View Full Version : Jetta/Vento/Bora
Pages : 1 2 [3] 4 5 6
  1. performance
  2. AutoCross
  3. Airbox silencer/snorkle question
  4. Smelly Heat
  5. Cost for new brake ?
  6. how's a jetta as an ideal project car?
  7. Cruise control problem
  8. Inaccurate Fuel Indicator
  9. CV Pronblem?
  10. Need Instructions on how to replace a strut bearing!!! Help
  11. Engine Idles Great, then Dies...Help!!!!
  12. Electrical Mystery
  13. Smoke!
  14. knock sensor problem
  15. What exactly is my car?
  16. Turn Signal issue
  17. fS: Mk2 sinlge round head light set up
  18. Electrical..
  19. Vw Incompetence!!!
  20. I have a short??? or wiring problem with windows/door locks
  21. Accelerator hum after hwy drive on 2004 Jetta
  22. Camshaft Position Sensor
  23. Reset Airbag memory
  24. Wiring problems?or Short?
  25. Question about Jetta reliability/problems
  26. Parts ID Question - VR6 Jetta GLX
  27. roof rack
  28. master cyl. losing fluid, no evidence of leak
  29. weird noises
  30. 1296 Air fuel metering code
  31. What is the best way to get rid of AC mildew smell in MKII Jetta?
  32. fast idle- need help!
  33. Anti-alarm, Key,Relay
  34. Keep blowing fuses part III
  35. Stolen Valet Key
  36. Car Doesn't Start(intermitent problem)
  37. Jetta IV VR6 manual shifter lash
  38. Jetta IV VR6 SRS light on
  39. Jetta IV VR6 throttle control issues
  40. Forced Motion/GHL Stainless Steel Turboback Exhuast And Altezza lights For Sale
  41. Speed Sensor/Odometer/Fuel Gauge
  42. Keep blowing fuses part II
  43. Could this be a strut problem
  44. please advise immediately - gears stuck in park - cannot shift gear!
  45. ignition coil???
  46. heater core or a/c
  47. Air Bag Replacement...
  48. AC Switch
  49. Check Engine Light????
  50. need help ASAP!!!!
  51. Speed Sensor
  52. Proportioning Valve Bad?
  53. turbo or supercharger?
  54. Back Seatbelt
  55. Is Jetta good to buy
  56. Brake and CD changer problems
  57. Tires anyone??
  58. how can i get a code for a jetta i just bought
  59. Jetta III GLX for sale
  60. VR6 Timing Belt or Chain?
  61. rotors and brake pads - help
  62. Customization Ideas
  63. Transmission Speed Sensor
  64. have shell...need power :P
  65. Electrical Problem
  66. HELP!!! Battery connected backwards!!!
  67. Where can I find a high output Alt ?
  68. steering leak
  69. No power to starter, but it does work
  70. nuespeed chip
  71. Alarm, Speakers and Cold Air Kit Questions
  72. buzzer alarm
  73. Radio Issue
  74. Was my engine swapped before i bought my car?
  75. Anybody in Utah, if so listen to this!
  76. catalytic converter? please help!
  77. Can't remove the starter
  78. AC leaks water in car
  79. race springs
  80. door wiring question
  81. New generation airbags decrease cost
  82. Useful info for all VW owners..
  83. body kit question
  84. Angel eyes on mk4 jetta
  85. Customising Jetta
  86. Newbie
  87. is my jetta christine?crazy electrical
  88. carfax help please
  89. battery replacement
  90. Steering wheel sticks when it rains, drivers side lock broke,amongst other problems.
  91. car help book
  92. carfax
  93. Electrical Problems
  94. speedometer cable replacement
  95. Replacement Grill...
  96. What should I expet to pay for Tranny work?
  97. Please Help Need Engine Removal Help
  98. air in fuel line
  99. Malfunctiion Indicator Lamp (MIL)
  100. 98 jetta stalling out
  101. Buying Jetta?
  102. control temperature sensor
  103. newbee questions AC and MAF
  104. jetta stuck in third gear
  105. Jetta Catalytic Converter
  106. shifting problem
  107. quick question
  108. fog light issue
  109. charging problems for my jetta can anyone help
  110. Alarm System Malfunction!
  111. short ram: good or bad?
  112. Jetta Rust?
  113. Broken Antenna
  114. VR6 Supercharger or Turbocharger ? Need Opinions
  115. Air Conditioner Not Functioning
  116. mkIII MAF cleaning?
  117. Advice Needed
  118. Volkswagen maintenance
  119. Shifting Linkage
  120. jetta shirt
  121. Are bora's geared different for the autobaun??
  122. Jetta TDI Performance
  123. Synthetic oil disappearing act
  124. car sat, won't start.. please help!
