View Full Version : Contour
Pages : 1 2 [3] 4 5
  1. 99 ford contour 4 cylener
  2. 98 contour radio,remote mirrors,map lights not working
  3. 99 contour idling rough
  4. Help by looking under your hood...
  5. Flashing O/D Off Light means what???
  6. are there 2 different spark plugs in this engine
  7. warped dash help
  8. contour keeps dieing 95 contour
  9. How to replace spark plugs v6 2.5
  10. help
  11. Engine
  12. tcc sylinoid
  13. Help Finding and removing ABS Module
  14. Heater fan blowing fuses 96 Contour
  15. 96 zetec timing marks
  16. 98 4 cylinder SE Alternator removal - HELP!
  17. 98 Ford Contour ABS light-how to replace fuse
  18. 96 contour no forward gear
  19. 1996 Contour wont start either
  20. engine replacement
  21. blown head gasket
  22. 1998 2.0 4 Cylinder Clicking won't start
  23. a REAL screw up!!
  24. 1999 Contour SVT- Catalytic Converter
  25. For Sale: Zetec head $95 Free Shipping!
  26. brakes 2000 contour SE
  27. 1995 4Cyl 2.0L Acceleration/Idle Problem
  28. 98 2.5L Idle Problem
  29. Need 96 Ford Contour 2.0 Timing marks
  30. 96 v6 contour surges
  31. Car Wont Start
  32. 96 Contour SE
  33. Idle Air Control Valve?
  34. Side View Mirror
  35. how do you replace tp sensor on v6 contour
  36. 96 contour motor ?
  37. Heater Core in Contour
  38. 98 contour random misfire help
  39. timing belt guides/idlers on 1996 contur 2.0 liter
  40. 96 contour v6 giving codes
  41. how much to replace headgasket?
  42. Fan Noisy
  43. 98 contur problem with belt keeps breaking PLEASE HELP!
  44. 1999 Rough Idle Problem
  45. Stalls/Rough Idle in Cold Weather
  46. IAC Valve.
  47. 96contour will not start
  48. swapped out engine
  49. Strange Idling Issue with 98 Contour
  50. tail light 1995
  51. 1995 ford contour want start
  52. 1996 Contour hard on fuel
  53. National Spring Zing 2006 SVT Contour Meet
  54. P0304 code, rough idle, better since code
  55. Turbo
  56. have to depress accelerator to start 95 contour
  57. Melted vacuum hose destination
  58. how to fix my wiring harness?
  59. Anyone live near pontiac Mi want to replace a timing belt?
  60. Timing belt/water pump installation - What did i do wrong?
  61. Battery Light Flicker & illumination
  62. Turbo for a Contour?
  63. Timing Belt Replacement Cost and Labor
  64. timing belt- what did i do wrong?
  65. timing belt- what did i do wrong?
  66. Broken cam/timing chain and I need a new engine???
  67. 98 Contour Duratec v6, Stalls at idle
  68. 1995 Contour tansmission
  69. 1995 Contour fuse layout
  70. 96 contour stalls, looking for filter.
  71. battery wont hold charge
  72. Contour 95 SE, need replace wiring harness?
  73. 97 contour (instument panel no lights)
  74. 95 Ford Contour 4cyl help please
  75. wont shut off, help!!!!!!!
  76. Pls Help is it the tranny ???
  77. A/t Transmission Problem
  78. svt contour catalytic converters
  79. Okay, it's not the VSS.......
  80. need BIG help
  81. Lumpy idle and bogs down at 4000rpm
  82. won't start
  83. ideas!!! plzz
  84. 2000 contour se 4cyl
  85. probs(please help)
  86. Water pump working?
  87. 96 Contour Overheating
  88. window
  89. just want to hear
  90. intake runner
  91. more probs (please help)
  92. rims
  93. my 1999 contour se
  94. need everbodys help
  95. 95 ford contour problems (please help)
  96. 1996 Speaker Size?
  97. 95 Ford Contour Stalling
  98. check that... I need a 2.5
  99. 94 countour starts then shuts off
  100. 2.0 Timing Marks
  101. 1998 Contour overheating
  102. Need To Find An Engine!!!!
  103. 96 Contour Flasher clicks anytime key is on
  104. 96 Contour right turn signal
  105. Steering Wheel Vibration (shake) Contour 97
  106. contourRadiator fan wont come on
  107. 97 starts, then stalls
  108. Speedo Stuck at 60kmh
  109. Speedometer Falure
  110. 95 mtx contour won't go; throttle cable or traction control?
  111. 96 contour intermittant no spark
  112. Rotors
  113. how to change the engine mount insert
  114. loud noise in rear
  115. 1998 Map/Interior light
  116. Contour SVT vs V6 Camaro
  117. 95 Ford Contour, 2.5 Automatic Trouble starting in cold
  118. speaker wiring diagram
  119. car problems, it won't move (even in neutral)
  120. electrical Problem
  121. wheel bearings
  122. 1998.5 contour svt catalytic converter
  123. 4 Sale 2000 Contour SVT 62K miles tons of mods $6400
  124. Same problem, new twist.
  125. Fuel Tank Door
  126. transmission or something else?
