View Full Version : '71-'87 Civic / CRX
Pages :
1 2 3 [ 4]
5 6 7 8
- body kits and repair
- whats going on with my car??
- 83 Civic: How can I tell if my valves are bent?
- engine swap into a 78 civic
- really need help w/my d16a1 swap ASAP!!!!!!
- dash modification
- 86 Si BLOWOUT
- FS: Time to replace your Timing Belt, Tensioner, and Water Pump?
- FS: Reman. A/c Compressor Honda Civic 1984-1987
- 83 Civic Timing Belt Replacement
- help with cvjoints
- 85 honda crx 1.5 hf
- 2000 Honda Civic Si enine swap into 1999 Integra Gs is it possible?
- is it possible for there to be a 85civic 5sp fuel injection??
- bad news guys :(
- dual carb 87 civic
- HELP! 87 Civic won't stay running.
- b16 into 83 civic hatch
- need parts?
- radiator fan has a mind of its own
- 87 DX parts for sale
- Help me find Custom Seat covers for my 91 CRX
- ATTN cvcc wagon: Iginition Coil Wiring
- car don't wanna start
- parting out 87 civic hatch
- SI motor wants to die
- 87 body kit question
- Civic valve cover/idle
- parting a 1987 crx si
- 84 civic smoking
- 1985 Crx Si
- My engine swap is finally getting off the ground!
- 86 civic runs hot....
- My 86 civic Si tire shakes on the drivers side.
- updated list of SI parts for sale.
- Honda CRX Question
- '87 Civic starter motor wont work
- 1987 Civic Sedan
- Hello, new to forum.
- 81 civic front lip?
- 86 civic trans swap
- 85 sedan suspension upgrades? (brakes)
- CRX smokes Neon on dirt & finshes 1st place
- For Sale: 1987 Honda Civic
- Acord engine in Civic??
- 87 CRX carbon fiber idea
- '85 CRX engine swap
- another 86' Si PARTS
- '85-'87 Civic/CRX SI ECU codes
- spare TPS and fast idle control valve?
- 86 CRX parts for sale
- don't have a manual... need help with ECU codes
- my radiator fan doesn't cut on
- brakes
- suspension differences? 1500s vs CRX SI 86
- 86 CRX SI pgm-FI light in dash cluster
- 82 Civic wagon transmission
- 81 civic 1500DX fuel /starting problems
- Sohc Zc Problems
- Carbed 87 CRX Cutting Out
- 83 Civic Wagon deq failed!
- 87 carbureted motor swap HELP
- shifting/gear problem... need help
- AC quit - what to do?
- help need for my 85 crx si
- 85 civic after market carbs?
- Bad Idle......
- Scammed
- Help needed: 1977 for sale in brussels
- 1986 CRX DX idle rough
- Civic wont start
- 86 CRX Header
- Looking for CHEAP 88-91 CRX in Ontario, Canada
- 87 crx with 88 and later engine?
- Kill Switch
- I need info on wheel bolt pattern for 87 crx hf?
- Weird Question
- HELP! 86 crx/89 civic
- Source for brake calipers and rotors
- 87 crx si driver door rubber trim
- 1987 crx hf electrical problems
- 1st Gen CRX parts for sale
- Need help with pushbutton start for race car
- 1985 crx si headlight conversion to 86-87 what do i need?>>>>
- CRX finished 2'nd "barely"
- I want to buy a 1st Gen CVCC
- Civiv actualy made
- rims
- i need fenders
- Tuning a 1980 Civic
- 81 civic carb tuning
- Does anyone have a '86-87 CRX Si with a blown engine for sale w/in 200 miles of Spri,
- '89 Integra dash in 86 CRX?
- 86 crx hf w/B16a
- 87 CRX Si Hard Morning start
- Head light
- 3g Civic website
- '85 1G CRX cuts off!
- Aftermarket & REAL EDM, JDM Parts 4 Sale!!!!!!!!!!!!
- Finally got a Honda! Need Help
- Can I use ZC Pistons On A D15A2 87 Civic
- RARE JDM RHD 1988 CRX Glasstop For sale!
- Radiator Fans
- 87 CRX SI on dirt / Crank pulley
- Raising the Ride Height
- Parts for my '83 Civic Hatchback 1.5DX
- 1987 civic wagon problems
- Vote for my rear panel cover!
- Back Seat
- 86' Si Venice,FL Engine Trouble
- Intake Manifold swap question
- Wtb Manual Transmishion, Need Manual for '87 CRX
- Building the D15A2
- 87 CRX Si color code needed
- NeW cAr!!!!!
