View Full Version : Engineering/Technical
  1. a question on motor mounts???
  2. Mid-Range Power
  3. b18c5 in 5th gen hatch
  4. Highest Compression on Pump Gas
  5. Anyone have an IAC valve from their old D series?
  6. Wiring diagram for MSD 5462 Boost Timing Master
  7. composites
  8. Turbo b16a?
  9. Need help on header install 911
  10. Feul cell cars
  11. spark plugs for b16a
  12. Windshield wipers won't turn off!!!
  13. Rev Limiter On 92 CIVIC Si
  14. Advancing timing if running constantly @ 4,000 + RPM's
  15. Headers
  16. cam help
  17. OBX Racing Sports?
  18. 2002 Civic si
  19. ZC swap
  20. compression and cold plugs
  21. Electical ?
  22. b16a1 install q's
  23. strength of stock valvetrain
  24. Where to find.....
  25. FUEL! Im stumped
  26. engine help plz
  27. Just Installed AEM Short Ram...
  28. b18b/b20b/turbo?
  29. SRR rear lower control arms & sway bar?
  30. Are cam gears illegal???
  31. b18b head + b20b block + turbo = good?
  32. Brake pads... Axxis Metal Master vs. EBC Green Stuff
  33. Engine swap cost?
  34. rebuilding b18b
  35. What does BHP mean
  36. torque converter
  37. oil catch cans
  38. lightened flywheel
  39. b20z vtec
  40. need more put you in your seat power
  41. I Have Issues.........Please Help
  42. Kill the MAN lol
  43. Cracked wheel lock update: pic inside...
  44. H22 and B20
  45. The brightest white paint
  46. What's the best belt dressing?
  47. 1st Gen B16a
  48. emissions
  49. h22 or b18c
  50. JDM Engines
  51. Where can I find a h23
  52. EGT Location
  53. How do i install an AEM Short ram on 02 civic ex???
  54. Engine swap in the Honda
  55. Differential Bearing
  56. 97 Del sol vtec engine?
  57. crv 2.0 or Integra Type R?
  58. Next Preformance Part?
  59. What is 70mm equal to in inches?
  60. short intake vs. CAI
  61. b16a o2 sensor
  62. any advice??
  63. hydro to cable?
  64. Good Swapping Sites
  65. '91 Si b18 swap info needed
  66. b16 axles
  67. Honda B16/B18 rebuild books?
  68. Smog legal?
  69. Haven't started the car in 2 years!!!
  70. Cam timing
  71. Questions about boreing (sp?) out the block!
  72. NGK standard vs. NGK V-Power
  73. project d16z6. imput wanted
  74. exhausts
  75. b16a1 throttle
  76. Emergency Problem! Need help asap!
  77. anodized purple cam gears...
  78. Help Help Help !!!B20b!!! Help Help Help
  79. Picture on posts?
  80. Auto ---> Manual??
  81. Power,Power,and More power!! Did I metion Power???
  82. Where to find good deals on performace clutch kits??
  83. tranny problems?
  84. Fuggi's Experiment - STAGE 1
  85. ZC Engine Specs
  86. inew intake too loud
  87. B20b Install Help
  88. What would you guys do?
  89. is there anyway
  90. hessatation
  91. is the resonator in my exhaust really necessary
  92. ZC Engine Specs
  93. attn: 5L eater.. knock sensor
  94. D16Z6 with bolt on hp
  95. anybody with a venom 400 on an auto?
  96. I need instructions on how to install coilovers?
  97. JDM Honda Civic B16A SiR II Automatic Engine
  98. Anyone SUCCESSFULLY performed the CRV-VTEC swap?
  99. ignition stuff
  100. question..NEED HELP!!!!!!!!!!!
  101. Automatic to Manual transformation?
  102. Jdm Parts
  103. B16a swap for 5g Civic HELP
  104. is this deal worth it
  105. Unorthodox underdrive crank pulley
  106. dsm injectors on b series motor
  107. b16b motor swap in 90' integra ls?
  108. b16a1 + hydro tranny...
  109. wich cams
  110. For Sale 89 Civic Lx 4dr!!!really Good Deal!!!
  111. Engine swaps on a 96' GSR!
  112. Jet Chip V-Force Power Modules
  113. maximum boost
  114. jumping wire for diagnosing?
  115. Can a b16 fit into a new civic
  116. b16a1 cap and rotor
  117. Pls Read! Very Important!
  118. Brake pads question
  119. Ceramic engines?
  120. Ceramic engines?
  121. How Much Would You Pay For A.......
  122. what ECU should be used for the B16A engine?
