View Full Version : Contour
- 98 Ford Contour overheating
- bad idle in gear, intermittent
- Camshaft Seal
- valve cover gasket?
- 99 2.0 Ford Contour
- 1999 Ford Contour Weird Blower Motor Issue
- 1999 ford contour no start
- 2.0L SES light, running lean
- Electrical issues, NOT fuses!
- Exhaust Pipe
- 2000 Contour/charging system prob.Need to solveASAP
- wire harness
- 2.0L timing belt issue
- No A/C No Heat No Blower 98 contour
- 95 bucking and kicking
- Trunk key separate?
- 1999 contour overhating thermostat has been changed
- AC not blowing cold
- no power through stock radio power wire
- 96 Contour GL, Blend door stuck
- 1999 contour idle problem
- 1999 Contour Turn signals
- 1995 Ford contour has no crank.
- How do you change the trunk support lifts on 98 Contour
- PCV valve on 1995 ford contour
- 98 Contour running on battery
- Help me figure out this A/C issue (video inside)
- 1995 ford contour Jerks when coasting in gear
- Cd4e
- Heater and AC fan problem, 2000 Contour
- Stalling Problems As Well
- Lets play "What am I?" // Part ID please
- Emergency brake light
- Towing with a 4 cyl
- Broken pully
- 98 contour surges
- making it LOUD
- A/C blend door stuck in defrost
- 98 contour 2.0 rear brake shoes retracting star
- Car cutting off randomly
- 1999 ford contour charging problems
- 98 contour auto throwing code 1383 again! @@ !
- 95 2.0 no power
- 98 Contour Codes P1131 and P0401
- 98 contour transmission problem
- 1998 contour
- 95 ford Contour rear strut
- Crankshaft Sensor 1998 Ford Contour 2.0L Auto
- Time to change my O2 sensors.
- P0420 and P0302
- O/D light,spdometer, tranny
- Airbag Light Flashing
- ABS Sensor cable location
- 99' Contour SE - Smells like exhaust inside my car!
- 1998 Contour SVT Problem: Cats and CEL: Please Help!
- Code/fix help please
- Muffler Replacement
- Service Engine Light
- Clock question.
- 99 Contour 2.0 oil leak + jerkiness + idle issues
- Noise from timing belt
- 1998 Contour Stalls when warm
- battery light
- Grounding question.
- Weird power door lock problem.
- Why won't my car shift? I swapped the tranny already!
- P0741 O/D light flashing
- Need a little water pump advice
- coolant fan running to loud
- how can i find out what options were installed
- Looking for dollar store lighters
- struts
- hho generator
- 1996 Ford Contour (Will only work in Reverse)
- 95 contour NO SPARK
- Running Cold
- 980 Contour 2.5l not getting fuel
- crappy brakes?
- 1998 2.0 Timming belt
- 96 Contour,automatic trans troubles.
- HELP!! Bad Alternator
- 96 Contour 2.0 automatic - stops while turning or when breaking at a stop sign
- 1998 Ford Contour Front Wheel Bearing Torque Specs?
- Oil Dipstick Broke off in Tube
- 1998 Ford Contour SVT starting on its own!!!!!!!!!!
- Wheel speed sensor trigger ring
- Looking for a tranny
- 95 Ford Contour Wiring Harness
- Swapped Tranny, No Fuel Pressure
- brakes lock up in reverse
- Car will not start... need help !!!!!
- 97 contour rattles on ignition
- Urgent, CV Boots
- Help... check engine ... no not starting!!!
- Help, check engine light on with driving problem
- 1995 Ford Contour Timing Issue..Help :(
- Downshift out of O/D
- got one around
- 96 Contour Bad Fuel Injectors -P0171
- Don't Know What To Do
- Power window problem
- 96 ford contour problems
- Rear door stuck 98 Contour
- 97 Ford contour fan
- 99 contour strut into steering knucle
- 97 contour knocking
- 99 Contour SE Cant remove A/C Line?
- 95 Contour V6 intermittent flashing check engine, temp goes on immediately on startu
- Urgent-95 won't turn over-PLEASE HELP!
- 1995 Contour tranny work in 1998 contour?
- 96 contour 2.0 over heating
- 95 Contour V6. Intermittant AC cooling ??
- Crash sensors
- timing
- Stereo and dash lights
- 98 2.0L DOHC no pwer in first gear idles rough.
- Water Pump Replacment
- IAC location on 97
- o2 sensor
- In need of Body Parts
- 97 Contour Vibrates and Shakes
- flashing airbag ligth
- PVC location
- 98 contour, will crank but won't fire
- MORE Pow Wah
- Front struts?
