View Full Version : Contour
Pages : 1 [2] 3 4 5
  1. power hesitation after 3000 rpm
  2. Rear disk brake - 95 Contour
  3. 95 Contour Electrical
  4. please help with my 98 countore
  5. What is the normal temp reading on the 98 contour?
  6. 98 idling and braking rough??
  7. 98 Contour Help.
  8. 99 contour.... HELP
  9. '99 Contour in serious trouble, dont know what else to check
  10. 98 Contour running hot - not overheating...
  11. Squeaking under the hood??
  12. missing power
  13. Engine Seizes with starter installed
  14. fuel filter on 95 contour
  15. 1997 Countor engine cooling fan fuses
  16. Spark Plugs and Wires
  17. SVT Bumbers and Sideskirts??
  18. Svt Engine Rebuild/ Replacement???
  19. Back-up light switch
  20. 95 Contour Electrical Issues
  21. code 172 system lean on 95 contour 2.0
  22. 2000 contour using lots of oil smoking sometimes
  23. Engine stutters after timing belt changed
  24. ford contour 95
  25. New SVT engine in, but have 2 engine codes popped
  26. Ford Contour Alternator Location Possible Problem
  27. 99 contour stalls when warms up
  28. 98 contour vacuum problems
  29. Nitrous for my contour svt
  30. O/D Rough Shift
  31. 99 SVT transmission gears not engaging
  32. 98 Contour Blower Motor Fuse / Relay
  33. motorcraft spark plugs for 1995 2.5 liter 6 cyl contour
  34. Temp switch
  35. 96 Sport, sucks gas, idles rough in drive
  36. 1996 Contour Tranny Elec O/D - Blowing PCM maxi fuse
  37. 1995 Contour head gasket kit...
  38. Haders?
  39. Look for the TSB on VCT service
  40. Power Steering Fluid
  41. Stuck brake rotor on 98 drivers side
  42. power door lock problem
  43. '98 Contour LS w/ bad tranny
  44. 1999 Ford contour auto transmission leak
  45. 1999 Ford contour AC evaporator where is?
  46. 99 contour speaker install problem
  47. New intake now "new problem"
  48. 97 Contour squeeling noise when put in drive
  49. How to take off 99 contour door panel
  50. What mufflers for my contour svt????
  51. Is the 95 Contour prone to cracked heads?
  52. still haveing prbs with the 95 contour
  53. 95 Contour: Antifreeze won't go into block...
  54. fuse box question
  55. trans comes out of the gear
  56. 1995 Stalls...in motion
  57. Little info big problem
  58. 00 Contour STALLS AND STARTS RIGHT BACK UP
  59. I need more!!! Running out of MOD ideas for my SVT HELP!
  60. 95 ford contour 2.0 code 335 KOEO, code 336 KOER
  61. 1999 Contou SVT performs worse with TruBendz Y-pipe, Help!
  62. having erk & gerk problems with my 95 2.5 contour
  63. ABS pump failure - truth or BS?
  64. '99 tranny fluid check?
  65. 95 2.5 ovreheating when I can keep it running...HELP
  66. Al's Weekly Car Review!!
  67. "SVT on Steroids" MM&FF article
  68. 1995 ford contour 2.0 timing belt change
  69. Air Conditioning Pressure Switch Connector (99M03)
  70. How much $$ to Install a Trubendz y-pipe?
  71. 2000 Contour SVT specs
  72. no fire
  73. CD player/Speakers not working right
  74. 2000 Ford Contour
  75. loss of power
  76. Help!1999 Ford Contour ABS replacement cost?
  77. 99 CSVT missing under acceleration
  78. 95 Contour gl turbo
  79. 95 COntour parts
  80. manual tranny problems
  81. contour died
  82. MSDS Headers - Presidents Day Sale
  83. Performance tires on the csvt any suggestions?
  84. Back up lights stay on
  85. flashing airbag light
  86. Power Steering Leak
  87. 99 Contour 2.5L Question!!!
  88. 96 contour check engine light
  89. Timing Belt Issues
  90. Tru Bendz catless y-pipe good investment??
  91. Car will not start
  92. 99 contour svt running VERY ruff new cold air problem?
  93. Engine Problem?
  94. Stalling to not starting at all
  95. Thinking about remote start
  96. Check engine light??? 99 Contour
  97. Need used pass R headlight assy 98 SE
  98. 98 contour electrical problem
  99. contour.org site down...
  100. 99 ford contour tail light
  101. 1999 v6 struts
  102. do contour have timming belts?
  103. 98 contour trans spew out dipstick hole
  104. yet another question
  105. 95 Contour with blown head gasket for sale $400
  106. 96 contour problems
  107. Too Lean Air/Fuel mix
  108. 95 Contour with blown head gaskets for sale $400
  109. 98 ford contour
  110. 96 4 cyl making noise turning left
  111. 2000 contour brake lights wont go off
  112. Running out of mod ideas!
  113. 1998 contour electrical problem
  114. 1998 Door won't unlock
  115. 2.5L DHOC- timing chains and crank shaft
  116. 98 contour 4cyl starts and stalls
  117. Looking at '00 Contour SE Sport
  118. 1995 Contour won't start unless i disconnect battery then reconnect
  119. Flickering Lights
  120. Flickering Lights
  121. contour svt 3.0 sable/taurus swap
  122. contour svt fast or flop?
