View Full Version : Jetta/Vento/Bora
- VR6 oil filter..
- 99 jetta running sluggish
- F@#* Volkswagen
- gas gauge problems
- 94 VW Jetta noise damper
- 1999 Jetta Will Not Start!
- interior cleaning??
- running problems with a 89 jetta
- engine check light??
- 98 Jetta GLX Horn Problem
- AirBAg Light
- Alternator Replacement
- song from the new jetta commercial
- oil changes and warranty
- help with 98 GLX with Bose System
- 96 jetta / golf good =?
- 83 Jetta Timing Issues
- FS 2000 afp VR6 12v with 35K miles
- bypass factory alarm
- Headlight Conversion
- vw bora alarm
- Jumpin ship From Honda/acura To Volkswagen
- Running problem with 16v
- Problems with 04 jetta?
- moonroof parts
- Radio problem
- check engine light stuck on for years
- Emissions problem
- Fuel indication
- Rims, lowering...
- Diesel : No juice to my cut off valve
- Jetta GLI - 18inch low profile, fun car
- Fuel problem
- bogged down engine
- wipers n heater fan out
- Thinking of Selling My 03 1.8 Turbo
- 3.0L V6 Toyota ==> 1.8T VW??
- vw jetta cranking too long with warm engine
- body kit
- Jetta 2.0 parts swap
- Gas mileage/Tank reading
- Killer VR6 Keychain
- Badgeless Grills
- cd changer
- signs that my clutch is going?
- what should I look for in a Jetta TDI?
- 91 Jetta GLI power window problem
- 2000 Jetta Tdi Flashing Glow Plug And Chech Engine Light
- 96 Jetta wiper problems
- Jetta died on highway
- does not stay running
- MPG reading
- Noise under emerg brake... Cat?
- 02 JETTA performance
- 96 Jetta 3
- 96 Jetta GLS stoplights always on/brake pedal switch OK
- Can you change the forum, please?
- obdII p0341 1996 jetta
- Question about Jetta transmissions
- jetta, mk3 engine noise
- 18" rims vs. potholes.. help!
- Diesel Jetta
- Parting out 97 Jetta Gl 5Spd
- new jetta
- 1996 jetta code reset
- 2000 Jetta with serious oil problems
- 1994 Jetta Reverse Problems
- BMW Angel Eyes DIY For 00' Jetta?
- 95 Jetta clutch peddle on the floor
- K.C. Converters
- HELP dead car
- few problems w/1997 jetta
- Car won't drive!!!
- Water on Driver's Side floor
- Jetta start problem
- Just bought 2000 Jetta
- 90 jetta sub zero starting problems
- 1996 jetta no spak
- Radio problems
- Less Gas Mileage
- 96 jetta glx
- Vandalism on my MKIII
- Jetta Automatic Transmission
- Jetta stalls when idling in cold weather
- Starting in cold weather
- 98 Jetta GLS
- who set this up
- 1996 VW jetta alarm and heat
- 1997 Jetta GLX Airbags
- Jet surges on acceleration
- new GTI whoas
- Jetta III, white smoke, NEW headgasket
- hid kit for 2000 jetta
- for sale 95 jetta runs needs work good project or parts car/ need advice for new car
- ---==headers???==----
- 2000 Jetta TDI Stalls at Operating Tempurature in Colder Weather
- 2001 Jetta problems = temperature gauges + shifter bunch up
- Jetta 95 coolant replacement
- 97 jetta 2.0
- slipping clutch
- 2002 Jetta whobbly noise and needed parts
- hard starting diesel
- Car hesitates when shifting
- Oil Light Flashing
- proud of your car? or you dont know what do to with it?
- 2000 GLS 2.0 Trouble Code Question
- will 16" rims fit on a 2004 Jetta GLI 1.8T
- Timing Belt 2001 TDI
- Jetta Forum Changes
- Questions about my jetta
- scrwed up a rim
- Sunroof Mishap
- Flooding VDub
- Premium Audio Lock Down
- I need help fast!!!!!!!!!