- 95 Contour not starting right
- A problem with the EEC module fuse in 95 tour
- Replace Wiper Motor
- I'm doing the atx to mtx. HELP!
- 2.5 SVT Won't Idle IAC?
- 2.0 z-tech timing belt , no timing marks ocrank pulley
- no heat
- 1998 Svt Front Bumper
- 1998 Ford Contour RPM High
- valve cover torque
- Oil pool at spark plugs
- Front door latch
- contour stalls out when put i n aforward gear
- Then there was the contour...
- 0171,0174 codes
- Where is the PCV on the '99 Contour?
- need help!
- starting car after accident
- up grades
- Windshield Wiper motor problem
- 98 contour 2.5l dohc misfire/rough idle
- 1998 Idiot lights
- Please Help... 1999 Contour SE Stiff brake pedal but idle is fine
- 2.0 to a v6 motor swap
- Bad Acceleration, then brake pedal Hard
- 98 motor swap to 96 2.0
- 1996 ford contour
- difficulty of installing L3 white face reverse glow gauges?
- 99 contour ignition removal
- 1995 Ford Contour shimmies
- 98 Ford Contour Speedometer intermittent
- 98 ford contour overheating
- 1995 contour stalling
- Lower engine air leak
- '99 Ford Contour- Died while turning and will not start
- 98 Contour Vacuum problem??
- Motor Swap Question
- 1998 Ford Contour Roughly Idling
- 1998 Ford Contour Loud Grinding Noise
- 1998 Ford Contour Coolant Light On
- 1998 Ford contour Parking Brake Very loose how to Adjust
- 1999 ford contour
- Just bought a 97 Contour
- 95 Contour Motor Mounts
- Contour SVT speaker size?
- 1998 contour ignition
- Why does my 2000 contour jerk?
- 97 Ford Contour Power Locks
- Belt squeaking now smoking??
- Cold Starting -- Engine Block
- ford contour 98
- 1999 Contour Sale for sale
- 99 Contour Alternator
- testing
- 1999 CSVT Any turbo/ supercharger kits?
- 99 svt
- Transmission done???
- Cant find DLC connector in engine compartment
- car dies when it shifts
- Overall satisfaction with Contour?
- Trying to locate a minor vibration
- Check Engine Light
- 1996 for contour
- 98 Contour Won't Start, Need Help Please
- 95' GL for 98' GL...i think...
- Duratech 2.5 rattling from front of Engine
- 1998 contour 2.0 Battery light flashing
- 2000 contour svt shift problem
- 1999 Ford Contour Tranny
- heater problem
- 98 contour 2.0 O/D light is flashing
- 96 contour turn signal problem
- Any Ideas ????
- 95 2.0 Severe engine miss
- AT Transmission Exchange 98 Contour
- 97 contour engine electrical problem
- stupid question
- 1998 Contour
- timing belt jumping
- Gearbox
- Oil pump issues ?
- Will my car make it?
- Right front caliper sticks
- 2000 Countour Power Loss Different
- Lights / Electrical - pulsate
- 98 stalling-different from the others i've read
- sputters under load
- 95 Contour V6 cooling Fans won't turn on
- Change Contour DPFE
- EGR Valve on 95 Ford Contour V6
- PFE sensor signal high
- Cleaning MAF on 1995 Contour V6
- Auto shifter suddenly became harder to select gears.
- 1995 Contour V6 engine light on
- 1995 Ford Contour V6 Fuel Pressure Regulator
- 1995 Ford Contour v6 engine light
- 97 contour trans
- 1996 Ford Contour PCV Valve
- 2000 Contour PCV valve 2.0l 4cl
- 95 Contour anit lock and traction lock issues
- sluggish fixed/alternator & battery isssues
- Overheating
- 95 Contour 2.0 Gl Wont Start
- Considering a contour svt, any advice?
- 2000 ford contour please help
- 98 Contour GL
- 96 2.0 contour wont start any ideas?
- Plz Help 1995 Ford Contour
- 98 contour electric problem
- 1995 Ford Contour Help Please
- 97 Fod Contour. Door/Lock question
- 97 Ford Contour A/C problem
- '99 contour 2.0 ohc power problem
- 98 contour se problem
- 1995 Ford Contour questions :)
- 96 Contour GL Alternator Question
- Please Help me 1995 Ford Contour
- 2.0 liter zetec
- have 98 contour with torque converter code
- please help with my contour transmission problem
- Starter woes!!!
