View Full Version : Engineering/Technical
  1. JDM tune ups
  2. MSD install w/ Blaster2 coil on 1.5 SOHC
  3. How much would ABS help me in autocrossing?
  4. VTEC activation
  5. H22a @ 12,000 RPM
  6. ZC question
  7. help w/ head swap
  8. need help with engine swap
  9. Any advice on replacing my stock pedals?
  10. Bodykits+Lower vs. Speedbumps
  11. World Sport Series for a 6th Gen Sedan???
  12. Does any one make cams for H23
  13. Naked chick pic inside
  14. h22a tubro setup,wat u think?
  15. '86 Chevy van - how to get the engine dome open??
  16. Passlock System on a 98 Malibu
  17. B16 in a 91 Hatch...How Much?
  18. Drag Car opinion
  19. GA emissions?
  20. B16A Where in the hell from?
  21. Jdm Parts And Accessories
  22. JDM Motor codes
  23. How much is involved in putting a h22 into a 92 integra???
  24. All Show And No Go!
  25. Looking for a new car... need opinions
  26. turbos to much for my engine?
  27. engine overheated
  28. How do u take of an emblem?????
  29. engine .vs. fuel grades
  30. Help
  31. 1993 Acura Integra JDM Recommendations
  32. engine serial number ID
  33. any one heard of...
  34. Spoon engines..
  35. Apex'i vs. Greddy
  36. beware may be dagerous
  37. graphing calculators
  38. Weird smell
  39. b16a swap
  40. Throttle Postioning Sensor
  41. important ECU CODE 9
  42. ECU code 9
  43. distributor question
  44. Want to install a free flow muffler on my....
  45. Alternative Theory
  46. Cylinder coating
  47. air intake question
  48. H22 in a 92 non-vtec??? please help
  49. ls b18b or crv b20z ????
  50. ECU Codes?
  51. h22a jdm cap
  52. i really need help with my decision, i went b-20
  53. i want to buy b20z
  54. some help hea plzzz
  55. ACURA {3.0 CL}....."TIMING BELT" Question
  56. B20 swap questions
  57. What would u do?
  58. AEM or Unorthodox Racing?
  59. Fuel Filter Location for 98 Ford Contour SE
  60. Would a airlock appear if thermostat is not working?
  61. R-12 to R-134
  62. b16a swap ? on speedometer
  63. Fuel Injectors
  64. TPS issues
  65. Coolant Issues
  66. Compression?
  67. 1.5L throttle body
  68. HP Racing vs. Landspeed Racing Powercore Headers
  69. Car won't start but stench of gasoline
  70. cold air intake
  71. matrix cold air kit
  72. Water pump question
  73. throttle cable on jdm b18c type r in 5th gen hatch
  74. MissFiring or Air in gas lines
  75. Sparco seats anyone?
  76. ball joints question
  77. Best place to buy from ?!
  78. very important
  79. Ran out of Gas now Engine Won't Start
  80. UK Honda DOHC 1.8 VTECH
  81. Vtec Controller?...why recomended for H22?
  82. overheating problem, maybe some suggestions please?
  83. perfect engine? and another OT q...
  84. JDM Sr20DET flywheel
  85. b16a1 into a crx dx
  86. V-tec ?
  87. Looking for End Cam Retainers
  88. Engine Swap
  89. Painted headers
  90. Low coolant warning lamp on and air coming out at expansion bottle
  91. Is any body doing a H22 swap I need the old motor!!!
  92. When's the best time to "floor it" when going through a corner?
  93. nsx vtec solenoid
  94. speed and power secrets
  95. Need more power!!!
  96. b16a powered 4g STD civic running like ass
  97. japanese b18b install
  98. New here, thought i'd introduce myself
  99. B16a long block?
  100. What exactly does increasing the stroke of your engine do?
  101. header problem
  102. d16y8 engine block
  103. headlights
  104. Phantom Grip - anyone has pratical experience / comments?
  105. Plasma BOOSTER
  106. HP/torque vs. RPM
  107. bonnet jacking
  108. How To Install CAI On 1990 Accord?
  109. gear ratios?
  110. 01 integra engine upgrade
  111. oil leak problem?
  112. Hi-Flow Cat
  113. cad
  114. For Integra owners
  115. where to get JDM parts??
  116. Calling all ZC experts/ anyone who can help
  117. fuel pump location?
  118. best degreaser and stuff?
  119. turbo + testpipe=good?
  120. crank pulley removal
  121. Mugen
  122. i need 88-91 SI parts
  123. Battery......
  124. Ford Tempo won't stay running
  125. !URGENT! Installing CLUTCH, Need Specifications and Info By 4pm!