  125. Replace 096 with a 01M trans?
  126. Argh!
  127. air conditioning recharge problem
  128. clutch is slipping after replacement
  129. radio no longer working
  130. speed sensor problem
  131. Transmission Flush Service
  132. Transmission Swap
  133. Radiator Support
  134. jetta oil pressure light
  135. Coolantlite/ place2get trans. fixed?
  136. Monsoon radio wont come on.
  137. Help reverse lights don't turn on
  138. Major electrical issues?????
  139. VW Recall... whats taking so long!?
  140. In need of tranny info
  141. wolfsburg?
  142. just wondering
  143. dash lights
  144. dash light not working...
  145. A2 DIGIFANT NEED HELP FAST. car dies after 10 mins
  146. Fsi
  147. stock airbox breather valve 2000 jetta???
  148. starter wiring
  149. speedo ?
  150. leather interior
  151. Im new to this and i need help!!!!!
  152. right rear window not working
  153. jetta alarm car won't start
  154. Alignment and strut issues
  155. 17x8" 5x100mm MAK Force 35mm offset hubcentric wheels for sale
  156. Wipers, ac, lights just stop. HELP!
  157. Class action lawsuite re: front end spoiler
  158. VW Jetta fact or myth?? Gas mileage?
  159. engine ecu
  160. P 1476 code, EVAP problems - what does this mean>>
  161. Does anybody know of any good mufflers for VR6
  162. very weird question
  163. Where's Mr. Bentley when I need him????
  164. A little off topic, but looking for input
  165. Driver door panel badly scratched/dented
  166. Little help with VW 2.0L and Timing Belts
  167. Struts/Mounting Plate?
  168. Disabling factory alarm
  169. Catalytic converter problems...
  170. trustworthy??
  171. Help W?paint Code
  172. Paint type???
  173. smelly Jetta
  174. Trunk lock assembly
  175. seat covers
  176. how to replace wheel bearings?
  177. main fuses
  178. DIY replace front blinker?
  179. Performance exhaust
  180. My Jetta Dies while I am driving
  181. HYPER White for sale
  182. body kits
  183. a/c recharge
  184. turbo timer
  185. keyless entry battery
  186. 17" Moda R6 wheels on a white Jetta?
  187. power door locks, won't start
  188. Transmission Jerk
  189. DIY on MKIV 2.0L timing belt?
  190. dash light problems
  191. Alarm remote control problems
  192. boosting horsepower
  193. Jetta III Transmission Problems?
  194. Power Door Locks
  195. 2.0L engine swap
  196. Temp Guage + Check Engine Light
  197. Plug in the Rear Wheels for Stateside Jetta III GL
  198. set timing on jetta III
  199. somethings wrong
  200. camshaft hp
  201. modify the 2.0L or swap for a VR6?
  202. converting airbox into cold air intake
  203. poor fuel economy
  204. 2.0L 16V swap
  205. VW help
  206. rattling and squeekin when not accelerating
  207. Where's the Transmission Dipstick? (Seriously)
  208. Hook?
  209. ScotchGuard
  210. bosch +4 platinum??
  211. Radio Display Color Change
  212. Hi all ~ New guy on the block
  213. Air Vent Lights
  214. newb at this forum
  215. Paint code location?
  216. Power Steering Fluid
  217. got a quick question
  218. Are Jettas reliable?
  219. engine code?
  220. spark plug change(?)
  221. After Service - loat all oil - car died - TDI
  222. diesel tach conversion
  223. black or gray velour (cloth) interior?
  224. Reverse/backup light switch
  225. front bumper
  226. Frankenstein my b18 'cura 'teg LS
  227. gauges not working
  228. Rattling noise around 2500RPM - Please Help!
  229. problem with 2.0 16V
  230. additives?
  231. 2.0 upgrades
  232. Fuse panel card symbols????
  233. are these girl cars?
  234. where to find hazard and signal relays?
  235. Other tuning chips
  236. Front Bearings
  237. How do I change right front blinker
  238. New Jetta driver, need your advice!
  239. Seat belt is jammed in...
  240. vr6 automatic supercharger
  241. jetta tdi
  242. TDI Tie Rod or Steering Gear
  243. New engine thoughts and ideas
  244. VR6 Swap
  245. possible cracked piston ring?
  246. Brake lights don't work and blinkers turn solid???
  247. what do the jetta vr6 superchagers look like?
  248. new to jettas.. help plz
  249. What do I need to switch to a Manual?
  250. whats goin on?