  123. Need some help with a ZC problem!
  124. Need some help with a ZC problem!
  125. GSR engine swap ecu plugs
  126. which dc headers would you guys recommend?
  127. Need help - My trannsmission
  128. advancing timing. What do you set it to?
  129. Can i use the old trans?
  130. b16a pros..i have a question..
  131. What is the difference b16a2 short and long block?
  132. ZC or D16Z6 swap in a 91 Civic Si
  133. ATTN: Moppie
  134. Relocating Battery to trunk
  135. cOSTS of a b16 or better engine
  136. Header
  137. Hondamotorsonline.com
  138. D16Z6 Problems in 90 CRX Si
  139. will a 99 civic valve cover fit on a 00 civic engine?
  140. To Be .... or Not To Be JDM
  141. port and polish
  142. aftermarket header for '90 SiR, worth it?
  143. does anybody know how to remove the back seats of a 2000 civic
  144. J1 tranny question!!
  145. Over Drive Is Not Working
  146. 3.2tl engine..?
  147. ECU location on EK?
  148. Looking for a DCOE manifold for a b16a
  149. torque specs on b16 head bolts
  150. Auto Shop
  151. Tranny fluid not gearbox fluid?
  152. Engine Swap advice needed
  153. Cold Air Intake
  154. MSD Ignition question.
  155. Code number 41.
  156. B16 is here! 1 problem...
  157. Brake noise - please advise
  158. missing gas cap
  159. missing gas cap
  160. missing gas cap
  161. computer chip upgrade
  162. computer chip upgrade
  163. PLEASE HELP!!!!!! Erractic Idle!
  164. Ls/vtec
  165. Mis SHIFT
  166. swap question...b16a owners..
  167. A Few Questions
  168. oil
  169. looking for parts
  170. Question about NOS (nitris oxide)
  171. swao question
  172. Why is LSD good?
  173. Metal Coupling Piece Thing?
  174. b16 question!!
  175. B16a in 1995 civic DX.... black smoke???
  176. b16a installed but some vaccuum lines are crossed...
  177. JDM ECU Question
  178. 92 accord automatic tranny question
  179. Brake pads
  180. need the stock bore diameter for a gs-r
  181. Ctr pistons..how can u tell?
  182. Brakes anyone?
  183. Brakes anyone?
  184. Brakes anyone?
  185. sensors on JDM B16A
  186. transfering mods to another engine
  187. Vtec not working!?
  188. JDM EG B16A into a EF SiR?
  189. crank pulley removal
  190. JG Engine Dynamics
  191. Question about fuel injectors?
  192. Need Help!
  193. shinning up the valve cover
  194. B20z w/ B16a head swap
  195. Matrix Headers?
  196. Fritz is outta here! (for now)
  197. AEM bypass valve
  198. Drifting how to's, is this bad?
  199. Ls valve cover on a b16?
  200. RSX type-s motor into a 99 civic
  201. Brakes: Fact vs Friction...
  202. charge for check?
  203. just a quick question on a zc
  204. diesel vs. gasoline
  205. Car care question
  206. B16 Head Studs?
  207. Anyone Hear of RK Sport?
  208. intake
  209. Electrical question....
  210. 2.25 inch vs 2.5 inch custom piping.
  211. CRV engine. How much is it?
  212. JDM integra front end
  213. The right AEM Intake?
  214. Exhaust piping
  215. B16A ==> into 99 civic
  216. Code 9??
  217. 99 civic ex
  218. Need proffessional Help on a brake system!
  219. Please Explain Port and Polish...
  220. Accord Type-R Rims...
  221. help with O2 sensor
  222. for the JDM GURU's
  223. With Mods on a stock 89 Civic Si engine, is the resulting bang worth the bucks?
  224. Is it possible??
  225. Cat-Back for 74 Cougar??
  226. Prelude tech problem!!
  227. CRX vs, Mustang 5.0
  228. obd II question
  229. Cheapest USDM engines??
  230. AEM BYPASS VALVE hp losses?
  231. spoon wheels
  232. ? about Mini-Me Sohc Vtec Head
  233. Ignition Wires?
  234. s2000 tranny swap
  235. Best Spark Plugs and Wires for GS-R?
  236. A question
  237. what clutch
  238. Way to check driveshafts?
  239. Transmission Swap
  240. What would you do...
  241. Short Shifter info
  242. What is mandrel piping?
  243. Fourier analysis of cam profile
  244. Stupid question, but please answer
  245. Im Back
  246. Superiority of different engine designs
  247. parts help, install help in Cincinnati Ohio
  248. 6th gen Accord w/ bolt-ons
  249. help!!!!
  250. How does a Turbo work.
