View Full Version : Contour
- what is better?
- Screeching
- contour w/codes p1131 & p171
- speakers
- battery won't hold charge
- Contour motor/vin number
- Contour temp unsteady
- Exhaust/Cold air or anyother suggestions?!
- 96 with check engine light
- 99 contour problems
- tachometer hook up?
- keyless entry programing
- losing power when going 65mph
- help
- where is the engine oil dip stick located in a 2000 contour 2.0L
- Water Pump Leaking
- Want to buy a contour
- transmision
- 98 ford contour
- 98 Contour hard shift 1st to 2nd.
- Newbie Here...
- check engine light code po136
- Stalling
- Head bolt torque.
- dead car
- Need to know how to wire a fan
- 96 Conour 'knocking'
- Changing head gasket and timing question
- stalling problem
- good bye
- 98 contour se getting code P1151
- 1998 Contour SE Air Bag Light Blinking
- Code P0708
- 95 contour, please help!
- temp gauge
- question
- Tire Rub or Suspension?
- Brake prob
- Dying car
- Check Engin Code P0401
- 95 contour
- What all do you need for a system
- maybe buying 1998 svt
- Bleeding brakes
- please help with this issue.
- System
- something is draining battery 1998 contour
- Timing Belt
- Buying SVT
- How to bleed cooling system, 96 Contour
- Svt
- Tires
- Lights
- 2000 Contour
- 1995 Ford Contour Won't Start
- 1995 alternator??
- Grinding Noise
- p0430
- Check engine light
- Wtf
- PCV Valve help
- 1996 contour need help
- 95 contour cruise control inop
- PLease help with 96 contour
- 98 countour won't start HELP
- 98 Contour grinding noise from engine
- Couple of Questions...
- wont start after installing new head gasket
- Rear Dash Pad Removal
- radiator fan install?
- Loud Fan Noise
- VCT Solenoid problem ??
- Newbie w/ Contour Issues
- 1997 Contour Idle
- '96 Contour battery problem
- 98 Contour GL possible transmission problem
- radiator
- Transmission Replacement
- '95 Intermitent Problem
- Recall information link
- 95' Contour Speed Sensor Code HELP!
- 1995 contour will not start
- 98 contour SE auto transmission problem?
- engine mounts
- HELP! my contour won't start
- 2000 2.0 contour engine
- i need easy power
- projector headlamps???
- 99 contour se 6cyl.
- 95 contour issues
- Reset Check Engine Light
- Engine ID 2000 contour need help
- Confused
- parts
- 96 Contour won't start
- in need of help
- what should I buy?
- 1999 Contour Lights / electrical problem
- Duratech
- Contour Problems
- Flasher Relay Clicking
- ?!?! Moosing sounds ?!?!
- 95 ford contour 2.0 for sale.
- 96 contour, changing plugs
- fixing vibrations in doors
- Gas Mileage
- how do i install headlights?
- No Brake Lights
- 95 Contour SE Engine Light
- tranny problems
- Sudden Loss of Power
- Alarm Wiring
- break lights
- installing power cable through firewall for amp
- My 98 Contour is garbage!!!
- 98 Contour Starting Problems
- intalling speakers
- air bag light blinking
- right directional not working
- Major Problems Please Help
- 2.0L Rough Idle Bad Throttle response
- Registration for Spring Zing 05 (May 19-22) is open!
- Ignition problems, please help
- 96 Overheating Problem
- weird heating problem
- New Engine help
- aftermarket upgrades
- '95 Contour 2.5L, Starter Replacement
- 1998 ford contour/transmission
- O2 sensors
- Front end issues!
- Rattling noise in front engine
- Rear Brakes
- rattling noise in rear-- suspension? struts?
- air bag deployed. car won't start now... like out of gas. Reset fuel pump? How?
- spark plugs
- 98 Ford Contour - ABS light on, No heater blower
- stereo installation(no acc on ignition)
- NO HEAT, LOW IDLE, CAR SHAKES, wINDSHIELD WASHER MOTOR NOT WORKING
- 1996 ford contour. courtesy lights flash on and off when turning wheel
- water pump difficulty level? 95, 4 cylinder.
- heater switch
- parking break light wont go off/lccks
- Starter 96?
- SVT Contour videos needed!!!
- 98 Contour SE No heater blower
- a/c clutch is "jingling"
- Looking to make a 2.0 Escort site
- ABS out when wet
- Transmission/Speed sensor Problem
- VIN # help
- new engine help
- 2000 Ford Contour rattling noise
- Turns off while in reverse
- 1998 Ford Contour Fuse Box
- For those that care...dyno results from yesterday
- beyondloadedSE quest
- Flasher replacement
- How to locate the paint code?
- Moisture in Headlight Assembly
- oxygen sensor
- Stalling 1999
- 00 Contour Airbag light stays on
- P0171 system too lean(bank 1)???????
- SCT Tuning Package Anyone?
- leaky fuel tank
- no heat from heater
- looses power when at half tank gas or less
- new cup holders for 98+
- changing break padds on a 2000?
- Trans fluid change
- Taking off the governor
- Blinking Overdrive light
- Intake
- Burning Plastic??
- 1996 Ford Contour starting and stalling problems
- engine light on "95 contour????
- Only 2 forward Gears
- Problems with Cold Start- Trans or Engine?
- shaking, really bad with AC!!! HELP!
- Rotor Problems. I can't remove them...
- bank1 oxygen sensor (by firewall)
- Scan Codes P1381,P0125, P1131
- 98 p 1131 code fix
- Gear Shift Problem...
- random switch
- air bag code 51
- no heat
- How do I use the overdrive?
- SRS Air Bag Warning Light Flashing
- EGR Woes Continue
- 95 contour constant high idle
- 98 ford contour question
- need help with transmission/mechanic
- No Turn Signals Or Blower Motor
- Code P040?
- P133 & P171 Codes on 96 Contour
- Thanks to Jesus...lol
- EGR and Cat "Check Engine" Codes
- Cyl 4 Misfire (Code P0304) 2.0 Liter. Stumped!
- Contour Hot and Jerky
- Trany Problem!
- OMG Guys help!
- 2000 Contour hard starting
- Still having problems....need help
- 95 SE question
- Stock AMP
- 98 Contour Trunk leaking
- 98 Automatic Trans Jumps between 1st and 2nd
- Wheel trouble 95 Contour
- Head Replacement Tips?
- Back on the road
- Upgrades
- Exhaust Question
- Remote starter
- Brake lights no working, 3rd brake lights is working?
- Traction Control - 98 SVT Contour
- Cold Start Problems with a 98 Bi Fuel
- Grrrr
- 98 contour SVT
- custom SVT one-off
- throttle cable
- Back with more questions
- Contour Stalling
- Seats
- P1131 Hell!
- overheating
- Check Engine Light - Need Advise
- Bolt on add ons?
- das anyone know how transmission range sensor works
- 1998 code P1131
- contour 96 automayic transmission
- brake pads
- SVT Contour or 300zx
- What to do to my Contour?
- 98 Contour SVT Catalytic Converter??
- 1998 Contour smoking from glovebox
- Inoperative Temperature Gauge
- 98 Contour Shuddering/Stalling/CEL
- 98 contour IAC LOCATION
- 1995 contour transmission jerks
- 96 Contour "Check Engine" light
- Breaks i cant get the dums on!!
- Buying SVT some advice please.
- 98 contour stalling
- 1998 Ford Contour
- Question on the driver seat
- 98 Contour 2.5 swap