  126. How to install a strutbrace
  127. ? year parts to swap DPfi to MPFi
  128. fuel filter fitting question
  129. !!--hardwire vtec
  130. JDM B16A 88-91 CRX Shop Manuel Also includes USDM & ZC
  131. JDM 88-91 CRX B16A Shop Manuel
  132. Exhaust
  133. Custom made front lips and bumpers
  134. Where to get an ECU
  135. exhaust for b16a in 92 cx
  136. My own H22a Thread, please join me!
  137. Forget cold air... you want Ram Air
  138. New Car, New CAT?
  139. Fog Lights: A How-To
  140. Weight difference in 5th gen civic models...
  141. Si coversion?
  142. Can I get some help from the pro's plz, Ime building my car and need help!
  143. exhaust mods...
  144. Air/Fuel monitor
  145. Ime selling my 3000gt and buyin a civic or integra I need help from every1
  146. Check engine light, HELP!!!
  147. Inaccurate speedo
  148. Honda Accord heart transplant !!!
  149. camshafts
  150. B16a questions
  151. B18C1 vs B18C5
  152. !!!help--ECU question--help!!!
  153. Anyone looking for a mugen emblem?
  154. question for ivymike: Ideal Gas Law
  155. Paint chip questions....
  156. Transmisson problems
  157. Looking for books/websites on suspensions
  158. h22 swap question
  159. Skunk 2 stage 3 cams question!!
  160. swap in TO
  161. B16A.. from a SiR-I or SiR-II
  162. Chaasie Number?
  163. iac the problem?
  164. stick-shift...PLEASE help!!
  165. Theoretically, how much torque could the strongest 6-speed manual gearbox take?
  166. need help wiring si motor!!!
  167. JDM final drive question...
  168. Cat
  169. Need some help on understanding the mid-engine AWD layout...
  170. Just a question about vtec controllers....
  171. 3s-fe?
  172. 1.5 tbi
  173. COLD COLD intake
  174. Bizarre D16 problem/engine numbers
  175. b16a1 into 88-91 CRX Si Swap
  176. Help for 2001 civic ex
  177. What do the different gears do?
  178. Need some information regarding spark plugs.
  179. How Can I Stop The Seat Belt Beeping?
  180. Auto Transmission Temp.
  181. b16a1 parts
  182. VTEC Controllers
  183. truth about LS/VTEC
  184. cam gears
  185. conversion from automatic to manual
  186. electric schema for Lancia Delta
  187. Question on Crane Cams roller rockers
  188. An odd problem, need some help.
  189. B16zc
  190. Need help quick
  191. New Project: '91 CRX
  192. my brakes and the mechanic
  193. Zc?
  194. Fuel Injectors
  195. żż 5th Gen - B16a2 - Turbo ??
  196. what engine is better for me
  197. 97 Accord fuel filter...
  198. H22A swap into a 95 hatch
  199. Head problems - Pin in Vtec rocker arm Sheared off
  200. Electric Turbo/Blower
  201. Cfm = Pounds
  202. sohc v-tec IAC valve ?
  203. Interesting Read
  204. Need Help/Ideas(grassroots upgrade)
  205. Mechanics please help
  206. difference between blowoff valve and wastegate?
  207. Supercharger
  208. B16A Starting problems
  209. O2 Sensor Question
  210. Bosch Spark Plugs?
  211. 2+ litre engines...
  212. I have a question about engine materials.
  213. Nology Hot Wires
  214. n20 on a jdm b18c
  215. Really Wide? or none at all :P
  216. B16A into Dodge Neon
  217. Grassroots upgrade (4th gen accord)
  218. Exhaust Cut-Out
  219. Please help! LS/VTEC
  220. b18b swap help!!
  221. b18b swap help!!
  222. Engine Swap
  223. torque vs horsepower
  224. torque vs horsepower?
  225. -=CR-VTEC or Turbo B16 ?=-
  226. audi 100 won't run off idle
  227. PrBLM with 3rd Gear
  228. go-cart
  229. Test Pipe Bad, Good? Help Please!
  230. JE Piston Rings, where??????
  231. half-shaft replacement
  232. need hlp prepping for a cross-country trip
  233. High pitched whine
  234. Rear-wheel Driven Honda?
  235. which engine is the best build on???
  236. JDM auto tranny!?
  237. APEXI N1 colored muffler NA or TURBO
  238. Where can i get a B16 or a B18C1??
  239. Turbo Install help
  240. One Piece Headlights For Vigor
  241. bad way to fix control arm
  242. what performance cams should i get?
  243. front end prob....
  244. check engine,HELP!
  245. Strange "loose" feeling in rear in an 89 Honda Accord coupe
  246. Buy from Honda?
  247. Car Broke Down, Need Help!
  248. Need help from the AC people.
  249. I know this is probably a dumb question but...
  250. mini me
