Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
2000 Civic suddenly won't start (trying to get back to college for civil war game!)
A loud noise
2003 Tahoe Door Locks
Larger displacement for better mpgs?
Disabling the Extras
Question w/ pics
battery question
air cooled engines
engine timing
Alternator putting out TOO MUCH amperage?
Cooling system
Let's get at that oxygen sensor!
Dented Fuel tank repair
Unlocking Electrical connector
Vacuum Pump Questions
Testing a Coil
Two unresolved mysteries
Lt5
Bouncing Idle
1989 markvii
Blown Turbo
IT exam preps ?
1994 honda civic runs rough
Need Help
1999 Suburban headlight problem
factors with airflow
Testing Stop Lamp
Is it possible to mount the hvac into sunvisors?
engine help
mazda chassis on ford escape
Smells after new exhaust?
Using Scored Pads on New Rotors?
breathers?
Mobil 1 extended
What temp thermostat should I buy?
Drowning in a cooling nightmare.
Pontiac 400
Hypothetical Question
pi car analysis
Friends Car Vandalized
DTC code problem
what seems to be the problem?
mechanic's books
Installing aftermarket wiring harness...hmmm
Premier Fuel Cell
What ECU do you use?
ECU reset
Different Idea
Charging the car battery? help
An engine swap?
UTI/WyoTech/Local Tech
Jet performance module?
Is this how mostly all manual cars' transmissions are engineered?
Problem starting car
What other names are there for the Suspension Uprights, Wheel hubs?
mep in 2stroke & 4stroke..
i need a new balljoint...
Diesel-electric cars...
Quick question about some adapters
removing wheel hub with Puller
Whats the proper forum to ask about gas prices?
Broken rods... from factory...
Why is gas still $3 a gallon in NY?
I think Dodge Bsed me...
Different lean on a 16v scirocco
Brake/Tail Light Problem
possible thermostat problem
backpressure
Driveline vibration.
Suspension Upright?
Hood question
How long should I let my car warm up?
lifters
Newb question but plz help
ecu
HW help please...
93 Skylark(I'm going crazy)
hot to cold
corvette tires
exhaust fireball
Engine knocking???
cabin air intake filter Grand Prix 2004
Stupid but fun idea
Replace, or re-ring?
GM 4th gen f-body suspension install ??s
2 stroke supercharger...?
Internal combustion engines question?
Interchanging car parts
Whining noise from rear end. HELP
question an=bout 300zx engin swap
Cost
Folding, Collapsble, Dismantlble, or Portable Vehicles
remove top speed limiter - saturn
Water in Engine
Engine Flush
engine flush
No cat on a ZX2 escort Ok?
autanual....manumatic...
Diesel engine sawp in minivan?
Metal shavings in engine
High Idle Issue
is this right?
tangengial engine design
Precursors to Engineering?
trying to make spark on 3cyl without brain
slapstick shifter
are these changes better for all of us?
rotary barrel throttle bodies
Brake line wont bleed? *Urgent*
boreing an engine
Variable ABS
Engine redline...
Carb. Cleaning
Wheel Torque Chart
"unique" muffler designs
smog pump specs
V8 Rumble
Question about the Fan Cars....'78 Brabham BT46B & '70 Chaparral 2J
E85 conversion chart and more information!
Magnets in Oil Filter?
ok plz help
Sup
Auto design question
Trouble Starting 88 Sunbird/Stick Shift
Ignition switch problem
Automatic transmission
Stereo Wiring
splitfire spark plugs and wires
Run Flat tricks?
Plate in front of rotors - how to get it off
Updating an OTC 4000 E
project
putting together a supercharger kit
car trouble starting then starts fine
Don't overfill your fuel tank
coolant question for you experts
dead battery or dead starter?
high reving in large displacement engines
remove governor from saturn
top speed of souped truck
Coolant Problem - Advice Desired
6speed manuel or a 6speed auto
Maintenance Questions
Anyone know of a 2 spd shift on fly gearbox?
What's the Difference?
Engine Stamp
Problem going into Drive or Reverse from Park when cold..
Gas Efficiency
CarFax 2005 Chevy Impala
part
electric circuit question
Crazy Idea
Burning a quart of oil every 200 miles towing ....
Greater application force, immediate response
How many miles (approx) can I drive with a spare tire?
10a ignition fuse keeps blowing
question about GM's
cars a/c shutting off?
flywheel lightening; accuracy of lathing machines
fun with an old muffler
tire pressure myth?
Brake bleeding necessary?
broken s/c belt on 2000 gtp
1st harmonic pulse???
Told ya
2001 325CI poorly maintained.. need advice
98 Malibu - Terrible gas mileage
Invincible Timing?
Good Gasket Remover?
Dodge Caravan Engine Inquiry
please help me im dumb
install my own muffler
Where did you learn what you know?
Porsche 962 Turbo intakes?
braking force, quick-take-up,
Help with stalling Jeep
car myth? no gas in tank leads to tank rusting out?
heat transfer and humidity
platinum "plus" spark plugs- any benifits?
"Seeing" exhaust on a warm day
NA vs Turbo
Typical camber gains on McPherson setup?
pure ethanol and hp,mpg..etc
Transmission Oil Filter on an Eclipse
clutch problem..
accord door
my carburettor seeks freedom from its computer control (electronic enslavement)
Engine flooding?
Engine Inquiry
Mystery Security alarm system
Question About Release Bearing/Gearbox, Please Help...
2000 Cougar transmission range sensor
Interesting ping phenomenon.
1982 Oldsmobile V8 not starting
Renault RE20 sliding skirts?
recharging your own a/c
Co2 cooled brakes and rotors
converting tq to hp
governor/RPM limiter?
02 galant completely DEAD! help!
Is this bull? Re:" Ground Voltage Stabilizer "
Extrude Honing
putting in a quieter muffler?
blow off valve for intake
Engine build/rebuild video?
ABS Brake Light always on, what to do?
O2 sensor heater circuit fault (code 41)
need a combo for 500hp 30over 351w
What is the difference between LSD Ratios?
Different Engine Blocks
Tire Size & Odometer Measurements
Engine timing?
What is a drilled thermostat?
Strange brake wear
91 Honda Legand, engine swap....
Temperature ranges of brake fluids
homemade headers
Learning about Cars... could somone give me a hand..
Car Won't Start After Sitting For A Long Time, Please Help...
Help, bumper, serial number?
wind shield wash causes blade hop=-
Strut Mount Bearings noisy - any danger?
Are DIY A/C leak detector kits worth it?
Aisin Automatic Transmission shift kit?
Have to reset check engine light?
Automatic Transmissions
Factory Service Manuals (Free!)
1997 honda accord ac
After cat o2
what? air conditioning?
03 Rav 4 Timing Belt
co2 intercoolers
Alternator Problem
Wheel/Tire idea
Tire Preferences
Some Electrical Issues
Window problems
Transmission cooling lines...
The hell is speed trap?
Tire Issue part 2
99 chevy cav serpentine belt
'99 Jeep GC heating fan wont come on
Disconnecting ABS
One piece rear main vs. two piece question
frozen crankshaft
installing five point harness
stretched chain, is it that bad?
Engine in front tranny in back???
need to start
Web
AF
