View Full Version : Engineering/Technical
  1. Dohc Zc Vtec
  2. List the Causes!!!
  3. VTEC and fuel economy?
  4. Cold start problem.
  5. 99 Civic Mugen Front Lip
  6. aem cold air intake
  7. Civic 96
  8. what's better for swap B16b, B18c1, B18c5
  9. "Kerplunk" sound!
  10. Technical AC Question
  11. valve adjusting???
  12. transmission out or torque convertere?
  13. JDM Legend
  14. Photoshop?
  15. OBD-1 and OBD-2
  16. Gull Wing Doors!?
  17. Apex Dunk
  18. Going Rate for JDM B20B and B18B
  19. Diff between H22 and H22A
  20. low idle?
  21. battery not charging
  22. Cams
  23. Best fuel system cleaner
  24. Head Gasket Questions!!!
  25. Very weird electrical problem
  26. Odyssey - the ultimate sleeper...
  27. d16y5 cam in d16y7?
  28. 1990 accord automatic to manual transmission swap
  29. Skunk2 Intake Manifold
  30. exhaust?
  31. Are the Stock 99 Si pads organic or semi-metallic?
  32. VTEC Problem
  33. Civic cam question
  34. custom or catback exhaust?
  35. K&N or Spoon drop in filter?
  36. shifter problems
  37. b20b+b16a head durable?
  38. alcohol carburator to gas
  39. VTEC Head
  40. here's a link
  41. Cubic Inches
  42. Need proffessional Help?!
  43. Perhaps, a stupid question
  44. Will this pass the smog test?
  45. 92 Civic HB VX
  46. What are underdrive pulleys?
  47. H22 Vs. B18C
  48. Looking for a truck.
  49. vafc question
  50. Shaved Door Handle How To???
  51. Underdrive pulleys??
  52. NGK or VITEK...
  53. paxton in-line fuel pump...
  54. Engine revs by it self on G3 teg.
  55. i have a ?
  56. Not sure what this is, need Help
  57. Looking for B16A install in 90 integra on east coast...
  58. The Murciélago's Engine
  59. Canadian Legal Issues
  60. Changing the drivetrain
  61. port & polish
  62. Does anyone have any Honda performance Mechanical skills?
  63. Engine Wash?
  64. Ignition Systems
  65. Nissan SR20DET Engine
  66. what kind of pistons?
  67. money burning a hole in my pocket
  68. h22 in a civic
  69. Which Vehicle Speed Sensor to use in B16
  70. Rebuilding engine
  71. cross drilled VS slotted brakes
  72. how hard would it be to.......
  73. Anyone with an Automatic Turbo or anyone have any knowledge on the subject?
  74. B16 B18 H22?????
  75. RAM Air VS. Cold Air
  76. Aftermarket Tachometer
  77. Help me out here!
  78. A/C Filter
  79. Honda Chassis Codes - JDM
  80. speed govenor
  81. GAINS: Cams -vs- Pistons
  82. BiG block, Small Block
  83. I'm so not car savy.
  84. CAI Injen or Aem
  85. Axle gone bad?
  86. PLEASE HELP! B16A wont start up!
  87. how does twin turbo work..
  88. which manual?
  89. D16 "mini-me" swap, is it worth it???
  90. transmission trouble?
  91. PermaPlate
  92. b18c1 in a 3g accord
  93. CTR Pistons in B16a -- Install
  94. ITR or CTR pistons in my b18c1?
  95. B18 motor, in a 1990 Civic Hatch.
  96. b18a in a 88hb
  97. Choosing an engine for your Cobra
  98. When to change a timing belt?
  99. parts after swap
  100. Help with H23 swap
  101. oil pressure....
  102. PTS Shiftronic?
  103. what cai do i use?
  104. Just kinda wonering why you come in here.
  105. DC sport CC headers worth the money?
  106. oxygen sensor gone bad?
  107. is this an indication of a transmission problem?
  108. Supersprint
  109. b18c1 swap JDM wiring?
  110. Port & Polish on SOHC VTEC... gains?
  111. Where to go to school to become an Auto Mechanic?
  112. Anyone try the Tornado?
  113. Bent connecting rod???
  114. internals #deuce
  115. brake pads
  116. What does "stock" mean?
  117. CTR pistons in my b18c1
  118. fuel relay question
  119. Torque steer vs understeer
  120. Easiest way to run under under 13's in a civic
  121. FYI: Group buy on engine swaps in group buy section!
  122. spec needed
  123. Bliker problem
  124. motor mounts
  125. f20c
  126. Rotary Engines
  127. What is the best ECU?
  128. Turbo & High-Tech Performance
  129. A h22 in a 3g civic
  130. underdrive pulleys
  131. LS-1 Motor block casting process??
  132. "I need NAWS I need NAWS!!! (seriously, safe use of Nitrous)
  133. HELP:A/F ratio meter in 92 civic
  134. Octane #
  135. dyno charts?