  127. Exhaust 97
  128. Sunroof won't shut... HELP!!!!
  129. 99 Contour SE's motor mount
  130. Re-set Fuel Pump
  131. 95 Contour 2.0L Lost speedometer,cruise,Overdrive
  132. Replacing engine
  133. 1999 ford contour no brakes
  134. 2000 contour code problem
  135. Odd idle from 98 2.0
  136. Broken Tep guage
  137. 98 contour transmission? need help plz
  138. MAF Sensor problem, 1995 Contour GL, 4cyl
  139. Wet Carpet
  140. 98 2.0L Vtec timing belt issue
  141. help
  142. 1998 contour SVT 4 sale
  143. 2000 Contour dashboard coming unglued
  144. Idle issue. Underhood wiring
  145. 97 Contour Vaccum Line Layout
  146. Oxygen sensor - which one?
  147. 98 Ford Contour 2.0L 4 cyl
  148. 98 contour se timing specs???
  149. Replaced PCV valve, now won't start
  150. 95 for contor wont start.
  151. Battery, air bag, parking brake, and ABS lights.
  152. missing belt
  153. Help Needed
  154. 1999 Contour SE turning over
  155. trany problem
  156. 98 contour 2.0 zetec need help please
  157. 1996 Contour Clutch problem
  158. 98 Se Tranny
  159. running hot
  160. 1995 Ford Contour
  161. Highway Hesitation or Jerk
  162. run hot when AC is on
  163. Buy Used Fuel Pump 00 V6 Contour
  164. please help
  165. 99 contour trans prob
  166. 2.0 DOHC motor timing belt/crank problem
  167. contour makes weird rattling noise...HELP
  168. reasonable price for a 1999 ford contour
  169. Can't get door panel off!
  170. water in oil ?
  171. adc turbo
  172. 1999 contour trans/speedo problem
  173. lookin for a supercharger for a 1995 contour 2.5L V6
  174. sparkplug gap
  175. Over heating Contour, any ideas...???
  176. overheating
  177. stalling car....HELP!!!!!
  178. 96 contour problems
  179. 98 Fuse for Courtesy lights
  180. leaking oil pan
  181. 99 Contour stalls
  182. '98 4dr Speedo & Fuel Gauge Quit At Same Time?
  183. Variable cam timing overretarded bank #1
  184. '95 - no cruise control, jumping gears, chk engn lt
  185. I4 timing belt
  186. 98 ford contour gl 2.0lt
  187. Fog light relay
  188. computer
  189. dies @ stoplight, idles rough
  190. New engine and mounts?
  191. Wheel bearings
  192. Thermostat
  193. ford contour overheating
  194. AC recharging
  195. where is the flasher on my contour located?
  196. Code P1518
  197. A/C Compressor Replaced
  198. 1998 Ford Contour Fuse Diagram
  199. 98 Ford Contour engine mounts?
  200. 98 Ford Contour engine mounts?
  201. 98 Ford Contour engine mounts?
  202. heater fan only works on high
  203. a/c - blowing only through the defrost vents
  204. running hot
  205. please help
  206. 98 Contour ventilation problem when it rains
  207. Air Bag light Problems
  208. Weird 98 ATX Problems
  209. 2 Problems Here, Getting Hot and hearing 5 beeps
  210. 98 contour 2.0 zetec
  211. Timing Belt
  212. Transmission screwed??
  213. Transmission Filter Installation - 95 Contour GL
  214. 1998 contour overheating
  215. Multiple water pump replacements - 95 Contour
  216. '97 2.0 running hot
  217. Heat/AC only works on "High" setting '99
  218. contour 95 clutch change
  219. 98 Contour 02 Sensors
  220. 98 Contour won't turn over
  221. Fuel Tank problem
  222. Brake light problem
  223. door panel problems
  224. What do you think is faster??
  225. Help Please Alternator Horror
  226. no more 96 contour
  227. 2000 engine in 95 Contour?
  228. Oxygen Sensor
  229. 95 Contour SE Odd Trouble Codes
  230. another coutour running hot
  231. 98 Contour Lights "pulsating"
  232. Is the 5spd mtx trans any good?
  233. 98 contour running hot
  234. Fuel tank cover
  235. A/C & Heater fan function
  236. staling on start
  237. 95 Contour won't start all of a sudden
  238. slipping clutch or fuel filter?
  239. Used Contour
  240. dropped in an engine and no start
  241. 96 Contour. Detailed explanation.
  242. 95 contour help
  243. CD Player
  244. HELP!! Whirling Noise!!!
  245. '95 Contour LX power questions.
  246. 96 contour 2.0L, Bad idle in drive,like everyone else, any answers yet?
  247. what is better?
  248. Screeching
  249. contour w/codes p1131 & p171
  250. speakers
