View Full Version : CL/Inspire/Saber/TL
Pages : [1] 2
  1. Acura Hydraulic Lifter
  2. Condensate Drain
  3. 2005 acura TL navigation problems!!
  4. Crankshaft pulley slipping
  5. 97 acura 3.0CL check engine light
  6. How long do TL's usually last?
  7. acura cl-s 2001 Problem
  8. Oil Change
  9. 2001 Acura 3.2CL Timing belt replacement
  10. 96 2.5tl acceleration problems
  11. Big VSA PROBLEM on 03 TL-S
  12. 99 Acura 3.2 Tl-how To Clear Airbag Srs Light
  13. How to retrieve "Code" for Radio\CD Player
  14. 2001 TL Won't Start . . .Help
  15. 1997 Acura CL 3.0 Keyless entry question
  16. 2009 Acura TL Official Images and details
  17. Stabilizer Links
  18. Auto to Manual
  19. 2K Acura 3.2 TL Fuel Filter
  20. Cost of keeping the car
  21. 98 2.5TL Idle problems, please help
  22. 99 Acura 3.0 Cl Problems
  23. 1998 Acura CL Radio
  24. HELP!!!!! 97 tl
  25. 1998 CL EGR Valve
  26. New 02 sensor cables too short
  27. Door sills
  28. 2002-3.2CL State Farm totaled it - most of the car is fine (including vtec)
  29. Thinking Of buying a TL
  30. Timing Belt or Not
  31. EGR valve
  32. CL & TL Add on lip
  33. Bad Alternator? or bad batteries.....
  34. 2004 Acura TL
  35. OBD code
  36. Go synthetic or not
  37. 2000 Acura 3.2TL Question
  38. 1996 acura tl cd player swap after doesnt start
  39. 2003 TL S-type Radio code
  40. 2000 TL questions
  41. Help With Tl Lights
  42. what is ABS DTC 62 "ignition Voltage"?
  43. Acura Transmission Miles to Engine Miles..Need Help..!
  44. OBDII connection on Inspire '95
  45. Just bought 95 honda inspire. need info please
  46. 03 TL type S clicking in the dash
  47. 05 acura tl remote programming instructions
  48. considering a 2002 Acura TL 3.1
  49. Acura CL SRS light not on at all!
  50. Acura TL 2003 Remote keyless help to program
  51. help me find the wing for 97 TL
  52. electrical problem?
  53. 97 cl 2.2 trans replacement
  54. 05 tl clear headlight
  55. Power difference between 3.0 and 3.2?
  56. Rear brake piston is sticking, any help?
  57. Distributor O-ring change
  58. H.I.D.'s Burned Out???
  59. 96 TL wont start... wtf
  60. tl stockies weight
  61. Questions about a 89 preludeproject
  62. 04-07 Acura TL Rear Seat Removal?
  63. After market air cleaner
  64. After market air cleaner
  65. After market air cleaner
  66. Acura TL 3.2 Altezzas?
  67. 2003 tl3.2 ?
  68. help help help...
  69. 99 tl 3.2 watery tail lense.
  70. 1996 2.5TL blower motor problem
  71. 2001 cL swap w/ 2004 TL engine
  72. Painting Acura CL2.0
  73. Mods for CL Type-S
  74. Timin Belt problems
  75. Automatic Trans problem?
  76. Engine Stutter
  77. 1997 Acura CL fuse cover
  78. rebuilt title
  79. where is obd 2 connector
  80. Current gear Lightbulb replacement...on the dashboard
  81. timing belt change
  82. 3.2 TL Assistance Please
  83. Acura Cl radio code!!
  84. 05' Acura Tl Key?
  85. 2000 Ford explorer limited
  86. annoying noise
  87. lookin 4 parts
  88. South Florida Acura Meet
  89. 1997 acura CL 2.2 vtech Idle Loping Issue
  90. Clicking noise
  91. Clicking noise
  92. Clicking noise
  93. Clicking noise
  94. Clicking noise
  95. Clicking noise
  96. Clicking noise
  97. Clicking noise
  98. Acura Car Owners
  99. 2005 ACURA TL w/manual trans-DON'T BUY!
  100. Device to use while changing a battery
  101. Engine Light and ABS Light
  102. Handsfree kit
  103. How do you know if your battery is weak?
  104. Mid Grade Gas in an Acura 3.2TL Type S?
  105. Replacement Parts
  106. 1999 Acura TL
  107. 2005-06 TL..how do you like yours?
  108. 2002 TL-S remote & key
  109. 1997 Acura CL 2.2 EGR Valve Sensor bad
  110. 1st Generation Audio
  111. ABS and TCS Lights On
  112. '96 TL radio code??
