View Full Version : Engineering/Technical
  1. Lights wont turn off!!!!
  2. Stock intake parts
  3. trouble shooting!
  4. Need help: connecting wires to a fuse box
  5. Engine dress-up question
  6. OEM or AFTERMARKET?
  7. Neuespeed Short Shifter Bushing
  8. keeping cai cool
  9. Clutch not making vtec work!?
  10. Upgrade to Cold Air Intake?
  11. More spark plug ideas
  12. Engine Mods
  13. Clutch issue
  14. How to tell if a fuel injectors cleaning is in order ?
  15. Looking for snow tires for slippery T/A
  16. Fuel injector cleaners tests
  17. Oil and Filter Comparisons
  18. b16a distributor.....how do these plugs wire up???
  19. *news flash* 10 dollar exhaust mod adds 20 horsepower!!!!
  20. Pics of my car... What to get next?
  21. Starting problems!!!!!
  22. Which one is better?
  23. Optimum Point to change Gear
  24. pneumatic and electro-magnetic valves
  25. An idea I had at work
  26. b18c1 swap help
  27. automatic to 5 speed tranny conversion
  28. B series in canada
  29. Does anyone know the Chassis codes?
  30. High Flow Cat for Accord?
  31. mozart exhaust opinions
  32. 97 CRV Code
  33. 97 CRV Code
  34. Jdm Garage Sale...
  35. Auto To Manual Conversion...??
  36. Flowmaster
  37. 4WD VTi-R Integra
  38. built engines
  39. List of motors please
  40. sparco custom floor mounts?
  41. If I made my own ghetto intake, would I get any real power?
  42. torque??
  43. best engine??
  44. Swap B16C-R???
  45. OBX Racing Sports????
  46. read it
  47. What engine???
  48. how do i install new tail lights on my '92 civic hatchback?
  49. sparco seats in 5 gen
  50. Big Problem Please Help
  51. The Search continues for the JDM B20a
  52. H22A Swap Question
  53. 92 Civic Start Problems?!?
  54. Polishing valve cover
  55. Put An End To This Craziness
  56. 4th gen Civic hatch, B16a
  57. automatic transmission pickup filter/screen
  58. ES Universal Oval Muffler
  59. Iceman?
  60. cylinder head question?
  61. Help!
  62. Best Acura/Honda Car
  63. brake troubles
  64. engine swap for 2001 civic
  65. 97 civic EX tranny Question
  66. wiring woes in b16a ef civic
  67. burning oil
  68. ls/vtec
  69. Si Ecu Help!!!!
  70. What Oil filters are you guys using and.....
  71. Auto Tranny
  72. Lights question
  73. Spark Plug Gapping....
  74. b16a swap issues
  75. Swap in an H22 or get a GSR
  76. no reverse
  77. Question about Catalytic converters.....
  78. Tach hook-up
  79. Any sites selling type r or si accessories
  80. Bent Valve?
  81. Apexi
  82. 1st gen B16a head on B20 crvtec
  83. Apex'i world sport exhaust
  84. is it worth it?
  85. 95 Integra GSR transmission problem
  86. Need 4 speed
  87. Is 22psi possible on a GS-T?
  88. 5zigen angled? tenzo angled?
  89. which of these is a better exhaust?
  90. how much performance decline?
  91. Burning about a quart of oil a week. Yikes!
  92. what should I do?
  93. Aluminum Flywheel ???
  94. CAI or Front Mount CAI
  95. 1991 Honda Accord EXR Intermittent Starts
  96. SI engine with auto tranny
  97. oil "weights"??
  98. Air Conditioning and engine
  99. Need tips on launching...
  100. What is prevailing torque?
  101. 2000 Civic 3door to b16a2
  102. Fair asking price, input please!
  103. Crank Pulley Bolt Torque Setting?
  104. Front Wing/Splitter/Diffuser
  105. wireing diagram for car stereo!
  106. ac autotechnic revolution intake
  107. brake lights stay on.... all the time.... not good...
  108. Engine lubrication
  109. zc distributor in place of b16a?
  110. zc distributor in place of b16a?
  111. 92 chevy 1/2 ton pickup
  112. car out of commission...
  113. Aluminum flywheel questions
  114. Car Wont Start
  115. JDM using USDM parts?!?
  116. Engine Swap Questions
  117. axle help....pleeease!
  118. Auto tranny + TURBO ok??
  119. swap in california?
