View Full Version : '71-'87 Civic | CRX
Pages :
1 2 [ 3]
4 5 6 7 8
- proper tire pressure for 87 honda civic si ( 175/70/13)
- will a dohc zc fit in my crx si?
- Recommended Oil & Oil Filter for 87 Civic SI
- wiring an 89 zc
- Whats the difference between '87 CRX and '88 CRX
- 87 si parts for sale
- 87 crx si fuel injectors and fuel rail
- parts diagram
- wide body kits
- ZC in CRX
- yes it'i me again the new guy
- 86 Civic Radio Replace
- Anyone want an 85 crx?
- CRX parts for sale
- need parts!!!
- driver side window
- Go Karts - off topic
- What could be causing this??
- suspension problems
- Car wont idle when it's cold.
- A thank you, and a question.
- 83 civic hatchback, e' route to fuel pump
- dead short or what?
- A Honda story...
- Low idle, low mental stability
- what model is my car?
- Emissions test
- Road trip anyone?
- where is o2 sensor?
- Front RH Fender..PLEASE!!!
- wheels
- Speed Limiter
- Smoking now?
- Side plastic lower door panel cracked
- What would be the best motor swap?
- Brakes Sticking
- Where in the world is cvcc_wagon?
- CRX exhaust
- engine surge
- no compression > bent valves??
- lighting
- 85 crx air intake
- Judder starting off
- Q about hatch shocks and MC
- 2nd Gen Hood Conversion?
- 87Si idel way to high
- off topic thought of the day: lxndr needs an avatar
- normal opperating tempurature
- 86 crx motor swap
- wholly rust holes batman!
- looking at 87 civic 4dr sedan and doing engine swap
- High Idle (stupid carbs)
- HOLY CRAP it's V day!
- 86 Civic Dashboard replace
- Engine or motor?
- What is this weird sound?
- hey people :)
- Where Is The Power Steering Fluid For An 86 Crx????
- Whatdo You Think About Your 71-87civic/rex
- yo
- Front End Swap for 84 CRX
- 1986 CRX Engine Swap
- gas mileage dropped off
- 82 honda civic cvcc 1.5l m/t wont iddle.
- 87 crx wit integra swap question
- 85 crx/92civic combo
- sway bar???
- Selling whole car 1987 crx cheap!
- Head gasket denial
- 1st Gen CRX Commercial
- 85 crx si parts for sale
- Hey guys,and girls,i have new speakers and wonderin the best place to put them
- 86 Crx Help!
- 1985 Civic 1500S startup/idle problems
- My 86 civic is dying
- 86 CRX - Brake Question / Problem???
- passenger brake doesn't work! Help please!
- Steering wheel changing
- 86 si cluch
- 87 Civic overheating problems
- WTB Bumper
- head light swap
- rear disks
- 84' Honda CRX Engine Replacement with an 85' Honda CRX Engine
- head issues - repair/mod advice needed
- WTB: 87 CRX Si -- Headlight and Wiper control stalks.
- i need help on my 87 crx si
- (for sale)85-86 civic and crx parts. cheap!!
- O2 sensor?????
- anybody with a 87 crx si??? need help here
- 2 '86 crx's for sale, ontario canada
- FORUM RULES AND GUIDELINES - MUST READ!!!
- d16a1 head and other parts for sale
- 87 CRX Si -- Pulley problem!
- No Spark from coil
- mileage
- door panels
- 300th post!
- plz help i need to know
- 86 crx upgrade
- 1986 Honda Civic for sale.
- pics on mah rex, but i seriously need help installing a tach!!!
- NEED HELP PLEASE!!!!! how to install a tachometer in a 87 crx si??
- NEED HELP PLEASE!!!! how to install a tachometer in a 85 crx si?
- 87CivicSi Aftermarket?
- Info on my car.
- sudden power loss
- 86 Crx Si Pgm_fi
- Pgm_fi
- 85 Vanowagon 4WD, what is engine type #
- 86 civic 1.5 won't idle, just dies?? HELP
- EK1 Power!
- cvcc engine swap??
- 1987 CRX SI Alloy Wheel
- 1987 Civic No Heat!!! Please HELP!!!
