View Full Version : Engineering/Technical
  1. B18 swap question
  2. How to adjust timing on a doch ?
  3. Newbeeee18c enthusiest.
  4. jdm or usdm engine?
  5. D16 cams non-V-TECH
  6. can i remove 180km/h limiter>??
  7. 514 Cobra Jet
  8. DYNO cost????
  9. Used Gunk to clean TB, should I have replaced gasket?
  10. jdm GSR
  11. Just Ordered New Exhaust!
  12. Need help ! B16a into a 93 Civic
  13. Auto change to manual
  14. What is torque?
  15. Glasspack help
  16. Are the motor mounts on a 2000 Civic Si the same as 98-01 GSR?
  17. Need More Help Please!!!
  18. H22 in 5th gen and A/C??
  19. Jackson Racing Boost Timing Controller kit
  20. What is a safe boost on a stock engine?
  21. engine internals
  22. engine
  23. Oil Change
  24. Is this bad?
  25. garaging car
  26. Q about Car Damage
  27. where are clevite bearings at?
  28. valve cover studs for b18c1
  29. HELP! VSS removal/installation...
  30. Where do i start?
  31. Catalytic Converter
  32. swapping B18b in 92 hatch, what year tranny?
  33. APEXI Dunk, 50 State Legal?
  34. optima blue top
  35. I'm building an LS/VTEC, what else do I need, please read.
  36. Need opinion on good brake pads
  37. Temp sensor
  38. need help on general Information about cars
  39. Is... bad for my car???
  40. EG SiR Guage HELP!!
  41. chrysler/plymouth mechanics
  42. Ignition.....where do I put it??
  43. Aren't there some manuals that are on-line?
  44. h22 in a 95 civic coupe!!!
  45. Redline of ZC?
  46. What's this noise???
  47. were to find a h22 engine?
  48. JDM valve cover for lude
  49. Child Safety Locks??????
  50. JDM Engine Sites?
  51. ECU question
  52. advice needed
  53. VTEC indicator light
  54. head swapping
  55. Ok, tell me what I need!!!
  56. ls block and gsr block?
  57. Looking for 88-89 Accord Corner lights
  58. tech heads - read this please ;) another j.fuggi dilemma
  59. 99 ex Tranny & ACT clutch
  60. 97 Civic Ex auto tranny to manual swap
  61. Turbo exhaust
  62. Anyone heard or have OBX spark plug wires (10 mm)
  63. new pics of my engine swap
  64. NGK Platinum
  65. B series Tranny needed, HELP!!!
  66. DC Sports Any Good?
  67. b18c into a crx
  68. sits crooked
  69. JDM PR3 ECU for sale
  70. Racecar engineering schools
  71. i-VTEC
  72. 88 z24 2.8 MPFI
  73. Intake vs. switching to K&n filter
  74. h22a accord?
  75. I want an integra LS engine
  76. i have 2 questions
  77. Angeleye Projector headlight
  78. what's jdm?
  79. Cheapest places to get OEM Honda/Acura parts for a ZC?
  80. HID help
  81. Working Cali Law!!
  82. Auto Painting Questions
  83. 1.5 way, or 2 way LSD??
  84. Building my own Go-Cart/Car
  85. OBD question
  86. spoon parts for a 95 GSR
  87. all motor or NOS?
  88. Adjusting Rocker Arms.
  89. closest place in cincy area for engine?
  90. How do you shut that key in the ign beep?
  91. interga R cluster will fit 92-95 civic eg?
  92. vtec controller
  93. b18c header?
  94. header question
  95. Poll What kind of oil do you use
  96. radiator caps
  97. Dream performance car? What am I missing?
  98. tach wiring help
  99. b16 tranny ???
  100. ac fan question
  101. HELP!! oil on spark plug?
  102. resleeving
  103. Splitfire Triple Platinum: Any good?
  104. power band
  105. why do cars have body roll
  106. Type-S ?
  107. New engine for 96 civic???
  108. enigne swap
  109. whats a robo shifter?
  110. Transmission Conversion
  111. Need to know how to program alpine alarm fro new remote
  112. AEM cam gears and pullys???
  113. Help!?
  114. pulleys
  115. I need some help!
  116. How to straighten a Integra GSR motor mount that got slightly bent out of shape?
  117. How to straighten a Integra GSR motor mount that got slightly bent out of shape?
  118. Anoyone Hear Of Reactive Exhaust?
  119. I know its not a honda but i need ur help on a supra!
  120. 93 civic cx with dx motor
  121. B16A non ODB
  122. how hard is it to convert non ABS car to ABS?