  120. Oil Question
  121. jdm b16a vacuum hose HELP/CRX
  122. question
  123. pivot air/feul controller
  124. Slower acceleration with new clutch?
  125. For Sale-jdm folding mirrors 90-93 integra 2dr
  126. Vtec not working!? (Again)
  127. Volts vs Amps
  128. Vacuum Shifter?
  129. I need help
  130. Head Lights!
  131. Nipple's
  132. JDM lights on a 90 Integra...
  133. question about transmission
  134. cheap engine?
  135. What steps do I need to take to get my car in the 13's...N/A?
  136. advice on engine swap...
  137. advice on engine swap...
  138. b16a intake mani
  139. obd2 to obd1 conv. harness question
  140. I'm a N00B
  141. Best engine setup for turbo?
  142. b16a oil pump
  143. Fuel Question
  144. vacuum hoses
  145. Itr pistons v.s. JE
  146. fuel filter
  147. '91 Integra motor in '89 Civic... NEED HELP Please
  148. New Engine for 92 Integra
  149. pleazzzzzzzzz tell me its posible!!!!!!!!
  150. CAI vs. Short Ram.
  151. Brake lights stay on while driving??
  152. is this everthing ?
  153. Wiring harness for denji projectors
  154. Compression ratio
  155. How too grab a code
  156. Torque Converter Question
  157. Common Question, but please humor me
  158. timing problem??
  159. Gasket HELP FAST!!!!
  160. Please help so i don't get ripped off
  161. 92 Marquis
  162. Windshield washer adjustment
  163. Questions- HP Gains
  164. hybrid ?
  165. Mini me hatch?
  166. learning to drive a manual (5 speed)
  167. front alignment question
  168. What way to go.....Engine swap?????
  169. Where in Indiana
  170. How to tell?
  171. Air filter cleaning question...
  172. In-line Transmission Filter With Bypass Valve
  173. Overdrive question
  174. Honda Tranny Code HELP
  175. Thanks to everyone here!
  176. Can i use a turbo and a super
  177. Odd tranny problem
  178. Dump Valves
  179. Frankenstein B20Z with B18c5 head ?
  180. transmission cooler installation
  181. weird question...
  182. 400h.p. 1.8?
  183. distributor issues on '92 Civic EX
  184. which motor...?!?
  185. I think
  186. Why do manuals roll backwards?
  187. fuel economy
  188. Ignitor
  189. What makes more HP in a JDM engine rather than a USDM engine?
  190. Excellent engine illustrations
  191. H22a Question
  192. aftermarket cruise control
  193. RB26DETT Skyline engine into a 3G Integra???????
  194. need help with vtec light
  195. engine swap
  196. exhaust question...
  197. Transmission troubles (strange stuff)
  198. Integra LS tranny with B16A2?
  199. Overstreer & understeer??
  200. orderin an h22 off net....which place is best to get the h22 from
  201. Help with 87' Chevy Caprice
  202. JDM-USDM Parts list...
  203. Euro-R Parts
  204. Give me and order to buy in here
  205. Question about fine-wire spark plugs...
  206. Used transmissions, what to look for?
  207. Exhaust
  208. civic trouble...HELP
  209. MAP sensor
  210. vtec or not vtec
  211. IACV Problem?
  212. block and crank
  213. Aem Cai ?
  214. Car Problems...Please Help
  215. VTEC Controller for EE9
  216. engine swap ?
  217. Jdm Vs. Usdm
  218. Spark Plug Comparisons & Explanations
  219. Oil and Filter Comparisons
  220. Exhaust Issue
  221. Best Piston Choice
  222. Throtle Body port matching
  223. Carbs for my accord
  224. Calling ZC Experts
  225. n00b question... plz answer.. then laugh
  226. JDM ITR Conversion
  227. Under the Hood MOD'S
  228. How much for a waterpump?
  229. gsr in a del sol
  230. Autometer Tach
  231. need to know code for b16a 92-95 civic code #37
  232. Idle Air Control
  233. kei hin duals
  234. b20b
  235. Power Pulleys/Cam Gears
  236. Accel 300+ in a honda?
  237. How to shave door handles on a 97 Honda Accord 4dr
  238. Parts Needed for b16 swap
  239. B16a
  240. B18c vs Crvtec
  241. Torque Master spark plugs... Do they work?
  242. HELP! Car issue!
  243. funny smell when pedal is put to the floor?
  244. general maintenance outline?
  245. Wont rev above 2800rpms?
  246. Trivia of the day (Can you solve this?)
  247. Where to get OEM parts?
  248. SOHC Cam Sprocket Advance or Retard?
  249. help
  250. b18c comp fit jdm b16a?
