View Full Version : GTRA / GTWS / GTS
- BAck to the Dyno! Ls1 update pics!
- oil coller in/out?
- Panoz # 211 Fires Up
- Reaction Time
- Steering shaft removal – anyone done this?
- Clutch Wear
- Switch Panel Help
- Fuel Cell Collectors
- paint help
- Daytona Track Event - Dec 4th - 6th
- Hedman Headers !!!
- "Economy" Axle seals from seals-it
- Dealing with crash damage
- Those who've installed a smaller fuel cell - which model/dimensions?
- 9" diff, differential, rearend tech
- Headers ...
- Hey eric1h
- Brake bias panel
- San Francisco SCCA Panoz results
- Is your rear differential silent?
- Why do my carrier bearings look like this?
- Maintenance/replacement schedule
- WTB: Good Car
- Dad getting chased by a modded C6 @ VIR w/ Mazdadrivers...
- Panoz finished 2nd in B Production and 10th in Group 10
- Is there a proper way to grease the upper ball joint?
- Driver side window Net mounting
- Left side wheel hubs have play, re-packing fix this?
- Bearing packing tool
- Today's results from VIR thus far...
- Chumpcar.com
- Racing at Road Atlanta with SVRA
- New GTS Owner
- GTS Rule Change
- Electrical Check on your GTS
- I am looking for 2 18" Wheels
- ALMS Pictures - St Pete 2009
- NASA VIR Oktoberfest - 10th & 11th
- Tarheel at CMP
- CHIN Event at Barber
- Panoz fastest in class in night practice.
- Another new owner...
- seat recovering
- Octane
- Exhaust hanger
- Fuel options on the GTS
- Don't call me superman - call it WTF
- Mass-Flo or FAST EFI for my new 408????
- 18" BBS wheels?
- Need info on burning a new chip for the 4.6
- Brembo Disk Bell Ring-Hub bolt Failure
- GTS Tremac Gear Ratios
- Anyone need a set of ABS/Fiberglass rocker panels??
- Anyone need ABS-fiberglass rocker panels? or spoiler uprights?
- Running Daytona in October, what kind of gear in the rear end?
- Just put my GTS on Ebay!!
- Trans aft oil seal part number???
- Rear Caliper part numbers?
- Coolant seep solved. What holds the rear brake pad pins in place?
- Crate Engine Options for CHEAP!
- WTB: Set of 17x9 BBS RKs (standard GTRA wheel)
- What are you running for coolant?
- Tires / Tire Vendors
- Traqmate Stuff
- Where to get the scew fasteners for the hood/trunk?
- The oil temp, oil viscosity, max rpm thread...
- 8 Panoz made the Chin Event @ R A
- Anyone ever have issues w/ the starter toggle switch? Question.
- Dumbest thing I've ever done at the track today @ VIR...
- Bad day on the dyno!
- Going to PAD tomorrow. Anyone want to come?
- Want to get new lugs... anyone know the tread/pitch?
- Traqmate install done... NACA ducts in. Need Traqmate help.
- Anyone running front and rear swaybars? What setting?
- Right Side Safety Net
- rally seat vs touring seat differences?
- Speed holes done... and a power plug for the Traqmate
- Need info on rear window
- Got the car back from VA Speed today... new catch can, adjusted valvetrian + gears
- db restrictions ???
- Barber Motorsports Park Oct 17 / 18
- Squerly, missed you today
- Saturday lunch at RA with Chin
- wheel info needed
- Those w/ a Traqmate... where'd you mount it? How'd you power it?
- Is anyone coming to the HSR event @ Road Atlanta next weekend
- GTRA engine # location
- Where to mount a NACA duct? Rear lexan? Will it pull air?
- HELP: Does the carb'd GTS motor use vaccum for crank case venting? Do I have to?
- For those Wondering, YES I am still alive!!!
- Good Weekend @ Road Atlanta
- No more hot feet, no more seeping valve covers!
- (2) GTS race cars for sale!
- New..to us..Panoz GTS
- Transmission Replacement Options
- brake pads
- No power to fuel pump?
- Need bolt hole locations for door hinge.
- Check out the 4 min mark :)
- Hood Ventilation
- For Sale Fuel Lines From WC car
- 2000 RA and race trailer for Sale
- Pictures of new Panoz model
- Anyone successfully use the PI dash to time laps?
- Lets talke gearing... wasn't using 5th at VIR at all.
- What size tires are you guys running on the 18" wheels?
- Much better weekend at VIR this go around...
- LS Engine is on its way
- Wanted 18" wheels
- Mufflers
- Panoz finishes 3rd in class @ R A
- Panoz GTS For Sale
- Anyone doing the SCCA event next weekend @ R A
- 3 days without a post
- 2006 Le Mans winning car
- Panoz returns to Road Atlanta
- Anyone changed rear end gears?
- Just in GTLM
- Jerico 5 speed
- engine specs for GT-WC cars
- new front wheel bearing PN#?