  123. Help...really bad please!
  124. Split exhaust system
  125. how to get rid of sticky substance on headlights
  126. clutch question
  127. Wheel bearing help needed
  128. Is the stock Honda LSD really good?
  129. question on oil and main req'd blinking
  130. Governor and Ignition
  131. can a ...
  132. vafc tuning
  133. Car suspensions
  134. Spark Plugs + Spark Plug wires
  135. Brake trouble
  136. My little b18b1 project...
  137. Shift light help
  138. Tanabe Hyper Med or Apexi WS, Dunk?
  139. oil analasys
  140. B16a2?
  141. Bosch Platinum +4
  142. Swap B20A5 for B18a
  143. engine build
  144. Do you use this often?
  145. help! piston rings
  146. need h22a pistonrings-aftermarket!
  147. spark plug replacement
  148. AEM Fuel Rail Question
  149. Help finding chip?!?!?!
  150. How to remove 88 Accord front bumper?
  151. CAI - lower revs?
  152. Intermittent electric failure
  153. 2 questions
  154. Bad for clutch??? or transmission
  155. How will a wing effect my 4 door front wheel drive honda at 80 mph?
  156. Resonator
  157. Need Help Asap
  158. ATTN: Moppie
  159. Fuel light?
  160. Lol Idiot!!
  161. Any good sites for indepth specs on internal parts??
  162. B16A1, A2, & A3 Which is which?
  163. B16A Question
  164. Cat-Back? Headers? Both?
  165. how do u remove rear seats 93 civic
  166. Diesal fuel Error
  167. I have three quick questions.
  168. need parts
  169. rattling?
  170. is this worth it
  171. 96-99 civic EK with h22a
  172. Mugen spoiler on 5th gen lude
  173. Engine for a 4th Gen Hatch
  174. Honda Engine Manuals
  175. jdm engine
  176. dodge truck transmission
  177. Transmission
  178. Try the easiest thing first
  179. got me a 90 integra
  180. racing fan
  181. Cheapest place for H22a
  182. 88-89 prelude jdm ecu
  183. Reset? Huh?
  184. Clutch goin...
  185. blow off valve
  186. stock ex clutch questions...
  187. engine info
  188. Spoon?????
  189. 89 accord wagon h22a?
  190. torque converter
  191. H22A in a 94-97 Accord questions
  192. Exhaust for around $300
  193. Intake\Filter Question
  194. Anyone ever seen this before?
  195. NoCal Hybrid Swap Shop?
  196. headers
  197. AEM Engine Mangement System Question?
  198. Question about shorter gears. Important!!
  199. equal boost but more power?
  200. D16 head swap?
  201. Short Shifter Quality?
  202. is it still legal???
  203. swap a 1.5 pgm-fi to a SI 1.6 pgm-fi
  204. swap a 1.5 pgm-fi to a SI 1.6 pgm-fi?
  205. Please Check Out My Auction
  206. how to recondition a 240k mi engine?
  207. Which engine? JDM/USDM?
  208. B16a opinion?
  209. Need Suggestion for Shock
  210. ITR AIRBOX FIT ON A 95 ciVic ex?
  211. auto tranny...
  212. Lookin for a H22 5psd
  213. 385hp SOHC NON-vtec ~~ I want one!
  214. Need some advice on making my engine look better...
  215. Auto-Manual Parts locating I need your help
  216. clutch problems
  217. Common Cause of A/C death in accord?
  218. towtruck/towing questions
  219. VIN stamped on USDM engines?
  220. ...
  221. Dohc Zc
  222. Complete system rebuild . . .
  223. transmission numbers?
  224. umm tha d16a6 -- what tha hell is that from?
  225. can you have a/c on a gsr hatchback swap?
  226. anything better about B20b over B18b besides it is a 2 liter?
  227. price differences
  228. Cat. Converter Deterioration
  229. Rod bearing about to go?
  230. rattling
  231. EF3 Si questions
  232. Lots of Brake Dust?!
  233. Just Dyno'd My Car Again
  234. '91 CRX turbo
  235. Dual Exhaust
  236. please help: oil leak
  237. synthetic + VTEC
  238. cross-drilled/slotted or just slotted
  239. I finished my b16 swap!! HELP!!!!
  240. fuel system parts
  241. Magnaflow exhaust?
  242. Engine comparison site/chart
  243. 5th Gen Civic Swap with a 93 Integra LS?????
  244. DC Sports 4-2-1 or 4-1?
  245. 4000 bhp Honda Intregra
  246. mandrell bent or no?
  247. Greddy Power Extreme for Turbo's
  248. question???
  249. honda motors online...
  250. what is ps opposed to hp?
