View Full Version : Jetta/Vento/Bora
- Oil Pan
- Outside Door Rubber Strips
- Decided Loss of Power
- Oil Change questions
- New parts fo engine??
- Cold Air Intake comparisons??
- Recharge A/C
- P1582 Malfunction Vehicle speed control
- Catalytic Converter HELP!
- Check Engine Light
- wheels
- Temp gauge occasionally works
- Radio Replacement
- Rear Seatbelt
- best exhaust system for price/performance?
- How do i replace the gauge lights?
- Alarm problems
- Can't get Jetta out of PARK
- dirty seats!!
- Does the monsoon stereo have pre-outs??? for amplifiers?
- Tool T10029
- HeadLights
- Jetta - Panasonic CD Changer
- mkiv REENFORCED ABD 28mm Rear Sway Bar For Sale - works with H&R Coilovers too!
- jetta bumper
- long cranking (starting) time
- Increasing Jettas power
- Engine Swap...
- strange vibration/new member
- jetta III cruise control
- What Is This Noise !!!!!!!!!!!
- Jetta security system
- P1582 Engine Code...???
- Knocking from under Carriage VR6 Jetta
- Turn Signal Issue...input highly appreciated!
- i have a wipers problem!!!!
- turbo bypass valve
- harness disconnected, somewhere
- Jetta MK2 Gas and Temp Gauge Problems
- Trek vs GLS, etc.
- Trunk button & cruise control
- advice on buying a jetta
- looking for factory recaros
- Wiring or what?
- Ebay listing for Full Bolt on Front end conversion of GTI
- Need some help please
- pimping out a jetta
- ricer questions
- plans
- jetta gli
- Subs
- Some noises...
- Jetta transmission problem
- Need Quick Help, how to can I pull codes from '91 Jetta? (GAS)
- calling all jetta experts..
- help!
- Power trunk problem
- Insurance Question and vr6 comparison
- Trailering on a Jetta
- 2000 jetta lowered question - steering shakes -
- jetta radio code
- major problems
- FS: LED dash sitches, red or blue
- Chips
- Turbo for my VR6
- Tire Size
- Jetta Pricing
- exhaust??????
- terrible mileage
- beeswax
- moisture in trunk
- Headlights
- Power Lock Motor Keeps Running
- Battery and Alarm Problems
- new tires
- RPMs jump when shifting
- Brakes and the ABS and E-brake lights
- Which is better? Supercharger or Turbo??
- performance mods and chip questions
- Brake Chime driving me NUTS!!!
- my car
- alternate blinker colors????
- header
- Wiper/Fuse Problems
- Cap and Rotor Replacement Question
- Jetta alarm prob.
- I need help!!!!!
- Intake Kits-need help choosing!
- Audible oil warning signal, and oil light
- Tire Wear
- Can I disable my mk4 factory alarm???
- Heater core? Thermostat? Recall?
- OBDII cannot find codes
- dash lights
- will after market intake really kill MAF???
- Need some help
- Removing Breather T-Connector
- Cat back system
- VR6 oil pan torque specs.
- VW dealer Q&A session: has this guy lost his mind?
- 97 Jetta: Protective Shield in Wheelhousing Noisy
- temp light and stalling????
- I need more power!!!
- tail lights
- transmission
- Performance Chip Questions
- Wipers stopped wiping
- weird sound from engine bay (sound clip)
- ft susp?? strut problems
- Electrical???
- Where to go to find out about Recalls?
- Lower clutch pedal
- What springs to pick.....
- GLX VR6 For Sale- Immaculate VW
- starter problem, and turbo question
- Full of shit?
- Modfied Jettas any type
- leak detection pump - evap emmisions
- Alarm
- Drive Cycle
- anyone use the K&N air filter on your VR6?
- anyone looking for LED's
- Do I need to remove the intake manifold to change Spark Plugs?
- battery drain
- gauge cluster
- can't get tranny into gear
- tail light problems- HELP!
- burning up blocks
- sites & links
- Help me purchase a performance jetta!