  123. 95 Contour SE 5 speed Electrical Problems
  124. idle problem!!!
  125. Jet chip for 1999 contour svt??
  126. transmission sporadically downshifting
  127. Need Serious Help
  128. 99 contour svt cold air intake???
  129. 1995 Ford Contour AC/Fan/Belt/Timing
  130. Hard starting and flooding. but many new parts
  131. i neep hp
  132. 96 Contour GL loss of power when wet (Battery)
  133. exhaust smells of sulfur, 96SE
  134. lost
  135. Speedometer quit working
  136. 1999 contour, hummm noise
  137. 98 contour running rough
  138. 98 contour
  139. '99 Contour LX
  140. 4 lug rims
  141. engine wont start
  142. Iac
  143. qwik question
  144. 96 zetec Bad pcm again?
  145. 96 Ford Contour Gear Shift Console
  146. Running lights dont work!
  147. ABS light and no power
  148. Countour stalls?
  149. Okay, I need some help
  150. 96 Ford Contour Vehicle Speed Sensor
  151. Basic 4 Cylinder 2.0 Engine - Interference?
  152. lugging problem
  153. wiring
  154. Mega Fuse Where?
  155. contour tranny problem
  156. Custom HVAC, Headlight Knob, and Gauge Faces
  157. Mount under air filter
  158. in need of a couple parts
  159. 98 running hot
  160. 1999 Ford Contour Fan relay
  161. 98 contour -- a couple problems
  162. what size?
  163. Fuel filter?
  164. Update - 98 Contour Reprogram Keyless Entry Transmitter
  165. ac and heater problems
  166. freedom at last!
  167. 98 Contour Reprogram Keyless Entry transmitter
  168. 98 Contour AC Compressor!!!!!
  169. 97 contour 2.5 Cam Chain tensioner question
  170. Very lost....
  171. im having alot of problems with my contour
  172. Battery light problems..
  173. 1998 vtec no start
  174. Help
  175. crakshaft bolt
  176. problems...1-10
  177. wiring diagram 96 zetec
  178. 96 contour zetec no spark
  179. 97 engine R&R
  180. 95 Ford Contour V6 with transmission(?) problem
  181. lack of power, rough idle
  182. Weird noise in cam....
  183. wheels and tires
  184. How to Remove cam Pully on 2.0 Z-tech that has oil&spring sprocket
  185. 1996 ford contour won't start
  186. parting out 1998 ford contour sport!!!!!!!!!!!
  187. problems with cONTOUR
  188. Fog Light Relay rewiring for fogs on...
  189. 2000 Contour automatic stutters/dies when gas is low
  190. crankshaft sensor problem ?
  191. 98 contour keeps stalling
  192. 99 contour backup lights
  193. 99 contour v6 runs rough and burns tons of gas
  194. trunk light 2
  195. '97 Contour GL, 2.0L, Manual, 4-Cyl, 140,000mi
  196. Clutch is shot on SVT?
  197. 98 Contour A/C Fan Died
  198. trunk light
  199. Dead 99 SVT HELP
  200. Couple problems
  201. Dire need
  202. aftermarket performance parts?????
  203. Turbonator---Worth the 130
  204. A few problems...
  205. Used Contour Sport
  206. Tire Won't Spin
  207. Car keeps stalling unless given gas
  208. my first car
  209. where is the pcv valve and how to I change it 95 contour
  210. 2.5L V6 Stalling in Cold Weather Sollution
  211. Various Problems with contour
  212. Brake Job (Drums)
  213. 95 contour turn signal relay
  214. 2000 Contour
  215. Speaker Replacement
  216. '95 2.0 idle prob
  217. 1997 Contour Transmission Problems
  218. cigar lighter wiring
  219. car speakers
  220. ABS Brakes Help!!!!!
  221. 97 trans problem
  222. Fuel pump problems
  223. Starts but then stalls instantly ???
  224. 2000 contour se won't start
  225. got a few issues
  226. Brake question
  227. 1997 contour blowing pcm fuses
  228. 99 ford contour 4 cylener
  229. need parts
  230. 98 V6 timing belt or chain
  231. need some help
  232. timing belt eater
  233. Coolant
  234. What the crap?
  235. Starting Problem
  236. '95 Contour. Diagnostic codes???
  237. 96 contour for the guys that know about codes
  238. 95 Ford Contour-running hot, can you prevent blowing a head gasket
  239. Parts for you
  240. 95 Ford Contour
  241. Lights
  242. 98 contour v6 throttle cable. please help!!
  243. 95 contours pleas help
  244. back with questions about the 96 contour
  245. 95 Contour GL with 2.0
  246. Looking for "beyondloadedSE"
  247. Accesory belt Replacement on 98 2.0,,AAARG!!!!!
  248. newbie
  249. performance
  250. 96 contour ticking noise
