View Full Version : Contour
Pages : 1 2 3 4 [5]
  1. No forward or reverse
  2. Back with another question
  3. 99 Contour 4cyl
  4. TDC Location (crank pulley)on 99 Contour
  5. '96 Contour electrical problem/please help!!!
  6. Cleaning of MAF sensor?
  7. VCT Solenoid
  8. Neutral safety switch
  9. signal light replacement
  10. Mods
  11. Subwoofer Power cabel/Window Crank
  12. 1996 Ford Contour GL no spark HELP!!!!
  13. more questions
  14. serpintine belt replacement
  15. 95 Contour A/C Problem
  16. '96 Ford Contour
  17. ignition cylinder replacement
  18. i got a ques.
  19. i got an idle prob
  20. fixed "Need help contour 96"
  21. Need help contour 96
  22. '96 Contour cannot start(it doesn't crank at all)
  23. Here is a funny question
  24. car hard to crank and sometimes shuts off
  25. Intake Question for a 98 2.5L
  26. Ignition Module?
  27. Stupid Question from a pretty dumb person...
  28. Rough Idle Only in Drive - Neutral okay
  29. Will a Borla fit my countour?
  30. Car is Toast?
  31. speaker cover
  32. "EGR" Repair
  33. cooling fan on 95 contour
  34. What's wrong with my car?
  35. new rotors and pads
  36. 3rd Gear Grind
  37. Question
  38. Gas Gauge Issues
  39. please help!...
  40. Need Help!!!!!!!!!!!!
  41. car revs up by it self....
  42. 1995 cotour tranny prob.
  43. 96 Contour - idle fluctuates with a/c on...
  44. 98 ford contour(catalytic converter)???
  45. emergency break light sticking..
  46. Air Conditioning gone wack
  47. No tach.. can i put one on?
  48. Contour knock sensor
  49. 95 contour power steering cuts out
  50. 99 Contour SVT Cosmo Racing Short Shifter?
  51. 96 4cyl contour
  52. some electrical problems
  53. window lift motors
  54. why won't my ar cd player play any sound?
  55. water pump on 98 contour gl 4cyl
  56. 2000 Svt Need Info. On Brake System
  57. Wacky Contour Problems ~~ Help!
  58. 1996 2 liter 4cyl contour running hot
  59. 96 Ford contour w/Transmission Problem
  60. Heating Issues
  61. Installing Cruise Control on My ride
  62. Daytime Running Lights
  63. 1998 contour svt f/s clwr fl
  64. 98 E0 SVT Contour for sale in NC
  65. radio
  66. 98 Contour automatic transmission problems
  67. svt contour performance parts.
  68. Shimmy in 98 Contour V6
  69. All air blows from defroster only...
  70. O2 sensor larger question
  71. Ok, so where is it??
  72. oxygen sensor install
  73. '95 contour passenger side door needed...
  74. Air Bag Light code 41!!!
  75. 96 Contour Clear "Check Engine" light
  76. just spent 130 on a new stereo at auto zone
  77. 99' svt check engine light
  78. 1995 Ford Contour 2.0 auto tranny problem....ELECTRICAL? JUNKYARD?
  79. Installing Universal Oxygen Sensor
  80. svt stall problems
  81. Motor Knocking
  82. Replacement 02 sensors
  83. Moonroof Motor
  84. Code Meanings
  85. Need more Info on this code
  86. 1995 contour overheating
  87. 800 bucks for a break job?
  88. 96 Transmission
  89. one running board missing, o2 sensor
  90. svt contour
  91. SVT Tranny problems
  92. ignition off, engine still runs
  93. sensor Help
  94. trans help
  95. 1995 Ford contour GL tranny slip drive to overdrive please look...
  96. is this a good deal?