- Great seeing everyone at CMP!
- a view from the nose of the Panoz
- Carb throttle cable?
- GTRA Roadster
- Quickest way to pull the tranny?
- GTRA 347 Conversion Sump Questions?
- Bad weekend at VIR... oh... and how can I make this car quiet? (supertraps?)
- Fuel cell removal
- Tiny found , motor pending
- Rear brake issue
- Headers for a 408 stroker engine???
- Panoz WC Motor For Sale!!
- Panoz LMP Spyder link
- driveshaft u-joint size?
- Anyone running R6s or V710s?
- Anyone else remove your fuel cell pickup filter? Any issues?
- 765 Hp Nascar Engined Panoz?
- Woot!!! Got the Panoz in the GRM UTCC!
- I finally shook of the Newbie title
- transmission ID
- anyone know where STEVE tiny WHITE my money and motor are missing
- Show me your cool-shirt setup.
- Spare GTS engine wanted
- Got a bunch done today w/ my father... new tach, new fire system, hood pins etc.
- For you WC owners still with your 32V OHC
- Dominik Farnbacher Race Report
- Another souce for Parts, working on our cars and advice.
- Fuel tank foam replacement cost
- Outer "tie rod" end thread size?
- Converting my hood supports to hood pins... this thing won't move anymore!
- Any suggestions on changing the Throtle Body?
- brake light activation sensor
- AT THE TRACK: Need more front grip
- HELP: Need to replace the fire bottle... not having much luck
- Jerico for GTS
- NASA TTB Appendix B change for GTRA shocks
- driveshaft movement with suspension?
- What happens to a 5.0 block if you stress it to much.....................!!
- Puke in panoz!!!
- GTS U-Joints
- Anyone know how many Panoz RC/WC Cars were made?
- GTS Battery
- What tranny fluid?
- Panoz gts uncovered
- Cost to Convert to Carb
- Painting Plastic Cars
- Motor Mounts / 2
- Best place to attach engine hoist to a 4.6l?
- Rear End Oil Leak.
- Anyone look into legalizing/registering their GTX?
- I can't get the oil pan plug aft of the dipstick tube to stop seeping...
- Can you "jiggle" your rotor on the rotor hat?
- Anyone have pics of where you converted your hood supports to pins?
- Wing cracks ...warning
- Interesting Penske car photos
- 6 Hour Race Result
- Lets talk Lexan windshields and rear "glass"?
- GTx Roadster sneak peek....
- Engine and Trans For Sale
- Anyone replace the mustang coolant reservoir with something smaller?
- Anyone running NASA TTS or ST2?
- Hooray... GTRA/GTWC/GTS all approved for NASA ST/SU racing!
- Adding the adjustable brake bais setup to a GTRA? Pics? Easy? Help?
- Anyone know the guy from Alpharetta, GA
- GTx Roadster?
- Results from the Panoz Racing Seriers
- 6 Hour Car Prep
- Kevozzi51 how are you coming with your car
- Headers for the 4.6
- Power Steering pump oil overflow
- Crude but Effective to make 92 db
- Hey Dawfan
- Carb recommendations?
- Open up North !!!
- Special ThankYou Message to Gatorac
- I see there is a new panoz site.
- Need info on Penske Shocks
- Panoz School Seat Cover
- BBS rims and tires
- Carb Throttle Linkage options
- No one is at Roebling Road this weekend
- Anyone seen an internal hydraulic TO bearing?
- short video of eric and me at vir
- Solution to over-boosted steering feel.
- Tires
- "New" power steering rack anyone?
- Help with the feel of the Brakes
- One set of uprights left
- Panoz Trans Am car
- Tranmission input shaft 10 spline or 26?
- More Oil Questions
- Time to change the Oil
- A Tribute to Eric's Vinyl Work
- 4.6l belt tensioner
- 12 Hours of Sebring Pictures
- Sebering Panoz
- FARA Event April 4/5th Homestead Miami
- Sebring ALMS Practice Pictures
- Going to SCCA School
- Sebring pics Monday & Tuesday
- GTS car for sale
- Need Panoz logo
- Nasa ttb
- Side Window Installation
- 18" BBS Wheels with Hoosier's
- Panoz Chassis
- Brake pedal going soft
- V8stockcar Winter Heat PR
- Fiberglass Parts
- Clutch effort reduction fix
- Panoz Related Site
- Panoz Wins SCCA Double National @ TWS
- Squerly, What happened today?
- Mufflers or no mufflers?
- Tribal Wisdom
- Web site for Gary Jones
- Pagid Vs PFC Brake Pads
- Wheel rotational weight impact on performance
- Looking for a car
- I wrecked my car
- GTS Rotors
- Just bought #28 GT WC car
- Highly Modified GTS for sale
- Panoz mini-reunion at the ESM event!
- Inlet Manifold Gasket Compression
- Bob and or Glenn
- Missing Panoz...
- GTS deck lid problems