- average life of a clutch
- How to replace airbags
- Oxygen Sensor
- heater core leaking
- Vento vs Jetta
- hey everyone ltns...
- can you make a tdi quiter?
- Electrical-
- freaked out speedo
- Wiring Diagram
- AM Radio distorted
- Hesatation when i try to accerate
- 2001 VR6 Electrical Issue?
- jetta help
- fusible link
- glow plug light is blinking
- Can only get up to about 20mph for first 5 minutes?!?!
- fuel pump running
- tire size help please
- Mk. V Jetta Press Release
- looking for advice
- Rattle in Intake Mani at 4000 RPM???
- car altonator problems
- newbie ? on fuel grade
- 17 Inch Rubber?
- starter help please
- windsheild wiper ?
- $100 Metal VR6 Coolant Pipes
- valve cover gasket
- Say goodbye to my resonater, anybody done this??
- jettaGL overheated is it serious?
- car cuts out when engine temp is half way when stopped
- Radio safe mode need code!!!help
- What Is The Best Sound System For The Jetta?? And What Do You Have???
- Newbie with a problem
- Should a jetta ISV make a clicking noise
- Check Engine Light!
- Rattling/knoking Noise During Acceleration
- No power to starter?
- Bizarre electrical problem
- rims for jetta
- Problem with Coolant Light
- Sreet Racing In New York
- Headlights
- Rattling Noise
- Newbie here...need infor on Jetta idle problems
- Extended Auto Warranty
- safe to drive in limp mode?
- new spark plugs
- race
- Two OBD Codes (P0411 & P0422)
- Jetta help
- audio question
- red anti/freeze
- rally
- A/C fan fan belt
- Lowering springs
- engine part question
- Jetta GLS Window Problems
- Codes: P0171 System Too Lean P0440 EVAP Emission Control System Malfunction
- Autotech
- GLS to GLX
- Oil
- mk3 alarm
- Hard starting
- Dead gas gauge mkIII
- tail light
- Black Smoke?? Mass air flow? o2 sensor??
- does anyone know......
- air mass sensor
- Ecu
- Performance Tires
- bumper question
- Need Advice Plz
- Alignment issues
- Metal VR6 Coolant Pipes
- intermittant air
- Passing Smog
- whats the best jetta year???
- Question catalytic converter
- Fuel Filter Connectors
- taking out radio
- Radiator cap question
- Blinkers, taillights, brakelights messin up
- What oil weight for a 99 Jetta?
- 2004 Jetta - Mexico Dealer Story
- Where have you gone, glovebox?
- Day time running lights
- lights out
- Double brake lights
- Two mufflers???
- Jetta Mk2 problems..
- speed sender?
- Error codes P0763 & P0715
- Suggestions for jetta mods.
- How hard is it too do this???
- need advice on motor oil selection
- cabin air filter/pollen filter
- Jetta aircon cutting in and out
- Jetta a kids car?
- Bumping noise when braking in reverse
- Rattle noise with reving
- fuel rail clicking
- Transmission
- Help with Roof-Rack
- uneven braking on Jetta III
- engine light goes off now what?
- Water Neck Leak at the head...
- Code p1142
- Yyyyyyyeeeeeehhhhaaawww!!!!
- Need help?
- Vibration in brake pedal
- Tranny Gone
- Flashing Check Engine Light
- Need Help - CD Changer error message - "NO DISC"
- Scan Tool Help Needed
- heelo everyone
- 17 inch wheels?
- newbie with clutch issues
- Painting
- gas mileage questions?
- Timing mark question??
- Code P1128
- remove manual window cranks
- another jetta ? on power steering
- Anyone know some one sellin a Jetta?
- MK2 cheap power trick
- Finding Top Dead Center
- Rattling in Jetta 2004
- newbie:struts info......
- overheating engine
- Oil smell through vents
- Manual transmission failure.
- Jetta CD changer