- 84' 1500S DX hatchback Preformance
- Need professional help. buying fully loaded 1st gen si civic. 1/4 mile times?
- Another clutch question
- Civic/Accord merging
- accel igntion coil
- im running on 3 cylinders
- Intake??
- problems turning off
- Clutch questions
- My good old clutch died......
- battery light came on
- Where's the EGR valve?
- 87 Sunroof needed
- 79 civic 1200/1500 info and links please
- Hey i need some help!
- Timing Procedures - 86 Civic 1.5
- 87 CRX parts needed
- CRX Radio Removal and Install
- 86 4 dr waggon alternator help
- CRX injectors...
- Vacuum Hose Diagram needed 86 Civic GL
- I need some links
- dizzy ?
- Overheating Prob. 86 Civic, Checked the obvious, Any ideas please
- Could It Be the Distributor?
- 1987 Civic / no spark after rebuilt engine installed
- 87 CRX header panel info...
- '85 CRX SI parts for sale
- 86 civic 1.5 carb,surging?
- brake line blew
- gas tank
- Firing order 86 civic si
- 1986 CRX Parts Interchangability
- need help please
- OverHeating Problems
- engine swap
- 87 crx alternator
- parting out a 91 interga b16a jdm
- Possible head Gasket?
- 87 CRX Si studdering...
- backfire
- When head gaskets attack!
- drag racing crx on ebay
- sunroof to moonroof
- Head swaps
- Front Wheel Bearing 86 CRX
- '86 CRX SI wheels for sale
- Help Me Help Me Please!!!!
- overheating problems
- HELP CAN't FIND REAR DRUM BRAKE ADJUSTMENT SCREW
- where can i get a bodykit and custom head and tail lights for a 83' honda civic wagon
- Interesting Find...
- Ew1,d15
- ideas
- Make my 87 civic 4dr sdn go faster
- 87 crx is overheating.
- Block Heater
- new head
- engine swap or rebuild?
- 86 civic idleing problems
- 87 crx upgrade?
- I am back once again with another ?
- EK1 rebuild progress report
- help on my crx si
- Crx Si
- sunroof
- pgm-fi/ staling
- WTB: Power Moonroof Switch for Si
- casting nuber for engine
- 87 CRX Si -- Won't Start
- Shock recomendation?
- Need part.....please help
- 85 crx si stalling
- 87 Civic Sedan, what a mess....
- H22 project
- 80 Civic
- white smoke
- f/s 87 civic hatch
- 87 CRX suggestions
- 86 civic si idle and other issues
- help with my horn
- 85 civic project
- Engine measurement estimate please
- Alternator Help!!!!!
- 1984 Civic Sites
- Engine Upgrades for '84 Civic
- used 86 crx si headers
- '83 Civic Hatch
- white smoke
- radio replacement
- which is better. D16 DOHC or D16 ZC(both JDM)
- D16 Swap
- looking for colors to paint 87 Civic
- cheap (maybe free) steelies in MA
- Help on 85 REX
- Civic Steering Problem
- im trying to rebulid my 87 civic Si
- which Acura axles for my 91 Zc to fit my 75 Civ?
- Project Si
- Crx performance links
- 87 honda crx si....upgrades??
- d16 a1
- 1987 CRX HF won't idle
- Engine
- High Idle
- 87 Integra Motor in 87 Rex Si
- 84 Honda Civic Starter Motor
- 86 civic wiring please help
- difference between 86 crx and 86 civic si hatchback?
- pgm-fi light/backfire
- The next chapter of my 87
- Got D16a1?
- Identify the exact engine/block
- Q about Seats
- 86 / 87 crx si upgrade option
- civic stalling driving me crazy
- Updates on my beast>>>>>
- 87 SALE question
- 87 Crx Smokes like a Cuban cigar....
- 83 Civic starter??
- my 84 show car!!!!!!!!
- "hondamatic" on an 86
- 87 tegra motor in 85 crx
- HELP with everything for 85 civic sedan
- swap an 86 hatch engine with a b16a2
- 85 crx fi WONT START
- Code 1 Problem
- '84-'87 CRX body kit
- '87 Civic died, won't start
- 82 civic dizzy placement
- Honda Engine List
- The lip difference
- tyres to..lol
- engines to put in a 84 hb