  136. 5th gen accord w/ H22A or 2nd gen Teg w/ b18C1
  137. What is that site that shows the washer / bolt trick for camber?
  138. Fritz, got one for you....ok two.
  139. The Mixing Of Oils.
  140. Am I paying too much for a new head+gasket?
  141. N1 vs Racing Medalion
  142. Port and Polish
  143. b18 internals
  144. '99 dx hatch w/ JRSC......my alternator/speed sensor fuse keeps popping......WHY?HELP
  145. 4th Gen B16 Swap
  146. Correct Fuses To Reset ECU
  147. jsm b20a5
  148. How to be a good driver
  149. '87
  150. turbo prep...Crower Cams & Pistons?
  151. PTC Receives $1 Million Order from Lamborghini
  152. good tech info site?
  153. flywheel installation cost
  154. Walbro fuel pump problem
  155. 4th gen ignition upgrade!?!?!?
  156. internals
  157. b20 head swap
  158. 300zx Engine Transfer
  159. 17 flashes on ECU???
  160. Civic HB Swap dilemma
  161. Tuning an Apexi VAFC
  162. Canada Swaps
  163. computers necessary
  164. Fuses??
  165. Potential hybrid?
  166. Wheel issue
  167. Tanabe Racing Medalion
  168. fuel injector leak, should i change myself?
  169. Hondata
  170. Whats Wrong wit my auto?
  171. Turbo/Supercharger question
  172. Engine Bay
  173. 300M engine into 94 Intrepid
  174. Need Opinion
  175. Jr Vpac
  176. will a b16a2 work on a 90 civic si
  177. Air Intake?
  178. popping after clutch release.
  179. Painting Ceramic Header
  180. Other AF tech forums.
  181. custom exhaust
  182. H22A vs. F20B SIR-T
  183. high compression
  184. Timing belt is loose!
  185. question on the f22b1
  186. what is a good engine swaps for a 91 accord
  187. auto to manual conversion for a 94 accord lx
  188. New Honda Buyer
  189. JDM B16A Aftermarket
  190. Turbo theory
  191. buying b18c1
  192. Type-R mirrors
  193. How much for I/H/E?
  194. S/C B16a
  195. 97gsr with a 97 b16 head - will this do?
  196. Need fast advice on buying an engine!!!!
  197. Does JDM engines pass smog test
  198. zc for a 92 + civic HB
  199. b series
  200. Computer Board (ECU Tweeking)
  201. A/F Gauge Install
  202. Longblock? Shortblock?
  203. Boost Spikes
  204. 99 Civic EX - B18C Swap.. Questions???
  205. Clutch Recomendations..............
  206. Ecu??
  207. Ecu??
  208. Swap this Swap that.....
  209. H22-B18c1-B16a2
  210. Trans options for B16A JP VS USA spec
  211. Lamborghini,Porsche,Ferrari & Alfa Romeo
  212. build up... the most serious parts
  213. Mugen for '99 Accord EX
  214. Help me ...my car is dead!
  215. B20 long block+b18c5 head=?
  216. Tranny for LS??
  217. aftermarket parts installation
  218. a lil imput please
  219. starting valve and hose #8 from pgm-fi on a 4th gen accord?
  220. suspension questions
  221. Whats the best swap for a 97 civic
  222. Port and polish?
  223. EGR on my 4th gen accord?
  224. NEED help about parts for JDM front end!
  225. vtec
  226. fuel filter
  227. tach install?
  228. engine papers
  229. B18c-r swap into 96-98 civic
  230. Single Cam Mods...what should we do?
  231. B16A2 into Civic 4spd
  232. TECH: Switch for Reverse Indiglo Gauges?
  233. ls/vtec how about a f22/vtec
  234. HELP! How-To put a B18c1 into a 88-91 civic DX
  235. problems due to aftermarket parts
  236. I am In need of HELP!!!
  237. I need HELP!!!
  238. Usdm Gsr Swap
  239. Cams??
  240. LS help
  241. 5th gen b16A
  242. Sorry..Mitsu question but I need help and that forum is slooooooooooow
  243. AEM intakes
  244. b16a into 97 Civic DX... Cost?
  245. Check engine light
  246. B16a wiring and shift linkage questions
  247. Oil Burning?
  248. how difficult is it...
  249. Att: Moppie Jdm Bumper Lights
  250. h22 in a 2000 civic
