View Full Version : Engineering/Technical
  1. I need a little help
  2. Clutch help
  3. car running after shut off?
  4. scraping sound coming from wheel
  5. what do i need for ls/vtec
  6. How close to ECVT? Also question on ceramic coating.
  7. 97 EX Parts on a 98 EX?
  8. working a SOHC Vtec
  9. Dumpin' the cluch
  10. exhaust control valve
  11. Engine problem - drained battery
  12. snythetic oil vs. regular oil whats difference
  13. DX With a EX VTEC Head Swap
  14. ?
  15. B16a jdm into a 93 civic coupe
  16. Aem Vs. Unorthodox
  17. Rattle Noise?
  18. swap
  19. Best places to buy Engines?Local and on the net
  20. Question on Natural Aspiration
  21. engine designation question
  22. crank shaft
  23. 96-98 B20 Ecu?
  24. Exhaust Cutout/Bypass
  25. Exhaust Cutouts?
  26. Anyone seen this Before on Ebay?
  27. B18b $$$?
  28. Stalling
  29. Need engine help/advice
  30. Mysterious Coolant dissapearance and Overheating!
  31. ls/vtec setup
  32. Autometer Tach problem
  33. Autometer Tach problem
  34. What Would You do?
  35. swap question
  36. VTEC Head
  37. Friend With badass CRX
  38. ECU program, or chip?
  39. SRS light
  40. Check Engine light came on
  41. 97 s-10 just quit
  42. whats needed for 97 civic to swap b18c jdm
  43. This is going to sound REALLY sad....
  44. Why am I burning so much oil???
  45. nology wires & amp...Need Help?!?
  46. how can i tell i my new engine is a REAL JDM TYPE R
  47. Jdm Gsr Civic!!!
  48. To Stroke or Not to Stroke???
  49. B16 problems
  50. Exhaust Question
  51. Anyone with shaved door handles?
  52. CI fuel injectors
  53. Caaaaan it be done?
  54. My Intercooler Concept (A/C. Nuff Said?)
  55. 1999 Honda Civic Ex Vtec 5speed is it fast?
  56. 99 ex vtec
  57. Crower Cams
  58. Bolt Size
  59. JDM Parts
  60. Another Header Question.....
  61. Polish?
  62. apex-i rev speed meter
  63. H22A Question?
  64. Jdm One Piece Head Light Kit
  65. Civic Type R
  66. Apex AVCR Questions!!??
  67. Royal Purple Synthetic Oil
  68. why do machine work on head?
  69. Engine Displacement and Cylinders
  70. New Header Gasket Or Keep Stock?
  71. New Car, New Mods
  72. which header????????
  73. which header????????
  74. Ignition Advance ?Cooler or hotter?
  75. Gm optima/Pontiac Lemans computer question
  76. B series engine swap
  77. Blown Head Gaskets
  78. What do "engine numbers" mean?.....
  79. Which would u buy?
  80. Obd2 to obd1 wire harness conversion help
  81. B18 into a 92-95 VX HB..HELP?
  82. is my ecu automatic?????
  83. żżż 5th gen or 6th gen ???
  84. price and risk of adjusting cam timing
  85. shocks worn out after ~10,000ks
  86. engine racing very high on start up - PLEASE HELP?
  87. B18C/R into 00LS Teg, engine harness wont fit ECU
  88. ls-v-tec build up on a 92 b18a
  89. I need some serious TECH help!!!
  90. Turbo?
  91. 1998 Civic Foglight install?
  92. how to install short ram intake on 95 Integra SE
  93. Silencer stuck, please help
  94. '87 Grand Marquis riding a bit rough...
  95. Need help from engine swappers....
  96. Valves, Valves, Valves!?!
  97. Need to know the best swaps for a 98 civic ex coupe
  98. Turn signals only work when car is warm?!?
  99. Stroking (Not that kind, sicko)
  100. Best motor swap for 90 CRX
  101. click click click click click click AAAAHHH!!!
  102. EF9 lighting problem
  103. engine problems, HELP!
  104. O2 vs N2O
  105. good sounding exhaust
  106. Em1
  107. Injecting N2O/Propane into a diesel engine?
  108. hi compression pistons
  109. The purpose of redline on the tact...
  110. S2000
  111. Short Ram vs. CAI
  112. Clutch pedal resistance
  113. 4-2-1 or 4-1
  114. window guide loose
  115. Help: Overdrive mode oes not work after transmission replacement
  116. I posted in the wrong place
  117. B16 A SiR2 swap
  118. I posted in the wrong place
  119. H22A into integra.. please help
  120. JDM H22A into my integra... opinions...
  121. Help quick please!
  122. reality on H22 engines
  123. changing tranny?
  124. How does a car amplifier work?
  125. need help removing exhaust!