  113. Spare Parts???
  114. differences between 2.2/2.3/3.0
  115. Seperating the forum: Giving the CL and TL each their own seperate forums
  116. 1st Gen TL fog lamps
  117. Waterleak into the trunk - 1998 TL
  118. Jsut got a 2000 tl any advice with mods
  119. Maintenance required
  120. ABS Light On
  121. 99 3.2tl
  122. 96 acura 2.5TL
  123. Acura CL vs Old Caddy
  124. Why not to buy an acura
  125. radio code
  126. Wiring Diag for 05 TL??
  127. Just curious of the kelvin rating on....
  128. 2001 acura cl ext paint color code please help
  129. 96 Acura TL 3.2 No Electricity going into the transmisson sub-harness connector
  130. What's That Smell
  131. aftermarket
  132. 99 TL idle rev 1000-2000 dies in gear
  133. low gas mileage on '97 cl 2.2
  134. 2003 TL v. TL-S
  135. carbonfiber hood for 98 acura cl
  136. 2000 tl a/c fan blower and compressor
  137. Does NE1 know where I can find info on how to fix ashtray?
  138. Vancouver BC Meet - July 1 11am
  139. 97 Cl 2.2
  140. Please help...1999 Acura CL 3.0
  141. 02 3.2TL-S odd noise - any ideas?
  142. Can anyone run carfax on this Acura?
  143. Programming keyless Entry for 2003 Acura
  144. '97 TL3.2 auto door lock
  145. Factory radio code?!?!
  146. acura cl 1997 srs and also cd error code
  147. 99 2.3cl intake noise
  148. 98 2.3 cl - fuel gauge problem
  149. Acura Tl
  150. 2.2CL Rear Suspension Question
  151. 2005 Acura TL vibration
  152. acura letters
  153. 97 Acura Cl 3.0 v6 Stroker Kit
  154. 02 Tl Tranny Question
  155. reset acura 99 cl check engine light
  156. HELP: 2000 TL HP gain
  157. Acura remote programming instructions
  158. looking to buy a 2002 tl . what 2 look out 4
  159. 99 tl aem short ram intake install
  160. aegean blue pearl paint code
  161. initial ignition timing advance possible?
  162. 99CL Engine Problem
  163. 3.2CL info please?
  164. Quarter mile performance for CL 3.0
  165. torque converter lockup solenoid
  166. EGR ISSUES on Acura CL 97 3.0CL
  167. Wanted 2004 stock TL wheels
  168. Moleskin for Tinted Windows
  169. 2003 TL brakes
  170. Project: Honda Inspire
  171. 2003 TL TYPE S mods
  172. 2003 Tl Type S Body Kit
  173. 96 3.2tl starter
  174. Whats The Diffrence?
  175. FORUM RULES AND GUIDELINES - MUST READ!!!
  176. Just finished timing belt & water pump install.
  177. Amp for stock Bose system?
  178. 2002 3.2 TL Type S
  179. No more CL?
  180. any good South Florida car clubs to join>?
  181. CL type S mods?
  182. TL Factory rims
  183. 1996 Tranny problems
  184. Used 99 TL
  185. Prices
  186. car won't start
  187. incorrect pin message
  188. 99 black housing headlight?
  189. Acura 98 TL 2.5 PROBLEMS
  190. cl headlights
  191. replacment bulb for TL HID
  192. Any clues?
  193. cold engine idle
  194. Is it the Starter?
  195. Where to buy?
  196. Looking for 02 TL type s rims
  197. Request for pricing info for '05 or '04 TL
  198. Resetting service options
  199. 03 3.2 CL tranny problems
  200. Cl recalls
  201. 03 Accord Coupe vs 02 acura CL
  202. 2.3 CL engine codes
  203. HELP! Car won't pass smog!
  204. P1259 VTEC Malfunction??????????????
  205. 2001 cl-s vs 2004 Mitsubishi Galant gts
  206. 2001 Acura 3.2TL Erratic RPM Problem
  207. Fourth Gear makes noise when you let off gas
  208. how do I program my garage door opener
  209. Acura 2.5 TL valve adjustment
  210. new problem for 01 acura cd has read
  211. Looking for 2.2CL Dash...
  212. Problems, problems, and more problems...
  213. h22 swap in the CL
  214. Repair manual?
  215. Racing Sparco Wheels
  216. Comptech parts...
  217. Opinions on the 04 TL
  218. Maint Req'd Light
  219. navigation
  220. Air Conditioning hissing noise! GGGRRRR...
  221. 1999 Acura 3.2 TL Passenger Airbag
  222. Transmission or throttle malfunction??
  223. Looking for performance shops in NYC
  224. 96-98 TLs-ABS and CHK ENG Lights
  225. 04 TL vibration
  226. Turning Off 2004 Acura TL Seatbelt Beep/Chime
  227. TL 2004 Ticking/Clicking Dash
  228. Should I by a 97' TL????
  229. honda accord....where is the fuse for the cig lighter and mirror adjustment
  230. Thinking about a CL
  231. Outside Temperature Not Accurate
  232. Updated Navigation DVD
  233. 2004 TL Rims
  234. 2004 Acura CL Type S prototype 300hp++
  235. Wheels on an '04 TL?
  236. fully built h22 turbo++
  237. 2.3 CL oscillating RPM - Possible valve problems?
  238. Guys Help
  239. NOS loaded J30 CL, 1st gen.
  240. New Navi DVD
  241. Cold air intake for 98 cl with the 3.0liter
  242. Distributor rotor for 3.0 CL
  243. 2004 acura tl seatbelt beeping
  244. Problem - Radio Resets and Loss of Memory
  245. Jspec Swap for 1997 2.2CL
  246. What do you guys think about the 2004 TL?
  247. 3.0cl VS 3.2cl
  248. Speaker Problems
  249. Supercharger for a 2.3CL?
  250. Body Parts for 3.2TL
