlight
Power difference between 3.0 and 3.2?
Rear brake piston is sticking, any help?
Distributor O-ring change
H.I.D.'s Burned Out???
96 TL wont start... wtf
tl stockies weight
Questions about a 89 preludeproject
04-07 Acura TL Rear Seat Removal?
After market air cleaner
Acura TL 3.2 Altezzas?
2003 tl3.2 ?
help help help...
99 tl 3.2 watery tail lense.
1996 2.5TL blower motor problem
2001 cL swap w/ 2004 TL engine
Painting Acura CL2.0
Mods for CL Type-S
Timin Belt problems
Automatic Trans problem?
Engine Stutter
1997 Acura CL fuse cover
rebuilt title
where is obd 2 connector
Current gear Lightbulb replacement...on the dashboard
timing belt change
3.2 TL Assistance Please
Acura Cl radio code!!
05' Acura Tl Key?
2000 Ford explorer limited
annoying noise
lookin 4 parts
South Florida Acura Meet
1997 acura CL 2.2 vtech Idle Loping Issue
Clicking noise
Clicking noise
Clicking noise
Clicking noise
Clicking noise
Clicking noise
Clicking noise
Clicking noise
Acura Car Owners
2005 ACURA TL w/manual trans-DON'T BUY!
Device to use while changing a battery
Engine Light and ABS Light
Handsfree kit
How do you know if your battery is weak?
Mid Grade Gas in an Acura 3.2TL Type S?
Replacement Parts
1999 Acura TL
2005-06 TL..how do you like yours?
2002 TL-S remote & key
1997 Acura CL 2.2 EGR Valve Sensor bad
1st Generation Audio
ABS and TCS Lights On
'96 TL radio code??
Spare Parts???
differences between 2.2/2.3/3.0
Seperating the forum: Giving the CL and TL each their own seperate forums
1st Gen TL fog lamps
Waterleak into the trunk - 1998 TL
Jsut got a 2000 tl any advice with mods
Maintenance required
ABS Light On
99 3.2tl
96 acura 2.5TL
Acura CL vs Old Caddy
Why not to buy an acura
radio code
Wiring Diag for 05 TL??
Just curious of the kelvin rating on....
2001 acura cl ext paint color code please help
96 Acura TL 3.2 No Electricity going into the transmisson sub-harness connector
What's That Smell
aftermarket
99 TL idle rev 1000-2000 dies in gear
low gas mileage on '97 cl 2.2
2003 TL v. TL-S
carbonfiber hood for 98 acura cl
2000 tl a/c fan blower and compressor
Does NE1 know where I can find info on how to fix ashtray?
Vancouver BC Meet - July 1 11am
97 Cl 2.2
Please help...1999 Acura CL 3.0
02 3.2TL-S odd noise - any ideas?
Can anyone run carfax on this Acura?
Programming keyless Entry for 2003 Acura
'97 TL3.2 auto door lock
Factory radio code?!?!
acura cl 1997 srs and also cd error code
99 2.3cl intake noise
98 2.3 cl - fuel gauge problem
Acura Tl
2.2CL Rear Suspension Question
2005 Acura TL vibration
acura letters
97 Acura Cl 3.0 v6 Stroker Kit
02 Tl Tranny Question
reset acura 99 cl check engine light
HELP: 2000 TL HP gain
Acura remote programming instructions
looking to buy a 2002 tl . what 2 look out 4
99 tl aem short ram intake install
aegean blue pearl paint code
initial ignition timing advance possible?
99CL Engine Problem
3.2CL info please?
Quarter mile performance for CL 3.0
torque converter lockup solenoid
EGR ISSUES on Acura CL 97 3.0CL
Wanted 2004 stock TL wheels
Moleskin for Tinted Windows
2003 TL brakes
Project: Honda Inspire
2003 TL TYPE S mods
2003 Tl Type S Body Kit
96 3.2tl starter
Whats The Diffrence?
FORUM RULES AND GUIDELINES - MUST READ!!!
Just finished timing belt & water pump install.
Amp for stock Bose system?
2002 3.2 TL Type S
No more CL?
any good South Florida car clubs to join>?
CL type S mods?
TL Factory rims
1996 Tranny problems
Used 99 TL
Prices
car won't start
incorrect pin message
99 black housing headlight?
Acura 98 TL 2.5 PROBLEMS
cl headlights
replacment bulb for TL HID
Any clues?
cold engine idle
Is it the Starter?
Where to buy?
Looking for 02 TL type s rims
Request for pricing info for '05 or '04 TL
Resetting service options
03 3.2 CL tranny problems
Cl recalls
03 Accord Coupe vs 02 acura CL
2.3 CL engine codes
HELP! Car won't pass smog!
P1259 VTEC Malfunction??????????????
2001 cl-s vs 2004 Mitsubishi Galant gts
2001 Acura 3.2TL Erratic RPM Problem
Fourth Gear makes noise when you let off gas
how do I program my garage door opener
Acura 2.5 TL valve adjustment
new problem for 01 acura cd has read
Looking for 2.2CL Dash...
Problems, problems, and more problems...
h22 swap in the CL
Repair manual?
Racing Sparco Wheels
Comptech parts...
Opinions on the 04 TL
Maint Req'd Light
navigation
Air Conditioning hissing noise! GGGRRRR...
1999 Acura 3.2 TL Passenger Airbag
Transmission or throttle malfunction??
Looking for performance shops in NYC
Automotive Network, Inc., Copyright ©2013