- Clutch problems.
- Lurk lurl lurkers...
- Can You Put 12V Head on D15a2
- Parting Out 87 CRX SI 5 spd
- Weird Overheating 87 Civic
- HELP - 87 Civic Wagon smokes after valve Job
- I need some CRX parts plz
- boring the ew4 motor out
- Power Windows anyone?
- 85 Civic Cooling Fan
- sorry about the already covered question(if it was)
- New or NOS rubber trim?
- PLEASE READ THE THREAD "a really bad idle"
- can you use cold air intake kits from a 2nd gen to a first gen
- 87 crx dx upgrade to si motor
- Anyone else have an old school CRX w/B16 & JR supercharger??
- 87 CRX Si ECU help
- CRX tails for sale
- loss of compression/ help
- turbo kit for 3g civics
- my hazard lights don't work
- transmission fit ?
- Engine Code?
- Weird Idle After Warm
- parts for 3gers
- YOU NEED 80s CRX PARTS?
- What will bolt into 84 CRX HF?
- 85 1.5 High rev miss ?
- Temperature gauge not reading
- 86 si engine up for grabs...
- No. 1 box
- valve cover and oil probs.
- diplacement
- 87 CRXsi electrical help needed
- Please Post D16A1 Swap Info Here
- engine question
- need help with crx engine swap to do list
- cuderbone
- !987 CRX planing a ZC swap and need help
- Timing belt running out???
- 86 crx si oxygen sensor
- 86 civic si brake conversion help needed
- '87 Engine Swap
- They do follow you home!
- I need a body for a 1987 CRX Si
- '84 CRX for sale
- 1987 CRX HF engine swap
- front speakers
- ecu swap
- What goes in this hole?
- font end mod question
- help me plz!!
- Fuel filter 87 CRX
- 86' crx zcsohc vtec(need help)
- 1986 crx si and 1985 crx hf for sale in texas
- in need of dc sports header
- 86' crx si
- parting out 87 CRX Si
- should I sale it?
- This Old Honda..
- buying plastic parts for 87 crx
- air filters
- lowering a 87 stock 87 crx with stock suspension
- euro tails for a 87 hatch
- control box
- Miss, low compression, and no problem found.
- Fuel Pump Voltage
- Engine Swap options for my 1986 Civic Si HB
- need help?
- which ones best
- 86 Civic DX and 87 CRX Si Engine Swap
- 1994 Honda Civic
- Is there Any Out There?
- anyone selling ???
- ? crx dan?
- 1st gen crx taillights for sale
- need help with my mini-stock crx pleease!!
- Acquired an 85 civic..
- suspension
- Will this CRX lip fit a hatch?
- fuel fouled plugs
- 86 Civic Wagon, 1.5 with burned valve!
- bodykit?
- 87 carbed crx
- 87 civic engine swap to a si from 91 hatchback
- where do i start?
- Need new valve seals for 1985 civic wagon
- New crx pics
- Clutch Problems
- 87 crx carb warm idle
- Trans Trouble
- tokicos made for hatch&sedan ????wagon?
- Breakin down
- 86 1.5 overheating
- MUGEN brand new muffler
- 1986 civic si
- My 87 CRX Si
- Talk to me daddy
- Fuel Problems???
- newbie question--why is the perfect sleeper so rare?
- WTB: 1st gen Si wiring harness..cash paid
- 87 civic motor swap question
- 95 civic front bumper on 86 crx si?
- Newbie
- 86 Civic swapping question
- carbed d16
- CRX wanted!!!!!
- Specs
- Track or drag?
- what happened
- '87 honda crx info needed
- Revamped 87 CRX in trouble
- 84 Civic HB kit
- '87 Civic swap questions
- 1979 honda civic...can i swap in a D-series?????
- 86 CRX SI Engine
- Pulley Gear
- Timing Belt Cover
- Fuel problem
- 87 civic 1600si hatch fuel problems.... help
- 87crx engine swap with b20a1/a5
- Pleas help! 2nd gen 5 spd transmission problem
- Help finding parts and bodykits
- carb ZC
- 84 crx B18C5 Swap ?
- weber carb
- CAn I see some nice CRXs please?
- Tuning for AS?
- I'm selling '87 CRX
- Need 85-87 crx Si parts
- Bad Ass bodykit for 1984-1987 Honda CRX
- "86 Civic Overheats and leaks water, Need help ASAP
- Hi all
- Cams
- Wow! 87' civic