  126. where to buy mounts
  127. H22A, auto and other mods...
  128. Confused about RPM and transmission
  129. brakes: to stop or not to stop
  130. mini me
  131. b16a head on b20 block query
  132. Don't Buy From Importridez.com
  133. Axles
  134. Distributor
  135. Need help with Carb.....
  136. Need to pass emmisions? Check this out
  137. Has anyone heard of this??
  138. HUGE turn signal problem
  139. HUGE turn signal problem
  140. Gm 3.8 V6
  141. Suspension Ideas
  142. 87 Honda Accord-removal of Harmonic balancer-bolt will NOT loosen, Now what?
  143. problem starting gsr swap
  144. obd1 to obd2 questions... type r in 92 hatch
  145. Help with posting pics?
  146. FWD vs. RWD
  147. bore and stroke
  148. bore and stroke
  149. engine changeover
  150. gearing ?
  151. biggest stock throttle body
  152. strengthenin internal for turbo
  153. Hey how about gear ratios?
  154. How do u drive a "standard" car?!?
  155. Tornado - snake oil or something else?
  156. ex swap
  157. were is the fuel filter?
  158. What do you think of Unorthodox?
  159. I need some serious tech help!!!
  160. Where do i find Spoon or Mugen Engines for sale??
  161. Electrical load detector, idle and aftermarket ECU?
  162. Rachet shifter
  163. Someone PLEASE make a list of good JDM part websites
  164. What Makes A Type-R?
  165. if you want new parts cheep............
  166. Help needed with wiring and electrical project...
  167. Keeping my hand on the stick ... does it ruin the transmission ??? Help !
  168. Help for an Acura n00b...
  169. B18B swap
  170. reverse indiglos on a 98 accord
  171. Need Engine swaps scientists, HLPLZ
  172. hard cold start
  173. I NEED info BADLY on this please, any help would be appriciated
  174. Engine Ignorant
  175. b16a1 into 90 integra
  176. Find Civic W/out Motor
  177. grit of sandpaper for valve cover?
  178. race seats
  179. zc block
  180. ?'s on angle valve jobs
  181. bad clutch
  182. Cutting control arm safe?
  183. I am burning rich
  184. Cran cams DMSI
  185. I have a quick question for anyone to answer
  186. Metallized Window Tint
  187. help on buget engine swap
  188. shifting at higher revs, better than at lower revs ??
  189. Friend Need Help Please!!
  190. '99+ B18C integra tyoe R in '99 civic EX
  191. 351 Cleveland, Big/Small Block??
  192. Jdm b16a swao in 96 civic
  193. Non-US D series transmissions
  194. Strange growling from left front.
  195. I have a dillemma!! (HELP)
  196. 4g usdm to jdm front clip conversion
  197. Loud motor/Exhaust leak?
  198. any jdm parts for 2001 and newer civic?
  199. Relocating battery
  200. Another picture question
  201. parts from f22 fit on f23?
  202. Import Builders
  203. Oxygen sensor locations
  204. Best engine coatings?
  205. 95 Accord not getting good Accel.
  206. HeLP
  207. HeLP
  208. Clutch Replacement
  209. do the 2001 civics and the 2002 have the same motors?
  210. I have a 2002 civic hx and want to know who makes the best exhaust,intake,headers....
  211. arent the 2002 civic hx and ex the same motor other than the emisions thing?
  212. clutch problem
  213. stage 2 cams ???
  214. when are they coming out with SPOON and MUGEN for 2002
  215. price for b16a
  216. Is this fixable?
  217. JDM Honda Civic B16A SiR II with an auto transmission
  218. Good Deals!?
  219. upgrading fuel system for a civic
  220. how do you go about changing an engine's octane requirements?
  221. Transmission Swap?
  222. Proportioning valve
  223. My swap...
  224. who is interested in titanium exhaust?
  225. Stronger D Series Tranny
  226. 4WD vs. AWD
  227. engine cough
  228. Modifying a 88-89 Civic Sedan..Which Engine fit??
  229. Help ! ! ! 3g prelude won't start
  230. what kind of hp gains would i get
  231. Cheapest place to order DC Header?
  232. Width and length?
  233. Engine swap
  234. Engine swap
  235. gsr swap - check engine light????
  236. Can i do it?
  237. mugen chip and rev high question!!
  238. B16 oil squirters
  239. How to reroute hood cable.
  240. b16a1 ecu/vtec solenoid problem
  241. Question about 93 Integra GS
  242. LOOK here.. I have a Q for engine swap.
  243. LOOK here.. I have a Q for engine swap.
  244. all power h22a
  245. Fast Idle Control Solenoid Valve
  246. spoon engines
  247. my car is on jack stands.....help
  248. Question
  249. Jdm B20
  250. CIVIC exhaust