  97. Help temp gauge dont work 1995 ford contour gl 2.0l
  98. 96 Contour Stalls when normal temp
  99. Need strut assembly for a 1995 ford contour gl 2.0 dohc what cars would be applicable
  100. Bosch Plantium +4's goods/bads 1995 ford contour gl 2.0 dohc
  101. 98 tour zetec cat
  102. 95 contour transmission trouble
  103. What can I do with a Non SVT?
  104. Stereo System Wiring
  105. Wtb: Svt Uim
  106. Fan light and dash/gear selector lights
  107. '98 Contour GL
  108. Ford Stereo installation
  109. auto to manual
  110. Catylitic Converter Problem?
  111. 96 contour will not turn over
  112. Contour 95 GL Atx - Is it a transmission breakdown
  113. Anyone Know of some good speakers to put in??
  114. PCV Valve
  115. 98 Contour probs please help
  116. 98 Contour rough Running
  117. contour forum
  118. 1999 Se Sport Factory Amp or Harness Problem??
  119. blinking airbag light 95 contour
  120. 1997 Ford Contour Electrical Problem
  121. WTB: Stock Zetec Fuel Rail
  122. 1996 contour se
  123. MODIFIED SVTs
  124. Changing the PCV Valve......
  125. Performance
  126. Engine Swap
  127. Help.... Confused and Engine Running Crappy!!!
  128. New Website!!!
  129. Oxy Sensor/CheckEngineLight/Major gas Problem
  130. Help,,,,Engine codes obd1 type
  131. Where do I lift to set on jack stands?
  132. 99 contour amp problems
  133. 98 contour problems with idling
  134. brakes question
  135. 98 Contour overheating with new t-stat & w-pump
  136. Vortech Supercharger!!! $ Reward!!!
  137. Cold....won't start
  138. Left turn signal running too fast
  139. Programming Keyless Remote 00 contour
  140. Mods
  141. 1998.5 SVT For Sale. $5,500 obo.
  142. Miss at and just off idle
  143. Is this a good ideal????????
  144. Car won't start, Crankshaft Sensor?? How do you change this?
  145. don't quite know what I should do...
  146. getting codes
  147. HU install question
  148. TURBO KIT DUE OUT DEC 19th!!!!!
  149. 95 Ford Contour Fan Problems
  150. Fuel injector question(s)
  151. change spark plugs
  152. Electrical problem?
  153. Short range keyless..
  154. Help I need a SVT engine!!
  155. svt parts
  156. HI Doens't work
  157. remove / fix Driver side window
  158. Just Got A 2000 Svt!!
  159. Check Engine Codes ...
  160. fogged up headlamps
  161. 1998.5 SVT Contour for Sale
  162. Cooling System Problem
  163. Wtb: Csvt Pls Help Me Out!
  164. supercharged 2000 svt contour for sale!
  165. new car
  166. Oxygen Sensors
  167. Premium Sound Wire Harness
  168. Codes, Codes, CODES!!!
  169. fuel mileage
  170. Check Engine Light
  171. 95 SE Aftermarket CD Player Problems
  172. contour rear drum/rear strut causes loud clunkingg
  173. thinking about a vortech supercharger
  174. thinking about borla catbacks
  175. my new 99 contour svt
  176. 98 contour overheating?
  177. rebuilt engines
  178. contour SVT swap into a focus
  179. AOL screen name list
  180. Hud??
  181. Good First Car?
  182. what can you do to it
  183. Problems with svt??
  184. contour svt knocking
  185. Got Boost? Want some?
  186. new guy
  187. Carbon Fiber Steering Wheel
  188. My A/C only works on HI!!!!
  189. i want 98 cobra low mile
  190. website
  191. PowerStop rear cross drilled rotors for sale
  192. Svt
  193. Any One Know Where I Can Get Upgrades For A 96' Contour?
  194. BOdy Kit??
  195. 1995 taurus 3.0 engine
  196. 24 valve...are they benders?
  197. Blowers for $3150 plus shipping
  198. CONTOUR SVT's
  199. reason for no posts...
  200. welcome to this new board