- Reliable? Class Action? Anyone?
- TDI Acceleration Problem
- speedometer
- Jetta TDI
- Jetta GLS Speeometer Problem
- F/S: 18' rims & Tires
- VR6 Engine Turns But Wont Start.
- Thick white smoke
- probs with my VR6 ( Diary )
- european oil for european car?
- I can't figure out my high idle speed?!?!?
- Radiator fan only comes on if I turn on the A/C or Heat!!?!?!
- When to Change the Transmission Fluid?
- CV Joint Problem??
- CD player problems
- Disengage ext. handle from operating bar
- tricking my MAF sensor..Please Help
- Question about Motor Oil
- Removing Door Panels on 96 Jetta
- Lock Cylinder plates
- M3 Spoiler
- block damaging intake 1.8t
- GTI Full Front End Converion/body kit for sale
- Automatic tranny in VR6 started to hang in gear occassionally, ideas....???
- speaker install
- hardcore jetta tuner?
- Jettas with a no spark condition.
- WTB>16V/4spd/4d/GoodCond/Jetta
- new Jetta VR6 owner with some questions.
- performansth 85 jetta
- question about acc's on my '90
- Borla or Dynomax???
- Keep Getting My Front Bumper Caught on Jetta NEED HELP
- Next Level Perfromance Module ?
- radio
- SRT-4 vs. VW 1.8T video
- 17550 Load Calculation Cross Check Limit exceeded
- Clutch Release bearing
- Special VW battery?
- radio (probably fuse)
- '96 jetta cold air intake kit
- 1996 no spark/no start saga
- Oil foam? on oil cap?
- Changing drivers side front bulb
- 1.8t Oil Drain Plug
- Turbo VR6 video
- Electrical Problems!! Please help!
- Window tint?
- OEM jetta cd changer
- Radio Code Please Help
- Slipping or Cold?
- Knowing when to get new clutch
- door problem?
- Rain/Snow Water leaking into cabin and more!
- popping sound?
- best exhaust?
- Second car just for fun
- Stalling volkswagen jetta
- Fuse or relay problems?????
- I dont know anything...
- Need turbo!!!HELP ME OUT
- CD changer problem
- simple transmission ques....
- speaker dimensions for MK4 Jetta
- For Sale!!!!!
- Code reader?
- I need a good intake
- painting tail lights/dont ignore help me
- MY jetta ?'s
- look at this PLEASE......
- Survay for Purdue ME design course
- what kind of exhaust ??? please help
- MK2 Jetta Starter Removal
- loss of power
- supercharge or turbo
- Torbo mod. for VR6
- circuit breaker for door locks, sunroof, etc.
- Washer Pump Replacement?
- Any advantage to using VW oil filters?
- Jetta Question
- Cat back xhaust?
- question please helpppp
- battery scam?!?
- onboard computer?
- TDI Stalling/ODB Bypass
- Why no beep when locking doors
- simultaneous Stereo, cig lighter, and trunk malfunction
- battery in my key
- Lowering springs vs Adj. Coil-overs
- stock stereo and engine diagnostics
- The new guy has a newb question
- slow accell./ stall when engine warm
- Check Engine light HELP
- is jetta and bora the same ???
- A2 trim parts
- Fuel Gauge and on board computer read outs not working
- Terrible Mileage - Spark Plugs???
- water in oil? how
- props for the vr6 t
- Need help installing a cd player
- oil in spark plugs
- Jetta Power Steerig Fluid?
- A/C bulb out, how to replace?
- Up 4 SALE!!!
- Rebuilding a 91 16V 2.0
- Jetta hesitation and stalling on startup.
- Starter on my 94 jetta
- Mod Chip
- Question
- electrical issues with trunk.....
- Can U fit a rotary into a jetta body?
- jetta backfires under load
- Won't start/stalling
- Tool Help
- power seats, climate control
- Brake Replacement
- jetta battery/replacement issue Dealer Rip-off?
- wipers died
- Door lock/arm circuit
